Getting BeeGFS to show up in gdscheck.py platform check
Problem:
I cannot get GDS configured with Beegfs support. Specifically “Beegfs: supported/unsupported” field does not show up when running the gdscheck.py script after following the instructions in NVIDIA GPUDirect Storage Installation and Troubleshooting Guide - NVIDIA Docs which outlines the procedure for installing gds and getting it to work with beegfs.
Context:
The system I am trying to build is a part of an academic research project which requires the optimizations offered by GDS in conjunction with Beegfs. I am working on configuring GDS to work with Beegfs Client service for an AMD HPC with the following specifications, drivers, and Beegfs packages:
 RHEL 8.5, Kernel: Linux 4.18.0-348.7.1.el8_5.x86_64
          NIC/HCA: Mellanox ConnectX5
      OFED Driver: MLNX_OFED_LINUX-5.5-1.0.3.2 (OFED-5.5-1.0.3)
    subnetmanager: opensm-5.10.0
              GPU: Nvidia A10
        Nvidia-fs: nvidia-fs-2.16.1 --installed via .runfile
    Nvidia Driver: nvidia-535.54.03 --installed via .runfile
     Cuda/toolkit: cuda-12.2 --installed via .runfile
           Beegfs: beegfs-client-20:7.3.3-el8.noarch --installed via yum
Following the beegfs-quickstart-guide running the management/storage/metadata services with RDMA over Infiniband. I have also verified that this configuration is working before doing anything GDS related. I do this by running the beegfs-net command which yields the following.
mgmt_nodes
HPC25-ALPACA [ID: 1]
Connections: TCP: 1 192.168.11.25:8008;
meta_nodes
HPC25-ALPACA [ID: 25]
Connections: RDMA: 1 192.168.11.25:8005;
storage_nodes
HPC25-ALPACA [ID: 2525]
Connections: RDMA: 1 192.168.11.25:8003;
After completing the steps in the beegfs GDS support document. I don’t have any “Beegfs: supported” or “Beegfs: unsupported” field which is supposed to show up when I run the gdscheck.py script. This python script ends up calling the gdscheck executable which I cannot find source files for anywhere. The buildargs in my beegfs-autobuild.conf file are:
buildArgs=-j8 OFED_INCLUDE_PATH=/usr/src/ofa_kernel/default/include NVFS_INCLUDE_PATH=/usr/src/nvidia-fs-2.16.1 NVIDIA_INCLUDE_PATH=/usr/src/nvidia-535.54.03/nvidia
I have verified that nvfs_dma.h/config-host.h is in the NVFS_INCLUDE_PATH and nv-p2p.h is in the NVIDIA_INCLUDE_PATH.
The output of the gdscheck.py -p script on my machine is bellow.
GDS release version: 1.7.0.149
nvidia_fs version: 2.16 libcufile version: 2.12
Platform: x86_64
ENVIRONMENT:
DRIVER CONFIGURATION:
NVMe : Supported
NVMeOF : Supported
SCSI : Unsupported
ScaleFlux CSD : Unsupported
NVMesh : Unsupported
DDN EXAScaler : Unsupported
IBM Spectrum Scale : Unsupported
NFS : Unsupported
WekaFS : Unsupported
Userspace RDMA : Unsupported
–Mellanox PeerDirect : Enabled
–rdma library : Not Loaded (libcufile_rdma.so)
–rdma devices : Not configured
–rdma_device_status : Up: 0 Down: 0
CUFILE CONFIGURATION:
properties.use_compat_mode : true
properties.force_compat_mode : false
properties.gds_rdma_write_support : true
properties.use_poll_mode : false
properties.poll_mode_max_size_kb : 4
properties.max_batch_io_size : 128
properties.max_batch_io_timeout_msecs : 5
properties.max_direct_io_size_kb : 1024
properties.max_device_cache_size_kb : 131072
properties.max_device_pinned_mem_size_kb : 18014398509481980
properties.posix_pool_slab_size_kb : 4 1024 16384
properties.posix_pool_slab_count : 128 64 32
properties.rdma_peer_affinity_policy : RoundRobin
properties.rdma_dynamic_routing : 0
fs.generic.posix_unaligned_writes : false
fs.lustre.posix_gds_min_kb: 0
fs.weka.rdma_write_support: false
fs.gpfs.gds_write_support: false
profile.nvtx : false
profile.cufile_stats : 0
miscellaneous.api_check_aggressive : false
execution.max_io_threads : 0
execution.max_io_queue_depth : 128
execution.parallel_io : false
execution.min_io_threshold_size_kb : 1024
execution.max_request_parallelism : 0
properties.force_odirect_mode : false
properties.prefer_iouring : false
GPU INFO:
GPU index 0 NVIDIA A10 bar:1 bar size (MiB):32768 supports GDS, IOMMU State: Disabled
GPU index 1 NVIDIA A10 bar:1 bar size (MiB):32768 supports GDS, IOMMU State: Disabled
PLATFORM INFO:
IOMMU: disabled
Platform verification succeeded
It may also be worth noting that the beegfs module is loaded. I checked this by running gdscheck.py -V which is the filesystem check.
FILESYSTEM VERSION CHECK:
Pre-requisite:
nvidia_peermem is loaded as required
nvme module is loaded
nvme module is correctly patched
nvme-rdma module is loaded
nvme-rdma module is correctly patched
ScaleFlux module is not loaded
NVMesh module is not loaded
Lustre module is not loaded
BeeGFS module is loaded
BeeGFS module is correctly patched
GPFS module is not loaded
rpcrdma module is not loaded
ofed_info:
current version: MLNX_OFED_LINUX-5.5-1.0.3.2: (Supported)
min version supported: MLNX_OFED_LINUX-4.6-1.0.1.1
I’m anxious to find out why I am not seeing Beegfs in the platform check(gdscheck.py -p) output at all. Let me know if I need to supply any more information about my system or provide more context to the issue.
Dan
We are addressing the issue in upcoming patch release. you can use the previous version of libcufile 1.6.0.25 version
Thank you for the quick response. In efforts to go back to libucfile 1.6.0.25 I decided to uninstall cuda toolkit 12.2 and install cuda toolkit 12.1. This did fix the issue of BeeGFS showing up, it also shows that it is supported! However, my libcufile version says 2.12, GDS release version is 1.6.1.9 and nvidia_fs version is 2.16. I thought I had uninstalled these properly by following the steps provided at the end of the .runfile installation(/usr/local/cuda-12.2/bin/cuda-uninstaller, nvidia-uninstall, and /usr/local/kernelobjects/bin/ko-uninstaller), but the versions that show up when running gdscheck.py -p don’t seem to match those in the installation of cudatoolkit 12.1. Here is the output of gdscheck.py:
GDS release version: 1.6.1.9
 Platform: x86_64
 ENVIRONMENT:
 NVMe               : Unsupported
 NVMeOF             : Unsupported
 SCSI               : Unsupported
 NFS                : Unsupported
 BeeGFS             : Supported
 --Mellanox PeerDirect : Enabled
 --rdma library        : Not Loaded (libcufile_rdma.so)
 --rdma devices        : Not configured
 --rdma_device_status  : Up: 0 Down: 0
 fs.beegfs.posix_gds_min_kb: 0
 GPU INFO:
 PLATFORM INFO:
 IOMMU: disabled
I just want to make sure I don’t have residual issues since this looks like libcufile stayed the same. Did I miss something in my uninstallation of the old toolkit/nvidia drivers? I ran a quick read test to the beegfs mount and it passes read verification, so perhaps this isn’t something to worry about since GDS seems to be working properly with BeeGFS now?
This is okay the libcufile version is the internal version. This is bumped when there is a compatibility issue from nvidia-fs. This version say the min nvidia_fs version that is supported.
