I’m not able to figure out why this gpu driver isn’t loading.
nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
sudo prime-select query
nvidia
ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00002507sv00001462sd0000C978bc03sc00i00
vendor : NVIDIA Corporation
driver : nvidia-driver-510-server - distro non-free
driver : nvidia-driver-510 - distro non-free recommended
driver : xserver-xorg-video-nouveau - distro free builtin
modprobe nvidia
modprobe: FATAL: Module nvidia not found in directory /lib/modules/5.18.0-051800rc1-generic
dkms status
nvidia, 510.60.02: added
gpu-manager.log
log_file: /var/log/gpu-manager.log
last_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
new_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
can’t access /run/u-d-c-nvidia-was-loaded file
can’t access /opt/amdgpu-pro/bin/amdgpu-pro-px
Looking for nvidia modules in /lib/modules/5.18.0-051800rc1-generic/kernel
Looking for nvidia modules in /lib/modules/5.18.0-051800rc1-generic/updates/dkms
Looking for amdgpu modules in /lib/modules/5.18.0-051800rc1-generic/kernel
Looking for amdgpu modules in /lib/modules/5.18.0-051800rc1-generic/updates/dkms
Is nvidia loaded? no
Was nvidia unloaded? no
Is nvidia blacklisted? no
Is intel loaded? yes
Is radeon loaded? no
Is radeon blacklisted? no
Is amdgpu loaded? no
Is amdgpu blacklisted? no
Is amdgpu versioned? no
Is amdgpu pro stack? no
Is nouveau loaded? no
Is nouveau blacklisted? yes
Is nvidia kernel module available? no
Is amdgpu kernel module available? no
Vendor/Device Id: 8086:4692
BusID “PCI:0@0:2:0”
Is boot vga? yes
Vendor/Device Id: 10de:2507
BusID “PCI:1@0:0:0”
Is boot vga? no
Error: can’t access /sys/bus/pci/devices/0000:01:00.0/driver
The device is not bound to any driver.
Chassis type: “3”
Laptop not detected
Is nvidia runtime pm supported for “0x2507”? no
Checking power status in /proc/driver/nvidia/gpus/0000:01:00.0/power
Error while opening /proc/driver/nvidia/gpus/0000:01:00.0/power
Is nvidia runtime pm enabled for “0x2507”? no
Skipping “/dev/dri/card0”, driven by “i915”
Found “/dev/dri/card0”, driven by “i915”
output 0:
card0-HDMI-A-3
Number of connected outputs for /dev/dri/card0: 1
Does it require offloading? yes
last cards number = 2
Has amd? no
Has intel? yes
Has nvidia? yes
How many cards? 2
Loading nvidia with “no” parameters
Has the system changed? No
can’t access /run/u-d-c-nvidia-drm-was-loaded file
… ^ x150 rows
Takes 10000ms to wait for nvidia udev rules completed.
Intel IGP detected
Desktop system detected
or laptop with open drivers
Nothing to do
711-u-c-d-gpu-detection.rules
Rule installed by ubuntu-drivers-common
Create a file with the card details for gpu-manager
ACTION==“add”, SUBSYSTEM==“drm”, DEVPATH==“/drm/card”, RUN+=“/sbin/u-d-c-print-pci-ids”
Create a file when a module is loaded
ACTION==“add”, SUBSYSTEMS==“pci”, DRIVERS==“nvidia”, RUN+=“/bin/touch /run/u-d-c-nvidia-was-loaded”
ACTION==“add”, SUBSYSTEM==“module”, KERNEL==“nvidia_drm”, RUN+=“/bin/touch /run/u-d-c-nvidia-drm-was-loaded”
