Based on your specifications, I created the following simple example using regular host and device memory, with pointers to allocated memory passed between the first and second wrapper functions.
#include <stdlib.h>
#include <stdio.h>
#define THREADS 128
// Macro to catch CUDA errors in CUDA runtime calls
#define CUDA_SAFE_CALL(call) \
do { \
cudaError_t err = call; \
if (cudaSuccess != err) { \
fprintf (stderr, "Cuda error in file '%s' in line %i : %s.\n",\
__FILE__, __LINE__, cudaGetErrorString(err) ); \
exit(EXIT_FAILURE); \
} while (0)
// Macro to catch CUDA errors in kernel launches
#define CHECK_LAUNCH_ERROR() \
do { \
/* Check synchronous errors, i.e. pre-launch */ \
cudaError_t err = cudaGetLastError(); \
/* Check asynchronous errors, i.e. kernel failed (ULF) */ \
err = cudaDeviceSynchronize(); \
__FILE__, __LINE__, cudaGetErrorString( err) ); \
} while (0)
__global__ void add5 (int *arr, int len)
int stride = gridDim.x * blockDim.x;
int tid = blockDim.x * blockIdx.x + threadIdx.x;
for (int i = tid; i < len; i += stride) {
arr[i] += 5;
__global__ void mul5 (int *arr, int len)
arr[i] *= 5;
void wrapper_1 (int len, int **d_arr, int **h_arr)
*h_arr = (int *)malloc (sizeof(*h_arr[0]) * len);
if (!*h_arr) {
fprintf (stderr, "host alloc failed in file '%s' in line %\n",
__FILE__, __LINE__);
exit(EXIT_FAILURE);
memset (*h_arr, 0x00, sizeof(*h_arr[0]) * len);
CUDA_SAFE_CALL (cudaMalloc((void**)d_arr, sizeof(*d_arr[0]) * len));
CUDA_SAFE_CALL (cudaMemset(*d_arr, 0x00, sizeof(*d_arr[0]) * len));
dim3 dimBlock (THREADS);
int threadBlocks = (len + (dimBlock.x - 1)) / dimBlock.x;
dim3 dimGrid(threadBlocks);
add5<<<dimGrid,dimBlock>>>(*d_arr, len);
CHECK_LAUNCH_ERROR();
void wrapper_2 (int len, int *d_arr, int *h_arr)
mul5<<<dimGrid,dimBlock>>>(d_arr, len);
CUDA_SAFE_CALL (cudaMemcpy (h_arr, d_arr, sizeof (h_arr[0]) * len,
cudaMemcpyDeviceToHost));
for (int i = 0; i < len; i++) {
printf ("%d: %d\n", i, h_arr[i]);
int main (void)
int *d_arr, *h_arr;
int len = 10;
wrapper_1 (len, &d_arr, &h_arr);
wrapper_2 (len, d_arr, h_arr);
CUDA_SAFE_CALL (cudaFree (d_arr));
free (h_arr);
return EXIT_SUCCESS;
