(gst-launch-1.0:11): GStreamer-CRITICAL **: 03:52:57.654: gst_mini_object_unref: assertion 'mini_object != NULL' failed
I encountered an error executing the following command
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0# gst-launch-1.0 rtspsrc location=rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream latency=200 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw, format=(string)BGRx ! videoconvert ! fakesink sync=false
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
(gst-launch-1.0:31): GStreamer-CRITICAL **: 05:24:58.650: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:03.065412691
Setting pipeline to READY …
^C
However, changing the decoder command does not report an error,I believe nvV4L2Decoder is the source of the problem
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0# gst-launch-1.0 rtspsrc location=rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream latency=200 ! rtph264depay ! h264parse ! avdec_h264 ! nvvideoconvert ! video/x-raw, format=(string)BGRx ! videoconvert ! fakesink sync=false
Redistribute latency…
Execution ended after 0:00:34.124400984
Setting pipeline to NULL …
Freeing pipeline …
I use a docker
https://docs.nvidia.com/metropolis/deepstream/5.0.1/dev-guide/text/DS_docker_containers.html
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-5.0 nvcr.io/nvidia/deepstream:5.0.1-20.09-devel
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0# gst-launch-1.0 --version
gst-launch-1.0 version 1.14.5
GStreamer 1.14.5
https://launchpad.net/distros/ubuntu/+source/gstreamer1.0
But there is no problem with the following docker
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.1 nvcr.io/nvidia/deepstream:6.1-devel
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-6.1# gst-launch-1.0 rtspsrc location=rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream latency=200 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw, format=(string)BGRx ! videoconvert ! fakesink sync=false
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-6.1# gst-launch-1.0 --version
gst-launch-1.0 version 1.16.2
GStreamer 1.16.2
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvmsgconv# gst-launch-1.0 --gst-debug-level=4 rtspsrc location=rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream latency=200 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw, format=(string)BGRx ! videoconvert ! tee! fakesink sync=false
0:00:00.000789056 194 0x559b3e9d32c0 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.001921222 194 0x559b3e9d32c0 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.002401372 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.002593050 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.002622944 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.002657564 194 0x559b3e9d32c0 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.019045573 194 0x559b3e9d32c0 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.x86_64.bin in 0.016340 seconds
0:00:00.019116422 194 0x559b3e9d32c0 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.020773752 194 0x559b3e9d32c0 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.020790857 194 0x559b3e9d32c0 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.020802398 194 0x559b3e9d32c0 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.020812874 194 0x559b3e9d32c0 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.020827817 194 0x559b3e9d32c0 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.020862703 194 0x559b3e9d32c0 INFO GST_PIPELINE gstparse.c:337:gst_parse_launch_full: parsing pipeline description ‘rtspsrc location=rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream latency=200 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw, format=(string)BGRx ! videoconvert ! tee! fakesink sync=false ’
0:00:00.023021098 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtsp.so” loaded
0:00:00.023049721 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtspsrc”
0:00:00.024486194 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstasf.so” loaded
0:00:00.024508626 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtspwms”
0:00:00.025026342 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrealmedia.so” loaded
0:00:00.025041054 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtspreal”
0:00:00.025804334 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtp.so” loaded
0:00:00.025821645 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtph264depay”
0:00:00.025912719 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRTPBaseDepayload@0x559b3ec18090 adding pad ‘sink’
0:00:00.025929633 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRTPBaseDepayload@0x559b3ec18090 adding pad ‘src’
0:00:00.026309136 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so” loaded
0:00:00.026322631 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “h264parse”
0:00:00.026387153 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0x559b3ec23260 adding pad ‘sink’
0:00:00.026413810 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseParse@0x559b3ec23260 adding pad ‘src’
0:00:00.026438199 194 0x559b3e9d32c0 INFO baseparse gstbaseparse.c:3961:gst_base_parse_set_pts_interpolation:GstH264Parse@0x559b3ec23260 PTS interpolation: no
0:00:00.030145549 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so” loaded
0:00:00.030168363 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “nvv4l2decoder”
0:00:00.030284389 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0x559b3ec40690 adding pad ‘sink’
0:00:00.030301119 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstVideoDecoder@0x559b3ec40690 adding pad ‘src’
0:00:00.078625796 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so” loaded
0:00:00.078656430 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “nvvideoconvert”
0:00:00.078837259 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x559b3eccf190 adding pad ‘sink’
0:00:00.078864248 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x559b3eccf190 adding pad ‘src’
0:00:00.079194512 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvideoconvert.so” loaded
0:00:00.079209897 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “videoconvert”
0:00:00.079447186 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x559b3ecd87e0 adding pad ‘sink’
0:00:00.079465506 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x559b3ecd87e0 adding pad ‘src’
0:00:00.079987544 194 0x559b3e9d32c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.080002280 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.080094288 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x559b3ecdf000 adding pad ‘sink’
0:00:00.080120151 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “fakesink”
0:00:00.080217055 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x559b3ece1a20 adding pad ‘sink’
0:00:00.080247385 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “pipeline”
0:00:00.080351662 194 0x559b3e9d32c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstRTSPSrc named rtspsrc0 to some pad of GstRtpH264Depay named rtph264depay0 (0/0) with caps “(NULL)”
0:00:00.080369763 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element rtspsrc0:(any) to element rtph264depay0:(any)
0:00:00.080399352 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad 'stream
%u’ in element “rtspsrc0”
0:00:00.080413786 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1227:gst_element_get_compatible_pad: Could not find a compatible pad to link to rtph264depay0:sink
0:00:00.080428322 194 0x559b3e9d32c0 INFO default gstutils.c:2162:gst_element_link_pads_filtered: Could not link pads: rtspsrc0:(null) - rtph264depay0:(null)
0:00:00.080453589 194 0x559b3e9d32c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstRtpH264Depay named rtph264depay0 to some pad of GstH264Parse named h264parse0 (0/0) with caps “(NULL)”
0:00:00.080466219 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element rtph264depay0:(any) to element h264parse0:(any)
0:00:00.080478187 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link rtph264depay0:src and h264parse0:sink
0:00:00.080495006 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:h264parse0:src pad has no peer
0:00:00.080518697 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: rtph264depay0 and h264parse0 in same bin, no need for ghost pads
0:00:00.080537916 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtph264depay0:src and h264parse0:sink
0:00:00.080549985 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:h264parse0:src pad has no peer
0:00:00.080564666 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtph264depay0:src and h264parse0:sink, successful
0:00:00.080577540 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.080588446 194 0x559b3e9d32c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:rtph264depay0:src Received event on flushing pad. Discarding
0:00:00.080611671 194 0x559b3e9d32c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstH264Parse named h264parse0 to some pad of nvv4l2decoder named nvv4l2decoder0 (0/0) with caps “(NULL)”
0:00:00.080624035 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element h264parse0:(any) to element nvv4l2decoder0:(any)
0:00:00.080636514 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link h264parse0:src and nvv4l2decoder0:sink
0:00:00.080652445 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvv4l2decoder0:src pad has no peer
0:00:00.080716444 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: h264parse0 and nvv4l2decoder0 in same bin, no need for ghost pads
0:00:00.080729931 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link h264parse0:src and nvv4l2decoder0:sink
0:00:00.080741019 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvv4l2decoder0:src pad has no peer
0:00:00.080783645 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked h264parse0:src and nvv4l2decoder0:sink, successful
0:00:00.080792439 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.080801111 194 0x559b3e9d32c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:h264parse0:src Received event on flushing pad. Discarding
0:00:00.080818193 194 0x559b3e9d32c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of nvv4l2decoder named nvv4l2decoder0 to some pad of Gstnvvideoconvert named nvvideoconvert0 (0/0) with caps “(NULL)”
0:00:00.080833012 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvv4l2decoder0:(any) to element nvvideoconvert0:(any)
0:00:00.080844819 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvv4l2decoder0:src and nvvideoconvert0:sink
0:00:00.080859860 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvvideoconvert0:src pad has no peer
0:00:00.080916542 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvv4l2decoder0 and nvvideoconvert0 in same bin, no need for ghost pads
0:00:00.080929796 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvv4l2decoder0:src and nvvideoconvert0:sink
0:00:00.080941156 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvvideoconvert0:src pad has no peer
0:00:00.080986809 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvv4l2decoder0:src and nvvideoconvert0:sink, successful
0:00:00.080995957 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.081004811 194 0x559b3e9d32c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvv4l2decoder0:src Received event on flushing pad. Discarding
0:00:00.081025347 194 0x559b3e9d32c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of Gstnvvideoconvert named nvvideoconvert0 to some pad of GstVideoConvert named videoconvert0 (0/0) with caps “video/x-raw, format=(string)BGRx”
0:00:00.081036563 194 0x559b3e9d32c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “capsfilter”
0:00:00.081102280 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x559b3ece8300 adding pad ‘sink’
0:00:00.081117837 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x559b3ece8300 adding pad ‘src’
0:00:00.081134335 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2089:gst_bin_get_state_func: getting state
0:00:00.081156353 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:00.081173601 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.081188463 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvvideoconvert0:(any) to element capsfilter0:sink
0:00:00.081198527 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.081210926 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvvideoconvert0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.081227638 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvvideoconvert0:src and capsfilter0:sink
0:00:00.081267326 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:capsfilter0:src pad has no peer
0:00:00.081285503 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvvideoconvert0:src and capsfilter0:sink, successful
0:00:00.081298026 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.081306923 194 0x559b3e9d32c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvvideoconvert0:src Received event on flushing pad. Discarding
0:00:00.081320469 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element capsfilter0:src to element videoconvert0:(any)
0:00:00.081330494 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.081341340 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link capsfilter0:src and videoconvert0:sink
0:00:00.081385745 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:videoconvert0:src pad has no peer
0:00:00.082310361 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: capsfilter0 and videoconvert0 in same bin, no need for ghost pads
0:00:00.082324915 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link capsfilter0:src and videoconvert0:sink
0:00:00.082371142 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:videoconvert0:src pad has no peer
0:00:00.083295953 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked capsfilter0:src and videoconvert0:sink, successful
0:00:00.083306384 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.083315503 194 0x559b3e9d32c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:capsfilter0:src Received event on flushing pad. Discarding
0:00:00.083337718 194 0x559b3e9d32c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstVideoConvert named videoconvert0 to some pad of GstTee named tee0 (0/0) with caps “(NULL)”
0:00:00.083349297 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element videoconvert0:(any) to element tee0:(any)
0:00:00.083360844 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link videoconvert0:src and tee0:sink
0:00:00.083469282 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: videoconvert0 and tee0 in same bin, no need for ghost pads
0:00:00.083482449 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link videoconvert0:src and tee0:sink
0:00:00.083593197 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked videoconvert0:src and tee0:sink, successful
0:00:00.083602794 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.083611332 194 0x559b3e9d32c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:videoconvert0:src Received event on flushing pad. Discarding
0:00:00.083630323 194 0x559b3e9d32c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstTee named tee0 to some pad of GstFakeSink named fakesink0 (0/0) with caps “(NULL)”
0:00:00.083641814 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element tee0:(any) to element fakesink0:(any)
0:00:00.083681078 194 0x559b3e9d32c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.083694161 194 0x559b3e9d32c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: tee0 and fakesink0 in same bin, no need for ghost pads
0:00:00.083706695 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee0:src_0 and fakesink0:sink
0:00:00.083814509 194 0x559b3e9d32c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee0:src_0 and fakesink0:sink, successful
0:00:00.083823598 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.083832760 194 0x559b3e9d32c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:tee0:src_0 Received event on flushing pad. Discarding
0:00:00.083889055 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.083901538 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.083911687 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.083935687 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘fakesink0’ changed state to 2(READY) successfully
0:00:00.083947510 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.083957398 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.083968956 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.083981160 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘tee0’ changed state to 2(READY) successfully
0:00:00.083992295 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.084002468 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.084012428 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.084024309 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 2(READY) successfully
0:00:00.084035564 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.084045294 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.084055344 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.084066906 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 2(READY) successfully
0:00:00.084078966 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.084089785 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.084099334 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.084111450 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvvideoconvert0’ changed state to 2(READY) successfully
0:00:00.084122682 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.084840369 194 0x559b3e9d32c0 INFO v4l2 v4l2_calls.c:622:gst_v4l2_open:nvv4l2decoder0:sink Opened device ‘’ (/dev/nvhost-nvdec) successfully
0:00:00.084860920 194 0x559b3e9d32c0 INFO v4l2 v4l2_calls.c:723:gst_v4l2_dup:nvv4l2decoder0:src Cloned device ‘’ (/dev/nvhost-nvdec) successfully
0:00:00.084881037 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1281:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink got 8 format(s):
0:00:00.084892801 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink YM12
0:00:00.084903224 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink MJPG
0:00:00.084913225 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink NM12
0:00:00.084919947 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink MPG4
0:00:00.084928929 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink H265
0:00:00.084939589 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink VP90
0:00:00.084949018 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink VP80
0:00:00.084958527 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:sink H264
0:00:00.084998446 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.085009835 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:00.085019467 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.085029530 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:00.085053316 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.085063109 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:00.085071907 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.085083923 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:00.085101820 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.085111613 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:00.085120131 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.085129893 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:00.085148143 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.085157684 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:00.085166562 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:00.085177932 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:00.085214542 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:4486:gst_v4l2_object_probe_caps:nvv4l2decoder0:sink probed caps: image/jpeg, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], parsed=(boolean)true; video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], parsed=(boolean)true; video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], parsed=(boolean)true; video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ]
0:00:00.085643795 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1281:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src got 6 format(s):
0:00:00.085656100 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src MJPG
0:00:00.085665950 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src NM12
0:00:00.085675375 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src MPG4
0:00:00.085686609 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src VP80
0:00:00.085695853 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src H265
0:00:00.085704547 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:1287:gst_v4l2_object_fill_format_list:nvv4l2decoder0:src H264
0:00:00.085722968 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:00.085734299 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2921:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:00.085743351 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:3035:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:00.085754428 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2927:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:00.085767918 194 0x559b3e9d32c0 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x559b3ec42ea0 Failed to determine interlace mode
0:00:00.085798591 194 0x559b3e9d32c0 INFO v4l2 gstv4l2object.c:4486:gst_v4l2_object_probe_caps:nvv4l2decoder0:src probed caps: video/x-raw, format=(string)NV12, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], pixel-aspect-ratio=(fraction)1/1
0:00:00.085810868 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.085822248 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.085840655 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2decoder0’ changed state to 2(READY) successfully
0:00:00.085859016 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.085870246 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.085937251 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.085949789 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 2(READY) successfully
0:00:00.085960827 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.085972668 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.085982809 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.085995138 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘rtph264depay0’ changed state to 2(READY) successfully
0:00:00.086007191 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.086029794 194 0x559b3e9d32c0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x559b3ec055b8 on task 0x559b3ec1d710
0:00:00.086050992 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.086061312 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.086075036 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘rtspsrc0’ changed state to 2(READY) successfully
0:00:00.086088445 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.086098384 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.086123431 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.086142997 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086163771 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func: child ‘fakesink0’ is changing state asynchronously to PAUSED
0:00:00.086175159 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086189672 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086199381 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.086211202 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘tee0’ changed state to 3(PAUSED) successfully
0:00:00.086220265 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086234916 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086244533 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.086256351 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 3(PAUSED) successfully
0:00:00.086267389 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086281567 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086291213 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.086302987 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 3(PAUSED) successfully
0:00:00.086316274 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086331093 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086340549 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.086352595 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvvideoconvert0’ changed state to 3(PAUSED) successfully
0:00:00.086363283 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086381614 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086391508 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.086403279 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2decoder0’ changed state to 3(PAUSED) successfully
0:00:00.086414387 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086689804 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086701106 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.086713545 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 3(PAUSED) successfully
0:00:00.086724904 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086740376 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086750248 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.086762211 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘rtph264depay0’ changed state to 3(PAUSED) successfully
0:00:00.086774204 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.086853891 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086864797 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.086887001 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2997:gst_bin_change_state_func: child ‘rtspsrc0’ changed state to 3(PAUSED) successfully without preroll
0:00:00.086900235 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.086909127 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.101331688 194 0x559b3ece6ed0 INFO rtspsrc gstrtspsrc.c:7364:gst_rtspsrc_retrieve_sdp: Now using version: 1.0
0:00:00.109638984 194 0x559b3ece6ed0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstudp.so” loaded
0:00:00.109688374 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:00:00.110041039 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0x7f6f0c024e00 adding pad ‘src’
0:00:00.110285726 194 0x559b3ece6ed0 INFO udpsrc gstudpsrc.c:1410:gst_udpsrc_open: setting udp buffer of 524288 bytes
0:00:00.110321904 194 0x559b3ece6ed0 INFO udpsrc gstudpsrc.c:1430:gst_udpsrc_open: have udp buffer of 425984 bytes
0:00:00.110383863 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.110412373 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.110513344 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:00.110543168 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.110587441 194 0x559b3ece6ed0 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose: 0x7f6f0c024e00 dispose
0:00:00.110615196 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad: removing pad ‘src’
0:00:00.110659254 194 0x559b3ece6ed0 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose: 0x7f6f0c024e00 parent class dispose
0:00:00.110682886 194 0x559b3ece6ed0 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize: 0x7f6f0c024e00 finalize
0:00:00.110711475 194 0x559b3ece6ed0 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize: 0x7f6f0c024e00 finalize parent
0:00:00.111103312 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:00:00.111129588 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0x7f6f0c024e00 adding pad ‘src’
0:00:00.111189182 194 0x559b3ece6ed0 INFO udpsrc gstudpsrc.c:1410:gst_udpsrc_open: setting udp buffer of 524288 bytes
0:00:00.111201700 194 0x559b3ece6ed0 INFO udpsrc gstudpsrc.c:1430:gst_udpsrc_open: have udp buffer of 425984 bytes
0:00:00.111224175 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.111242047 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.111357080 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:00:00.111380680 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0x7f6f0c027670 adding pad ‘src’
0:00:00.111441372 194 0x559b3ece6ed0 INFO udpsrc gstudpsrc.c:1430:gst_udpsrc_open: have udp buffer of 212992 bytes
0:00:00.111460618 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.111475646 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.116178050 194 0x559b3ece6ed0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtpmanager.so” loaded
0:00:00.116199442 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “rtpbin” named “manager”
0:00:00.116548004 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.116562774 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.116600247 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.116615017 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.116626257 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.116698797 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘recv_rtp_sink_0’ in element “manager”
0:00:00.116718405 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpsession”
0:00:00.117048064 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpssrcdemux”
0:00:00.117112399 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpSsrcDemux@0x7f6f0c01e2b0 adding pad ‘sink’
0:00:00.117128570 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpSsrcDemux@0x7f6f0c01e2b0 adding pad ‘rtcp_sink’
0:00:00.117142245 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpstorage”
0:00:00.117240206 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpStorage@0x559b3ec1db40 adding pad ‘src’
0:00:00.117252992 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpStorage@0x559b3ec1db40 adding pad ‘sink’
0:00:00.117285292 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “funnel”
0:00:00.117330888 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstFunnel@0x559b3ec1dc60 adding pad ‘src’
0:00:00.117343736 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “funnel”
0:00:00.117363206 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstFunnel@0x559b3ec1dd80 adding pad ‘src’
0:00:00.117473600 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.117488545 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.117512847 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.117527468 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.117540422 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.117557144 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.117568121 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.117587949 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.117599240 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.117612317 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.117631622 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.117648675 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.117669234 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.117687583 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.117707083 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.117732955 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.117743694 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.117762713 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.117779833 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.117794829 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.117813396 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.117823739 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.117848846 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.117871779 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:00:00.117883150 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.117899889 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘recv_rtp_sink’ in element “rtpsession0”
0:00:00.117939033 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtp_sink’
0:00:00.118065588 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtp_src’
0:00:00.118100029 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘funnelpad0’
0:00:00.118115189 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad funnel0:src
0:00:00.118131598 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link funnel0:src and rtpsession0:recv_rtp_sink
0:00:00.118150181 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked funnel0:src and rtpsession0:recv_rtp_sink, successful
0:00:00.118157582 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118222837 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link recv_rtp_sink_0:proxypad0 and funnel0:funnelpad0
0:00:00.118240254 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked recv_rtp_sink_0:proxypad0 and funnel0:funnelpad0, successful
0:00:00.118252282 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118271654 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtp_sink_0’
0:00:00.118287219 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpsession0:recv_rtp_src
0:00:00.118299634 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpstorage0:sink
0:00:00.118313938 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpsession0:recv_rtp_src and rtpstorage0:sink
0:00:00.118328417 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:rtpstorage0:src pad has no peer
0:00:00.118343333 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpsession0:recv_rtp_src and rtpstorage0:sink, successful
0:00:00.118349935 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118363271 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpstorage0:src
0:00:00.118372850 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpssrcdemux0:sink
0:00:00.118386022 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpstorage0:src and rtpssrcdemux0:sink
0:00:00.118398633 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpstorage0:src and rtpssrcdemux0:sink, successful
0:00:00.118406943 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118431317 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘recv_rtcp_sink_0’ in element “manager”
0:00:00.118451318 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘recv_rtcp_sink’ in element “rtpsession0”
0:00:00.118477584 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtcp_sink’
0:00:00.118497803 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘sync_src’
0:00:00.118520128 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘funnelpad1’
0:00:00.118531700 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpsession0:sync_src
0:00:00.118541536 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpssrcdemux0:rtcp_sink
0:00:00.118556562 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpsession0:sync_src and rtpssrcdemux0:rtcp_sink
0:00:00.118573282 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpsession0:sync_src and rtpssrcdemux0:rtcp_sink, successful
0:00:00.118583049 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118601915 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad funnel1:src
0:00:00.118616686 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link funnel1:src and rtpsession0:recv_rtcp_sink
0:00:00.118637361 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked funnel1:src and rtpsession0:recv_rtcp_sink, successful
0:00:00.118647919 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118679919 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link recv_rtcp_sink_0:proxypad1 and funnel1:funnelpad1
0:00:00.118699114 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked recv_rtcp_sink_0:proxypad1 and funnel1:funnelpad1, successful
0:00:00.118710351 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118728571 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtcp_sink_0’
0:00:00.118751583 194 0x559b3ece6ed0 INFO rtspsrc gstrtspsrc.c:3633:gst_rtspsrc_stream_configure_manager: configure bandwidth in session 0x7f6f0c03e060
0:00:00.118767619 194 0x559b3ece6ed0 INFO rtspsrc gstrtspsrc.c:3639:gst_rtspsrc_stream_configure_manager: setting AS: 5000000.000000
0:00:00.118809760 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad udpsrc1:src
0:00:00.118835820 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link udpsrc1:src and manager:recv_rtp_sink_0
0:00:00.118849307 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked udpsrc1:src and manager:recv_rtp_sink_0, successful
0:00:00.118858330 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118868443 194 0x559b3ece6ed0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:udpsrc1:src Received event on flushing pad. Discarding
0:00:00.118920295 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad udpsrc2:src
0:00:00.118933513 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link udpsrc2:src and manager:recv_rtcp_sink_0
0:00:00.118944970 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked udpsrc2:src and manager:recv_rtcp_sink_0, successful
0:00:00.118953239 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.118962590 194 0x559b3ece6ed0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:udpsrc2:src Received event on flushing pad. Discarding
0:00:00.119108058 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsink”
0:00:00.119245225 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x7f6f0c053010 adding pad ‘sink’
0:00:00.119774248 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “fakesrc”
0:00:00.119883532 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0x7f6f0c056100 adding pad ‘src’
0:00:00.119938249 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakesrc0:src to element udpsink0:sink
0:00:00.119954790 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakesrc0:src
0:00:00.119965149 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad udpsink0:sink
0:00:00.119976190 194 0x559b3ece6ed0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakesrc0 and udpsink0 in same bin, no need for ghost pads
0:00:00.119991110 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakesrc0:src and udpsink0:sink
0:00:00.120004326 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakesrc0:src and udpsink0:sink, successful
0:00:00.120010536 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.120019941 194 0x559b3ece6ed0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:fakesrc0:src Received event on flushing pad. Discarding
0:00:00.120144314 194 0x559b3ece6ed0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsink”
0:00:00.120166110 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x7f6f0c058df0 adding pad ‘sink’
0:00:00.120407416 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.120420799 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.120437800 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:00:00.120464091 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.120474762 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.120485745 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:00:00.120496027 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.120506973 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.120528679 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad udpsink1:sink
0:00:00.120542706 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘send_rtcp_src_0’ in element “manager”
0:00:00.120559150 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘send_rtcp_src’ in element “rtpsession0”
0:00:00.120583701 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘send_rtcp_src’
0:00:00.120632348 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpsession0:send_rtcp_src and send_rtcp_src_0:proxypad2
0:00:00.120652274 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpsession0:send_rtcp_src and send_rtcp_src_0:proxypad2, successful
0:00:00.120664233 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.120682112 194 0x559b3ece6ed0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘send_rtcp_src_0’
0:00:00.120699268 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link manager:send_rtcp_src_0 and udpsink1:sink
0:00:00.120711981 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked manager:send_rtcp_src_0 and udpsink1:sink, successful
0:00:00.120720918 194 0x559b3ece6ed0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
0:00:00.121131985 194 0x559b3e9d32c0 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.121223976 194 0x559b3e9d32c0 INFO bin gstbin.c:2783:gst_bin_do_latency_func: configured latency of 0:00:00.000000000
0:00:00.121308350 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending PAUSED, desired next PLAYING
0:00:00.121343116 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func: child ‘fakesink0’ is changing state asynchronously to PLAYING
0:00:00.121382054 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.121414760 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.121445768 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.121483663 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘tee0’ changed state to 4(PLAYING) successfully
0:00:00.121522058 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.121558256 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.121584241 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.121622871 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 4(PLAYING) successfully
0:00:00.121668089 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.121702822 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.121734561 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.121767671 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 4(PLAYING) successfully
0:00:00.121806485 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.121846659 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.121871751 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.121918013 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvvideoconvert0’ changed state to 4(PLAYING) successfully
0:00:00.121952388 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.121990097 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.122026421 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.122075151 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘nvv4l2decoder0’ changed state to 4(PLAYING) successfully
0:00:00.122124194 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.122156244 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.122189117 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.122238269 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘h264parse0’ changed state to 4(PLAYING) successfully
0:00:00.122287363 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.122319375 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.122353855 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.122394659 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘rtph264depay0’ changed state to 4(PLAYING) successfully
0:00:00.122509669 194 0x559b3ece6ed0 INFO task gsttask.c:316:gst_task_func: Task going to paused
0:00:00.122545061 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘udpsink1’ changed state to 4(PLAYING) successfully
0:00:00.122582579 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘udpsink0’ changed state to 4(PLAYING) successfully
0:00:00.122628450 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘manager’ changed state to 4(PLAYING) successfully
0:00:00.122660711 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘fakesrc0’ changed state to 4(PLAYING) successfully
0:00:00.122694093 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘udpsrc1’ changed state to 4(PLAYING) successfully
0:00:00.122727619 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘udpsrc2’ changed state to 4(PLAYING) successfully
0:00:00.122784917 194 0x559b3ece6ed0 INFO task gsttask.c:318:gst_task_func: Task resume from paused
0:00:00.122787310 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.122849842 194 0x559b3e9d32c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.122855898 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:00.122919799 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:00:00.122928094 194 0x559b3e9d32c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘rtspsrc0’ changed state to 4(PLAYING) successfully
0:00:00.122943798 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.123036831 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.123072629 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:00:00.123089364 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.123102912 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.123116205 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
New clock: GstSystemClock
0:00:00.123127675 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.123148977 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.123166451 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.123175638 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.123188879 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:00:00.123220587 194 0x559b3ece6ed0 INFO basesrc gstbasesrc.c:1358:gst_base_src_do_seek: seeking: bytes segment start=0, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1
0:00:00.123246313 194 0x559b3ece6ed0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x7f6f0c04ac60 on task 0x559b3ec1def0
0:00:00.123258165 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:fakesrc0:src created task 0x559b3ec1def0
0:00:00.123395939 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.123412040 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.123423460 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:00:00.123431619 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.123439632 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
Progress: (request) Sending PLAY request
0:00:00.123568032 194 0x7f6f0c0410a0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink’ in element “fakesrc0”
0:00:00.123651677 194 0x7f6f0c0410a0 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc0:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.123837647 194 0x7f6f0c0410a0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event bytes segment start=0, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1
0:00:00.123879333 194 0x7f6f0c0410a0 INFO basesrc gstbasesrc.c:2945:gst_base_src_loop: marking pending DISCONT
0:00:00.124138623 194 0x7f6f0c0410a0 INFO basesrc gstbasesrc.c:2839:gst_base_src_loop: pausing after gst_base_src_get_range() = eos
0:00:00.124177695 194 0x7f6f0c0410a0 INFO task gsttask.c:316:gst_task_func:fakesrc0:src Task going to paused
0:00:00.183896066 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.183918347 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.183934662 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.183981107 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘rtpssrcdemux0’ changed state to 4(PLAYING) successfully
0:00:00.183999198 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.184013735 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.184029044 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.184054831 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘rtpstorage0’ changed state to 4(PLAYING) successfully
0:00:00.184071495 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.184145934 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.184161145 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.184193227 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘rtpsession0’ changed state to 4(PLAYING) successfully
0:00:00.184218277 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.184240058 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.184256213 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.184282332 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘funnel0’ changed state to 4(PLAYING) successfully
0:00:00.184318160 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.184340444 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.184360960 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.184387443 194 0x559b3ece6ed0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘funnel1’ changed state to 4(PLAYING) successfully
0:00:00.184404927 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.184418983 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.184471553 194 0x559b3ece6ed0 INFO basesrc gstbasesrc.c:1358:gst_base_src_do_seek: seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.184506151 194 0x559b3ece6ed0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x559b3eceaab0 on task 0x7f6f0c044050
0:00:00.184526556 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:udpsrc1:src created task 0x7f6f0c044050
0:00:00.184645631 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.184667688 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.184695286 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:00:00.184711144 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.184734022 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.184771909 194 0x559b3ece6ed0 INFO basesrc gstbasesrc.c:1358:gst_base_src_do_seek: seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.184796821 194 0x559b3ece6ed0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x559b3ecead00 on task 0x7f6f0c044170
0:00:00.184808581 194 0x559b3ece6ed0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:udpsrc2:src created task 0x7f6f0c044170
0:00:00.184856123 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink’ in element “udpsrc1”
0:00:00.184907592 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.184946586 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.184984119 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:00:00.185007265 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.185029709 194 0x559b3ece6ed0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
Progress: (request) Sent PLAY request
0:00:00.185170048 194 0x7f6f0c040a80 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink’ in element “udpsrc2”
0:00:00.185209095 194 0x7f6f0c040b20 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z00AKp2oHgCJ+WbgICAoAAADAAgAAAMAxCA=,aO48gA==”, a-recvonly=(string)“”, x-dimensions=(string)“1920,1080”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)591639206, clock-base=(uint)937087438, seqnum-base=(uint)32769, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
0:00:00.185356184 194 0x7f6f0c040a80 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event application/x-rtcp
0:00:00.331965556 194 0x7f6f0c040b20 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.332014827 194 0x7f6f0c040b20 INFO basesrc gstbasesrc.c:2945:gst_base_src_loop: marking pending DISCONT
0:00:00.332562456 194 0x7f6f0c040b20 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z00AKp2oHgCJ+WbgICAoAAADAAgAAAMAxCA=,aO48gA==”, a-recvonly=(string)“”, x-dimensions=(string)“1920,1080”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)591639206, clock-base=(uint)937087438, seqnum-base=(uint)32769, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
0:00:00.332608849 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_591639206’
0:00:00.332636364 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘rtcp_src_591639206’
0:00:00.332675159 194 0x7f6f0c040b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpjitterbuffer”
0:00:00.333028745 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpJitterBuffer@0x7f6eec022b00 adding pad ‘src’
0:00:00.333057132 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpJitterBuffer@0x7f6eec022b00 adding pad ‘sink’
0:00:00.333089825 194 0x7f6f0c040b20 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpptdemux”
0:00:00.333247966 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpPtDemux@0x7f6eec025040 adding pad ‘sink’
0:00:00.333378620 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element rtpjitterbuffer0:src to element rtpptdemux0:sink
0:00:00.333404598 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpjitterbuffer0:src
0:00:00.333426483 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpptdemux0:sink
0:00:00.333448940 194 0x7f6f0c040b20 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: rtpjitterbuffer0 and rtpptdemux0 in same bin, no need for ghost pads
0:00:00.333480594 194 0x7f6f0c040b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpjitterbuffer0:src and rtpptdemux0:sink
0:00:00.333519712 194 0x7f6f0c040b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpjitterbuffer0:src and rtpptdemux0:sink, successful
0:00:00.333539498 194 0x7f6f0c040b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.333560350 194 0x7f6f0c040b20 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:rtpjitterbuffer0:src Received event on flushing pad. Discarding
0:00:00.333598552 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.333623154 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.333670425 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:00:00.333704007 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.333726343 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.333759085 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:00:00.333780793 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.333800996 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.333878466 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.333902293 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.333948455 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:00:00.334126309 194 0x7f6f0c040b20 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x7f6f0c04bc90 on task 0x7f6f0c044710
0:00:00.334152040 194 0x7f6f0c040b20 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:rtpjitterbuffer0:src created task 0x7f6f0c044710
0:00:00.334283800 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.334309031 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.334342521 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:00:00.334370754 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:00:00.334399836 194 0x7f6f0c040b20 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.334441063 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpssrcdemux0:src_591639206
0:00:00.334462935 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpjitterbuffer0:sink
0:00:00.334493139 194 0x7f6f0c040b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpssrcdemux0:src_591639206 and rtpjitterbuffer0:sink
0:00:00.334524642 194 0x7f6f0c040b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpssrcdemux0:src_591639206 and rtpjitterbuffer0:sink, successful
0:00:00.334543983 194 0x7f6f0c040b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.334595479 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpssrcdemux0:rtcp_src_591639206
0:00:00.334620528 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_rtcp’ in element “rtpjitterbuffer0”
0:00:00.334675819 194 0x7f6f0c040b20 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘sink_rtcp’
0:00:00.334708996 194 0x7f6f0c040b20 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpssrcdemux0:rtcp_src_591639206 and rtpjitterbuffer0:sink_rtcp
0:00:00.334733442 194 0x7f6f0c040b20 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpssrcdemux0:rtcp_src_591639206 and rtpjitterbuffer0:sink_rtcp, successful
0:00:00.334753080 194 0x7f6f0c040b20 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.334975547 194 0x7f6f0c040b20 INFO rtpjitterbuffer rtpjitterbuffer.c:778:rtp_jitter_buffer_calculate_pts: resync to time 0:00:00.211023192, rtptime 2:53:32.082644444
0:00:00.335176438 194 0x7f6eec002a30 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)420029, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z00AKp2oHgCJ+WbgICAoAAADAAgAAAMAxCA=,aO48gA==”, a-recvonly=(string)“”, x-dimensions=(string)“1920,1080”, a-Media_header=(string)“MEDIAINFO=494D4B48010300000400000100000000000000000000000000000000000000000000000000000000;”, a-appversion=(string)1.0, ssrc=(uint)591639206, clock-base=(uint)937087438, seqnum-base=(uint)32769, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
0:00:00.335245174 194 0x7f6eec002a30 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_96’
0:00:00.335337506 194 0x7f6eec002a30 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpptdemux0:src_96 and recv_rtp_src_0_591639206_96:proxypad3
0:00:00.335373057 194 0x7f6eec002a30 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpptdemux0:src_96 and recv_rtp_src_0_591639206_96:proxypad3, successful
0:00:00.335392302 194 0x7f6eec002a30 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.335460333 194 0x7f6eec002a30 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtp_src_0_591639206_96’
0:00:00.335561475 194 0x7f6eec002a30 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link manager:recv_rtp_src_0_591639206_96 and recv_rtp_src_0_591639206_96:proxypad4
0:00:00.335597411 194 0x7f6eec002a30 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked manager:recv_rtp_src_0_591639206_96 and recv_rtp_src_0_591639206_96:proxypad4, successful
0:00:00.335615985 194 0x7f6eec002a30 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.335683676 194 0x7f6eec002a30 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtp_src_0_591639206_96’
0:00:00.335724005 194 0x7f6eec002a30 INFO GST_PIPELINE grammar.y:524:gst_parse_found_pad: trying delayed linking one pad some pad of GstRTSPSrc named rtspsrc0 to some pad of GstRtpH264Depay named rtph264depay0
0:00:00.335752173 194 0x7f6eec002a30 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element rtspsrc0:(any) to element rtph264depay0:(any)
0:00:00.335792500 194 0x7f6eec002a30 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link rtspsrc0:recv_rtp_src_0_591639206_96 and rtph264depay0:sink
0:00:00.335855485 194 0x7f6eec002a30 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: rtspsrc0 and rtph264depay0 in same bin, no need for ghost pads
0:00:00.335889236 194 0x7f6eec002a30 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtspsrc0:recv_rtp_src_0_591639206_96 and rtph264depay0:sink
0:00:00.335943788 194 0x7f6eec002a30 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtspsrc0:recv_rtp_src_0_591639206_96 and rtph264depay0:sink, successful
0:00:00.335963764 194 0x7f6eec002a30 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.336082727 194 0x7f6eec002a30 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:00.338841145 194 0x7f6eec002a30 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h264, stream-format=(string)byte-stream, alignment=(string)au
0:00:00.341359065 194 0x7f6eec002a30 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:00.344253522 194 0x7f6eec002a30 INFO v4l2 gstv4l2object.c:3148:gst_v4l2_object_setup_pool:nvv4l2decoder0:sink accessing buffers via mode 2
0:00:00.344413251 194 0x7f6eec002a30 INFO v4l2bufferpool gstv4l2bufferpool.c:817:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:sink increasing minimum buffers to 2
0:00:00.344425189 194 0x7f6eec002a30 INFO v4l2bufferpool gstv4l2bufferpool.c:824:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:sink increasing minimum buffers to 4
0:00:00.344434408 194 0x7f6eec002a30 INFO v4l2bufferpool gstv4l2bufferpool.c:830:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:sink reducing maximum buffers to 32
0:00:00.344443492 194 0x7f6eec002a30 INFO v4l2bufferpool gstv4l2bufferpool.c:841:gst_v4l2_buffer_pool_set_config:nvv4l2decoder0:pool:sink can’t allocate, setting maximum to minimum
0:00:00.344505054 194 0x7f6eec002a30 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.211023192, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.211023192, position 0:00:00.211023192, duration 99:99:99.999999999
0:00:00.345549671 194 0x7f6eec002a30 INFO h264parse gsth264parse.c:1793:gst_h264_parse_update_src_caps: resolution changed 1920x1080
0:00:00.345579508 194 0x7f6eec002a30 INFO baseparse gstbaseparse.c:4004:gst_base_parse_set_latency: min/max latency 0:00:00.083333333, 0:00:00.083333333
0:00:00.345615395 194 0x7f6eec002a30 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, framerate=(fraction)12/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, level=(string)4.2
(gst-launch-1.0:194): GStreamer-CRITICAL **: 09:18:53.949: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
0:00:01.550224395 194 0x7f6f0c040ad0 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event application/x-rtcp
0:00:01.550351582 194 0x7f6f0c040ad0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:05:36.569072954 194 0x7f6f0c040b20 INFO rtpsource rtpsource.c:1155:update_receiver_stats: duplicate or reordered packet (seqnr 44053, expected 44055)
0:06:14.644721549 194 0x7f6f0c040b20 INFO rtpsource rtpsource.c:1155:update_receiver_stats: duplicate or reordered packet (seqnr 52019, expected 52022)
0:06:14.645135452 194 0x7f6f0c040b20 INFO rtpsource rtpsource.c:1155:update_receiver_stats: duplicate or reordered packet (seqnr 52020, expected 52022)
0:09:43.218595743 194 0x7f6f0c040b20 INFO rtpsource rtpsource.c:1155:update_receiver_stats: duplicate or reordered packet (seqnr 32807, expected 32809)
0:09:43.218757206 194 0x7f6f0c040b20 INFO rtpsource rtpsource.c:1155:update_receiver_stats: duplicate or reordered packet (seqnr 32811, expected 32813)
0:10:04.219984329 194 0x7f6f0c040b20 INFO rtpsource rtpsource.c:1155:update_receiver_stats: duplicate or reordered packet (seqnr 37591, expected 37594)
0:10:04.221003553 194 0x7f6f0c040b20 INFO rtpsource rtpsource.c:1155:update_receiver_stats: duplicate or reordered packet (seqnr 37603, expected 37605)
• DeepStream Version
• TensorRT Version
• Hardware Platform GPU
• DeepStream Version 5.0.0
• TensorRT Version 7.0
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0# deepstream-app --version-all
(gst-plugin-scanner:12): GStreamer-WARNING **: 07:54:03.752: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtrtserver.so: cannot open shared object file: No such file or directory
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 11.0
CUDA Runtime Version: 10.2
TensorRT Version: 7.0
cuDNN Version: 7.6
libNVWarp360 Version: 2.0.1d3
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0# nvidia-smi
Thu May 26 07:56:06 2022
| NVIDIA-SMI 450.156.00 Driver Version: 450.156.00 CUDA Version: 11.0 |
| 0 Tesla T4 A piece of T4 GPU
I encountered an error executing the following command
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0# gst-launch-1.0 rtspsrc location=rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream latency=200 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw, format=(string)BGRx ! videoconvert ! fakesink sync=false
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
(gst-launch-1.0:31): GStreamer-CRITICAL **: 05:24:58.650: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:03.065412691
Setting pipeline to READY …
^C
However, changing the decoder command does not report an error,I believe nvV4L2Decoder is the source of the problem
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0# gst-launch-1.0 rtspsrc location=rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream latency=200 ! rtph264depay ! h264parse ! avdec_h264 ! nvvideoconvert ! video/x-raw, format=(string)BGRx ! videoconvert ! fakesink sync=false
Redistribute latency…
Execution ended after 0:00:34.124400984
Setting pipeline to NULL …
Freeing pipeline …
I use a docker
NVIDIA NGC Catalog
DeepStream | NVIDIA NGC
DeepStream SDK delivers a complete streaming analytics toolkit for AI based video and image understanding and multi-sensor processing. This container is for data center GPUs such as NVIDIA T4 running on x86 platform.
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-5.0 nvcr.io/nvidia/deepstream:5.0.1-20.09-devel
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-5.0# gst-launch-1.0 --version
gst-launch-1.0 version 1.14.5
GStreamer 1.14.5
But there is no problem with the following docker
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.1 nvcr.io/nvidia/deepstream:6.1-devel
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-6.1# gst-launch-1.0 rtspsrc location=rtsp://admin:1234qwer@10.0.7.127:554/h264/ch1/main/av_stream latency=200 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw, format=(string)BGRx ! videoconvert ! fakesink sync=false
root@ht-2288H-V5:/opt/nvidia/deepstream/deepstream-6.1# gst-launch-1.0 --version
gst-launch-1.0 version 1.16.2
GStreamer 1.16.2
ht@ht-2288H-V5:~$ docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-5.0 nvcr.io/nvidia/deepstream:5.0.1-20.09-devel
(gst-launch-1.0:18): GStreamer-CRITICAL **: 07:59:23.803: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
Execution ended after 0:00:02.554460508
^C
Please use latest versin 6.1
[/quote]
So is this a 5.0 bug that only works if 6.1 is installed? Can you help me explain? Thank you very much!
Yes, it’s a bug in version 5.0
