Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
I am trying to get histogram data from the Tegra hardware ISP. We are currently using the SIPL camera API, however I cannot see any option to get a histogram from the ISP in this API under DriveOS 5.1.6, only under 5.2.0. Is this correct? I see that it’s possible to get the histogram using the old NvMedia ISP API. It looked fairly simple, and I started implemented a temporary solution (until we migrate to 5.2), but I ran into many issues. Some of these issue are likely to be connected.
We currently have two SIPL consumers - one for the raw image, one for processed YUV.
The first problem I ran into is that when I try to disable the YUV consumer, only keep the raw (ICP) consumer, INvSIPLCamera::Start call fails.
Since this is supposed top be a temporary solution, I would be okay with the image processing running twice for starters. When trying to reprocess the image, I ran into the issue, that it it comes out purple - the green channel is completely missing. Otherwise the processing does appear work. (The image from SIPL is fine.)
Note that I may not have configured the ISP correctly - I’ve set eg. the calibration matrix, but haven’t set most of the other options. I don’t see any way to specify eg. the sensor layout (one of the things I suspected being wrong).
The retrieved histogram is also unusable - it seems to register all the pixels in the topmost bin. I use the following settings (expecting a simple histogram):
controls.enable = true;
controls.offset = 0.0f; //Holds offset to be applied to input data prior to bin mapping
controls.knees[0] = 32 - 1;
controls.knees[1] = 2*32 - 1;
controls.knees[2] = 3*32 - 1;
controls.knees[3] = 4*32 - 1;
controls.knees[4] = 5*32 - 1;
controls.knees[5] = 6*32 - 1;
controls.knees[6] = 7*32 - 1;
controls.knees[7] = 8*32 - 1;
controls.ranges[0] = 5; //Holds \(log_2\) range of the pixel values to be considered for each zone
controls.ranges[1] = 5; //
controls.ranges[2] = 5; //
controls.ranges[3] = 5; //
controls.ranges[4] = 5; //
controls.ranges[5] = 5; //
controls.ranges[6] = 5; //
controls.ranges[7] = 5; //
All the calls for setting this up seem to succeed.
Anyone have any tips? Which of these issues are related?
