Jetson TK1: Gstreamer application RTSP stream to OPENCV processing
Hello everybody,
I am setting this topic up as I am facing an issue that my poor gstreamer capabilities are not able to deal with. Briefly, I have to make an application that reads an h264 encoded stream from an IP camera via an RTSP stream and allows us to use incoming decoded images with opencv. To do this I am writting a gestreamer application that implements a pipeline with an appsink at the end. My firts test based on examples aims at achieving to put GStreamer and Opencv processing together and it is working fine. It reads not a stream but an internet hosted file sets a position, grabs the image at the current position and stores it as a png file on first hand and process the image with 2 opencv filters (gaussian and canny edge detector) to store edges in a second png file. Well this was just for the principal and to make me more familiar with gstreamer.
The actual issue is that when I want to go to a live stream and not a file I get into troubles and my applications in not able to get a single frame from the stream and I have very few information for debug. This is all the more weird in my gstreamer newby point of view because when I set the pipeline (with xvimagesink instead of appsink) using gst-launch-1.0 I can get the live stream perfectly.
So my first question is does someone have an idea of what I am missing?
here is the gst-launch pipeline to get the RTSP h264 encoded stream (also attached as simple_test.cpp)
gst-launch-1.0 rtspsrc location="rtsp://192.168.1.72:554/stream1" latency=0 ! decodebin ! xvimagesink
Here is the code used for the first test (can be found mostly on the web) but I also made some modifications to the example (Opencv dependent functions have been added):
#include <gst/gst.h>
#include <opencv2/opencv.hpp>
#ifdef HAVE_GTK
#include <gtk/gtk.h>
#include <gdk-pixbuf/gdk-pixbuf.h>
#endif
#include <stdlib.h>
#define CAPS "video/x-raw,format=RGB,width=320,pixel-aspect-ratio=1/1"
int main (int argc, char *argv[])
	GstElement *pipeline, *sink;
	gint width, height;
	GstSample *sample;
	gchar *descr;
	GError *error = NULL;
	gint64 duration, position;
	GstStateChangeReturn ret;
	gboolean res;
	GstMapInfo map;
	gst_init (&argc, &argv);
	if (argc != 2)
		g_print ("usage: %s <uri>\n Writes snapshot.png in the current directory\n", argv[0]);
		exit (-1);
	/* create a new pipeline */
	descr = g_strdup_printf ("uridecodebin uri=%s ! videoconvert ! videoscale ! appsink name=sink caps=\"" CAPS "\"", argv[1]);
	pipeline = gst_parse_launch (descr, &error);
	if (error != NULL)
		g_print ("could not construct pipeline: %s\n", error->message);
		g_error_free (error);
		exit (-2);
	/* get sink */
	sink = gst_bin_get_by_name (GST_BIN (pipeline), "sink");
	/* set to PAUSED to make the first frame arrive in the sink */
	ret = gst_element_set_state (pipeline, GST_STATE_PAUSED);
	switch (ret)
		case GST_STATE_CHANGE_FAILURE:
			g_print ("failed to play the file\n");
			exit (-1);
		case GST_STATE_CHANGE_NO_PREROLL:
			/* for live sources, we need to set the pipeline to PLAYING before we can
			* receive a buffer. We don't do that yet */
			g_print ("live sources not supported yet\n");
			exit (-3);
		default:
			break;
	/* This can block for up to 5 seconds. If your machine is really overloaded,
	* it might time out before the pipeline prerolled and we generate an error. A
	* better way is to run a mainloop and catch errors there. */
	ret = gst_element_get_state (pipeline, NULL, NULL, 5 * GST_SECOND);
	if (ret == GST_STATE_CHANGE_FAILURE)
		exit (-4);
	/* get the duration */
	gst_element_query_duration (pipeline, GST_FORMAT_TIME, &duration);
	if (duration != -1)
	/* we have a duration, seek to 5% */
	position = duration * 5 / 100;
	else
	/* no duration, seek to 1 second, this could EOS */
	position = 1 * GST_SECOND;
	/* seek to the a position in the file. Most files have a black first frame so
	* by seeking to somewhere else we have a bigger chance of getting something
	* more interesting. An optimisation would be to detect black images and then
	* seek a little more */
	gst_element_seek_simple (pipeline, GST_FORMAT_TIME, GST_SEEK_FLAG_KEY_UNIT | GST_SEEK_FLAG_FLUSH, position);
	/* get the preroll buffer from appsink, this block untils appsink really
	* prerolls */
	g_signal_emit_by_name (sink, "pull-preroll", &sample, NULL);
	/* if we have a buffer now, convert it to a pixbuf. It's possible that we
	* don't have a buffer because we went EOS right away or had an error. */
	if (sample)
		GstBuffer *buffer;
		GstCaps *caps;
		GstStructure *s;
		/* get the snapshot buffer format now. We set the caps on the appsink so
		 * that it can only be an rgb buffer. The only thing we have not specified
		 * on the caps is the height, which is dependant on the pixel-aspect-ratio
		 * of the source material */
		caps = gst_sample_get_caps (sample);
		if (!caps)
			g_print ("could not get snapshot format\n");
			exit (-5);
		s = gst_caps_get_structure (caps, 0);
		/* we need to get the final caps on the buffer to get the size */
		res = gst_structure_get_int (s, "width", &width);
		res |= gst_structure_get_int (s, "height", &height);
		if (!res)
			g_print ("could not get snapshot dimension\n");
			exit (-6);
		/* create pixmap from buffer and save, gstreamer video buffers have a stride
		 * that is rounded up to the nearest multiple of 4 */
		buffer = gst_sample_get_buffer (sample);
		gst_buffer_map (buffer, &map, GST_MAP_READ);
		#ifdef HAVE_GTK
			GdkPixbuf *pixbuf = gdk_pixbuf_new_from_data (map.data,
			GDK_COLORSPACE_RGB, FALSE, 8, width, height,
			GST_ROUND_UP_4 (width * 3), NULL, NULL);
			/* save the pixbuf */
			gdk_pixbuf_save (pixbuf, "snapshot.png", "png", &error, NULL);
		#endif
		#ifdef HAVE_OPENCV
			cv::Mat image(cv::Size(width, height), CV_8UC3, (char*)map.data, cv::Mat::AUTO_STEP);
			cv::Mat edges;
			cv::cvtColor(image, edges, CV_RGB2GRAY);
			cv::GaussianBlur(edges, edges, cv::Size(7,7), 1.5, 1.5);
			cv::Canny(edges, edges, 0, 30, 3);
			cv::imwrite("snapshot_edges.png",edges);
		#endif
		gst_buffer_unmap (buffer, &map);
		gst_sample_unref (sample);
	else
		g_print ("could not make snapshot\n");
	/* cleanup and exit */
	gst_element_set_state (pipeline, GST_STATE_NULL);
	gst_object_unref (pipeline);
	exit (0);
To fully compile it one needs to use g++ with opencv, GTK, CUFFT, CUDART and Gstreamer dependencies and declare HAVE_GTK and HAVE_OPENCV. I can provide a CMakeLists.txt file to build it if necessary.
This code works well when used with the following command (obviously simple_test is the program name):
simple_test http://mirrorblender.top-ix.org/peach/bigbuckbunny_movies/big_buck_bunny_480p_h264.mov
The big buck bunny can be replaced by another online video.
My second question is do I did something really bad in this example (except that it is not threaded and not really able to deal with stream (I only get one image and do not implement loop iterations here)?
Finally here is the code that I’d love to have help on (also attached as main.cpp). It should deal with live streams (no preroll is done?) and I don’t know why I never receive a single image (new_sample callback is never run).
#include <gst/app/gstappsink.h>
#include <stdlib.h>
#include "opencv2/opencv.hpp"
using namespace cv;
#define CAPS "video/x-raw,height=480,pixel-aspect-ratio=1/1"
// TODO: use synchronized deque
GMainLoop *loop;
std::deque<Mat> frameQueue;
int live_flag = 0;
int quit_flag = 0;
GstFlowReturn new_preroll(GstAppSink *appsink, gpointer data)
	g_print ("Got preroll!\n");
	return GST_FLOW_OK;
GstFlowReturn new_sample(GstAppSink *appsink, gpointer data)
	static int framecount = 0;
	framecount++;
	static int width=0, height=0 ;
	GstSample *sample = gst_app_sink_pull_sample(appsink);
	GstCaps *caps = gst_sample_get_caps(sample);
	GstBuffer *buffer = gst_sample_get_buffer(sample);
	static GstStructure *s;
	const GstStructure *info = gst_sample_get_info(sample);
	// ---- get width and height
	if(framecount==1)
		if(!caps)
			g_print("Could not get image info from filter caps");
			exit(-11);
		s = gst_caps_get_structure(caps,0);
		gboolean res = gst_structure_get_int(s, "width", &width);
		res |= gst_structure_get_int(s, "height", &height);
		if(!res)
			g_print("Could not get image width and height from filter caps");
			exit(-12);
		g_print("Image size: %d\t%d\n",width,height);
	// ---- Read frame and convert to opencv format ---------------
	GstMapInfo map;
	// convert gstreamer data to OpenCV Mat, you could actually
	// resolve height / width from caps...
	Mat frame(Size(width, height), CV_8UC3, (char*)map.data, Mat::AUTO_STEP);
        // this lags pretty badly even when grabbing frames from webcam
        Mat edges;
        cvtColor(frame, edges, CV_RGB2GRAY);
        GaussianBlur(edges, edges, Size(7,7), 1.5, 1.5);
        imshow("stream", edges);
        char key = cv::waitKey(10);
        if(key!=-1) quit_flag = 1;
	gst_buffer_unmap(buffer, &map);
	// print dot every 30 frames
	if (framecount%30 == 0) {
	g_print (".");
	// show caps on first frame
	if (framecount == 1) {
	g_print ("%s\n", gst_caps_to_string(caps));
	return GST_FLOW_OK;
static gboolean my_bus_callback (GstBus *bus, GstMessage *message, gpointer data)
    g_print ("Got %s message from %s\n", GST_MESSAGE_TYPE_NAME (message), GST_OBJECT_NAME (message->src));
    switch (GST_MESSAGE_TYPE (message))
            case GST_MESSAGE_ERROR:
                    GError *err;
                    gchar *debug;
                    gst_message_parse_error (message, &err, &debug);
                    g_print ("Error from %s: %s\n", GST_OBJECT_NAME (message->src), err->message);
                    g_error_free (err);
                    g_free (debug);
                    break;
            case GST_MESSAGE_EOS:
                    /* end-of-stream */
                    quit_flag = 1;
                    break;
            case GST_MESSAGE_STATE_CHANGED:
                    GstState oldstate, newstate;
                    gst_message_parse_state_changed(message, &oldstate, &newstate, NULL);
                    g_print ("Element %s changed state from %s to %s.\n",
                            gst_element_state_get_name (oldstate),
                            gst_element_state_get_name (newstate));
                    break;
            default:
                    /* unhandled message */
                    break;
    /* we want to be notified again the next time there is a message
    * on the bus, so returning TRUE (FALSE means we want to stop watching
    * for messages on the bus and our callback should not be called again)
    return TRUE;
	GstStateChangeReturn state_ret;
	GstSample *sample;
	gchar *descr = g_strdup(
		"rtspsrc location=\"rtsp://192.168.1.72:554/stream1\" latency=0 ! "
		"rtph264depay ! "
		"decodebin ! "
		"appsink name=sink sync=true caps=\"" CAPS "\""
	if (error != NULL)
		exit (-1);
	/* get sink */
	/*set to pause*/
	state_ret = gst_element_set_state(pipeline, GST_STATE_PAUSED);
	switch(state_ret)
			exit (-2);
			* receive a buffer. */
			g_print ("live source detected\n");
			live_flag = 1;
			break;
		default:
			break;
	gst_app_sink_set_emit_signals((GstAppSink*)sink, true);
	gst_app_sink_set_drop((GstAppSink*)sink, true);
	gst_app_sink_set_max_buffers((GstAppSink*)sink, 1);
	GstAppSinkCallbacks callbacks = { NULL, new_preroll, new_sample };
	gst_app_sink_set_callbacks (GST_APP_SINK(sink), &callbacks, NULL, NULL);
	GstBus *bus;
	guint bus_watch_id;
	bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
	bus_watch_id = gst_bus_add_watch (bus, my_bus_callback, NULL);
	gst_object_unref (bus);
        gst_element_set_state (GST_ELEMENT (pipeline), GST_STATE_PLAYING);
	namedWindow("stream",1);
	loop = g_main_loop_new(NULL,false);
        g_main_loop_run(loop);
	cv::destroyWindow("stream");
	g_print ("Going to end of main!\n");
	gst_element_set_state (GST_ELEMENT (pipeline), GST_STATE_NULL);
	gst_object_unref (GST_OBJECT (pipeline));
	return 0;
So the final and most important question is: does someone can explain me what is wrong in this code and induces this behavior?
Thanks you a lot for reading until here! and thank you even more if you have any clue.
Best regards,
Olivier.
simple_test.cpp (4.53 KB)
main.cpp (5.59 KB)
I made some more tests with my main code mostly to get debug information to provide.
attached to with post is the log (debug level=4) that shows some interesting things
0:00:00.032969051  5377      0x1a64e40 INFO        GST_ELEMENT_PADS gstelement.c:646:gst_element_add_pad:<GstDecodeBin@0x1c2c050> adding pad 'sink'
0:00:00.033229330  5377      0x1a64e40 INFO      GST_PLUGIN_LOADING gstplugin.c:830:gst_plugin_load_file: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstapp.so" loaded
0:00:00.033246844  5377      0x1a64e40 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:365:gst_element_factory_create: creating element "appsink"
0:00:00.033401352  5377      0x1a64e40 INFO        GST_ELEMENT_PADS stelement.c:646:gst_element_add_pad:<GstBaseSink@0x1c392a0> adding pad 'sink' 0:00:00.033487647  5377      0x1a64e40 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:365:gst_element_factory_create: creating element "pipeline"
Shows me the decodebin get a sink pad (but no trace of a src pad) and that appsink get a sink pad too which is i think completely obvious for a sink bin.
Now a little down the log I get
0:00:00.033586892  5377      0x1a64e40 INFO            GST_PIPELINE ./grammar.y:578:gst_parse_perform_link: linking rtspsrc0:(any) to rtph264depay0:(any) (0/0) with caps "(NULL)"
0:00:00.033605192  5377      0x1a64e40 INFO        GST_ELEMENT_PADS gstutils.c:1543:gst_element_link_pads_full: trying to link element rtspsrc0:(any) to element rtph264depay0:(any)
0:00:00.033644868  5377      0x1a64e40 INFO        GST_ELEMENT_PADS gstelement.c:894:gst_element_get_static_pad: no such pad 'stream_%u' in element "rtspsrc0"
0:00:00.033665969  5377      0x1a64e40 INFO        GST_ELEMENT_PADS gstutils.c:1123:gst_element_get_compatible_pad:<rtspsrc0> Could not find a compatible pad to link to rtph264depay0:sink
0:00:00.033678830  5377      0x1a64e40 INFO                 default gstutils.c:1889:gst_element_link_pads_filtered: Could not link pads: rtspsrc0:(null) - rtph264depay0:(null)
So as decode bin may not have a src pad this “Could not find a compatible pad” between decodebin and appsink. This I think is a good reason for the pipeline not to provide appsink any image… Therefore the question is How do I solve this pad problem. I attached 3 log files 2 from the application and 1 from the pipeline for more exhaustive information.
Best regards.
testGstreamerOCVd_debug.log (21.6 KB)
testGstreamerOCVd_debug2.log (27 KB)
pipeline.log (181 KB)
right now I’m facing the same problem: h264/mpeg4 stream from IP camera, but I’m not able to catch the new-sample signal to be able to run the callbacks. Did you find any solution?
My pipeline is
            "rtspsrc location=\"rtsp://192.0.0.69:554/mpeg4?stream=2\" latency=0 ! "
            "rtpmp4vdepay ! "
            "decodebin ! "
            "appsink name=sink sync=true caps=\""CAPS"\" "
thx
Hai
I trying to do processed opencv frames on snap drogan board to stream on my system using gstream and rtsp is that possible.please help me how to do that.
Here is an example of running rtsp on TK1:
[url]https://devtalk.nvidia.com/default/topic/968782/jetson-tk1/making-a-720p-live-video-monitoring/post/4994290/#4994290[/url]
When I try to compile the code in the original post, I get an error:
/usr/local/include/opencv2/core/cvstd.hpp:648: error: undefined reference to `cv::String::deallocate()’
I have been looking online; but nothing I found helped me.
Do you have an idea about how to solve this?
Thanks in advance.
My system:
Ubuntu 16.04
Building with QT Creator 5.9.1 with qmake
Linked libs: -lglib -lgstreamer -lopencv_core -lopencv_highgui -lopencv_imgproc
-lpthread -lrt -lgthread-2.0 -lgobject-2.0 -lxml2
WE don’t have much experience in QT. Hope other users can share experience and suggestion.
I don’t know about this particular case, and I can’t see from what you’ve added if this is a linker error or a compile error, but the error says it is looking for “cv::String::deallocate()”. The file itself which wants this is in “/usr/local/…”, not the system provided files of “/usr”. So either there is a file to link against in “/usr/local” (a library path needing a “-L path” to find it) or a header somewhere under “/usr/local” (a header needing “-I path” to find it). You might have what you need, but if you do, then the linker or compiler search paths need to point there.
Hi great day,
i get some error while using OpenCV 3.4.1 capture rtsp h264 streaming:
The error code show as below:
  1. error while decoding MB 14 16
  2. P sub_mb_type 16 out of range at 62 25
  3. left block unavailable for requested intra4x4 mode -1
  4. cbp too large <3199971767> at 29 25
  5. mb_type 84 in P slice too large at 11 45
  6. out of range intra chroma pred mode
  7. negative number of zero coeffs at 14 35
does anyone know how to fix this?
Hi andrew,
for OpenCv + gstreamer, we suggest you use TX1 or TX2. Below is a post for reference:
[url]https://devtalk.nvidia.com/default/topic/1024245/jetson-tx2/opencv-3-3-and-integrated-camera-problems-/post/5210735/#5210735[/url]
