I have longstanding problems with texture mutexes.
I have rewritten some of my old code in a new framework, and am still getting the same problems.
Here is a string literal containing the body of a fragment shader that, when run on an NVIDIA GeForce GTX 580M, with driver 340.52, deadlocks the driver. The texture mutex (of type UINT32 R) is in img2D_0, and is initialized each frame to VALUE_UNLOCKED:
" ivec2 coord = ivec2(gl_FragCoord.xy);\n"
" float depth_added = /*some easy calculation*/;\n"
" bool have_written = false;\n"
" while (!have_written) {\n"
" bool can_write = imageAtomicExchange(img2D_0,coord," STRINGIFY_VALUE(VALUE_LOCKED) ")==" STRINGIFY_VALUE(VALUE_UNLOCKED) ";\n"
" memoryBarrier();\n"
" if (can_write) {\n"
//critical section:
" imageAtomicExchange(img2D_0,coord," STRINGIFY_VALUE(VALUE_UNLOCKED) ");\n"
" have_written = true;\n"
" }\n"
//Just some extra method. Deleting these two lines doesn't affect the failure.
" if (!have_written) continue;\n"
" break;\n"
" }\n"
" discard;\n"
I can replace the while loop with a for loop that puts a hard limit on the number of loops, but then some fragments’ critical sections aren’t run (a bit of extra imageStore-ing to other images confirms that).
What is going on here, and how can I fix it?
Thanks,
imallett
