Log from gst-device-monitor-1.0
Probing devices...
Device found:
name : Monitor of tegra-snd-t210ref-mobile-rt565x Analog Stereo
class : Audio/Source
caps : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
properties:
device.description = "Monitor\ of\ tegra-snd-t210ref-mobile-rt565x\ Analog\ Stereo"
device.class = monitor
alsa.card = 1
alsa.card_name = tegra-snd-t210ref-mobile-rt565x
alsa.long_card_name = tegra-snd-t210ref-mobile-rt565x
device.bus_path = platform-sound.27
sysfs.path = /devices/platform/sound.27/sound/card1
device.string = 1
module-udev-detect.discovered = 1
device.icon_name = audio-card
Device found:
name : tegra-snd-t210ref-mobile-rt565x Analog Stereo
properties:
alsa.resolution_bits = 16
device.api = alsa
device.class = sound
alsa.class = generic
alsa.subclass = generic-mix
alsa.name = ""
alsa.id = "ADMAIF1\ CIF\ ADMAIF1-0"
alsa.subdevice = 0
alsa.subdevice_name = "subdevice\ \#0"
alsa.device = 0
alsa.card = 1
device.string = hw:1
device.buffering.buffer_size = 32768
device.buffering.fragment_size = 16384
device.access_mode = mmap+timer
device.profile.name = analog-stereo
device.profile.description = "Analog\ Stereo"
device.description = "tegra-snd-t210ref-mobile-rt565x\ Analog\ Stereo"
Device found:
class : Audio/Sink
properties:
device.api = alsa
alsa.name = ""
alsa.subdevice = 0
alsa.device = 0
alsa.card = 1
Device found:
name : vi-output-0, imx274 7-001a
class : Video/Source
caps : video/x-bayer, format=(string)rggb, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1;
video/x-bayer, format=(string)rggb, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1;
video/x-raw, format=(string)I420, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1;
video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1;
video/x-raw, format=(string)YV12, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1;
video/x-raw, format=(string)YV12, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1;
video/x-raw, format=(string)BGR, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)sRGB, framerate=(fraction)60/1;
video/x-raw, format=(string)BGR, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)sRGB, framerate=(fraction)60/1;
video/x-raw, format=(string)RGB, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)sRGB, framerate=(fraction)60/1;
video/x-raw, format=(string)RGB, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)sRGB, framerate=(fraction)60/1;
properties:
udev-probed = true
device.bus_path = platform-vi
sysfs.path = /sys/devices/platform/host1x/vi/video4linux/video0
device.subsystem = video4linux
device.product.name = "vi-output-0\,\ imx274\ 7-001a"
device.capabilities = :capture:
device.api = v4l2
device.path = /dev/video0
v4l2.device.driver = tegra-video
v4l2.device.card = "vi-output-0\,\ imx274\ 7-001a"
v4l2.device.bus_info = platform:vi:0
v4l2.device.version = 199264 (0x00030a60)
v4l2.device.capabilities = 2233466881 (0x85200001)
v4l2.device.device_caps = 85983233 (0x05200001)
Device found:
name : vi-output-2, imx274 8-001a
properties:
udev-probed = true
sysfs.path = /sys/devices/platform/host1x/vi/video4linux/video1
device.product.name = "vi-output-2\,\ imx274\ 8-001a"
device.api = v4l2
device.path = /dev/video1
v4l2.device.card = "vi-output-2\,\ imx274\ 8-001a"
v4l2.device.bus_info = platform:vi:2
Device found:
name : vi-output-4, imx274 9-001a
properties:
udev-probed = true
sysfs.path = /sys/devices/platform/host1x/vi/video4linux/video2
device.product.name = "vi-output-4\,\ imx274\ 9-001a"
device.api = v4l2
device.path = /dev/video2
v4l2.device.card = "vi-output-4\,\ imx274\ 9-001a"
v4l2.device.bus_info = platform:vi:4
