RTX 3090
• Deeptream Version
nvcr.io/nvidia/deepstream:6.1.1-triton
N/A
• TensorRT Version
515.86.01
questions
Hi All,
I am developing a custom model and want to deploy it using DeepStream. I am using python as the primary development language because I can use NumPy. To parse the model result and attach it to the metadata structure, I am following the example and try to turn the final tensor output to a NumPy array for further processing.
After some search, I follow this thread and was able to convert the result if the output is FP32 format. If the output is FP16 format, I encounter a segmentation fault. Segmentation faults still happens if I use pyds.get_detections()
start = time.time()
output_layer = pyds.get_nvds_LayerInfo(tensor_meta, 0)
ptr = ctypes.cast(pyds.get_ptr(output_layer.buffer), ctypes.POINTER(ctypes.c_float))
output = np.ctypeslib.as_array(ptr, shape=(25200, 85))
print(f"Transform takes {(time.time() - start) / 1e-3} ms")
print(output)
May I ask
Is there any way to get the fp16 tensor output in NumPy array? Since it is pretty important to use half-precision model for best inference speed. It will also be much easier for developers to get the tensor output and perform post-processing in python for faster development cycles. (ML background developers are familiar with python.)
about the parsing speed. Compare to cpp / cuda, will it create a lot of overhead (such as copy memory to NumPy) if we use python to develop the parsing function (for the mode output)? If so, is it the recommended way to use cpp to develop DeepStream application instead of Python?
Many Thanks!
