Hi Guys,
This is my first post, i´m trying to do my first cuda program but then the problens begins…
I´ve seached in the forum about my problem and i found some things but i dont know how to do…if someone knows what i am doing wrong, and could tell me…
Thats the error:
[codebox]First-chance exception at 0x7c812afb in cppIntegration.exe: Microsoft C++ exception: cudaError_enum at memory location 0x0012fdec…
The thread ‘Win32 Thread’ (0x3cc) has exited with code -1 (0xffffffff).
The program ‘[3112] cppIntegration.exe: Native’ has exited with code -1 (0xffffffff).[/codebox]
And this is the code:
[codebox]
/* Example of integrating CUDA functions into an existing
application / framework.
Device code.
#ifndef TD_KERNEL_H
#define TD_KERNEL_H
global void montar_carga_global (float** outMatriz, float** inMatriz, int num_col, int tam_out_mat){
const unsigned int i = threadIdx.x;
int pos = (i * num_col);
if(pos < tam_out_mat)
for(int j= 0;j < num_col; j++)
outMatriz[pos+j][0] = inMatriz[i][j];
#endif // #ifndef TD_KERNEL_H
[/codebox]
[codebox]
Copyright 1993-2009 NVIDIA Corporation. All rights reserved.
NVIDIA Corporation and its licensors retain all intellectual property and
proprietary rights in and to this software and related documentation and
any modifications thereto. Any use, reproduction, disclosure, or distribution
of this software and related documentation without an express license
agreement from NVIDIA Corporation is strictly prohibited.
Host part of the device code.
Compiled with Cuda compiler.
// includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
// includes, project
#include <cutil_inline.h>
// includes, kernels
#include <TD_kernel.cu>
// declaration, forward
extern “C” void
runTest(const int argc, const char** argv,
float** carga_global,unsigned int nLin_carga_global,unsigned int nCol_carga_global,
float** carga_nodal,unsigned int nLin_carga_nodal,unsigned int nCol_carga_nodal)
// use command-line specified CUDA device, otherwise use device with highest Gflops/s
if( cutCheckCmdLineFlag(argc, (const char**)argv, "device") )
cutilDeviceInit(argc, (char**)argv);
else
cudaSetDevice( cutGetMaxGflopsDeviceId() );
const unsigned int num_threads = 16;
const unsigned int mem_size_cargaG = sizeof(float) * nLin_carga_global * nCol_carga_global;
const unsigned int mem_size_cargaN = sizeof(float) * nLin_carga_nodal * nCol_carga_nodal;
// allocate device memory
float** d_cargaN;
cutilSafeCall(cudaMalloc((void**) &d_cargaN, mem_size_cargaN));
cutilSafeCall(cudaMemcpy(d_cargaN, carga_nodal, mem_size_cargaN,
cudaMemcpyHostToDevice) );
float** d_cargaG;
cutilSafeCall(cudaMalloc((void**) &d_cargaG, mem_size_cargaG));
cutilSafeCall(cudaMemcpy(d_cargaG, carga_global, mem_size_cargaG,
// setup execution parameters
dim3 grid(1, 1, 1);
dim3 threads(num_threads, 1, 1);
cudaGetLastError();
// execute the kernel
montar_carga_global<<< grid, threads >>>(d_cargaG, d_cargaN, nCol_carga_nodal, (nLin_carga_nodal * nCol_carga_nodal));
cudaGetLastError();
// check if kernel execution generated and error
cutilCheckMsg("Kernel execution failed");
// copy results from device to host
cutilSafeCall(cudaMemcpy(carga_global, d_cargaG, mem_size_cargaG,
cudaMemcpyDeviceToHost));
printf(“Test PASSED”);
cutilSafeCall(cudaFree(d_cargaG));
cutilSafeCall(cudaFree(d_cargaN));
cudaThreadExit();
[/codebox]
Thx guys External Image
