Upon using the appropriate marketplace deployment script with the only components changed being selecting the T4 GPU and ticking to enabled Nvidia grid, the instance failed to launch appropriately (see below). I’m hoping someone here may be able to help.
Many thanks,
Elliott
Welcome to Ubuntu 22.04.4 LTS (GNU/Linux 6.5.0-1014-gcp x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/pro
System information as of Sat Mar 30 19:26:22 UTC 2024
System load: 0.046875 Processes: 161
Usage of /: 5.1% of 48.27GB Users logged in: 0
Memory usage: 1% IPv4 address for ens5: 10.128.0.2
Swap usage: 0%
Expanded Security Maintenance for Applications is not enabled.
0 updates can be applied immediately.
Enable ESM Apps to receive additional future security updates.
See https://ubuntu.com/esm or run: sudo pro status
The list of available updates is more than a week old.
To check for new updates run: sudo apt update
Last login: Sat Mar 30 19:15:08 2024 from 35.235.244.33
NVIDIA RTX Virtual Workstation (vWS) is an optimized software environment that requires the
latest NVIDIA drivers to operate. If you do not download the NVIDIA vGPU drivers at
this time, your instance will shut down. Would you like to download the latest
NVIDIA vGPU drivers so vWS can finish installing? (Y/n)
y
chmod: cannot access '/etc/nvidia/NVIDIA-Linux-x86_64-550.54.14-grid.run': No such file or directory
......................Installing NVIDIA vGPU Driver........................
[sudo] password for elliotthughdyson:
sudo: /etc/nvidia/NVIDIA-Linux-x86_64-550.54.14-grid.run: command not found
Error! Could not find module source directory.
Directory: /usr/src/nvidia-550.54.14 does not exist.
==============NVIDIA vGPU Driver installation failed. Contact Support=================
elliotthughdyson@nvidia-rtx-virtual-workstation-ubuntu-2-vm:~$
