Hi there!
I’m a new comer to CUDA, and i’m trying to program a code related to isosurface rendering. In this program I call the following function:
device bool searchValue2(tGPUMatryoshka gpuMatryoshka, int searchPosVal1, int val2)
int beginPos, searchPos, lastPos;
beginPos = gpuMatryoshka.cols_value2_index[searchPosVal1];
if(searchPosVal1!=(gpuMatryoshka.nCols-1))
lastPos = gpuMatryoshka.cols_value2_index[searchPosVal1+1];
else lastPos = gpuMatryoshka.nActiveCells - 1;
bool foundElem, foundPos;
foundElem = foundPos = false;
foundElem = val2<10;
if(lastPos<beginPos)
return false;
foundElem = (gpuMatryoshka.cols_value2[beginPos]==val2);
foundPos = ((lastPos-beginPos)<=2);
if(beginPos!=lastPos)
foundElem = foundElem || (gpuMatryoshka.cols_value2[lastPos]==val2);
if(gpuMatryoshka.cols_value2[beginPos]<val2 && !foundElem && !foundPos)
while(true)
searchPos = (beginPos+lastPos)/2;
foundElem = (gpuMatryoshka.cols_value2[beginPos]==val2) || (gpuMatryoshka.cols_value2[searchPos]==val2) || (gpuMatryoshka.cols_value2[lastPos]==val2);
foundPos = (beginPos==lastPos) || (beginPos+1==lastPos);
if(foundElem || foundPos)
break;
if(gpuMatryoshka.cols_value2[searchPos]<val2)
beginPos = searchPos;
else
lastPos = searchPos;
return foundElem;
If i comment the code in red the function doesn’t give me any problem, but if i try to run the program with this code there, the program send a erro that reads: “too many requested resources to launch”. The program runs in emurelease mode and execute correctly, however i think this happens because in emurelease mode the pc execute the code in CPU, and don’t simulate the GPU threads.
When I try to search the problem on google I found out that the this error is related to registers or shared memory. In this code I don’t make use of shared memory, this only leave me 1 option to explore: Register overusage. Is there some one that could teach me a way to calculate the registers used by my GPU kernel? Does anyone know why this code probably don’t run correctly in GPU?
Thanks alot in advance.
