Can the tlt models generated on GPU 1080 be inferred on Triton server with GPU 3070, 3080?
Yes, but please note that it is .etlt model. You can run tao export and then copy the .etlt model to Trition server.
Thank you!
How to run a detectnet_v2 model on the triton server, it is a little confusing?
For running detectnet_v2 model in triton server, you can refer to Integrating TAO CV Models with Triton Inference Server — TAO Toolkit 3.22.05 documentation.
I saw this documentation earlier, but it is not clear…
Is there another client that I have to install for Detectnet_v2?
After you have trained a detectnet_v2 model, you can deploy the model to run inference.
For inference, usually there are below ways.
How about the post processing, is it a file or a folder?
If it is a file then what is the extension?
The DetectNet_v2 inference sample has 2 components that can be configured
For running in triton server, please refer to the README.
For example, running official released peoplenet model with it, see its postprocessing config file in tao-toolkit-triton-apps/clustering_config_peoplenet.prototxt at main · NVIDIA-AI-IOT/tao-toolkit-triton-apps (github.com)
Can I run classification with a standalone inference code?
Yes, it can. You can leverage GitHub - NVIDIA-AI-IOT/tao-toolkit-triton-apps: Sample app code for deploying TAO Toolkit trained models to Triton
or search/find some topics in forum. For example,
