Hi, guys
I followed the operation steps in the blog (https://developer.nvidia.com/blog/nvidia-nim-offers-optimized-inference-microservices-for-deploying-ai-models-at-scale/) for reproduction, but encountered the following error.
root@a100-test-ser000:~$ ngc registry model download-version “ohlfw0olaadg/ea-participants/llama-2-7b:LLAMA-2-7B-4K-FP16-1-A100.24.01”
Client Error: 403 Response: Access Denied - Request Id: ad9d65d2-4328730 Url: https://api.ngc.nvidia.com/v2/org/ohlfw0olaadg/team/ea-participants/models/llama-2-7b/versions/LLAMA-2-7B-4K-FP16-1-A100.24.01
root@a100-test-ser000:~$ ngc registry model list “ohlfw0olaadg/ea-participants/llama-2-7b:*”
‘NoneType’ object is not iterable
Is this repository a private repository that developers do not have permission to access?
If we want to reproduce the functionality of NIM, is there a more detailed quick start tutorial?
Thank you.
I would like to do the same. Also, obtained some more details with --debug on the model list command
File "ngccli/ngc.py", line 156, in main
File "ngcbpc/tracing.py", line 174, in wrapper_span
File "ngcbpc/command/clicommand.py", line 216, in traced_func
File "registry/command/model.py", line 193, in list
TypeError: 'NoneType' object is not iterable
Can any bloggers help answer this question? Thanks.
@ Amanda Saunders @ Neal Vaidya @ Adam Tetelman @ Nik Spirin
I am also facing the same issue can any one answer how to deploy llm with NIM
Client Error: 403 Response: Access Denied - Request Id: 3919aa59-213897 Url: https://api.ngc.nvidia.com/v2/org/ohlfw0olaadg/team/ea-participants/models/llama-2-7b/versions/LLAMA-2-7B-4K-FP16-1-A100.24.01
To get started with a NIM do I need an Ingress/Egress controller and what’s recommended?
To access NIM prerequisites, you need to apply for early access authorization.
You need to find NV’s enterprise-level sales.
You can refer to the following Chinese community posts. https://zhuanlan.zhihu.com/p/684106121
NVIDIA Microservices is currently under limited availability. Please submit a request to get access.
