Hi folks! I’m stuck in making CUDA to work the way i think it must. I plan to use my box mostly for rendering and work with Blender. I brand a CUDA supported graphic card:
01:00.0 VGA compatible controller: NVIDIA Corporation GK107 [GeForce GT 640] (rev a1)
Now, the thing is, when i’m rendering entirely with the GPU, via Blender Cycles, i notice the rendering speed up almost 20x fast, but my machine starts to lag and freeze, instead of when i’m rendering with all my CPU cores. I’ve an AMD Fx 6100 with 8 Gb of RAM. I think it must be the other way around, my machine works very nice even when i’m rendering with all the CPU load, and on the other hand with GPU CUDA rendering that it lags my pc.
CUDA version:
community/cuda 5.0.35-3 [installed]
NVIDIA’s GPU programming toolkit
Blender:
Blender 2.66 (sub 1)
build date: 2013-03-09
build time: 01:22:40
build revision: unknown
build platform: Linux
build type: Release
build c flags: -Wall -Wcast-align -Werror=declaration-after-statement -Werror=implicit-function-declaration -Werror=return-type -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wnonnull -Wmissing-include-dirs -Wno-div-by-zero -Wuninitialized -Wno-error=unused-but-set-variable -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -D_FORTIFY_SOURCE=2 -fopenmp -msse2 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing
build c++ flags: -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wuninitialized -Wundef -Wmissing-declarations -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -D_FORTIFY_SOURCE=2 -D__STDC_CONSTANT_MACROS -fopenmp -msse2 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing
build link flags: -Wl,–version-script=/build/src/blender-2.66a/source/creator/blender.map -pthread
build system: CMake
Actually using the Con Koliva’s kernel and last NVIDIA driver
repo-ck/nvidia-ck-bulldozer 313.26-1 (ck-bulldozer) [installed]
NVIDIA drivers for linux-ck. AMD Bulldozer Family 15h microarchitecture optimized.
I’m thinking of downgrading the driver to 304xx, or i’m wrong and it’s normal to have that lag?
Thanks in advance!
iamgabo
