GeForce GTX 765M + TurboVNC
I’m trying to remotely render CARLA using VirtualGL and TurboVNC and it keeps using MesaGL. I did try a remote VNC server and a local one and I got the same problem. “nvidia-settings” doesn’t detect any graphic accelerator inside the VNC session but works well outside of it.
It turns out this setup doesn’t work. So I switched to ‘x11vnc’ server which is a way better solution because it renders on the local X server.
