Gst-launch-1.0 nvcompositor bug in tegra-l4t-r32.5.1?
We have a loop which means we are changing the video layout between two nvcompositor.
The changing time is 12 secs.
The output res is 3840x2160@60Hz
It’s works but After some hours the jetson nano cant open the nvcompositors, this command and responses:
gst-launch-1.0 -v nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 sink_1::height=1080 sink_2::xpos=960 sink_2::ypos=1080 sink_2::width=1920 sink_2::height=1080 ! nvoverlaysink sync=true uridecodebin uri=“rtsp://admin:admin1991@192.168.1.209/” ! nvvidconv ! queue max-size-bytes=0 max-size-buffers=0 ! comp. uridecodebin uri=“rtsp://admin:admin@192.168.1.210/” ! nvvidconv ! queue max-size-bytes=0 max-size-buffers=0 ! comp. uridecodebin uri=“file:///tmp/network/192.168.1.2_DEXON_2016//7_Production/8_Test/1080p_demo_videos/Dubai in 4K - City of Gold.mp4” ! nvvidconv ! queue max-size-bytes=0 max-size-buffers=0 ! comp.
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2: source = “(GstFileSrc)\ source”
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/quicktime, variant=(string)iso
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1: source = “(GstRTSPSrc)\ source”
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:Dexon1991@192.168.1.210/
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: source = “(GstRTSPSrc)\ source”
Progress: (connect) Connecting to rtsp://admin:Dexon1991@192.168.1.209/
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)high, codec_data=(buffer)01640028ffe1001967640028acd100780227e5c04400000fa40002ee003c60c44801000468ebef2c, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)high, codec_data=(buffer)01640028ffe1001967640028acd100780227e5c04400000fa40002ee003c60c44801000468ebef2c, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/avdec_aac:avdec_aac0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:src: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-buffers = 5
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-time = 0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-bytes = 2097152
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4, profile=(string)high, codec_data=(buffer)01640028ffe1001967640028acd100780227e5c04400000fa40002ee003c60c44801000468ebef2c, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1
Progress: (request) SETUP stream 0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1210, rate=(int)44100, channels=(int)2
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)high, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/avdec_aac:avdec_aac0.GstPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)44100, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager: latency = 2000
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager: latency = 2000
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager: ntp-sync = false
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager: rfc7273-sync = false
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager: rfc7273-sync = false
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager: ntp-time-source = NTP time based on realtime clock
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager: ntp-time-source = NTP time based on realtime clock
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager: drop-on-latency = false
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager: drop-on-latency = false
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager: max-rtcp-rtp-time-diff = 1000
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager: max-ts-offset-adjustment = 0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager: buffer-mode = Slave receiver to sender clock
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager: max-rtcp-rtp-time-diff = 1000
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager: max-ts-offset-adjustment = 0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager: buffer-mode = Slave receiver to sender clock
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc3: timeout = 5000000000
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstUDPSrc:udpsrc2: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc3: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstUDPSrc:udpsrc5: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc4: caps = application/x-rtcp
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) SETUP stream 1
Progress: (request) Sending PLAY request
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc6: timeout = 5000000000
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc6: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc7: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstUDPSrc:udpsrc2: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
Progress: (request) Sent PLAY request
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstUDPSrc:udpsrc2.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0.GstProxyPad:proxypad4: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstFunnel:funnel1.GstFunnelPad:funnelpad0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstUDPSrc:udpsrc5.GstPad:src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0.GstProxyPad:proxypad7: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstFunnel:funnel3.GstFunnelPad:funnelpad3: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0: caps = application/x-rtcp
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)high, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)high, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)high, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc3: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc6: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc3.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc4.GstPad:src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0.GstProxyPad:proxypad5: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0.GstProxyPad:proxypad6: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstFunnel:funnel2.GstFunnelPad:funnelpad2: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc6.GstPad:src: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_1.GstProxyPad:proxypad10: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstFunnel:funnel4.GstFunnelPad:funnelpad4: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_1: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc7.GstPad:src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_1.GstProxyPad:proxypad11: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstFunnel:funnel5.GstFunnelPad:funnelpad5: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_1: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstUDPSrc:udpsrc2: timeout = 0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstFunnel:funnel1.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession1.GstPad:recv_rtp_src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstRtpStorage:rtpstorage1.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux1.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstRtpStorage:rtpstorage1.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession1.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2.GstGhostPad:src_1.GstProxyPad:proxypad14: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)44100, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPipeline:pipeline0/Gstnvvconv:nvvconv2.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)24000/1001, format=(string)NV12
/GstPipeline:pipeline0/GstQueue:queue2.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)24000/1001, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv2.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2.GstGhostPad:src_0.GstProxyPad:proxypad13: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin2/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad2: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPipeline:pipeline0/GstNvCompositor:comp.GstNvCompositorPad:sink_2: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)24000/1001, format=(string)NV12
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc3: timeout = 0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSrc:udpsrc6: timeout = 0
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstFunnel:funnel0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession2.GstPad:recv_rtp_src: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpStorage:rtpstorage2.GstPad:src: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux2.GstPad:sink: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpStorage:rtpstorage2.GstPad:sink: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession2.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpStorage:rtpstorage0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpStorage:rtpstorage0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer1.GstPad:sink: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer1.GstPad:src: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpPtDemux:rtpptdemux0.GstPad:sink: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer2.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager/GstRtpPtDemux:rtpptdemux1.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1.GstGhostPad:sink.GstProxyPad:proxypad17: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1/GstTypeFindElement:typefind.GstPad:src: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer2.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpPtDemux:rtpptdemux2.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2.GstGhostPad:sink.GstProxyPad:proxypad21: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/GstTypeFindElement:typefind.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1/GstMuLawDec:mulawdec0.GstPad:sink: caps = audio/x-mulaw, channels=(int)1, rate=(int)8000
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1/GstRtpPcmuDepay:rtppcmudepay0.GstPad:src: caps = audio/x-mulaw, channels=(int)1, rate=(int)8000
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1/GstRtpPcmuDepay:rtppcmudepay0.GstPad:sink: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1/GstTypeFindElement:typefind.GstPad:sink: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1.GstGhostPad:sink: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source.GstGhostPad:recv_rtp_src_1_194599922_0.GstProxyPad:proxypad16: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtp_src_1_194599922_0.GstProxyPad:proxypad15: caps = application/x-rtp, media=(string)audio, payload=(int)0, clock-rate=(int)8000, encoding-name=(string)PCMU, a-recvonly=(string)"", a-Media_header=(string)“MEDIAINFO=494D4B48010200000400000110710110401F000000FA000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)194599922, clock-base=(uint)319508688, seqnum-base=(uint)48689, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1/GstMuLawDec:mulawdec0.GstPad:src: caps = audio/x-raw, format=(string)S16LE, layout=(string)interleaved, rate=(int)8000, channels=(int)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0.GstGhostPad:src_0.GstProxyPad:proxypad27: caps = audio/x-raw, format=(string)S16LE, layout=(string)interleaved, rate=(int)8000, channels=(int)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin1.GstDecodePad:src_0.GstProxyPad:proxypad18: caps = audio/x-raw, format=(string)S16LE, layout=(string)interleaved, rate=(int)8000, channels=(int)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/GstRtpH265Depay:rtph265depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/GstTypeFindElement:typefind.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2.GstGhostPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source.GstGhostPad:recv_rtp_src_0_829356762_96.GstProxyPad:proxypad20: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_829356762_96.GstProxyPad:proxypad19: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-sps=(string)“QgEBAWAAAAMAgAAAAwAAAwB4oAKAgC0f42u7U3dyXWAtwEBAQQAAAwPoAABOIHId7lEACZGAAKw+AATIwABWHwg=”, sprop-pps=(string)RAHBcrCcOHYkAAAA, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, a-Media_header=(string)“MEDIAINFO=494D4B48010200000400050000000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)829356762, clock-base=(uint)1446745192, seqnum-base=(uint)62896, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/GstH265Parse:h265parse0.GstPad:sink: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101016000000300800000f000fcfdfbfa00000f03200001001740010c01ffff016000000300800000030000030078ac092100010041420101016000000300800000030000030078a00280802d1fe36bbb5377725d602dc040404100000303e800004e20721dee510009918000ac3e0004c8c000561f0822000100094401c172b09c387624
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/GstRtpH265Depay:rtph265depay0.GstPad:src: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101016000000300800000f000fcfdfbfa00000f03200001001740010c01ffff016000000300800000030000030078ac092100010041420101016000000300800000030000030078a00280802d1fe36bbb5377725d602dc040404100000303e800004e20721dee510009918000ac3e0004c8c000561f0822000100094401c172b09c387624
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3/GstTypeFindElement:typefind.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3.GstGhostPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source.GstGhostPad:recv_rtp_src_0_1788310595_96.GstProxyPad:proxypad23: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_1788310595_96.GstProxyPad:proxypad22: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z01AII2NQCgC3/gLcBAQFAAAD6AAATiDoYADksAABAUku8uNDAAclgAAICkl3lwo,aO44gA==”, a-recvonly=(string)"", x-dimensions=(string)“1280,720”, ssrc=(uint)1788310595, clock-base=(uint)1446984502, seqnum-base=(uint)6223, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/GstH265Parse:h265parse0.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, framerate=(fraction)20/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3/GstH264Parse:h264parse1.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.2, profile=(string)main, pixel-aspect-ratio=(fraction)1/1, width=(int)1280, height=(int)720, framerate=(fraction)10/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
NvMMLiteOpen : Block : BlockType = 279
NvMMLiteBlockCreate : Block : BlockType = 279
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/nvv4l2decoder:nvv4l2decoder1.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, framerate=(fraction)20/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, framerate=(fraction)20/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, framerate=(fraction)20/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3/nvv4l2decoder:nvv4l2decoder2.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.2, profile=(string)main, pixel-aspect-ratio=(fraction)1/1, width=(int)1280, height=(int)720, framerate=(fraction)10/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.2, profile=(string)main, pixel-aspect-ratio=(fraction)1/1, width=(int)1280, height=(int)720, framerate=(fraction)10/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.2, profile=(string)main, pixel-aspect-ratio=(fraction)1/1, width=(int)1280, height=(int)720, framerate=(fraction)10/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2/nvv4l2decoder:nvv4l2decoder1.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)20/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)NV12
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)NV12
/GstPipeline:pipeline0/GstNvCompositor:comp.GstNvCompositorPad:sink_1: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)NV12
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv1.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)20/1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1.GstGhostPad:src_0.GstProxyPad:proxypad28: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)20/1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin1/GstDecodeBin:decodebin2.GstDecodePad:src_0.GstProxyPad:proxypad26: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)20/1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3/nvv4l2decoder:nvv4l2decoder2.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)10/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1, format=(string)NV12
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1, format=(string)NV12
/GstPipeline:pipeline0/GstNvCompositor:comp.GstNvCompositorPad:sink_0: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1, format=(string)NV12
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)10/1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0.GstGhostPad:src_1.GstProxyPad:proxypad29: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)10/1
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin3.GstDecodePad:src_0.GstProxyPad:proxypad25: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)10/1
/GstPipeline:pipeline0/GstNvCompositor:comp.GstAggregatorPad:src: caps = video/x-raw(memory:NVMM), format=(string)RGBA, width=(int)3840, height=(int)2160, framerate=(fraction)24000/1001, chroma-site=(string)NULL, colorimetry=(string)sRGB
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)RGBA, width=(int)3840, height=(int)2160, framerate=(fraction)24000/1001, chroma-site=(string)NULL, colorimetry=(string)sRGB
Redistribute latency…
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)1788310595,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.209:8374,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)289205,\ packets-received=(guint64)210,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)92,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)0,\ sent-rb-exthighestseq=(uint)6433,\ sent-rb-jitter=(uint)92,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)2808888132,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;” >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstUDPSink:udpsink2.GstPad:sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0.GstProxyPad:proxypad8: caps = application/x-rtcp
NvRmChannelSubmit: NvError_IoctlFailed with error code 22
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 14, SyncPointValue = 0)
fence_set_name ioctl failed with 22
NvDdkVicExecute Failed
nvbuffer_composite Failed
Got EOS from element “pipeline0”.
Execution ended after 0:00:02.309151405
Setting pipeline to PAUSED …
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Do you have any idea or solution?
Thanks in advance!
We would need to replicate the issue and do investigation. So you run this pipeline:
gst-launch-1.0 -v nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 sink_1::height=1080 sink_2::xpos=960 sink_2::ypos=1080 sink_2::width=1920 sink_2::height=1080 ! nvoverlaysink sync=true uridecodebin uri=“rtsp://admin:admin1991@192.168.1.209/” ! nvvidconv ! queue max-size-bytes=0 max-size-buffers=0 ! comp. uridecodebin uri=“rtsp://admin:admin@192.168.1.210/” ! nvvidconv ! queue max-size-bytes=0 max-size-buffers=0 ! comp. uridecodebin uri=“file:///tmp/network/192.168.1.2_DEXON_2016//7_Production/8_Test/1080p_demo_videos/Dubai in 4K - City of Gold.mp4” ! nvvidconv ! queue max-size-bytes=0 max-size-buffers=0 ! comp.
After 2+ hours, you hit the issue. Is it correct?
Yes it is and the jetson’s hdmi output relsolution is 3840x2160@60Hz and we close and reopen this pipeline with 12 secs.
Thank you for your investigation.
Not sure how to do this in running gst-launch command. Please share more detail about it.
This is our method:
while true
do
gst-launch-1.0 nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 sink_1::height=1080 sink_2::xpos=0 sink_2::ypos=1080 sink_2::width=1920 sink_2::height=1080 sink_3::xpos=1920 sink_3::ypos=1080 sink_3::width=1920 sink_3::height=1080 ! nvoverlaysink sync=true uridecodebin uri=“file:///tmp/network/192.168.1.2_DEXON_2016//7_Production/8_Test/4K_demo_videos/New_York_in_4K.mp4” ! nvvidconv ! queue ! comp. uridecodebin uri=“rtsp://labi:admin@192.168.1.210:554/Streaming/Channels/101?transportmode=unicast&profile=Profile_1” ! nvvidconv ! queue ! comp. uridecodebin uri=“rtsp://admin:admin@192.168.1.210/” ! nvvidconv ! queue ! comp. uridecodebin uri=“file:///tmp/network/192.168.1.2_DEXON_2016//7_Production/8_Test/1080p_demo_videos/Dubai in 4K - City of Gold.mp4” ! nvvidconv ! comp. &
sleep 12
killall -2 gst-launch-1.0
sleep 1
gst-launch-1.0 uridecodebin uri="file:///tmp/network/192.168.1.2_DEXON_2016//7_Production/8_Test/1080p_demo_videos/Dubai in 4K - City of Gold.mp4" name=bin ! queue ! nvoverlaysink overlay=2 overlay-x=1920 overlay-y=0 overlay-w=1920 overlay-h=2160 bin. ! queue ! audioconvert ! audioresample ! autoaudiosink  &
gst-launch-1.0 uridecodebin uri="file:///tmp/network/192.168.1.2_DEXON_2016//7_Production/8_Test/4K_demo_videos/New_York_in_4K.mp4" name=bin ! queue ! nvoverlaysink overlay=1 overlay-x=0 overlay-y=0 overlay-w=1920 overlay-h=2160 bin. ! queue ! audioconvert ! audioresample ! autoaudiosink  &
sleep 12
sleep 1
done
Are you able to exit gracefully? Killing the processes directly is not proper. It is better to switch to NULL state and unref the pipeline
Is the SIGINT not enough gracefully close?
what do you suggest to me or I should use SIGTERM signal?
I tried SIGTERM signal. The issue occurred again.
For issuing SIGTERM signal, do you see the pipeline changes to NULL state like:
Interrupt: Stopping pipeline ...
Execution ended after 0:00:03.273529999
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
In case of “killall -2” i see these states:
nv@DEXONNV:~$ sudo sh gsttest.sh
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:Dexon1991@192.168.1.210/
Progress: (connect) Connecting to rtsp://labi:Dexon1991@192.168.1.210:554/Streaming/Channels/101?transportmode=unicast&profile=Profile_1
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
handling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:11.683270829
Freeing pipeline …
Pipeline is PREROLLING …
Pipeline is PREROLLED …
New clock: GstPulseSinkClock
handling interrupt.
handling interrupt.
Execution ended after 0:00:11.470225360
Execution ended after 0:00:11.427300933
Freeing pipeline …
Freeing pipeline …
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
handling interrupt.
Execution ended after 0:00:11.684596923
Freeing pipeline …
handling interrupt.
handling interrupt.
Execution ended after 0:00:11.429059475
Execution ended after 0:00:11.469032287
Freeing pipeline …
Freeing pipeline …
After several hours, the bug is occurred, in this case I have to reboot the OS to use the gst-launch again:
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 21, SyncPointValue = 0)
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 20, SyncPointValue = 0)
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 25, SyncPointValue = 0)
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 24, SyncPointValue = 0)
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 13, SyncPointValue = 0)
Execution ended after 0:00:00.463166094
Freeing pipeline …
Have you tried four 1080p60 sources? The supported case is single 4Kp60. Looks like you have four 4Kp60 sources.
I’m using:
1x 1080p @ 24fps (dubai)
1x 2160p @ 30fps (new york)
2x 720p @ 20fps (ip cameras)
So I am not using 4k60 sources. Only the jetson’s output timing is 4K.
The log shows VIC engine hangs. Not sure if it helps but please disable DFS and try. The steps to disable DFS:
Nvvideoconvert issue, nvvideoconvert in DS4 is better than Ds5? - #3 by DaneLLL
I run this command:
sudo echo on > /sys/devices/50000000.host1x/54340000.vic/power/control
and after I started the my script and the issue occurred after about 4-5 hours.
Please execute sudo tegrastats and check thermal condition. Probably the Nano module is overheating and hardware engine hangs. If it is the case, we suggest try this fan:
Jetson Nano Fan - #7 by dusty_nv
Thanks, I added the tegrastats into my script.
Which temperature values are meaning the overheat?
After several working loop I got these values:
RAM 1796/3956MB (lfb 84x4MB) SWAP 0/1978MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [25%@102,5%@102,3%@102,5%@102] EMC_FREQ 15%@1600 GR3D_FREQ 0%@76 VIC_FREQ 0%@627 APE 25 PLL@33.5C CPU@36C PMIC@100C GPU@35.5C AO@39C thermal@35.75C POM_5V_IN 3015/3015 POM_5V_GPU 0/0 POM_5V_CPU 158/158
Here is the last messages before hang, is this values high or not?
Execution ended after 0:00:02.258893176
Freeing pipeline …
gst-launch-1.0: no process found
RAM 1818/3956MB (lfb 85x4MB) SWAP 0/1978MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [18%@102,9%@102,5%@102,3%@102] EMC_FREQ 8%@1600 GR3D_FREQ 0%@76 VIC_FREQ 0%@627 APE 25 PLL@33C CPU@36C PMIC@100C GPU@35C AO@39C thermal@35.5C POM_5V_IN 3015/3015 POM_5V_GPU 0/0 POM_5V_CPU 158/158
RAM 1818/3956MB (lfb 85x4MB) SWAP 0/1978MB (cached 0MB) IRAM 0/252kB(lfb 252kB) CPU [24%@102,11%@102,6%@204,6%@204] EMC_FREQ 7%@1600 GR3D_FREQ 0%@76 VIC_FREQ 0%@627 APE 25 PLL@33C CPU@36C PMIC@100C GPU@35C AO@39C thermal@35.5C POM_5V_IN 3015/3015 POM_5V_GPU 0/0 POM_5V_CPU 158/158
