Thanks for your reporting.
Confirmed that we can reproduce this issue in our environment.
We are checking this with our internal team. Will get back to you later.
Well, I was expecting an answer but …
Today I’ve also seen a GPU fault without using nvprof. Not sure it is related.
I think it happened when trying to display an H264 encoded video with Totem, but I failed to reproduce it.
For reference, the relevant syslog is below. I’d futher suggest to add kernel timing to tegrastats, so that it would be much easier to see tegratstats when the fault happened.
Mar 2 23:11:14 Xavier-NX dbus-daemon[7442]: [session uid=1000 pid=7442] Activating service name='org.gnome.Totem' requested by ':1.107' (uid=1000 pid=10460 comm="/usr/bin/nautilus --gapplication-service ")
Mar 2 23:11:15 Xavier-NX /usr/lib/gdm3/gdm-x-session[7427]: (--) NVIDIA(GPU-0): Samsung S34J55x (DFP-0): connected
Mar 2 23:11:15 Xavier-NX /usr/lib/gdm3/gdm-x-session[7427]: (--) NVIDIA(GPU-0): Samsung S34J55x (DFP-0): External TMDS
Mar 2 23:11:15 Xavier-NX /usr/lib/gdm3/gdm-x-session[7427]: (--) NVIDIA(GPU-0): Samsung S34J55x (DFP-0) Name Aliases:
Mar 2 23:11:15 Xavier-NX /usr/lib/gdm3/gdm-x-session[7427]: (--) NVIDIA(GPU-0): DFP
Mar 2 23:11:15 Xavier-NX /usr/lib/gdm3/gdm-x-session[7427]: (--) NVIDIA(GPU-0): DFP-0
Mar 2 23:11:15 Xavier-NX /usr/lib/gdm3/gdm-x-session[7427]: (--) NVIDIA(GPU-0): DPY-0
Mar 2 23:11:15 Xavier-NX /usr/lib/gdm3/gdm-x-session[7427]: (--) NVIDIA(GPU-0): HDMI-0
Mar 2 23:11:15 Xavier-NX /usr/lib/gdm3/gdm-x-session[7427]: (--) NVIDIA(GPU-0): DPY-EDID-6c7fa4d9-4543-f1d3-0379-6c61d3c1aed9
Mar 2 23:11:15 Xavier-NX dbus-daemon[7442]: [session uid=1000 pid=7442] Successfully activated service 'org.gnome.Totem'
Mar 2 23:11:16 Xavier-NX org.gnome.Totem[7442]: Opening in BLOCKING MODE
Mar 2 23:11:16 Xavier-NX totem[10604]: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
Mar 2 23:11:16 Xavier-NX totem[10604]: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
Mar 2 23:11:16 Xavier-NX org.gnome.Totem[7442]: NvMMLiteOpen : Block : BlockType = 261
Mar 2 23:11:16 Xavier-NX totem[10604]: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
Mar 2 23:11:16 Xavier-NX totem[10604]: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
Mar 2 23:11:16 Xavier-NX totem[10604]: gst_structure_get_string: assertion 'structure != NULL' failed
Mar 2 23:11:16 Xavier-NX totem[10604]: gst_mini_object_unref: assertion 'mini_object != NULL' failed
Mar 2 23:11:16 Xavier-NX org.gnome.Totem[7442]: NVMEDIA: Reading vendor.tegra.display-size : status: 6
Mar 2 23:11:16 Xavier-NX org.gnome.Totem[7442]: NvMMLiteBlockCreate : Block : BlockType = 261
Mar 2 23:11:16 Xavier-NX org.gnome.Totem[7442]: Allocating new output: 2000x1504 (x 16), ThumbnailMode = 0
Mar 2 23:11:16 Xavier-NX org.gnome.Totem[7442]: OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 2000, nFrameHeight = 1500
Mar 2 23:11:17 Xavier-NX kernel: [ 8202.542273] nvgpu: 17000000.gv11b gp10b_priv_ring_isr:121 [ERR] ringmaster intr status0: 0x00000000,status1: 0x00000001
Mar 2 23:11:17 Xavier-NX kernel: [ 8202.542525] nvgpu: 17000000.gv11b gp10b_priv_ring_isr:175 [ERR] GPC0 write error. ADR 0x00418020 WRDAT 0x00000000 INFO 0x1d40822a (subid 0x0000001d priv level 0), CODE 0xbadf1201
Mar 2 23:11:17 Xavier-NX kernel: [ 8202.542807] nvgpu: 17000000.gv11b gp10b_priv_ring_decode_error_code:79 [ERR] client timeout
Mar 2 23:11:17 Xavier-NX kernel: [ 8202.542958] nvgpu: 17000000.gv11b gk20a_ptimer_isr:50 [ERR] PRI timeout: ADR 0x00418020 READ DATA 0x00000000
Mar 2 23:11:17 Xavier-NX kernel: [ 8202.543147] nvgpu: 17000000.gv11b gk20a_ptimer_isr:56 [ERR] FECS_ERRCODE 0xbadf1201
Mar 2 23:11:17 Xavier-NX kernel: [ 8202.543298] nvgpu: 17000000.gv11b gp10b_priv_ring_decode_error_code:79 [ERR] client timeout
