Hello,everyone:
I decoded rtsp stream from IP camera with gstreamer-1.0,but meet some errors.
System environments:Ubuntu16.04、GTX1060、gstreamer-1.8.3、cuda-9.2
First,I just the below code:
sudo rm -rf ~/.cache/gstreamer-1.0/registry.x86_64.bin
Second,
gst-launch-1.0 --gst-debug=4 -v rtspsrc location="rtsp://admin:admin12345@192.168.0.64:554/Streaming/Channels/101?transportmode=unicast&profile=Profile_1 protocols=tcp latency=0" ! rtph264depay ! h264parse ! nvdec_h264 ! nvinfer ! 'video/x-raw(memory:NVMM),format=(string)NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=(string)RGBA,width=(int)1920, height=(int)1080,fFramerate=30/1' ! nvosd ! nveglglessink
Some errors happened.
0:00:00.000685338 5324 0xe06920 INFO GST_INIT gstmessage.c:119:_priv_gst_message_initialize: init messages
0:00:00.001825178 5324 0xe06920 INFO GST_INIT gstcontext.c:83:_priv_gst_context_initialize: init contexts
0:00:00.002440383 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:316:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.002689963 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:224:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.002719723 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.002756663 5324 0xe06920 INFO GST_REGISTRY gstregistry.c:1723:ensure_current_registry: reading registry cache: /home/chen/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.032927861 5324 0xe06920 INFO GST_REGISTRY gstregistrybinary.c:619:priv_gst_registry_binary_read_cache: loaded /home/chen/.cache/gstreamer-1.0/registry.x86_64.bin in 0.030134 seconds
0:00:00.033015917 5324 0xe06920 INFO GST_REGISTRY gstregistry.c:1579:scan_and_update_registry: Validating plugins from registry cache: /home/chen/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.033346053 5324 0xe06920 INFO GST_REGISTRY gstregistry.c:1329:gst_registry_scan_path_level:<registry0> cached info for /usr/local/lib/libnccl.so is stale
0:00:00.113268402 5324 0xe06920 WARN GST_REGISTRY gstregistry.c:461:gst_registry_add_plugin:<registry0> Not replacing plugin because new one (/usr/local/lib/python2.7/dist-packages/torch/lib/libnccl.so) is blacklisted but for a different location than existing one (/usr/local/lib/libnccl.so)
0:00:00.113624594 5324 0xe06920 INFO GST_REGISTRY gstregistry.c:1690:scan_and_update_registry: Registry cache changed. Writing new registry cache
0:00:00.113633854 5324 0xe06920 INFO GST_REGISTRY gstregistrybinary.c:368:priv_gst_registry_binary_write_cache: Building binary registry cache image
0:00:00.124605798 5324 0xe06920 INFO GST_REGISTRY gstregistrybinary.c:400:priv_gst_registry_binary_write_cache: Writing binary registry cache
0:00:00.197305991 5324 0xe06920 INFO GST_REGISTRY gstregistrybinary.c:261:gst_registry_binary_cache_finish: Wrote binary registry cache
0:00:00.197367035 5324 0xe06920 INFO GST_REGISTRY gstregistry.c:1699:scan_and_update_registry: Registry cache written successfully
0:00:00.197371684 5324 0xe06920 INFO GST_REGISTRY gstregistry.c:1758:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.197377778 5324 0xe06920 INFO GST_INIT gst.c:724:init_post: GLib runtime version: 2.48.2
0:00:00.197384155 5324 0xe06920 INFO GST_INIT gst.c:726:init_post: GLib headers version: 2.48.2
0:00:00.197388450 5324 0xe06920 INFO GST_INIT gst.c:727:init_post: initialized GStreamer successfully
0:00:00.197449577 5324 0xe06920 INFO GST_PIPELINE gstparse.c:323:gst_parse_launch_full: parsing pipeline description 'rtspsrc location=rtsp://admin:admin12345@192.168.0.64:554/Streaming/Channels/101?transportmode=unicast&profile=Profile_1\ protocols=tcp\ latency=0 ! rtph264depay ! h264parse ! nvdec_h264 ! nvinfer ! video/x-raw(memory:NVMM),format=(string)NV12 ! nvvidconv ! video/x-raw(memory:NVMM),format=(string)RGBA,width=(int)1920,\ height=(int)1080,fFramerate=30/1 ! nvosd ! nveglglessink '
0:00:00.198618158 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtsp.so" loaded
0:00:00.198632219 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "rtspsrc"
0:00:00.199666744 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrmdemux.so" loaded
0:00:00.199681934 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "rtspreal"
0:00:00.199969530 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstasf.so" loaded
0:00:00.199982168 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "rtspwms"
0:00:00.200493539 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtp.so" loaded
0:00:00.200507581 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "rtph264depay"
0:00:00.200568599 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstRTPBaseDepayload@0x12360a0> adding pad 'sink'
0:00:00.200581731 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstRTPBaseDepayload@0x12360a0> adding pad 'src'
0:00:00.200898279 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so" loaded
0:00:00.200910597 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "h264parse"
0:00:00.200967595 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseParse@0x123d260> adding pad 'sink'
0:00:00.200980318 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseParse@0x123d260> adding pad 'src'
0:00:00.200994919 5324 0xe06920 INFO baseparse gstbaseparse.c:3942:gst_base_parse_set_pts_interpolation:<GstH264Parse@0x123d260> PTS interpolation: no
0:00:00.204536061 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvvideocodecs.so" loaded
0:00:00.204550932 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "nvdec_h264"
0:00:00.204632393 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstVideoDecoder@0x110eba0> adding pad 'sink'
0:00:00.204647458 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstVideoDecoder@0x110eba0> adding pad 'src'
0:00:00.262797858 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvinfer.so" loaded
0:00:00.262813657 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "nvinfer"
0:00:00.262927032 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x146a640> adding pad 'sink'
0:00:00.262937675 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x146a640> adding pad 'src'
0:00:00.262945597 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad (null):sink
0:00:00.263198944 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so" loaded
0:00:00.263206243 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "nvvidconv"
0:00:00.263249400 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x147bbe0> adding pad 'sink'
0:00:00.263257700 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x147bbe0> adding pad 'src'
0:00:00.263549666 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvosd.so" loaded
0:00:00.263557243 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "nvosd"
0:00:00.263600257 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x147ecd0> adding pad 'sink'
0:00:00.263608766 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x147ecd0> adding pad 'src'
0:00:00.264340263 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so" loaded
0:00:00.264348791 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "nveglglessink"
0:00:00.264431610 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSink@0x14c6f00> adding pad 'sink'
0:00:00.264457190 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "pipeline"
0:00:00.264501453 5324 0xe06920 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of GstRTSPSrc named rtspsrc0 to some pad of GstRtpH264Depay named rtph264depay0 (0/0) with caps "(NULL)"
0:00:00.264511835 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element rtspsrc0:(any) to element rtph264depay0:(any)
0:00:00.264525553 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad: no such pad 'stream_%u' in element "rtspsrc0"
0:00:00.264531176 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1124:gst_element_get_compatible_pad:<rtspsrc0> Could not find a compatible pad to link to rtph264depay0:sink
0:00:00.264535343 5324 0xe06920 INFO default gstutils.c:1962:gst_element_link_pads_filtered: Could not link pads: rtspsrc0:(null) - rtph264depay0:(null)
0:00:00.264542873 5324 0xe06920 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of GstRtpH264Depay named rtph264depay0 to some pad of GstH264Parse named h264parse0 (0/0) with caps "(NULL)"
0:00:00.264550502 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element rtph264depay0:(any) to element h264parse0:(any)
0:00:00.264556130 5324 0xe06920 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link rtph264depay0:src and h264parse0:sink
0:00:00.264563888 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<h264parse0:src> pad has no peer
0:00:00.264569876 5324 0xe06920 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: rtph264depay0 and h264parse0 in same bin, no need for ghost pads
0:00:00.264577289 5324 0xe06920 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link rtph264depay0:src and h264parse0:sink
0:00:00.264584083 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<h264parse0:src> pad has no peer
0:00:00.264588611 5324 0xe06920 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked rtph264depay0:src and h264parse0:sink, successful
0:00:00.264593664 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.264597846 5324 0xe06920 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<rtph264depay0:src> Received event on flushing pad. Discarding
0:00:00.264603880 5324 0xe06920 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of GstH264Parse named h264parse0 to some pad of GstNvcuvidH264Dec named nvcuvidh264dec0 (0/0) with caps "(NULL)"
0:00:00.264610532 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element h264parse0:(any) to element nvcuvidh264dec0:(any)
0:00:00.264615793 5324 0xe06920 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link h264parse0:src and nvcuvidh264dec0:sink
0:00:00.264622422 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvcuvidh264dec0:src> pad has no peer
0:00:00.264638891 5324 0xe06920 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: h264parse0 and nvcuvidh264dec0 in same bin, no need for ghost pads
0:00:00.264645495 5324 0xe06920 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link h264parse0:src and nvcuvidh264dec0:sink
0:00:00.264652091 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvcuvidh264dec0:src> pad has no peer
0:00:00.264661591 5324 0xe06920 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked h264parse0:src and nvcuvidh264dec0:sink, successful
0:00:00.264666628 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.264670651 5324 0xe06920 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<h264parse0:src> Received event on flushing pad. Discarding
0:00:00.264676664 5324 0xe06920 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of GstNvcuvidH264Dec named nvcuvidh264dec0 to some pad of GstNvInfer named nvinfer0 (0/0) with caps "(NULL)"
0:00:00.264686179 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element nvcuvidh264dec0:(any) to element nvinfer0:(any)
0:00:00.264693115 5324 0xe06920 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link nvcuvidh264dec0:src and nvinfer0:sink
0:00:00.264702977 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvinfer0:src> pad has no peer
0:00:00.264717205 5324 0xe06920 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: nvcuvidh264dec0 and nvinfer0 in same bin, no need for ghost pads
0:00:00.264723970 5324 0xe06920 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link nvcuvidh264dec0:src and nvinfer0:sink
0:00:00.264730886 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvinfer0:src> pad has no peer
0:00:00.264738874 5324 0xe06920 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked nvcuvidh264dec0:src and nvinfer0:sink, successful
0:00:00.264744020 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.264747833 5324 0xe06920 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<nvcuvidh264dec0:src> Received event on flushing pad. Discarding
0:00:00.264753180 5324 0xe06920 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of GstNvInfer named nvinfer0 to some pad of Gstnvvidconv named nvvidconv0 (0/0) with caps "video/x-raw(memory:NVMM), format=(string)NV12"
0:00:00.264960335 5324 0xe06920 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/local/lib/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.264967252 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "capsfilter"
0:00:00.264997633 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x14d02b0> adding pad 'sink'
0:00:00.265006128 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x14d02b0> adding pad 'src'
0:00:00.265012818 5324 0xe06920 INFO GST_STATES gstbin.c:1915:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.265022081 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.265029053 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.265036465 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element nvinfer0:(any) to element capsfilter0:sink
0:00:00.265042261 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.265046409 5324 0xe06920 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: nvinfer0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.265052786 5324 0xe06920 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link nvinfer0:src and capsfilter0:sink
0:00:00.265067586 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<capsfilter0:src> pad has no peer
0:00:00.265073402 5324 0xe06920 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked nvinfer0:src and capsfilter0:sink, successful
0:00:00.265078356 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.265082135 5324 0xe06920 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<nvinfer0:src> Received event on flushing pad. Discarding
0:00:00.265087846 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element capsfilter0:src to element nvvidconv0:(any)
0:00:00.265092909 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.265097386 5324 0xe06920 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link capsfilter0:src and nvvidconv0:sink
0:00:00.265110344 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvvidconv0:src> pad has no peer
0:00:00.265141118 5324 0xe06920 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: capsfilter0 and nvvidconv0 in same bin, no need for ghost pads
0:00:00.265147727 5324 0xe06920 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link capsfilter0:src and nvvidconv0:sink
0:00:00.265161311 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvvidconv0:src> pad has no peer
0:00:00.265184696 5324 0xe06920 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked capsfilter0:src and nvvidconv0:sink, successful
0:00:00.265189591 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.265193226 5324 0xe06920 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<capsfilter0:src> Received event on flushing pad. Discarding
0:00:00.265198706 5324 0xe06920 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of Gstnvvidconv named nvvidconv0 to some pad of GstNvOsd named nvosd0 (0/0) with caps "video/x-raw(memory:NVMM), format=(string)RGBA, width=(int)1920, height=(int)1080, fFramerate=(fraction)30/1"
0:00:00.265211060 5324 0xe06920 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "capsfilter"
0:00:00.265220278 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x14d05e0> adding pad 'sink'
0:00:00.265227427 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x14d05e0> adding pad 'src'
0:00:00.265233684 5324 0xe06920 INFO GST_STATES gstbin.c:1915:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.265241017 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter1> completed state change to NULL
0:00:00.265246281 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.265250711 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element nvvidconv0:(any) to element capsfilter1:sink
0:00:00.265255616 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad capsfilter1:sink
0:00:00.265259822 5324 0xe06920 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: nvvidconv0 and capsfilter1 in same bin, no need for ghost pads
0:00:00.265265261 5324 0xe06920 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link nvvidconv0:src and capsfilter1:sink
0:00:00.265291086 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<capsfilter1:src> pad has no peer
0:00:00.265298367 5324 0xe06920 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked nvvidconv0:src and capsfilter1:sink, successful
0:00:00.265303200 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.265306707 5324 0xe06920 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<nvvidconv0:src> Received event on flushing pad. Discarding
0:00:00.265311695 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element capsfilter1:src to element nvosd0:(any)
0:00:00.265316458 5324 0xe06920 INFO GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad: found pad capsfilter1:src
0:00:00.265320826 5324 0xe06920 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link capsfilter1:src and nvosd0:sink
0:00:00.265346840 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvosd0:src> pad has no peer
0:00:00.265354936 5324 0xe06920 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: capsfilter1 and nvosd0 in same bin, no need for ghost pads
0:00:00.265360303 5324 0xe06920 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link capsfilter1:src and nvosd0:sink
0:00:00.265384969 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvosd0:src> pad has no peer
0:00:00.265392634 5324 0xe06920 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked capsfilter1:src and nvosd0:sink, successful
0:00:00.265397238 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.265401069 5324 0xe06920 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<capsfilter1:src> Received event on flushing pad. Discarding
0:00:00.265406294 5324 0xe06920 INFO GST_PIPELINE grammar.y:596:gst_parse_perform_link: linking some pad of GstNvOsd named nvosd0 to some pad of GstEglGlesSink named eglglessink0 (0/0) with caps "(NULL)"
0:00:00.265412680 5324 0xe06920 INFO GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full: trying to link element nvosd0:(any) to element eglglessink0:(any)
0:00:00.265417589 5324 0xe06920 INFO GST_PADS gstutils.c:932:gst_pad_check_link: trying to link nvosd0:src and eglglessink0:sink
0:00:00.265461238 5324 0xe06920 INFO GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting: nvosd0 and eglglessink0 in same bin, no need for ghost pads
0:00:00.265467610 5324 0xe06920 INFO GST_PADS gstpad.c:2315:gst_pad_link_prepare: trying to link nvosd0:src and eglglessink0:sink
0:00:00.265507485 5324 0xe06920 INFO GST_PADS gstpad.c:2521:gst_pad_link_full: linked nvosd0:src and eglglessink0:sink, successful
0:00:00.265512790 5324 0xe06920 INFO GST_EVENT gstevent.c:1382:gst_event_new_reconfigure: creating reconfigure event
0:00:00.265516368 5324 0xe06920 INFO GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<nvosd0:src> Received event on flushing pad. Discarding
Setting pipeline to PAUSED ...
0:00:00.265544866 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<eglglessink0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269371923 5324 0xe06920 INFO egladaption ext/eglgles/gstegladaptation_egl.c:175:gst_egl_adaptation_init_display:<eglglessink0> System reports supported EGL version v1.4
0:00:00.269469067 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<eglglessink0> completed state change to READY
0:00:00.269475809 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<eglglessink0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269486472 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'eglglessink0' changed state to 2(READY) successfully
0:00:00.269496090 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvosd0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269502414 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvosd0> completed state change to READY
0:00:00.269506168 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvosd0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269511822 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvosd0' changed state to 2(READY) successfully
0:00:00.269517360 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter1> current NULL pending VOID_PENDING, desired next READY
0:00:00.269522190 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter1> completed state change to READY
0:00:00.269525825 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269531060 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 2(READY) successfully
0:00:00.269536269 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvidconv0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269541194 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvidconv0> completed state change to READY
0:00:00.269544700 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvidconv0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269549730 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvvidconv0' changed state to 2(READY) successfully
0:00:00.269555076 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269559678 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:00.269563122 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269569207 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:00.269574972 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvinfer0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269580757 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvinfer0> completed state change to READY
0:00:00.269583877 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvinfer0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269589148 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvinfer0' changed state to 2(READY) successfully
0:00:00.269594727 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvcuvidh264dec0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269600011 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvcuvidh264dec0> completed state change to READY
0:00:00.269603613 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvcuvidh264dec0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269608247 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvcuvidh264dec0' changed state to 2(READY) successfully
0:00:00.269613741 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<h264parse0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269618798 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<h264parse0> completed state change to READY
0:00:00.269622301 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<h264parse0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269626956 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'h264parse0' changed state to 2(READY) successfully
0:00:00.269632091 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<rtph264depay0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269636954 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<rtph264depay0> completed state change to READY
0:00:00.269640532 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtph264depay0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269645536 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'rtph264depay0' changed state to 2(READY) successfully
0:00:00.269651129 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<rtspsrc0> current NULL pending VOID_PENDING, desired next READY
0:00:00.269663841 5324 0xe06920 INFO task gsttask.c:451:gst_task_set_lock: setting stream lock 0x11c55a8 on task 0x14f9050
0:00:00.269674521 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<rtspsrc0> completed state change to READY
0:00:00.269678831 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtspsrc0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.269684774 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'rtspsrc0' changed state to 2(READY) successfully
0:00:00.269690709 5324 0xe06920 INFO GST_STATES gstelement.c:2347:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.269695480 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.269711830 5324 0xe06920 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:00.269721738 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<eglglessink0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.269770787 5324 0xe06920 INFO GST_STATES gstbin.c:2770:gst_bin_change_state_func:<pipeline0> child 'eglglessink0' is changing state asynchronously to PAUSED
0:00:00.269778759 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvosd0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.362344999 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvosd0> completed state change to PAUSED
0:00:00.362360415 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvosd0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.362372988 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvosd0' changed state to 3(PAUSED) successfully
0:00:00.362383200 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter1> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.362391471 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter1> completed state change to PAUSED
0:00:00.362395775 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.362404056 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 3(PAUSED) successfully
0:00:00.362410069 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvidconv0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.362440860 5324 0xe06920 INFO GST_PADS gstpad.c:4098:gst_pad_peer_query:<rtph264depay0:sink> pad has no peer
0:00:00.362512347 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvidconv0> completed state change to PAUSED
0:00:00.362518988 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvidconv0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.362525594 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'nvvidconv0' changed state to 3(PAUSED) successfully
0:00:00.362531387 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.362537134 5324 0xe06920 INFO GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:00.362540533 5324 0xe06920 INFO GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.362549407 5324 0xe06920 INFO GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:00.362556327 5324 0xe06920 INFO GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvinfer0> current READY pending VOID_PENDING, desired next PAUSED
>>> Generating new GIE model cache
Using FP32 data type.
could not open file
How to slove this problem? Thanks for you in advance!
