PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/cuda-10.0/bin:.:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/cuda-10.0/bin nvcc -I/usr/local/cuda-10.0/include -arch=compute_30 -ptx compare.cu -o compare.ptx
/usr/local/cuda-10.0/nvvm/bin/cicc: IO error: Error opening output file ‘compare.ptx’: Permission denied
g++ -O3 -Wno-unused-result -I/usr/local/cuda-10.0/include -c gpu_burn-drv.cpp
gpu_burn-drv.cpp: In member function ‘void GPU_Test::initCompareKernel()’:
gpu_burn-drv.cpp:222:14: warning: ‘CUresult cuParamSetSize(CUfunction, unsigned int)’ is deprecated [-Wdeprecated-declarations]
checkError(cuParamSetSize(d_function, __alignof(T*) + __alignof(int*) + __alignof(size_t)), “set param size”);
In file included from gpu_burn-drv.cpp:48:0:
/usr/local/cuda-10.0/include/cuda.h:10998:36: note: declared here
__CUDA_DEPRECATED CUresult CUDAAPI cuParamSetSize(CUfunction hfunc, unsigned int numbytes);
gpu_burn-drv.cpp:223:14: warning: ‘CUresult cuParamSetv(CUfunction, int, void*, unsigned int)’ is deprecated [-Wdeprecated-declarations]
checkError(cuParamSetv(d_function, 0, &d_Cdata, sizeof(T*)), “set param”);
/usr/local/cuda-10.0/include/cuda.h:11099:36: note: declared here
__CUDA_DEPRECATED CUresult CUDAAPI cuParamSetv(CUfunction hfunc, int offset, void ptr, unsigned int numbytes);
gpu_burn-drv.cpp:223:14: warning: ‘CUresult cuParamSetv(CUfunction, int, void, unsigned int)’ is deprecated [-Wdeprecated-declarations]
gpu_burn-drv.cpp:224:14: warning: ‘CUresult cuParamSetv(CUfunction, int, void, unsigned int)’ is deprecated [-Wdeprecated-declarations]
checkError(cuParamSetv(d_function, __alignof(T*), &d_faultyElemData, sizeof(T*)), “set param”);
gpu_burn-drv.cpp:225:14: warning: ‘CUresult cuParamSetv(CUfunction, int, void, unsigned int)’ is deprecated [-Wdeprecated-declarations]
checkError(cuParamSetv(d_function, __alignof(T*) + __alignof(int*), &d_iters, sizeof(size_t)), “set param”);
gpu_burn-drv.cpp:227:14: warning: ‘CUresult cuFuncSetBlockShape(CUfunction, int, int, int)’ is deprecated [-Wdeprecated-declarations]
checkError(cuFuncSetBlockShape(d_function, g_blockSize, g_blockSize, 1), “set block size”);
/usr/local/cuda-10.0/include/cuda.h:10932:36: note: declared here
__CUDA_DEPRECATED CUresult CUDAAPI cuFuncSetBlockShape(CUfunction hfunc, int x, int y, int z);
gpu_burn-drv.cpp: In member function ‘void GPU_Test::compare()’:
gpu_burn-drv.cpp:233:14: warning: ‘CUresult cuLaunchGrid(CUfunction, int, int)’ is deprecated [-Wdeprecated-declarations]
checkError(cuLaunchGrid(d_function, SIZE/g_blockSize, SIZE/g_blockSize), “Launch grid”);
/usr/local/cuda-10.0/include/cuda.h:11175:36: note: declared here
__CUDA_DEPRECATED CUresult CUDAAPI cuLaunchGrid(CUfunction f, int grid_width, int grid_height);
gpu_burn-drv.cpp: In instantiation of ‘void GPU_Test::compare() [with T = double]’:
gpu_burn-drv.cpp:297:4: required from ‘void startBurn(int, int, T, T*, bool) [with T = double]’
gpu_burn-drv.cpp:544:15: required from ‘void launch(int, bool) [with T = double]’
gpu_burn-drv.cpp:605:39: required from here
gpu_burn-drv.cpp:233:26: warning: ‘CUresult cuLaunchGrid(CUfunction, int, int)’ is deprecated [-Wdeprecated-declarations]
gpu_burn-drv.cpp: In instantiation of ‘void GPU_Test::compare() [with T = float]’:
gpu_burn-drv.cpp:297:4: required from ‘void startBurn(int, int, T*, T*, bool) [with T = float]’
gpu_burn-drv.cpp:544:15: required from ‘void launch(int, bool) [with T = float]’
gpu_burn-drv.cpp:607:38: required from here
gpu_burn-drv.cpp: In instantiation of ‘void GPU_Test::initCompareKernel() [with T = double]’:
gpu_burn-drv.cpp:188:20: required from ‘void GPU_Test::initBuffers(T*, T*) [with T = double]’
gpu_burn-drv.cpp:285:3: required from ‘void startBurn(int, int, T*, T*, bool) [with T = double]’
gpu_burn-drv.cpp:222:28: warning: ‘CUresult cuParamSetSize(CUfunction, unsigned int)’ is deprecated [-Wdeprecated-declarations]
gpu_burn-drv.cpp:223:25: warning: ‘CUresult cuParamSetv(CUfunction, int, void*, unsigned int)’ is deprecated [-Wdeprecated-declarations]
gpu_burn-drv.cpp:223:25: warning: ‘CUresult cuParamSetv(CUfunction, int, void, unsigned int)’ is deprecated [-Wdeprecated-declarations]
gpu_burn-drv.cpp:224:25: warning: ‘CUresult cuParamSetv(CUfunction, int, void, unsigned int)’ is deprecated [-Wdeprecated-declarations]
gpu_burn-drv.cpp:225:25: warning: ‘CUresult cuParamSetv(CUfunction, int, void, unsigned int)’ is deprecated [-Wdeprecated-declarations]
gpu_burn-drv.cpp:227:33: warning: ‘CUresult cuFuncSetBlockShape(CUfunction, int, int, int)’ is deprecated [-Wdeprecated-declarations]
gpu_burn-drv.cpp: In instantiation of ‘void GPU_Test::initCompareKernel() [with T = float]’:
gpu_burn-drv.cpp:188:20: required from ‘void GPU_Test::initBuffers(T, T*) [with T = float]’
gpu_burn-drv.cpp:285:3: required from ‘void startBurn(int, int, T*, T*, bool) [with T = float]’
__CUDA_DEPRECATED CUresult CUDAAPI cuParamSetv(CUfunction hfunc, int offset, void *ptr, unsigned int numbytes);
Assembler messages:
Fatal error: can’t create gpu_burn-drv.o: Permission denied
Makefile:10: recipe for target ‘drv’ failed
make: *** [drv] Error 1
Got This error after running gpu-burn
kindly suggest now what to do??
