Get actual Height and width of frame from metadata
**• Hardware Platform (Jetson / GPU)**GPU
• DeepStream Version6.2
• Issue Type( questions, new requirements, bugs) question
Is it possible to get the actual width and height of a frame after a frame has gone through streammux?
Hi @daredeviles888
You can get the original resolution from NvDsFrameMeta
property source_frame_height
    height of the frame at the input of stream muxer
property source_frame_width
    width of the frame at the input of stream muxer
