why batch-size is 1 ? from the code, all are 2.
By batch size, I mean the number of frames in that batched buffer.
Here is another instance of the error:
Batched buffer 0, 1, 5, 71, 104 all have 1 frame and everything work fine, the frame batch_id remain as 0 (i.e., mux_src_probe doesn’t print error message), batch 268 also has 1 frame, but the batch_id of that frame is changed from 0 to 1 (i.e., mux_src_probe print error message and call exit(1)). The batched-push-timeout is 40 msec, so it could be that after 40 msec, a batch size 2 cannot be formed so an incomplete batch is pushed. Regardless, the batch_is of the frame shouldn’t change from 0 to 1 when it’s the only frame in the batch, is that right?
** Message: 10:01:03.710: ==============BATCH[0]==============
** Message: 10:01:03.710: demux_sink_probe: num frames=1, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=95651155
** Message: 10:01:03.765: ==============BATCH[1]==============
** Message: 10:01:03.765: demux_sink_probe: num frames=1, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=1903664705
** Message: 10:01:03.828: ==============BATCH[2]==============
** Message: 10:01:03.828: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=1971666454
** Message: 10:01:03.828: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=242856356
** Message: 10:01:03.872: ==============BATCH[3]==============
** Message: 10:01:03.872: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2035657663
** Message: 10:01:03.872: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2050856701
** Message: 10:01:03.936: ==============BATCH[4]==============
** Message: 10:01:03.936: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2103653634
** Message: 10:01:03.936: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2118852747
** Message: 10:01:04.029: ==============BATCH[5]==============
** Message: 10:01:04.030: demux_sink_probe: num frames=1, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2167671632
** Message: 10:01:04.068: ==============BATCH[6]==============
** Message: 10:01:04.068: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2235668688
** Message: 10:01:04.068: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2250911663
** Message: 10:01:04.136: ==============BATCH[7]==============
** Message: 10:01:04.136: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2303650618
** Message: 10:01:04.136: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2314857709
** Message: 10:01:04.204: ==============BATCH[8]==============
** Message: 10:01:04.204: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2367603518
** Message: 10:01:04.204: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2382903648
** Message: 10:01:04.268: ==============BATCH[9]==============
** Message: 10:01:04.268: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2435655618
** Message: 10:01:04.268: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2450849756
** Message: 10:01:04.336: ==============BATCH[10]==============
** Message: 10:01:04.336: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2499658605
** Message: 10:01:04.336: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2514852749
** Message: 10:01:04.400: ==============BATCH[11]==============
** Message: 10:01:04.400: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2567654567
** Message: 10:01:04.400: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2582915759
** Message: 10:01:04.468: ==============BATCH[12]==============
** Message: 10:01:04.468: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2635650577
** Message: 10:01:04.468: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2646856698
** Message: 10:01:04.532: ==============BATCH[13]==============
** Message: 10:01:04.532: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2699666400
** Message: 10:01:04.532: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2714852711
** Message: 10:01:04.600: ==============BATCH[14]==============
** Message: 10:01:04.600: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2767650670
** Message: 10:01:04.600: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2782847754
** Message: 10:01:04.668: ==============BATCH[15]==============
** Message: 10:01:04.668: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2831668651
** Message: 10:01:04.668: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2846853748
** Message: 10:01:04.732: ==============BATCH[16]==============
** Message: 10:01:04.732: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2899660722
** Message: 10:01:04.732: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2914908737
** Message: 10:01:04.800: ==============BATCH[17]==============
** Message: 10:01:04.800: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=2963657544
** Message: 10:01:04.800: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=2978913747
** Message: 10:01:04.864: ==============BATCH[18]==============
** Message: 10:01:04.864: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3031652619
** Message: 10:01:04.864: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3046909652
** Message: 10:01:04.932: ==============BATCH[19]==============
** Message: 10:01:04.932: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3099661719
** Message: 10:01:04.932: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3110918759
** Message: 10:01:05.000: ==============BATCH[20]==============
** Message: 10:01:05.000: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3163666554
** Message: 10:01:05.000: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3178851718
** Message: 10:01:05.064: ==============BATCH[21]==============
** Message: 10:01:05.064: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3231652657
** Message: 10:01:05.064: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3246907707
** Message: 10:01:05.132: ==============BATCH[22]==============
** Message: 10:01:05.132: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3295654699
** Message: 10:01:05.132: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3310911703
** Message: 10:01:05.196: ==============BATCH[23]==============
** Message: 10:01:05.196: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3363659617
** Message: 10:01:05.196: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3378850705
** Message: 10:01:05.264: ==============BATCH[24]==============
** Message: 10:01:05.264: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3431662847
** Message: 10:01:05.264: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3442854798
** Message: 10:01:05.332: ==============BATCH[25]==============
** Message: 10:01:05.332: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3495648764
** Message: 10:01:05.332: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3510848747
** Message: 10:01:05.396: ==============BATCH[26]==============
** Message: 10:01:05.396: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3563653631
** Message: 10:01:05.396: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3578844723
** Message: 10:01:05.464: ==============BATCH[27]==============
** Message: 10:01:05.464: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3627660698
** Message: 10:01:05.464: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3642851709
** Message: 10:01:05.528: ==============BATCH[28]==============
** Message: 10:01:05.528: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3695648727
** Message: 10:01:05.528: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3710848705
** Message: 10:01:05.596: ==============BATCH[29]==============
** Message: 10:01:05.596: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3763661646
** Message: 10:01:05.596: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3774850752
** Message: 10:01:05.664: ==============BATCH[30]==============
** Message: 10:01:05.664: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3827651787
** Message: 10:01:05.664: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3842907704
** Message: 10:01:05.728: ==============BATCH[31]==============
** Message: 10:01:05.728: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3895647746
** Message: 10:01:05.728: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3910904709
** Message: 10:01:05.796: ==============BATCH[32]==============
** Message: 10:01:05.796: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=3959667797
** Message: 10:01:05.796: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=3974850791
** Message: 10:01:05.860: ==============BATCH[33]==============
** Message: 10:01:05.860: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4027652672
** Message: 10:01:05.860: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4042845733
** Message: 10:01:05.928: ==============BATCH[34]==============
** Message: 10:01:05.928: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4095646625
** Message: 10:01:05.928: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4106851632
** Message: 10:01:05.996: ==============BATCH[35]==============
** Message: 10:01:05.996: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4159650485
** Message: 10:01:05.996: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4174847708
** Message: 10:01:06.060: ==============BATCH[36]==============
** Message: 10:01:06.060: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4227646627
** Message: 10:01:06.060: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4242845672
** Message: 10:01:06.128: ==============BATCH[37]==============
** Message: 10:01:06.128: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4291659716
** Message: 10:01:06.128: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4306911587
** Message: 10:01:06.221: ==============BATCH[38]==============
** Message: 10:01:06.221: demux_sink_probe: num frames=1, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4359659616
** Message: 10:01:06.260: ==============BATCH[39]==============
** Message: 10:01:06.260: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4427644749
** Message: 10:01:06.260: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4438850703
** Message: 10:01:06.328: ==============BATCH[40]==============
** Message: 10:01:06.328: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4491661622
** Message: 10:01:06.328: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4506899617
** Message: 10:01:06.392: ==============BATCH[41]==============
** Message: 10:01:06.392: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4559656620
** Message: 10:01:06.392: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4574843709
** Message: 10:01:06.460: ==============BATCH[42]==============
** Message: 10:01:06.460: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4623648794
** Message: 10:01:06.460: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4638847775
** Message: 10:01:06.524: ==============BATCH[43]==============
** Message: 10:01:06.524: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4691654416
** Message: 10:01:06.524: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4706841527
** Message: 10:01:06.592: ==============BATCH[44]==============
** Message: 10:01:06.592: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4759643498
** Message: 10:01:06.592: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4770846508
** Message: 10:01:06.660: ==============BATCH[45]==============
** Message: 10:01:06.660: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4823591508
** Message: 10:01:06.660: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4838899657
** Message: 10:01:06.724: ==============BATCH[46]==============
** Message: 10:01:06.724: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4891643611
** Message: 10:01:06.724: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4906841657
** Message: 10:01:06.792: ==============BATCH[47]==============
** Message: 10:01:06.792: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=4955658763
** Message: 10:01:06.792: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=4970846692
** Message: 10:01:06.856: ==============BATCH[48]==============
** Message: 10:01:06.856: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5023643605
** Message: 10:01:06.856: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5038842701
** Message: 10:01:06.924: ==============BATCH[49]==============
** Message: 10:01:06.924: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5091640722
** Message: 10:01:06.924: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5102847751
** Message: 10:01:06.988: ==============BATCH[50]==============
** Message: 10:01:06.988: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5155643717
** Message: 10:01:06.988: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5170905613
** Message: 10:01:07.056: ==============BATCH[51]==============
** Message: 10:01:07.056: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5223642710
** Message: 10:01:07.056: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5238839753
** Message: 10:01:07.124: ==============BATCH[52]==============
** Message: 10:01:07.124: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5287655701
** Message: 10:01:07.124: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5302844698
** Message: 10:01:07.188: ==============BATCH[53]==============
** Message: 10:01:07.188: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5355657704
** Message: 10:01:07.188: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5370841675
** Message: 10:01:07.256: ==============BATCH[54]==============
** Message: 10:01:07.256: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5419647710
** Message: 10:01:07.256: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5434845740
** Message: 10:01:07.320: ==============BATCH[55]==============
** Message: 10:01:07.320: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5487642569
** Message: 10:01:07.320: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5502900680
** Message: 10:01:07.388: ==============BATCH[56]==============
** Message: 10:01:07.388: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5555646759
** Message: 10:01:07.388: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5566904709
** Message: 10:01:07.456: ==============BATCH[57]==============
** Message: 10:01:07.456: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5619654723
** Message: 10:01:07.456: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5634843802
** Message: 10:01:07.520: ==============BATCH[58]==============
** Message: 10:01:07.520: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5687649610
** Message: 10:01:07.520: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5702837624
** Message: 10:01:07.588: ==============BATCH[59]==============
** Message: 10:01:07.588: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5751657699
** Message: 10:01:07.588: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5766843742
** Message: 10:01:07.652: ==============BATCH[60]==============
** Message: 10:01:07.652: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5819642637
** Message: 10:01:07.652: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5834905738
** Message: 10:01:07.720: ==============BATCH[61]==============
** Message: 10:01:07.720: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5887640628
** Message: 10:01:07.720: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5898844637
** Message: 10:01:07.788: ==============BATCH[62]==============
** Message: 10:01:07.788: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=5951661525
** Message: 10:01:07.788: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=5966841726
** Message: 10:01:07.852: ==============BATCH[63]==============
** Message: 10:01:07.852: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6019648761
** Message: 10:01:07.852: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6034838608
** Message: 10:01:07.920: ==============BATCH[64]==============
** Message: 10:01:07.920: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6083644629
** Message: 10:01:07.920: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6098842611
** Message: 10:01:07.984: ==============BATCH[65]==============
** Message: 10:01:07.984: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6151640629
** Message: 10:01:07.984: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6166897695
** Message: 10:01:08.052: ==============BATCH[66]==============
** Message: 10:01:08.052: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6219648721
** Message: 10:01:08.052: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6230843759
** Message: 10:01:08.120: ==============BATCH[67]==============
** Message: 10:01:08.120: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6283645533
** Message: 10:01:08.120: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6298837659
** Message: 10:01:08.184: ==============BATCH[68]==============
** Message: 10:01:08.184: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6351646709
** Message: 10:01:08.184: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6366836701
** Message: 10:01:08.252: ==============BATCH[69]==============
** Message: 10:01:08.252: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6415642449
** Message: 10:01:08.252: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6430902722
** Message: 10:01:08.316: ==============BATCH[70]==============
** Message: 10:01:08.316: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6483654576
** Message: 10:01:08.316: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6498838727
** Message: 10:01:08.409: ==============BATCH[71]==============
** Message: 10:01:08.409: demux_sink_probe: num frames=1, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6551636626
** Message: 10:01:08.453: ==============BATCH[72]==============
** Message: 10:01:08.453: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6615640738
** Message: 10:01:08.453: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6630839659
** Message: 10:01:08.516: ==============BATCH[73]==============
** Message: 10:01:08.516: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6683637619
** Message: 10:01:08.516: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6698835619
** Message: 10:01:08.584: ==============BATCH[74]==============
** Message: 10:01:08.584: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6747641494
** Message: 10:01:08.584: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6762902628
** Message: 10:01:08.648: ==============BATCH[75]==============
** Message: 10:01:08.648: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6815655640
** Message: 10:01:08.648: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6830836742
** Message: 10:01:08.716: ==============BATCH[76]==============
** Message: 10:01:08.716: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6883640741
** Message: 10:01:08.716: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6894901727
** Message: 10:01:08.784: ==============BATCH[77]==============
** Message: 10:01:08.784: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=6947667742
** Message: 10:01:08.784: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=6962835668
** Message: 10:01:08.848: ==============BATCH[78]==============
** Message: 10:01:08.848: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7015647781
** Message: 10:01:08.848: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7030898719
** Message: 10:01:08.916: ==============BATCH[79]==============
** Message: 10:01:08.916: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7079655745
** Message: 10:01:08.916: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7094838740
** Message: 10:01:08.980: ==============BATCH[80]==============
** Message: 10:01:08.980: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7147637756
** Message: 10:01:08.980: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7162831762
** Message: 10:01:09.048: ==============BATCH[81]==============
** Message: 10:01:09.048: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7215641640
** Message: 10:01:09.048: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7226901626
** Message: 10:01:09.116: ==============BATCH[82]==============
** Message: 10:01:09.116: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7279637741
** Message: 10:01:09.116: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7294894615
** Message: 10:01:09.180: ==============BATCH[83]==============
** Message: 10:01:09.180: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7347585477
** Message: 10:01:09.180: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7362897755
** Message: 10:01:09.248: ==============BATCH[84]==============
** Message: 10:01:09.248: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7411587622
** Message: 10:01:09.248: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7426837714
** Message: 10:01:09.312: ==============BATCH[85]==============
** Message: 10:01:09.312: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7479583701
** Message: 10:01:09.312: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7494833661
** Message: 10:01:09.380: ==============BATCH[86]==============
** Message: 10:01:09.380: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7547577742
** Message: 10:01:09.380: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7558897744
** Message: 10:01:09.444: ==============BATCH[87]==============
** Message: 10:01:09.444: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7611587639
** Message: 10:01:09.444: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7626832699
** Message: 10:01:09.512: ==============BATCH[88]==============
** Message: 10:01:09.512: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7679633489
** Message: 10:01:09.512: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7694830439
** Message: 10:01:09.580: ==============BATCH[89]==============
** Message: 10:01:09.580: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7743649625
** Message: 10:01:09.580: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7758835715
** Message: 10:01:09.644: ==============BATCH[90]==============
** Message: 10:01:09.644: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7811638705
** Message: 10:01:09.644: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7826831626
** Message: 10:01:09.712: ==============BATCH[91]==============
** Message: 10:01:09.712: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7879574614
** Message: 10:01:09.712: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7890838723
** Message: 10:01:09.776: ==============BATCH[92]==============
** Message: 10:01:09.776: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=7943633617
** Message: 10:01:09.776: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=7958892671
** Message: 10:01:09.844: ==============BATCH[93]==============
** Message: 10:01:09.844: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8011648716
** Message: 10:01:09.844: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8026828735
** Message: 10:01:09.912: ==============BATCH[94]==============
** Message: 10:01:09.912: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8075639583
** Message: 10:01:09.912: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8090833666
** Message: 10:01:09.976: ==============BATCH[95]==============
** Message: 10:01:09.976: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8143632582
** Message: 10:01:09.976: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8158831703
** Message: 10:01:10.044: ==============BATCH[96]==============
** Message: 10:01:10.044: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8207593737
** Message: 10:01:10.044: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8222893698
** Message: 10:01:10.108: ==============BATCH[97]==============
** Message: 10:01:10.108: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8275641745
** Message: 10:01:10.108: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8290831800
** Message: 10:01:10.176: ==============BATCH[98]==============
** Message: 10:01:10.176: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8343630632
** Message: 10:01:10.176: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8354836738
** Message: 10:01:10.244: ==============BATCH[99]==============
** Message: 10:01:10.244: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8407579592
** Message: 10:01:10.244: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8422830625
** Message: 10:01:10.308: ==============BATCH[100]==============
** Message: 10:01:10.308: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8475646631
** Message: 10:01:10.308: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8490829631
** Message: 10:01:10.376: ==============BATCH[101]==============
** Message: 10:01:10.376: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8539635667
** Message: 10:01:10.376: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8554898677
** Message: 10:01:10.440: ==============BATCH[102]==============
** Message: 10:01:10.440: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8607649788
** Message: 10:01:10.440: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8622880741
** Message: 10:01:10.508: ==============BATCH[103]==============
** Message: 10:01:10.508: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8675634670
** Message: 10:01:10.508: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8686889695
** Message: 10:01:10.601: ==============BATCH[104]==============
** Message: 10:01:10.601: demux_sink_probe: num frames=1, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8739643491
** Message: 10:01:10.640: ==============BATCH[105]==============
** Message: 10:01:10.640: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8807574386
** Message: 10:01:10.640: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8822889472
** Message: 10:01:10.708: ==============BATCH[106]==============
** Message: 10:01:10.708: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8871646623
** Message: 10:01:10.708: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8886833617
** Message: 10:01:10.772: ==============BATCH[107]==============
** Message: 10:01:10.772: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=8939646616
** Message: 10:01:10.772: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=8954829646
** Message: 10:01:10.840: ==============BATCH[108]==============
** Message: 10:01:10.840: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9007627667
** Message: 10:01:10.840: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9018833662
** Message: 10:01:10.908: ==============BATCH[109]==============
** Message: 10:01:10.908: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9071647656
** Message: 10:01:10.908: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9086829658
** Message: 10:01:10.972: ==============BATCH[110]==============
** Message: 10:01:10.972: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9139627747
** Message: 10:01:10.972: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9154886710
** Message: 10:01:11.040: ==============BATCH[111]==============
** Message: 10:01:11.040: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9203632612
** Message: 10:01:11.040: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9218889656
** Message: 10:01:11.104: ==============BATCH[112]==============
** Message: 10:01:11.104: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9271629552
** Message: 10:01:11.104: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9286826705
** Message: 10:01:11.172: ==============BATCH[113]==============
** Message: 10:01:11.172: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9339636525
** Message: 10:01:11.172: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9350892708
** Message: 10:01:11.240: ==============BATCH[114]==============
** Message: 10:01:11.240: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9403642530
** Message: 10:01:11.240: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9418828632
** Message: 10:01:11.304: ==============BATCH[115]==============
** Message: 10:01:11.304: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9471626547
** Message: 10:01:11.304: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9486885520
** Message: 10:01:11.372: ==============BATCH[116]==============
** Message: 10:01:11.372: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9535640613
** Message: 10:01:11.372: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9550829711
** Message: 10:01:11.436: ==============BATCH[117]==============
** Message: 10:01:11.436: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9603633661
** Message: 10:01:11.436: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9618825659
** Message: 10:01:11.504: ==============BATCH[118]==============
** Message: 10:01:11.504: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9671639643
** Message: 10:01:11.504: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9682889620
** Message: 10:01:11.572: ==============BATCH[119]==============
** Message: 10:01:11.572: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9735629619
** Message: 10:01:11.572: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9750885684
** Message: 10:01:11.636: ==============BATCH[120]==============
** Message: 10:01:11.636: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9803636620
** Message: 10:01:11.636: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9818823610
** Message: 10:01:11.704: ==============BATCH[121]==============
** Message: 10:01:11.704: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9867644620
** Message: 10:01:11.704: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9882828704
** Message: 10:01:11.768: ==============BATCH[122]==============
** Message: 10:01:11.768: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=9935631741
** Message: 10:01:11.768: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=9950825720
** Message: 10:01:11.836: ==============BATCH[123]==============
** Message: 10:01:11.836: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10003624628
** Message: 10:01:11.836: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10014889634
** Message: 10:01:11.900: ==============BATCH[124]==============
** Message: 10:01:11.900: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10067628749
** Message: 10:01:11.900: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10082823752
** Message: 10:01:11.968: ==============BATCH[125]==============
** Message: 10:01:11.968: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10135635661
** Message: 10:01:11.968: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10150819708
** Message: 10:01:12.036: ==============BATCH[126]==============
** Message: 10:01:12.036: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10199642638
** Message: 10:01:12.036: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10214827752
** Message: 10:01:12.100: ==============BATCH[127]==============
** Message: 10:01:12.100: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10267626240
** Message: 10:01:12.100: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10282887702
** Message: 10:01:12.168: ==============BATCH[128]==============
** Message: 10:01:12.168: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10335620615
** Message: 10:01:12.168: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10346885721
** Message: 10:01:12.232: ==============BATCH[129]==============
** Message: 10:01:12.232: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10399642703
** Message: 10:01:12.232: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10414884655
** Message: 10:01:12.300: ==============BATCH[130]==============
** Message: 10:01:12.300: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10467625625
** Message: 10:01:12.300: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10478828682
** Message: 10:01:12.368: ==============BATCH[131]==============
** Message: 10:01:12.368: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10531663757
** Message: 10:01:12.368: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10546825713
** Message: 10:01:12.432: ==============BATCH[132]==============
** Message: 10:01:12.432: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10599638678
** Message: 10:01:12.432: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10614883704
** Message: 10:01:12.500: ==============BATCH[133]==============
** Message: 10:01:12.500: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10663638611
** Message: 10:01:12.500: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10678825518
** Message: 10:01:12.564: ==============BATCH[134]==============
** Message: 10:01:12.564: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10731628308
** Message: 10:01:12.564: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10746821722
** Message: 10:01:12.632: ==============BATCH[135]==============
** Message: 10:01:12.632: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10799633453
** Message: 10:01:12.632: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10810887646
** Message: 10:01:12.700: ==============BATCH[136]==============
** Message: 10:01:12.700: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10863626688
** Message: 10:01:12.700: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10878875750
** Message: 10:01:12.764: ==============BATCH[137]==============
** Message: 10:01:12.764: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10931620696
** Message: 10:01:12.764: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=10946877611
** Message: 10:01:12.832: ==============BATCH[138]==============
** Message: 10:01:12.832: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=10995647786
** Message: 10:01:12.832: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11010825649
** Message: 10:01:12.896: ==============BATCH[139]==============
** Message: 10:01:12.896: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11063623775
** Message: 10:01:12.896: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11078881679
** Message: 10:01:12.964: ==============BATCH[140]==============
** Message: 10:01:12.964: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11131619719
** Message: 10:01:12.964: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11142881646
** Message: 10:01:13.032: ==============BATCH[141]==============
** Message: 10:01:13.032: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11195624730
** Message: 10:01:13.032: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11210822573
** Message: 10:01:13.096: ==============BATCH[142]==============
** Message: 10:01:13.096: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11263621613
** Message: 10:01:13.096: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11278882619
** Message: 10:01:13.164: ==============BATCH[143]==============
** Message: 10:01:13.164: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11327626703
** Message: 10:01:13.164: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11342823485
** Message: 10:01:13.228: ==============BATCH[144]==============
** Message: 10:01:13.228: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11395621624
** Message: 10:01:13.228: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11410820542
** Message: 10:01:13.296: ==============BATCH[145]==============
** Message: 10:01:13.296: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11463621589
** Message: 10:01:13.296: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11474824694
** Message: 10:01:13.364: ==============BATCH[146]==============
** Message: 10:01:13.364: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11527622608
** Message: 10:01:13.364: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11542884645
** Message: 10:01:13.428: ==============BATCH[147]==============
** Message: 10:01:13.428: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11595618522
** Message: 10:01:13.428: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11610879589
** Message: 10:01:13.496: ==============BATCH[148]==============
** Message: 10:01:13.496: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11659637510
** Message: 10:01:13.496: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11674822673
** Message: 10:01:13.560: ==============BATCH[149]==============
** Message: 10:01:13.560: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11727620664
** Message: 10:01:13.560: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11742818730
** Message: 10:01:13.628: ==============BATCH[150]==============
** Message: 10:01:13.628: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11795616568
** Message: 10:01:13.628: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11806822676
** Message: 10:01:13.696: ==============BATCH[151]==============
** Message: 10:01:13.696: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11859634520
** Message: 10:01:13.696: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11874819679
** Message: 10:01:13.760: ==============BATCH[152]==============
** Message: 10:01:13.760: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11927618470
** Message: 10:01:13.760: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=11942875713
** Message: 10:01:13.828: ==============BATCH[153]==============
** Message: 10:01:13.828: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=11991622683
** Message: 10:01:13.828: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12006820678
** Message: 10:01:13.892: ==============BATCH[154]==============
** Message: 10:01:13.892: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12059623602
** Message: 10:01:13.892: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12074815661
** Message: 10:01:13.960: ==============BATCH[155]==============
** Message: 10:01:13.960: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12127627472
** Message: 10:01:13.960: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12138821558
** Message: 10:01:14.028: ==============BATCH[156]==============
** Message: 10:01:14.028: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12191628540
** Message: 10:01:14.028: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12206868660
** Message: 10:01:14.092: ==============BATCH[157]==============
** Message: 10:01:14.092: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12259616592
** Message: 10:01:14.092: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12274813710
** Message: 10:01:14.160: ==============BATCH[158]==============
** Message: 10:01:14.160: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12323637655
** Message: 10:01:14.160: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12338883664
** Message: 10:01:14.224: ==============BATCH[159]==============
** Message: 10:01:14.224: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12391635671
** Message: 10:01:14.224: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12406815649
** Message: 10:01:14.292: ==============BATCH[160]==============
** Message: 10:01:14.292: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12459623660
** Message: 10:01:14.292: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12470820662
** Message: 10:01:14.356: ==============BATCH[161]==============
** Message: 10:01:14.356: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12523632531
** Message: 10:01:14.356: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12538875730
** Message: 10:01:14.424: ==============BATCH[162]==============
** Message: 10:01:14.424: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12591615601
** Message: 10:01:14.424: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12606812671
** Message: 10:01:14.492: ==============BATCH[163]==============
** Message: 10:01:14.492: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12655637505
** Message: 10:01:14.492: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12670817584
** Message: 10:01:14.556: ==============BATCH[164]==============
** Message: 10:01:14.556: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12723615174
** Message: 10:01:14.556: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12738814515
** Message: 10:01:14.624: ==============BATCH[165]==============
** Message: 10:01:14.624: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12791558559
** Message: 10:01:14.624: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12802816425
** Message: 10:01:14.688: ==============BATCH[166]==============
** Message: 10:01:14.688: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12855615654
** Message: 10:01:14.688: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12870815665
** Message: 10:01:14.756: ==============BATCH[167]==============
** Message: 10:01:14.756: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12923611746
** Message: 10:01:14.756: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=12938809611
** Message: 10:01:14.824: ==============BATCH[168]==============
** Message: 10:01:14.824: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=12987631658
** Message: 10:01:14.824: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13002815703
** Message: 10:01:14.888: ==============BATCH[169]==============
** Message: 10:01:14.888: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13055625674
** Message: 10:01:14.888: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13070810709
** Message: 10:01:14.956: ==============BATCH[170]==============
** Message: 10:01:14.956: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13119630752
** Message: 10:01:14.956: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13134866742
** Message: 10:01:15.020: ==============BATCH[171]==============
** Message: 10:01:15.020: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13187624633
** Message: 10:01:15.020: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13202878716
** Message: 10:01:15.088: ==============BATCH[172]==============
** Message: 10:01:15.088: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13255556727
** Message: 10:01:15.088: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13266818722
** Message: 10:01:15.156: ==============BATCH[173]==============
** Message: 10:01:15.156: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13319630521
** Message: 10:01:15.156: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13334815670
** Message: 10:01:15.220: ==============BATCH[174]==============
** Message: 10:01:15.220: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13387628611
** Message: 10:01:15.220: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13402871609
** Message: 10:01:15.313: ==============BATCH[175]==============
** Message: 10:01:15.313: demux_sink_probe: num frames=1, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13451617721
** Message: 10:01:15.352: ==============BATCH[176]==============
** Message: 10:01:15.352: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13519625718
** Message: 10:01:15.352: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13534811748
** Message: 10:01:15.420: ==============BATCH[177]==============
** Message: 10:01:15.420: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13587614571
** Message: 10:01:15.420: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13598816426
** Message: 10:01:15.488: ==============BATCH[178]==============
** Message: 10:01:15.488: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13651615393
** Message: 10:01:15.488: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13666813753
** Message: 10:01:15.552: ==============BATCH[179]==============
** Message: 10:01:15.552: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13719630444
** Message: 10:01:15.552: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13734874488
** Message: 10:01:15.620: ==============BATCH[180]==============
** Message: 10:01:15.620: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13783630657
** Message: 10:01:15.620: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13798814625
** Message: 10:01:15.684: ==============BATCH[181]==============
** Message: 10:01:15.684: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13851616531
** Message: 10:01:15.684: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13866811569
** Message: 10:01:15.752: ==============BATCH[182]==============
** Message: 10:01:15.752: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13919618628
** Message: 10:01:15.752: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13930816756
** Message: 10:01:15.820: ==============BATCH[183]==============
** Message: 10:01:15.820: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=13983620541
** Message: 10:01:15.820: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=13998873614
** Message: 10:01:15.884: ==============BATCH[184]==============
** Message: 10:01:15.884: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14051554710
** Message: 10:01:15.884: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14066867675
** Message: 10:01:15.952: ==============BATCH[185]==============
** Message: 10:01:15.952: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14115623661
** Message: 10:01:15.952: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14130810705
** Message: 10:01:16.016: ==============BATCH[186]==============
** Message: 10:01:16.016: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14183621750
** Message: 10:01:16.016: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14198809742
** Message: 10:01:16.084: ==============BATCH[187]==============
** Message: 10:01:16.084: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14251622358
** Message: 10:01:16.084: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14262873609
** Message: 10:01:16.152: ==============BATCH[188]==============
** Message: 10:01:16.152: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14315627545
** Message: 10:01:16.152: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14330874740
** Message: 10:01:16.216: ==============BATCH[189]==============
** Message: 10:01:16.216: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14383608602
** Message: 10:01:16.216: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14398866708
** Message: 10:01:16.284: ==============BATCH[190]==============
** Message: 10:01:16.284: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14447627592
** Message: 10:01:16.284: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14462811744
** Message: 10:01:16.348: ==============BATCH[191]==============
** Message: 10:01:16.348: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14515624492
** Message: 10:01:16.348: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14530807521
** Message: 10:01:16.416: ==============BATCH[192]==============
** Message: 10:01:16.416: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14583618538
** Message: 10:01:16.416: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14594872534
** Message: 10:01:16.484: ==============BATCH[193]==============
** Message: 10:01:16.484: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14647612526
** Message: 10:01:16.484: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14662868615
** Message: 10:01:16.548: ==============BATCH[194]==============
** Message: 10:01:16.548: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14715620736
** Message: 10:01:16.548: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14730805736
** Message: 10:01:16.616: ==============BATCH[195]==============
** Message: 10:01:16.616: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14779616627
** Message: 10:01:16.616: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14794808707
** Message: 10:01:16.680: ==============BATCH[196]==============
** Message: 10:01:16.680: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14847609645
** Message: 10:01:16.680: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14862806707
** Message: 10:01:16.748: ==============BATCH[197]==============
** Message: 10:01:16.748: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14915605701
** Message: 10:01:16.748: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14926875758
** Message: 10:01:16.812: ==============BATCH[198]==============
** Message: 10:01:16.812: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=14979611605
** Message: 10:01:16.812: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=14994872701
** Message: 10:01:16.880: ==============BATCH[199]==============
** Message: 10:01:16.880: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15047608506
** Message: 10:01:16.880: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15062803676
** Message: 10:01:16.948: ==============BATCH[200]==============
** Message: 10:01:16.948: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15111622743
** Message: 10:01:16.948: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15126809760
** Message: 10:01:17.012: ==============BATCH[201]==============
** Message: 10:01:17.012: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15179608661
** Message: 10:01:17.012: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15194805748
** Message: 10:01:17.080: ==============BATCH[202]==============
** Message: 10:01:17.080: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15247603614
** Message: 10:01:17.080: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15258810525
** Message: 10:01:17.144: ==============BATCH[203]==============
** Message: 10:01:17.144: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15311616699
** Message: 10:01:17.144: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15326865679
** Message: 10:01:17.212: ==============BATCH[204]==============
** Message: 10:01:17.212: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15379606669
** Message: 10:01:17.212: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15394801754
** Message: 10:01:17.280: ==============BATCH[205]==============
** Message: 10:01:17.280: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15443617585
** Message: 10:01:17.280: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15458807701
** Message: 10:01:17.344: ==============BATCH[206]==============
** Message: 10:01:17.344: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15511622576
** Message: 10:01:17.344: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15526862705
** Message: 10:01:17.412: ==============BATCH[207]==============
** Message: 10:01:17.412: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15579608591
** Message: 10:01:17.412: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15590870712
** Message: 10:01:17.476: ==============BATCH[208]==============
** Message: 10:01:17.476: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15643607590
** Message: 10:01:17.476: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15658864656
** Message: 10:01:17.544: ==============BATCH[209]==============
** Message: 10:01:17.544: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15711605393
** Message: 10:01:17.544: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15722809108
** Message: 10:01:17.612: ==============BATCH[210]==============
** Message: 10:01:17.612: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15775551468
** Message: 10:01:17.612: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15790801688
** Message: 10:01:17.676: ==============BATCH[211]==============
** Message: 10:01:17.676: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15843607567
** Message: 10:01:17.676: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15858859583
** Message: 10:01:17.744: ==============BATCH[212]==============
** Message: 10:01:17.744: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15907615664
** Message: 10:01:17.744: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15922862537
** Message: 10:01:17.808: ==============BATCH[213]==============
** Message: 10:01:17.808: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=15975606549
** Message: 10:01:17.808: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=15990868615
** Message: 10:01:17.876: ==============BATCH[214]==============
** Message: 10:01:17.876: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16043604756
** Message: 10:01:17.876: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16054867729
** Message: 10:01:17.944: ==============BATCH[215]==============
** Message: 10:01:17.944: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16107624555
** Message: 10:01:17.944: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16122802636
** Message: 10:01:18.008: ==============BATCH[216]==============
** Message: 10:01:18.008: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16175549321
** Message: 10:01:18.008: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16190801756
** Message: 10:01:18.076: ==============BATCH[217]==============
** Message: 10:01:18.076: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16239619614
** Message: 10:01:18.076: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16254805368
** Message: 10:01:18.140: ==============BATCH[218]==============
** Message: 10:01:18.140: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16307613743
** Message: 10:01:18.140: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16322862716
** Message: 10:01:18.208: ==============BATCH[219]==============
** Message: 10:01:18.208: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16375604803
** Message: 10:01:18.208: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16386806689
** Message: 10:01:18.276: ==============BATCH[220]==============
** Message: 10:01:18.276: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16439602663
** Message: 10:01:18.276: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16454801752
** Message: 10:01:18.340: ==============BATCH[221]==============
** Message: 10:01:18.340: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16507600569
** Message: 10:01:18.340: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16522864672
** Message: 10:01:18.408: ==============BATCH[222]==============
** Message: 10:01:18.408: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16571622669
** Message: 10:01:18.408: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16586804627
** Message: 10:01:18.472: ==============BATCH[223]==============
** Message: 10:01:18.472: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16639602672
** Message: 10:01:18.472: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16654865590
** Message: 10:01:18.540: ==============BATCH[224]==============
** Message: 10:01:18.540: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16707542367
** Message: 10:01:18.540: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16718859653
** Message: 10:01:18.608: ==============BATCH[225]==============
** Message: 10:01:18.608: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16771617528
** Message: 10:01:18.608: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16786801703
** Message: 10:01:18.672: ==============BATCH[226]==============
** Message: 10:01:18.672: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16839609576
** Message: 10:01:18.672: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16854798704
** Message: 10:01:18.740: ==============BATCH[227]==============
** Message: 10:01:18.740: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16903613665
** Message: 10:01:18.740: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16918868727
** Message: 10:01:18.804: ==============BATCH[228]==============
** Message: 10:01:18.804: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=16971601546
** Message: 10:01:18.804: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=16986863703
** Message: 10:01:18.872: ==============BATCH[229]==============
** Message: 10:01:18.872: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17039599656
** Message: 10:01:18.872: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17050804752
** Message: 10:01:18.940: ==============BATCH[230]==============
** Message: 10:01:18.940: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17103611536
** Message: 10:01:18.940: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17118798619
** Message: 10:01:19.004: ==============BATCH[231]==============
** Message: 10:01:19.004: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17171598574
** Message: 10:01:19.004: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17186797523
** Message: 10:01:19.072: ==============BATCH[232]==============
** Message: 10:01:19.072: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17235617547
** Message: 10:01:19.072: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17250859707
** Message: 10:01:19.136: ==============BATCH[233]==============
** Message: 10:01:19.136: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17303600688
** Message: 10:01:19.136: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17318797765
** Message: 10:01:19.204: ==============BATCH[234]==============
** Message: 10:01:19.204: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17371595758
** Message: 10:01:19.204: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17382856761
** Message: 10:01:19.272: ==============BATCH[235]==============
** Message: 10:01:19.272: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17435615702
** Message: 10:01:19.272: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17450798647
** Message: 10:01:19.336: ==============BATCH[236]==============
** Message: 10:01:19.336: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17503620633
** Message: 10:01:19.336: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17518794711
** Message: 10:01:19.404: ==============BATCH[237]==============
** Message: 10:01:19.404: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17567613629
** Message: 10:01:19.404: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17582865650
** Message: 10:01:19.468: ==============BATCH[238]==============
** Message: 10:01:19.468: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17635611747
** Message: 10:01:19.468: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17650796813
** Message: 10:01:19.536: ==============BATCH[239]==============
** Message: 10:01:19.536: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17703593582
** Message: 10:01:19.536: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17714799611
** Message: 10:01:19.600: ==============BATCH[240]==============
** Message: 10:01:19.600: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17767612793
** Message: 10:01:19.600: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17782798742
** Message: 10:01:19.668: ==============BATCH[241]==============
** Message: 10:01:19.668: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17835597570
** Message: 10:01:19.668: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17850794750
** Message: 10:01:19.736: ==============BATCH[242]==============
** Message: 10:01:19.736: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17899609656
** Message: 10:01:19.736: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17914799750
** Message: 10:01:19.800: ==============BATCH[243]==============
** Message: 10:01:19.800: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=17967600569
** Message: 10:01:19.800: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=17982854663
** Message: 10:01:19.868: ==============BATCH[244]==============
** Message: 10:01:19.868: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18035593733
** Message: 10:01:19.868: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18046861795
** Message: 10:01:19.932: ==============BATCH[245]==============
** Message: 10:01:19.932: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18099604541
** Message: 10:01:19.932: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18114794720
** Message: 10:01:20.000: ==============BATCH[246]==============
** Message: 10:01:20.000: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18167612544
** Message: 10:01:20.000: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18178800758
** Message: 10:01:20.068: ==============BATCH[247]==============
** Message: 10:01:20.068: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18231605733
** Message: 10:01:20.068: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18246856712
** Message: 10:01:20.132: ==============BATCH[248]==============
** Message: 10:01:20.132: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18299609629
** Message: 10:01:20.132: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18314793710
** Message: 10:01:20.200: ==============BATCH[249]==============
** Message: 10:01:20.200: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18363601811
** Message: 10:01:20.200: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18378859803
** Message: 10:01:20.264: ==============BATCH[250]==============
** Message: 10:01:20.264: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18431605710
** Message: 10:01:20.264: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18446793705
** Message: 10:01:20.332: ==============BATCH[251]==============
** Message: 10:01:20.332: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18499609704
** Message: 10:01:20.332: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18510857749
** Message: 10:01:20.400: ==============BATCH[252]==============
** Message: 10:01:20.400: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18563597529
** Message: 10:01:20.400: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18578795698
** Message: 10:01:20.464: ==============BATCH[253]==============
** Message: 10:01:20.464: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18631550617
** Message: 10:01:20.464: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18646792701
** Message: 10:01:20.532: ==============BATCH[254]==============
** Message: 10:01:20.532: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18695598549
** Message: 10:01:20.532: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18710796612
** Message: 10:01:20.596: ==============BATCH[255]==============
** Message: 10:01:20.596: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18763543626
** Message: 10:01:20.596: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18778852760
** Message: 10:01:20.664: ==============BATCH[256]==============
** Message: 10:01:20.664: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18831604702
** Message: 10:01:20.664: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18842798707
** Message: 10:01:20.732: ==============BATCH[257]==============
** Message: 10:01:20.732: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18895612465
** Message: 10:01:20.732: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18910794642
** Message: 10:01:20.796: ==============BATCH[258]==============
** Message: 10:01:20.796: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=18963592702
** Message: 10:01:20.796: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=18978789753
** Message: 10:01:20.864: ==============BATCH[259]==============
** Message: 10:01:20.864: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19027609790
** Message: 10:01:20.864: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19042795739
** Message: 10:01:20.928: ==============BATCH[260]==============
** Message: 10:01:20.928: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19095541667
** Message: 10:01:20.928: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19110849752
** Message: 10:01:20.996: ==============BATCH[261]==============
** Message: 10:01:20.996: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19163592615
** Message: 10:01:20.996: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19174796711
** Message: 10:01:21.064: ==============BATCH[262]==============
** Message: 10:01:21.064: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19227609782
** Message: 10:01:21.064: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19242851715
** Message: 10:01:21.128: ==============BATCH[263]==============
** Message: 10:01:21.128: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19295538666
** Message: 10:01:21.128: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19310790705
** Message: 10:01:21.196: ==============BATCH[264]==============
** Message: 10:01:21.196: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19359610614
** Message: 10:01:21.196: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19374793727
** Message: 10:01:21.260: ==============BATCH[265]==============
** Message: 10:01:21.260: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19427606663
** Message: 10:01:21.260: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19442789669
** Message: 10:01:21.328: ==============BATCH[266]==============
** Message: 10:01:21.328: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19495536613
** Message: 10:01:21.328: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19506848719
** Message: 10:01:21.396: ==============BATCH[267]==============
** Message: 10:01:21.396: demux_sink_probe: num frames=2, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19559594672
** Message: 10:01:21.396: demux_sink_probe: num frames=2, frame_meta->batch_id=1, frame_meta->source_id=1, frame_meta->buf_pts=19574791808
** Message: 10:01:21.485: ==============BATCH[268]==============
** Message: 10:01:21.485: demux_sink_probe: num frames=1, frame_meta->batch_id=0, frame_meta->source_id=0, frame_meta->buf_pts=19627594762
** Message: 10:01:21.525: ==============BATCH[268]==============
** (deepstream-test1-app:7171): ERROR **: 10:01:21.526: mux_src_probe: num frames=1, frame_meta->batch_id=1, frame_meta->source_id=0, frame_meta->buf_pts=19627594762
Trace/breakpoint trap (core dumped)
