Hi… :-)
When installing rams, it seems to be a problem with the glic libraries. Here is the prompt:
make[2]: Leaving directory `/home/waldyd/rams44/bin’
ar x rams-4.4.a rammain.o
pgf90 -o rams-4.4 rammain.o -v -Wl,-static rams-4.4.a
./librams-4.4.a ./libutils-1.1.a -L/usr/local/ncarg/lib -lncarg -lncarg_gks -lncarg_c -L/usr/X11R6/lib -lX11 -lpthread
/usr/bin/ld /usr/lib/crt1.o /usr/lib/crti.o /usr/lib/gcc/i386-redhat-linux/4.0.0/crtbegin.o /usr/pgi/linux86/lib/f90main.o rammain.o rams-4.4.a ./librams-4.4.a ./libutils-1.1.a -o rams-4.4 -static -L/usr/local/ncarg/lib -lncarg -lncarg_gks -lncarg_c -L/usr/X11R6/lib -lX11 -lpthread -L/usr/pgi/linux86/lib -L/usr/lib -L/usr/lib/gcc/i386-redhat-linux/4.0.0 -rpath /usr/pgi/linux86/lib -m elf_i386 -dynamic-linker /lib/ld-linux.so.2 -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lm -lc -lpgc -lgcc -lc -lgcc /usr/lib/gcc/i386-redhat-linux/4.0.0/crtend.o /usr/lib/crtn.o
/usr/local/ncarg/lib/libncarg_c.a(ncarg_path.o)(.text+0x1b9): In function _NGResolvePath': ncarg_path.c: warning: Using 'getpwnam' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking /usr/local/ncarg/lib/libncarg_c.a(ncarg_path.o)(.text+0x1cc):ncarg_path.c: warning: Using 'getpwuid' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking /usr/local/ncarg/lib/libncarg_c.a(ncarg_path.o)(.text+0x13d):ncarg_path.c: warning: Using 'endpwent' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking /usr/X11R6/lib/libX11.a(GetDflt.o)(.text+0x9a): In function
GetHomeDir’:
GetDflt.c: warning: Using ‘getpwnam_r’ in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/usr/X11R6/lib/libX11.a(GetDflt.o)(.text+0xf6):GetDflt.c: warning: Using ‘getpwuid_r’ in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/usr/X11R6/lib/libX11.a(x11trans.o)(.text+0x64): In function _X11TransSocketOpen': x11trans.c: warning: Using 'getaddrinfo' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking /usr/X11R6/lib/libX11.a(x11trans.o)(.text+0xa39): In function
_X11TransSocketUNIXConnect’:
x11trans.c: warning: Using ‘gethostbyname’ in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/usr/X11R6/lib/libX11.a(x11trans.o)(.text+0x1d9a): In function _X11TransSocketINETConnect': x11trans.c: warning: Using 'getservbyname' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking /usr/lib/libpthread.a(unwind.o)(.text+0x44): In function
unwind_stop’:
: undefined reference to _Unwind_GetCFA' /usr/lib/libpthread.a(unwind.o)(.text+0x72): In function
unwind_stop’:
: undefined reference to _Unwind_GetCFA' /usr/lib/libpthread.a(unwind.o)(.text+0x11e): In function
__pthread_unwind’:
: undefined reference to _Unwind_ForcedUnwind' /usr/lib/libpthread.a(unwind.o)(.text+0x15c): In function
__pthread_unwind_next’:
: undefined reference to _Unwind_ForcedUnwind' /usr/lib/libc.a(iofclose.o)(.text+0x196): In function
fclose’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(iofclose.o)(.eh_frame+0x12): undefined reference to
__gcc_personality_v0’
/usr/lib/libc.a(iofflush.o)(.text+0xcd): In function fflush': : undefined reference to
_Unwind_Resume’
/usr/lib/libc.a(iofflush.o)(.eh_frame+0x12): undefined reference to __gcc_personality_v0' /usr/lib/libc.a(iofgets.o)(.text+0x12c): In function
fgets’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(iofgets.o)(.eh_frame+0x12): undefined reference to
/usr/lib/libc.a(iofputs.o)(.text+0xf3): In function fputs': : undefined reference to
_Unwind_Resume’
/usr/lib/libc.a(iofputs.o)(.eh_frame+0x12): undefined reference to __gcc_personality_v0' /usr/lib/libc.a(iofwrite.o)(.text+0x106): In function
fwrite’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(iofwrite.o)(.eh_frame+0x12): undefined reference to
/usr/lib/libc.a(ioputs.o)(.text+0x125): In function puts': : undefined reference to
_Unwind_Resume’
/usr/lib/libc.a(ioputs.o)(.eh_frame+0x12): undefined reference to __gcc_personality_v0' /usr/lib/libc.a(ioseekoff.o)(.text+0x190): In function
_IO_seekoff’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(ioseekoff.o)(.eh_frame+0x12): undefined reference to
/usr/lib/libc.a(iosetvbuf.o)(.text+0x14a): In function setvbuf': : undefined reference to
_Unwind_Resume’
/usr/lib/libc.a(iosetvbuf.o)(.eh_frame+0x12): undefined reference to __gcc_personality_v0' /usr/lib/libc.a(wfileops.o)(.text+0x48e): In function
_IO_wfile_underflow’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(wfileops.o)(.eh_frame+0x12): undefined reference to
/usr/lib/libc.a(fileops.o)(.text+0x37d): In function _IO_new_file_underflow': : undefined reference to
_Unwind_Resume’
/usr/lib/libc.a(fileops.o)(.text+0x218a): In function _IO_file_fopen': : undefined reference to
_Unwind_Resume’
/usr/lib/libc.a(fileops.o)(.eh_frame+0x12): undefined reference to __gcc_personality_v0' /usr/lib/libc.a(syslog.o)(.text+0x1b8): In function
closelog’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(syslog.o)(.text+0x235): In function
openlog’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(syslog.o)(.text+0x6cd): In function
vsyslog’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(syslog.o)(.text+0x6de): In function
vsyslog’:
: undefined reference to _Unwind_Resume' /usr/lib/libc.a(syslog.o)(.eh_frame+0x12): undefined reference to
/usr/lib/libc.a(backtrace.o)(.text+0x1b): In function backtrace_helper': : undefined reference to
_Unwind_GetIP’
/usr/lib/libc.a(backtrace.o)(.text+0x34): In function backtrace_helper': : undefined reference to
_Unwind_GetGR’
/usr/lib/libc.a(backtrace.o)(.text+0x3f): In function backtrace_helper': : undefined reference to
_Unwind_GetCFA’
/usr/lib/libc.a(backtrace.o)(.text+0x98): In function backtrace': : undefined reference to
_Unwind_Backtrace’
pgf90-Fatal-linker completed with exit code 1
make[1]: *** [rams-4.4] Error 2
make[1]: Leaving directory `/home/waldyd/rams44/bin’
make: *** [rams] Error 2
How can i solve this?
