I want to create a project for face detection by processing the video stream I generate with Gstreamer using OpenCV. I am using a Jetson Nano with the ımx219-77 camera. Initially, I couldn’t even display the image on the screen, but I overcame this issue, and now I can display live video. However, at this stage, although I can display the image on the screen, I realized that I cannot process it with OpenCV. In Gstreamer, there is a function called ‘g_signal_connect,’ and I am using it, but I do not receive any return from this function every time a new frame arrives. Below, I will share the code, the output of the execution, and the ‘GST_DEBUG=3’ output. If a more detailed debug output is needed, just let me know.
Thank you again for your assistance. I am new to Gstreamer, so please enlighten me. Also, if I have misaddressed or omitted anything in the topic, I apologize to the moderators; please help me :).
It is my code;
#include <gst/gst.h>
#include <gst/app/gstappsink.h>
#include <opencv2/opencv.hpp>
GMainLoop *loop;
static gboolean bus_call(GstBus *bus, GstMessage *msg, gpointer data) {
switch (GST_MESSAGE_TYPE(msg)) {
case GST_MESSAGE_EOS:
g_print("End of stream\n");
g_main_loop_quit(loop);
break;
case GST_MESSAGE_ERROR: {
gchar *debug;
GError *error;
gst_message_parse_error(msg, &error, &debug);
g_free(debug);
g_printerr("Error: %s\n", error->message);
g_error_free(error);
break;
default:
break;
return TRUE;
static GstFlowReturn on_new_sample(GstElement *sink, gpointer user_data) {
static int frame_count = 0;
printf("Frame %d received\n", frame_count++);
GstSample *sample = gst_app_sink_pull_sample(GST_APP_SINK(sink));
g_print("on_new_sample called\n");
if (sample) {
GstBuffer *buffer = gst_sample_get_buffer(sample);
GstMapInfo map;
gst_buffer_map(buffer, &map, GST_MAP_READ);
// Convert NV12 format to BGR format for OpenCV display
cv::Mat frame_nv12(2464 + 2464 / 2, 3280, CV_8UC1, map.data);
cv::Mat frame;
cv::cvtColor(frame_nv12, frame, cv::COLOR_YUV2BGR_NV12);
// Perform face detection using OpenCV Haar Cascade
cv::CascadeClassifier face_cascade;
if (!face_cascade.load("/usr/local/share/opencv4/haarcascades/haarcascade_frontalface_default.xml")) {
std::cerr << "Haar Cascade dosyası yüklenemedi." << std::endl;
//return GST_FLOW_ERROR;
std::vector<cv::Rect> faces;
face_cascade.detectMultiScale(frame, faces, 1.1, 2, 0 | cv::CASCADE_SCALE_IMAGE, cv::Size(30, 30));
// Draw rectangles around detected faces
for (const auto &face : faces) {
cv::rectangle(frame, face, cv::Scalar(0, 255, 0), 2);
// Display the frame using OpenCV
cv::imshow("GStreamer OpenCV Display", frame);
// Release the buffer
gst_buffer_unmap(buffer, &map);
gst_sample_unref(sample);
// Handle keyboard input for exiting the loop
if (cv::waitKey(10) == 27) {
return GST_FLOW_OK;
int main(int argc, char *argv[]) {
// Initialize GStreamer
g_main_context_push_thread_default(NULL);
gst_init(&argc, &argv);
// Create elements
GstElement *pipeline = gst_pipeline_new("mypipeline");
GstElement *source = gst_element_factory_make("nvarguscamerasrc", "src");
GstElement *capsfilter1 = gst_element_factory_make("capsfilter", "filter1");
GstElement *nvvidconv1 = gst_element_factory_make("nvvidconv", "nvvidconv1");
GstElement *nvegltransform = gst_element_factory_make("nvegltransform", "nvegltransform");
GstElement *appsink = gst_element_factory_make("nveglglessink", "appsink"); // Change to appsink - nveglglessink
// Check for element creation errors
if (!pipeline || !source || !capsfilter1 || !nvvidconv1 || !nvegltransform || !appsink) {
g_printerr("Not all elements could be created. Exiting.\n");
return -1;
// Set element properties
g_object_set(G_OBJECT(capsfilter1), "caps",
gst_caps_from_string("video/x-raw(memory:NVMM), width=1280, height=720, format=NV12, framerate=120/1"), NULL);
// Configure appsink for efficient data retrieval
//g_object_set(appsink, "emit-signals", TRUE, "sync", FALSE, "max-buffers", 1, NULL);
g_signal_connect(appsink, "sample", G_CALLBACK(on_new_sample), NULL);
// Add elements to pipeline and link them
gst_bin_add_many(GST_BIN(pipeline), source, capsfilter1, nvvidconv1, nvegltransform, appsink, NULL);
gst_element_link_many(source, capsfilter1, nvvidconv1, nvegltransform, appsink, NULL);
// Add bus watch to listen for events
GstBus *bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
gst_bus_add_watch(bus, (GstBusFunc)bus_call, loop);
gst_object_unref(bus);
// Set pipeline to PLAYING state
GstStateChangeReturn ret = gst_element_set_state(pipeline, GST_STATE_PLAYING);
if (ret == GST_STATE_CHANGE_FAILURE) {
g_printerr("Unable to set the pipeline to the playing state. Exiting.\n");
gst_object_unref(pipeline);
return -1;
// Create GMainLoop for handling GStreamer events
loop = g_main_loop_new(nullptr, FALSE);
// Run the main loop
g_main_loop_run(loop);
// Clean up
gst_element_set_state(pipeline, GST_STATE_NULL);
g_main_loop_unref(loop);
return 0;
It is my output;
(QTVideoTracking:18709): GLib-GObject-WARNING **: 16:36:19.054: ../../../../gobject/gsignal.c:2524: signal 'sample' is invalid for instance '0x556afc7940' of type 'GstEglGlesSink'
Using winsys: x11
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 5
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
and It is my Gst_debug=3 output;
futuris@futuris-desktop:~/Desktop/gstreamerImx/QtVideoTrack/build-QTVideoTracking-Desktop-Debug$ GST_DEBUG=3 ./QTVideoTracking
(QTVideoTracking:19447): GLib-GObject-WARNING **: 16:41:44.842: ../../../../gobject/gsignal.c:2524: signal 'sample' is invalid for instance '0x55a782d940' of type 'GstEglGlesSink'
Using winsys: x11
0:00:00.483651406 19447 0x55a78204a0 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:<src:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Camera index = 0
Camera mode = 5
seconds to Run = 0
and It is GST_DEBUG=4 output;
futuris@futuris-desktop:~/Desktop/gstreamerImx/QtVideoTrack/build-QTVideoTracking-Desktop-Debug$ GST_DEBUG=4 ./QTVideoTracking
0:00:00.000159583 19782 0x559aa96200 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.5
0:00:00.000225104 19782 0x559aa96200 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000260677 19782 0x559aa96200 INFO GST_INIT gst.c:607:init_pre: Linux futuris-desktop 4.9.253-tegra #1 SMP PREEMPT Mon Jul 26 12:13:06 PDT 2021 aarch64
0:00:00.000769531 19782 0x559aa96200 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.001678177 19782 0x559aa96200 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.002077812 19782 0x559aa96200 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.002279791 19782 0x559aa96200 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.002308802 19782 0x559aa96200 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.002356146 19782 0x559aa96200 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/futuris/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.048161302 19782 0x559aa96200 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/futuris/.cache/gstreamer-1.0/registry.aarch64.bin in 0.045731 seconds
0:00:00.048308281 19782 0x559aa96200 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/futuris/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.055634323 19782 0x559aa96200 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.055686250 19782 0x559aa96200 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.055711093 19782 0x559aa96200 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.055736145 19782 0x559aa96200 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.055754583 19782 0x559aa96200 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.055823593 19782 0x559aa96200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "pipeline" named "mypipeline"
0:00:00.476712135 19782 0x559aa96200 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so" loaded
0:00:00.476764374 19782 0x559aa96200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvarguscamerasrc" named "src"
0:00:00.477204999 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSrc@0x559ad295d0> adding pad 'src'
0:00:00.478694010 19782 0x559aa96200 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.478737083 19782 0x559aa96200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "capsfilter" named "filter1"
0:00:00.478894270 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x559ad36260> adding pad 'sink'
0:00:00.478941666 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x559ad36260> adding pad 'src'
0:00:00.479872552 19782 0x559aa96200 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so" loaded
0:00:00.479911145 19782 0x559aa96200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvvidconv" named "nvvidconv1"
0:00:00.480146718 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x559abe84d0> adding pad 'sink'
0:00:00.480192604 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x559abe84d0> adding pad 'src'
0:00:00.481337916 19782 0x559aa96200 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so" loaded
0:00:00.481376562 19782 0x559aa96200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvegltransform" named "nvegltransform"
0:00:00.481547031 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x559ad3e120> adding pad 'sink'
0:00:00.481590677 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x559ad3e120> adding pad 'src'
0:00:00.483932760 19782 0x559aa96200 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so" loaded
0:00:00.483979583 19782 0x559aa96200 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nveglglessink" named "appsink"
0:00:00.484364531 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSink@0x559ad45750> adding pad 'sink'
0:00:00.484530468 19782 0x559aa96200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
(QTVideoTracking:19782): GLib-GObject-WARNING **: 16:45:06.138: ../../../../gobject/gsignal.c:2524: signal 'sample' is invalid for instance '0x559ad45750' of type 'GstEglGlesSink'
0:00:00.484819791 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element src:(any) to element filter1:(any)
0:00:00.484854635 19782 0x559aa96200 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link src:src and filter1:sink
0:00:00.484906458 19782 0x559aa96200 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<filter1:src> pad has no peer
0:00:00.484955572 19782 0x559aa96200 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: src and filter1 in same bin, no need for ghost pads
0:00:00.484997343 19782 0x559aa96200 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src:src and filter1:sink
0:00:00.485029999 19782 0x559aa96200 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<filter1:src> pad has no peer
0:00:00.485067031 19782 0x559aa96200 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src:src and filter1:sink, successful
0:00:00.485086562 19782 0x559aa96200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.485107552 19782 0x559aa96200 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<src:src> Received event on flushing pad. Discarding
0:00:00.485147291 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element filter1:(any) to element nvvidconv1:(any)
0:00:00.485175989 19782 0x559aa96200 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link filter1:src and nvvidconv1:sink
0:00:00.485221302 19782 0x559aa96200 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvidconv1:src> pad has no peer
0:00:00.485407499 19782 0x559aa96200 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: filter1 and nvvidconv1 in same bin, no need for ghost pads
0:00:00.485446614 19782 0x559aa96200 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link filter1:src and nvvidconv1:sink
0:00:00.485490885 19782 0x559aa96200 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvidconv1:src> pad has no peer
0:00:00.485635156 19782 0x559aa96200 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked filter1:src and nvvidconv1:sink, successful
0:00:00.485656041 19782 0x559aa96200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.485676666 19782 0x559aa96200 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<filter1:src> Received event on flushing pad. Discarding
0:00:00.485711927 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvvidconv1:(any) to element nvegltransform:(any)
0:00:00.485741145 19782 0x559aa96200 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvvidconv1:src and nvegltransform:sink
0:00:00.485851458 19782 0x559aa96200 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvegltransform:src> pad has no peer
0:00:00.485973177 19782 0x559aa96200 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvvidconv1 and nvegltransform in same bin, no need for ghost pads
0:00:00.486011822 19782 0x559aa96200 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvvidconv1:src and nvegltransform:sink
0:00:00.486124479 19782 0x559aa96200 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvegltransform:src> pad has no peer
0:00:00.486217708 19782 0x559aa96200 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvvidconv1:src and nvegltransform:sink, successful
0:00:00.486237604 19782 0x559aa96200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.486257604 19782 0x559aa96200 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvvidconv1:src> Received event on flushing pad. Discarding
0:00:00.486291093 19782 0x559aa96200 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvegltransform:(any) to element appsink:(any)
0:00:00.486320052 19782 0x559aa96200 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvegltransform:src and appsink:sink
0:00:00.486553072 19782 0x559aa96200 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvegltransform and appsink in same bin, no need for ghost pads
0:00:00.486596249 19782 0x559aa96200 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvegltransform:src and appsink:sink
0:00:00.486817552 19782 0x559aa96200 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvegltransform:src and appsink:sink, successful
0:00:00.486838385 19782 0x559aa96200 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.486859999 19782 0x559aa96200 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvegltransform:src> Received event on flushing pad. Discarding
0:00:00.486968281 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<appsink> current NULL pending VOID_PENDING, desired next READY
Using winsys: x11
0:00:00.487179166 19782 0x559aa96200 INFO egladaption gstegladaptation_egl.c:186:gst_egl_adaptation_init_display:<appsink> System reports supported EGL version v1.5
0:00:00.487550364 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<appsink> completed state change to READY
0:00:00.487590156 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<appsink> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.487629635 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'appsink' changed state to 2(READY) successfully
0:00:00.487663489 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvegltransform> current NULL pending VOID_PENDING, desired next READY
0:00:00.487689583 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvegltransform> completed state change to READY
0:00:00.487714114 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvegltransform> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.487743802 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'nvegltransform' changed state to 2(READY) successfully
0:00:00.487773072 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvidconv1> current NULL pending VOID_PENDING, desired next READY
0:00:00.487798333 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvidconv1> completed state change to READY
0:00:00.487821249 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvidconv1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.487850416 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'nvvidconv1' changed state to 2(READY) successfully
0:00:00.487879270 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<filter1> current NULL pending VOID_PENDING, desired next READY
0:00:00.487902604 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<filter1> completed state change to READY
0:00:00.487924947 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<filter1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.487964583 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'filter1' changed state to 2(READY) successfully
0:00:00.487992239 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src> current NULL pending VOID_PENDING, desired next READY
0:00:00.488015937 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src> completed state change to READY
0:00:00.488038593 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.488068437 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'src' changed state to 2(READY) successfully
0:00:00.488101093 19782 0x559aa96200 INFO GST_STATES gstelement.c:2651:gst_element_continue_state:<mypipeline> committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.488124635 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<mypipeline> notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.488154166 19782 0x559aa96200 INFO GST_STATES gstelement.c:2658:gst_element_continue_state:<mypipeline> continue state change READY to PAUSED, final PLAYING
0:00:00.488194791 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<appsink> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.495979843 19782 0x559aa96200 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func:<mypipeline> child 'appsink' is changing state asynchronously to PAUSED
0:00:00.496043229 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvegltransform> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.496240104 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvegltransform> completed state change to PAUSED
0:00:00.496282812 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvegltransform> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.496323072 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'nvegltransform' changed state to 3(PAUSED) successfully
0:00:00.496358177 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvidconv1> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.496626249 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvidconv1> completed state change to PAUSED
0:00:00.496659427 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvidconv1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.496696041 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'nvvidconv1' changed state to 3(PAUSED) successfully
0:00:00.496730260 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<filter1> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.496767239 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<filter1> completed state change to PAUSED
0:00:00.496790833 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<filter1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.496876302 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'filter1' changed state to 3(PAUSED) successfully
0:00:00.496908177 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.497014583 19782 0x559aa96200 INFO basesrc gstbasesrc.c:1358:gst_base_src_do_seek:<src> seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.497122812 19782 0x559aa96200 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x559ad30130 on task 0x559ad97050
0:00:00.497149270 19782 0x559aa96200 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:<src:src> created task 0x559ad97050
0:00:00.497403697 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src> completed state change to PAUSED
0:00:00.497449531 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.497518124 19782 0x559aa96200 INFO GST_STATES gstbin.c:2997:gst_bin_change_state_func:<mypipeline> child 'src' changed state to 3(PAUSED) successfully without preroll
0:00:00.497588541 19782 0x559aa96200 INFO GST_STATES gstelement.c:2651:gst_element_continue_state:<mypipeline> committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.497613697 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<mypipeline> notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.497677343 19782 0x559aa96200 INFO GST_STATES gstelement.c:2658:gst_element_continue_state:<mypipeline> continue state change PAUSED to PLAYING, final PLAYING
0:00:00.497917291 19782 0x559aa96200 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.498003645 19782 0x559aa96200 INFO bin gstbin.c:2783:gst_bin_do_latency_func:<mypipeline> configured latency of 0:00:00.000000000
0:00:00.498060052 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<appsink> current READY pending PAUSED, desired next PLAYING
0:00:00.498088489 19782 0x559aa96200 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func:<mypipeline> child 'appsink' is changing state asynchronously to PLAYING
0:00:00.498119322 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvegltransform> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.498145052 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvegltransform> completed state change to PLAYING
0:00:00.498169322 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvegltransform> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.498198437 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'nvegltransform' changed state to 4(PLAYING) successfully
0:00:00.498230052 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvidconv1> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.498256666 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvidconv1> completed state change to PLAYING
0:00:00.498282031 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvidconv1> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.498313489 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'nvvidconv1' changed state to 4(PLAYING) successfully
0:00:00.498446458 19782 0x559aa96200 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<filter1> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.498476458 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<filter1> completed state change to PLAYING
0:00:00.498501354 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<filter1> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.498538177 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'filter1' changed state to 4(PLAYING) successfully
0:00:00.498569999 19782 0x559aa96200 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src> completed state change to PLAYING
0:00:00.498594687 19782 0x559aa96200 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.498626614 19782 0x559aa96200 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'src' changed state to 4(PLAYING) successfully
0:00:00.499093124 19782 0x559ad384a0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad 'sink' in element "src"
0:00:00.499145677 19782 0x559ad384a0 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:<src:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.500356041 19782 0x559ad384a0 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)120/1
0:00:00.500483229 19782 0x559ad384a0 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps:<filter1> reuse caps
0:00:00.500543749 19782 0x559ad384a0 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)120/1
0:00:00.500958229 19782 0x559ad384a0 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps:<nvvidconv1> reuse caps
0:00:00.501023072 19782 0x559ad384a0 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)120/1
0:00:00.501163906 19782 0x559ad384a0 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:EGLImage), width=(int)1280, height=(int)720, format=(string)RGBA, framerate=(fraction)120/1
0:00:00.507372552 19782 0x559ad380f0 INFO nveglglessink gsteglglessink.c:2685:gst_eglglessink_configure_caps:<appsink> No window. Will attempt internal window creation
0:00:00.507424687 19782 0x559ad380f0 INFO nveglglessink gsteglglessink.c:937:gst_eglglessink_create_window:<appsink> Attempting internal window creation
0:00:00.623783020 19782 0x559ad380f0 INFO egladaption gstegladaptation_egl.c:254:gst_egl_adaptation_update_surface_dimensions:<appsink> Got surface of 1280x720 pixels
0:00:00.627379427 19782 0x559ad380f0 INFO egladaption gstegladaptation.c:611:gst_egl_adaptation_init_surface:<appsink> Performing initial texture setup
0:00:00.627524791 19782 0x559ad380f0 INFO nveglglessink gsteglglessink.c:2726:gst_eglglessink_configure_caps:<appsink> Configured caps successfully
Camera index = 0
Camera mode = 5
seconds to Run = 0
0:00:00.858522187 19782 0x559ad384a0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.858631874 19782 0x559ad384a0 INFO basesrc gstbasesrc.c:2945:gst_base_src_loop:<src> marking pending DISCONT
0:00:00.891259531 19782 0x559ad380f0 INFO nveglglessink gsteglglessink.c:980:gst_eglglessink_setup_vbo:<appsink> VBO setup. have_vbo:0
0:00:00.901362343 19782 0x559ad384a0 INFO GST_STATES gstbin.c:3433:bin_handle_async_done:<mypipeline> setting state from PAUSED to PAUSED, pending PLAYING
0:00:00.901410468 19782 0x559ad384a0 INFO GST_STATES gstbin.c:3453:bin_handle_async_done:<mypipeline> continue state change, pending PLAYING
0:00:00.901679010 19782 0x7f8c004680 INFO GST_STATES gstbin.c:3250:gst_bin_continue_func:<mypipeline> continue state change PAUSED to PLAYING, final PLAYING
0:00:00.901843697 19782 0x7f8c004680 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.901926718 19782 0x7f8c004680 INFO bin gstbin.c:2783:gst_bin_do_latency_func:<mypipeline> configured latency of 0:00:00.000000000
0:00:00.902041145 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<appsink> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.902088489 19782 0x7f8c004680 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<appsink> completed state change to PLAYING
0:00:00.902115781 19782 0x7f8c004680 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<appsink> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.902247603 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'appsink' changed state to 4(PLAYING) successfully
0:00:00.902296926 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvegltransform> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.902330051 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvegltransform> skipping transition from PLAYING to PLAYING
0:00:00.902362708 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'nvegltransform' changed state to 4(PLAYING) successfully
0:00:00.902400416 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvidconv1> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.902441197 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvvidconv1> skipping transition from PLAYING to PLAYING
0:00:00.902466301 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'nvvidconv1' changed state to 4(PLAYING) successfully
0:00:00.902494322 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<filter1> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.902535937 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<filter1> skipping transition from PLAYING to PLAYING
0:00:00.902563385 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'filter1' changed state to 4(PLAYING) successfully
0:00:00.903116614 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.903169635 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<src> skipping transition from PLAYING to PLAYING
0:00:00.903200468 19782 0x7f8c004680 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<mypipeline> child 'src' changed state to 4(PLAYING) successfully
0:00:00.903241770 19782 0x7f8c004680 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<mypipeline> completed state change to PLAYING
0:00:00.903286458 19782 0x7f8c004680 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<mypipeline> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
I thank you again. If GST_DEBUG=5 is needed, I can share that as well. And I emphasize once again, if I have done anything wrong at any point, just let me know, and I will correct it. :) Wishing you a productive day.
