xhuv_NV
September 4, 2019, 1:54am
1
I have successfully run deepstream3_example with N number of uri. Now I am trying to get information like source stream ID from nvosd plugin through buffer probe. I have added probe like this:
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
gst_element_link_many (streammux, pgie, tiler, nvvidconv, nvosd, transform, sink,NULL)
tiler_src_pad = gst_element_get_static_pad (nvosd, "src");
gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
tiler_src_pad_buffer_probe, NULL, NULL);
From buffer probe, which metadata contains this stream_id info? I am confused with the metadata received…
static GstPadProbeReturn tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
long int src_id = (gulong) info->id;
printf(" Source ID = %d", src_id);
return GST_PAD_PROBE_OK;
This always prints “1” . But I needed the specific source_id that has been muxed with streammux.
The source_id in gstnvinfer.cpp → gst_nvinfer_sink_event()
is the sequence order of source adding
For example,
In application:
gchar pad_name_sink[16] = "sink_<b>2</b>";
sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
In streammux,
sscanf (name, "sink_%u", &stream_index);
pad_data->pad_id = stream_index;
frame_meta->source_id = pad_data->pad_id;
So this source id is 2
source_id is in NvDsFrameMeta
When I try to access source_id using :
frame_meta = (NvDsFrameMeta *) (l_frame->data);
NvOSD_RectParams rect_params;
guint source_id_info = frame_meta->source_id;
I get null , just to be on the same page , I want to access either uri or some some source id which helps me to find this frame belongs to specific camera.
this is my config example of source :
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../../streams/sample_1080p_h264.mp4
#uri=rtsp://admin:@192.168.1.10:554/mode=real&idc=1&ids=1
num-sources=1
gpu-id=0
#drop-frame-interval=5
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
I am also trying the same but instead of getting null I’m getting ‘0’, I’m using the sample-app\deepstream-app … any ideas what it could be ? Happy to paste code if needed.
Can you create a new topic?
I want to get the target location information of multiple sources in deepstream-app. Can you tell me how your code has changed? Thank you
Hi Chris,
Where should I put this piece of code? Thanks.
