$ gst-launch-1.0 --gst-debug=v4l2videodec:5 rtspsrc location=rtsp://admin:admin@192.168.1.168/0 protocol=4 ! rtph265depay ! nvv4l2decoder ! fakesink
0:00:00.077213693 10930 0x5592266980 DEBUG v4l2videodec gstv4l2videodec.c:1728:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps image/jpeg, width=(in$)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-h264, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(f$action)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/x-h265, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=($raction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(f$action)[ 0/1, 2147483647/1 ], mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framera$e=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)[ 1, 2 ], systemstream=(boolean)false, parsed=(boolean)true; video/x-divx, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], divxversion=(int)[ 4, 5 ]; video/x-vp8, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-vp9, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.077507709 10930 0x5592266980 DEBUG v4l2videodec gstv4l2videodec.c:1728:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps image/jpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-h264, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/x-h265, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)[ 1, 2 ], systemstream=(boolean)false, parsed=(boolean)true; video/x-divx, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], divxversion=(int)[ 4, 5 ]; video/x-vp8, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-vp9, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.077614794 10930 0x5592266980 DEBUG v4l2videodec gstv4l2videodec.c:1704:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.077671514 10930 0x5592266980 DEBUG v4l2videodec gstv4l2videodec.c:1704:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
Setting pipeline to PAUSED ...
0:00:00.077812559 10930 0x5592266980 DEBUG v4l2videodec gstv4l2videodec.c:555:gst_v4l2_video_dec_open:<nvv4l2decoder0> Opening
Opening in BLOCKING MODE
0:00:00.121296242 10930 0x5592266980 DEBUG v4l2videodec gstv4l2videodec.c:637:gst_v4l2_video_dec_start:<nvv4l2decoder0> Starting
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:admin@192.168.1.168/0
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
WARNING: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not read from resource.
Additional debug info:
gstrtspsrc.c(5427): gst_rtspsrc_reconnect (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
Could not receive any UDP packets for 5,0000 seconds, maybe your firewall is blocking it. Retrying using a tcp connection.
0:00:07.907896309 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1728:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h265, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:07.908881796 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1728:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h265, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:07.909283210 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:694:gst_v4l2_video_dec_set_format:<nvv4l2decoder0> Setting format: video/x-h265, stream-format=(string)byte-stream, alignment=(string)au
NvMMLiteOpen : Block : BlockType = 279
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 279
0:00:07.922237672 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 0
0:00:07.922279600 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1377:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Sending header
0:00:08.027147042 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1470:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Acquired caps: video/x-raw, format=(string)NV12, width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt601, framerate=(fraction)0/1
0:00:08.028125758 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1477:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Available caps: video/x-raw, format=(string)NV12, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-raw, format=(string)Y42B, width=(int)[ 48, 4096 ], height=(int)[ 48, 4096 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:08.028702280 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1485:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Filtered caps: video/x-raw, format=(string)NV12, width=(int)2560, height=(int)1440, framerate=(fraction)0/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt601; video/x-raw, format=(string)Y42B, width=(int)2560, height=(int)1440, framerate=(fraction)0/1, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt601
0:00:08.029432033 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1502:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Possible decoded caps: video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:08.030321112 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1511:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Chosen decoded caps: video/x-raw(memory:NVMM), width=(int)1, height=(int)1, framerate=(fraction)0/1
0:00:08.032927515 10930 0x7fa8054e30 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:08.036384768 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1564:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Starting decoding thread
0:00:08.037816149 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 1
0:00:08.038256522 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 2
0:00:08.038867992 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 3
0:00:08.039174143 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 4
0:00:08.039596235 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 5
0:00:08.039955929 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 6
0:00:08.040390104 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 7
0:00:08.040810893 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 8
0:00:08.041212202 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 9
0:00:08.052907370 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 10
0:00:08.066945916 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 11
0:00:08.075426492 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 12
0:00:08.084653905 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 13
0:00:08.094668052 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 14
0:00:08.105002569 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 15
0:00:08.114819525 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 16
0:00:08.119546801 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 17
0:00:08.123688858 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 18
0:00:08.128192172 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 19
0:00:08.138238299 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 20
0:00:08.138971229 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 21
0:00:08.140937985 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 22
0:00:08.145290150 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 23
0:00:08.149915602 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 24
0:00:08.154370165 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 25
0:00:08.158946240 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 26
0:00:08.163330646 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 27
0:00:08.168129382 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 28
0:00:08.172900878 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 29
0:00:08.177273200 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 30
0:00:08.183006537 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 31
0:00:08.187338754 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 32
0:00:08.192276659 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 33
0:00:08.196266213 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 34
0:00:08.200905051 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 35
0:00:08.205045493 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 36
0:00:08.209305365 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 37
0:00:08.213605810 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 38
0:00:08.218243658 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 39
0:00:08.227737691 10930 0x7fa8054e30 DEBUG v4l2videodec gstv4l2videodec.c:1337:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 40
