Hi gys,
Below is my code for conversoin of rgba image to greyscale. I am using textures but the output isnt coming what is expected.
kernel code:
float elapsedtime;
texture<uchar4, 2, cudaReadModeElementType> texSrc;
__global__ void convert(unsigned char *iin_1)
int tx = threadIdx.x + blockIdx.x * blockDim.x;
int ty = threadIdx.y + blockIdx.y * blockDim.y;
int offset = tx + ty * blockDim.x * gridDim.x;
const float x = (float)tx + 0.5f;
const float y = (float)ty + 0.5f;
if(offset < 320*240)
return;
uchar4 temp;
temp = tex2D(texSrc,x,y);
float color = 0.3 * temp.x + 0.6 * temp.y + 0.1 * temp.z ;
iin_1[offset] = color;
function code:
float tograyscale(unsigned char *in, unsigned char * in_1)
unsigned char *iin_1;
cudaMalloc((void **)&iin_1, (240*320*sizeof(unsigned char)));
cudaArray *src;
cudaChannelFormatDesc floatTex = cudaCreateChannelDesc(8, 8, 8, 8, cudaChannelFormatKindUnsigned);
cudaMallocArray(&src, &floatTex, 240, 320);
cudaMemcpyToArray(src, 0, 0, in, 4 * 240 * 320, cudaMemcpyHostToDevice);
cudaBindTextureToArray(texSrc, src, floatTex);
dim3 grid(18,18);
dim3 block(16,16);
convert<<<grid,block>>>(iin_1);
cudaMemcpy( in_1, iin_1, (240*320*sizeof(unsigned char)), cudaMemcpyDeviceToHost);
return elapsedtime;
The output is all messed up. Can anyone tell me whats is it that i am doing wrong…
Thnx…
EDIT: The in buffer is in rgba format and in_1 buffer is in 1 channel format.
