I don’t know what pwd I’m in when I run gdb through kdevelop - i don’t want to use gdb in the terminal as I’m used with debugging through xcode and kdevelop
I placed a copy of the binary produced in …/linux32/debug in my project folder in order to have both binary and source files in the same folder
maybe I haven’t got a variable properly set in kdevelop project options that makes me run gdb from another directory??? I’ve set the run and build options
full output:
<edit: new output with proper folder in “build options”, same errors">
gdb gpumain -fullname -quiet
(gdb) set edit off
(gdb) set confirm off
Using host libthread_db library “/lib/tls/i686/cmov/libthread_db.so.1”.
(gdb)
(gdb)
(gdb) set print static-members off
(gdb) tty /dev/pts/3
(gdb) set width 0
(gdb) set height 0
(gdb) set stop-on 1
(gdb) handle SIG32 pass nostop noprint
(gdb) handle SIG41 pass nostop noprint
(gdb) handle SIG42 pass nostop noprint
(gdb) handle SIG43 pass nostop noprint
(gdb) set print asm-demangle on
(gdb) set output-radix 10
(gdb) cd /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/
(gdb) set args /home/alex/NVIDIA_CUDA_SDK/bin/linux32/release/test_files/fp793.wsq.xyt /home/alex/NVIDIA_CUDA_SDK/bin/linux32/release/test_files/fp793.wsq.xyt
(gdb) set environment LD_LIBRARY_PATH=/usr/local/cuda/lib
(gdb) break /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c:92
No source file named /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c.
(gdb) break /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c:86
(gdb) break /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c:88
(gdb) break /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c:89
(gdb) break /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c:90
(gdb) break /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c:30
(gdb) break /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c:32
(gdb) break /home/alex/NVIDIA_CUDA_SDK/projects/libFingCUDA/gpumain.c:18
(gdb) run
Stopped due to shared library event
(gdb) continue
[Thread debugging using libthread_db enabled]
[New Thread -1223338256 (LWP 28595)]
(gdb) info thread
1 Thread -1223338256 (LWP 28595) 0xb7fa76f0 in _dl_debug_state () from /lib/ld-linux.so.2
(gdb) continue
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1223338256 (LWP 28595)]
0xb7c1bdc9 in vfprintf () from /lib/tls/i686/cmov/libc.so.6
(gdb) info thread
- 1 Thread -1223338256 (LWP 28595) 0xb7c1bdc9 in vfprintf () from /lib/tls/i686/cmov/libc.so.6
(gdb) backtrace
#0 0xb7c1bdc9 in vfprintf () from /lib/tls/i686/cmov/libc.so.6
#1 0xb7c24d22 in fprintf () from /lib/tls/i686/cmov/libc.so.6
#2 0x0804af18 in zs_rcp_load ()
#3 0x0804b225 in match ()
#4 0x0804b52f in main ()
(gdb) info args
No symbol table info available.
(gdb) info local
