GPU device routine calculates the sum incorrectly in vector mode
Hello, the following subroutine calculates the sum incorrectly if runs in vector mode. Could you please explain why and suggest solution if there is any.
[ilkhom@t020 MCCC]$ cat seq_vector.f90
module array
  implicit none
  real(kind=8), allocatable, dimension(:,:) :: a
!$acc declare create(a)
end module array
subroutine acc_rout(tmp1)
!$acc routine seq   !vector
  use array
  implicit none
  integer :: i,j
  real*8, intent(out) :: tmp1
  real*8 :: tmp2
  tmp1=0.d0
!$acc loop reduction(+:tmp1)
  do i=1,3
    tmp2=0.d0
!$acc loop reduction(+:tmp2)
    do j=1,2
      tmp2=tmp2+a(i,j)
    enddo
    tmp1=tmp1+tmp2
  enddo
end subroutine acc_rout
program test
  use array
  implicit none
  real(kind=8) :: tmp
  allocate(a(1:3,1:2))
  a(1,1)=1.d0; a(1,2)=2.d0
  a(2,1)=3.d0; a(2,2)=4.d0
  a(3,1)=5.d0; a(3,2)=6.d0
!$acc update device(a)
!$acc parallel copy(tmp) num_gangs(1) vector_length(128)
  call acc_rout(tmp)
!$acc end parallel
print*,'tmp=',tmp
end program test
[ilkhom@t020 MCCC]$ nvfortran -acc -Minfo=accel -ta=tesla:cuda11.6 seq_vector.f90 && ./a.out
acc_rout:
      7, Generating acc routine seq
         Generating NVIDIA GPU code
test:
     37, Generating update device(a(:,:))
     38, Generating copy(tmp) [if not already present]
     39, Reference argument passing prevents parallelization: tmp
 tmp=    21.00000000000000
[ilkhom@t020 MCCC]$
If I run it in vector mode I am getting 9 instead of 21.
Hi Ilkhom,
Since you’re using F77 style calling, you need to add:
!$acc routine(acc_rout) vector
in the caller’s routine else the caller assumes its sequential. Alternately add an interface to the routine or place it in a module so F90 calling is used.
For example:
% cat seq_vector.f90
module array
  implicit none
end module array
!$acc routine vector
  use array
  implicit none
  integer :: i,j
  real*8 :: tmp2
  tmp1=0.d0
  do i=1,3
    tmp2=0.d0
    do j=1,2
      tmp2=tmp2+a(i,j)
    enddo
    tmp1=tmp1+tmp2
  enddo
program test
  use array
  implicit none
  real(kind=8) :: tmp
  call acc_rout(tmp)
!$acc end parallel
print*,'tmp=',tmp
end program test
% nvfortran -acc seq_vector.f90 -Minfo=accel -V22.3 ; a.out
acc_rout:
      7, Generating NVIDIA GPU code
         16, !$acc loop seq
             Generating reduction(+:tmp1)
         19, !$acc loop vector ! threadidx%x
             Generating reduction(+:tmp2)
             Vector barrier inserted for vector loop reduction
     16, Loop is parallelizable
     19, Loop is parallelizable
test:
Hope this helps,
Mat
Thank you very much for such a nice explanation. I would not figure it out myself.
Ilkhom
