Does a global memory RW operation really take 400-600 cycles even when it’s coalesced? Same question for local device memory .
And other question… is this coalesced?
__device__ float4 d[2048];
__global__ void myKernel ()
const unsigned int tidx(blockDim.x*blockIdx.x+threadIdx.x);
d[tidx] = make_float4(1.0f,2.0f,3.0f,4.0f);
or, to be coalesced needs to be
__device__ float d[2048];
in 32bit size and not 128.
thx
JHHPC
June 22, 2008, 10:36am
2
Yes but the system transfers more than 4 bytes per latency.
thx
[snapback]397678[/snapback]
Haven’t workes with e.g. float4 yet, sry. But try profiling with the cuda visual profiler and look at the coherent/incoherent counts. If float4 works like the normal float than you should have a coalesced load, as thread 0 block 0 treats element 0 and so on
Johannes
�   const unsigned int tidx(blockDim.x*blockIdx.x+threadIdx.x);
�   d[tidx] = make_float4(1.0f,2.0f,3.0f,4.0f);
thx
Yep this should work with float4s. Float3 cannot be coalesced (well, not out of the box anyway) but float4s are no problem since each thread will be fetching/writing 128bits words.
[snapback]398034[/snapback]
I figured it… any aligned type should be coalesced, thx!
And… is the local memory faster than the global one or is it excatly the same?
ps: the CUDa profiled does not work with my app.
[snapback]398036[/snapback]
Section 5.1.2.2 of the programming guide. (beta2v2)
