Tried it Getting following error, printing with logs. Have modified the original rtsp URL for privacy
gst-launch-1.0 --gst-debug=rtspsrc:5 rtspsrc location=“rtsp://auth:auth@ip:add:dest:ser/H264?ch=3&subtype=0” ! decodebin ! fakesink
0:00:00.074940467 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:8617:gst_rtspsrc_uri_set_uri: parsing URI
0:00:00.075003333 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:8624:gst_rtspsrc_uri_set_uri: configuring URI
0:00:00.075029896 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:8640:gst_rtspsrc_uri_set_uri: set uri: rtsp://auth:auth@ip:add:dest:ser/H264?ch=3&subtype=0
0:00:00.075046980 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:8642:gst_rtspsrc_uri_set_uri: request uri is: rtsp://ip:add:dest:ser/H264?ch=3&subtype=0
Setting pipeline to PAUSED …
0:00:00.078515274 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:8391:gst_rtspsrc_start: starting
0:00:00.078748247 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd OPEN
0:00:00.078774706 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5598:gst_rtspsrc_loop_send_cmd: not interrupting busy cmd unknown
Pipeline is live and does not need PREROLL …
0:00:00.079042731 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command OPEN
0:00:00.079079763 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:00.079112316 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4614:gst_rtsp_conninfo_connect: creating connection (rtsp://auth:auth@ip:add:dest:ser/H264?ch=3&subtype=0)…
Progress: (open) Opening Stream
0:00:00.079444614 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4625:gst_rtsp_conninfo_connect: sanitized uri rtsp://ip:add:dest:ser/H264?ch=3&subtype=0
0:00:00.079496594 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4659:gst_rtsp_conninfo_connect: connecting (rtsp://auth:auth@ip:add:dest:ser/H264?ch=3&subtype=0)…
Progress: (connect) Connecting to rtsp://auth:auth@ip:add:dest:ser/H264?ch=3&subtype=0
0:00:00.155243951 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7342:gst_rtspsrc_retrieve_sdp: create options… (async)
0:00:00.155283483 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7351:gst_rtspsrc_retrieve_sdp: send options…
0:00:00.155353641 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.155379162 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.155393329 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
Progress: (open) Retrieving server options
0:00:00.162356011 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:00.162394450 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:00.162416429 12309 0x5586f78940 INFO rtspsrc gstrtspsrc.c:7364:gst_rtspsrc_retrieve_sdp: Now using version: 1.0
0:00:00.162440805 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7371:gst_rtspsrc_retrieve_sdp: create describe…
0:00:00.162461118 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7388:gst_rtspsrc_retrieve_sdp: send describe…
0:00:00.162516223 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.162537109 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.162550755 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
Progress: (open) Retrieving media info
0:00:00.168671546 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:00.168732850 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 401
0:00:00.168768111 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5785:gst_rtspsrc_setup_auth: Attempting authentication using credentials from the URL
0:00:00.168793007 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5814:gst_rtspsrc_setup_auth: Attempting Digest authentication
0:00:00.168820247 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.168839675 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.168856029 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
0:00:01.660526429 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:01.660821591 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:01.660958156 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7446:gst_rtspsrc_retrieve_sdp: parse SDP…
0:00:01.661423894 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7077:gst_rtspsrc_parse_range: parsed range npt=0-
0:00:01.661830360 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7088:gst_rtspsrc_parse_range: range: type 0, min 0.000000 - type 2, max 0.000000
0:00:01.661912966 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7098:gst_rtspsrc_parse_range: range: min 0:00:00.000000000
0:00:01.661973592 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7113:gst_rtspsrc_parse_range: range: max 99:99:99.999999999
0:00:01.662280212 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1782:gst_rtspsrc_collect_payloads: mapping sdp session level attributes to caps
0:00:01.662378287 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1784:gst_rtspsrc_collect_payloads: mapping sdp media level attributes to caps
0:00:01.662480268 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1802:gst_rtspsrc_collect_payloads: looking at 0 pt: 96
0:00:01.662755377 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1941:gst_rtspsrc_create_stream: stream 0, (0x7fa004b930)
0:00:01.662851317 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1942:gst_rtspsrc_create_stream: port: 0
0:00:01.662921995 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1943:gst_rtspsrc_create_stream: container: 0
0:00:01.663009809 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1944:gst_rtspsrc_create_stream: control: trackID=1
0:00:01.663119499 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1979:gst_rtspsrc_create_stream: setup: rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=1
0:00:01.663266949 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1782:gst_rtspsrc_collect_payloads: mapping sdp session level attributes to caps
0:00:01.663357055 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1784:gst_rtspsrc_collect_payloads: mapping sdp media level attributes to caps
0:00:01.663458203 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1802:gst_rtspsrc_collect_payloads: looking at 0 pt: 8
0:00:01.663639092 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1941:gst_rtspsrc_create_stream: stream 1, (0x7fa004d540)
0:00:01.663773990 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1942:gst_rtspsrc_create_stream: port: 0
0:00:01.663862481 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1943:gst_rtspsrc_create_stream: container: 0
0:00:01.663950816 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1944:gst_rtspsrc_create_stream: control: trackID=2
0:00:01.664047641 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1979:gst_rtspsrc_create_stream: setup: rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=2
0:00:01.664183529 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:455:default_select_stream: default handler
0:00:01.664281760 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:466:select_stream_accum: accum 1
0:00:01.664354053 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:455:default_select_stream: default handler
0:00:01.664466868 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6798:gst_rtspsrc_setup_streams_start: doing setup of stream 0x7fa004b930 with rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=1
0:00:01.664573432 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6813:gst_rtspsrc_setup_streams_start: protocols = 0x7, protocol mask = 0x1
0:00:01.664667340 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6281:gst_rtspsrc_create_transports_string: got transports (NULL)
0:00:01.664764582 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6311:gst_rtspsrc_create_transports_string: adding UDP unicast
0:00:01.664860417 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6338:gst_rtspsrc_create_transports_string: prepared transports RTP/AVP;unicast;client_port=%%u1-%%u2
0:00:01.664932970 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6828:gst_rtspsrc_setup_streams_start: replace ports in RTP/AVP;unicast;client_port=%%u1-%%u2
0:00:01.669425711 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2167:gst_rtspsrc_alloc_udp_ports: got RTP port 57789
0:00:01.669513160 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2175:gst_rtspsrc_alloc_udp_ports: RTP port not even
0:00:01.669554880 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2177:gst_rtspsrc_alloc_udp_ports: free RTP udpsrc
0:00:01.669835823 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2182:gst_rtspsrc_alloc_udp_ports: retry 1
0:00:01.670971104 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2167:gst_rtspsrc_alloc_udp_ports: got RTP port 57790
0:00:01.671757838 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2199:gst_rtspsrc_alloc_udp_ports: starting RTCP on port 57791
0:00:01.672001436 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6839:gst_rtspsrc_setup_streams_start: transport is now RTP/AVP;unicast;client_port=57790-57791
0:00:01.672134876 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:01.672180710 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:01.672219253 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
Progress: (request) SETUP stream 0
0:00:01.681694639 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:01.681764588 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:01.681844537 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6555:gst_rtsp_src_setup_stream_from_response: stream 0x7fa004b930 as UDP unicast
0:00:01.681920632 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4248:gst_rtspsrc_stream_configure_transport: configuring transport for stream 0x7fa004b930
0:00:01.681954748 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4257:gst_rtspsrc_stream_configure_transport: setting media type to application/x-rtp
0:00:01.682016103 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3491:gst_rtspsrc_stream_configure_manager: using manager rtpbin
0:00:01.684605631 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3202:set_manager_buffer_mode: auto buffering mode, have clock (NULL)
0:00:01.684657350 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3222:set_manager_buffer_mode: auto buffering mode
0:00:01.684675580 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3227:set_manager_buffer_mode: selected slave
0:00:01.684706362 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3590:gst_rtspsrc_stream_configure_manager: connect to signals on session manager, stream 0x7fa004b930
0:00:01.689726924 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 0, stream 0x7fa004b930, 0
0:00:01.689956825 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtp_sink_0
0:00:01.689986044 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:01.690187923 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 0, stream 0x7fa004b930, 0
0:00:01.690362718 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtcp_sink_0
0:00:01.690390010 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:01.690422615 12309 0x5586f78940 INFO rtspsrc gstrtspsrc.c:3633:gst_rtspsrc_stream_configure_manager: configure bandwidth in session 0x7fa00660f0
0:00:01.690448605 12309 0x5586f78940 INFO rtspsrc gstrtspsrc.c:3639:gst_rtspsrc_stream_configure_manager: setting AS: 8192000.000000
0:00:01.690535013 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3981:gst_rtspsrc_stream_configure_udp: setting up UDP source
0:00:01.690601785 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4007:gst_rtspsrc_stream_configure_udp: connecting UDP source 0 to manager
0:00:01.690676630 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4038:gst_rtspsrc_stream_configure_udp: connecting UDP source 1 to manager
0:00:01.690718141 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4082:gst_rtspsrc_stream_configure_udp_sinks: configure RTP UDP sink for ip:add:dest:ser:6970
0:00:01.692593176 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4105:gst_rtspsrc_stream_configure_udp_sinks: RTP UDP src has sock 0x7fa0021520
0:00:01.692911620 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4147:gst_rtspsrc_stream_configure_udp_sinks: configure RTCP UDP sink for ip:add:dest:ser:6971
0:00:01.694341334 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4171:gst_rtspsrc_stream_configure_udp_sinks: RTCP UDP src has sock 0x7fa00213d0
0:00:01.694580245 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3294:request_rtcp_encoder: decoder session 0, stream 0x7fa004b930, 0
0:00:01.694741706 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:send_rtcp_src_0
0:00:01.694769831 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:01.694843531 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:455:default_select_stream: default handler
0:00:01.694868792 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:466:select_stream_accum: accum 1
0:00:01.694888584 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:455:default_select_stream: default handler
0:00:01.694913376 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6798:gst_rtspsrc_setup_streams_start: doing setup of stream 0x7fa004d540 with rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=2
0:00:01.694935824 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6813:gst_rtspsrc_setup_streams_start: protocols = 0x1, protocol mask = 0x1
0:00:01.694956189 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6281:gst_rtspsrc_create_transports_string: got transports (NULL)
0:00:01.694975564 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6311:gst_rtspsrc_create_transports_string: adding UDP unicast
0:00:01.694995304 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6338:gst_rtspsrc_create_transports_string: prepared transports RTP/AVP;unicast;client_port=%%u1-%%u2
0:00:01.695014471 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6828:gst_rtspsrc_setup_streams_start: replace ports in RTP/AVP;unicast;client_port=%%u1-%%u2
0:00:01.695969646 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2167:gst_rtspsrc_alloc_udp_ports: got RTP port 41783
0:00:01.696001625 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2175:gst_rtspsrc_alloc_udp_ports: RTP port not even
0:00:01.696019178 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2177:gst_rtspsrc_alloc_udp_ports: free RTP udpsrc
0:00:01.696098554 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2182:gst_rtspsrc_alloc_udp_ports: retry 1
0:00:01.696724504 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2167:gst_rtspsrc_alloc_udp_ports: got RTP port 41784
0:00:01.697343005 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2199:gst_rtspsrc_alloc_udp_ports: starting RTCP on port 41785
0:00:01.697527279 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6839:gst_rtspsrc_setup_streams_start: transport is now RTP/AVP;unicast;client_port=41784-41785
0:00:01.697666240 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:01.697701605 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:01.697748689 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
Progress: (request) SETUP stream 1
0:00:01.707576894 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:01.707622781 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:01.707670073 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:6555:gst_rtsp_src_setup_stream_from_response: stream 0x7fa004d540 as UDP unicast
0:00:01.707732210 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4248:gst_rtspsrc_stream_configure_transport: configuring transport for stream 0x7fa004d540
0:00:01.707751377 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4257:gst_rtspsrc_stream_configure_transport: setting media type to application/x-rtp
0:00:01.707775127 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3491:gst_rtspsrc_stream_configure_manager: using manager rtpbin
0:00:01.708930930 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 1, stream 0x7fa004b930, 0
0:00:01.708963847 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 1, stream 0x7fa004d540, 1
0:00:01.709132549 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtp_sink_1
0:00:01.709160205 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:01.709380314 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 1, stream 0x7fa004b930, 0
0:00:01.709409793 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 1, stream 0x7fa004d540, 1
0:00:01.709570994 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtcp_sink_1
0:00:01.709596880 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:01.709695528 12309 0x5586f78940 INFO rtspsrc gstrtspsrc.c:3633:gst_rtspsrc_stream_configure_manager: configure bandwidth in session 0x7fa0066420
0:00:01.709728445 12309 0x5586f78940 INFO rtspsrc gstrtspsrc.c:3639:gst_rtspsrc_stream_configure_manager: setting AS: 8192000.000000
0:00:01.709804905 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3981:gst_rtspsrc_stream_configure_udp: setting up UDP source
0:00:01.709855166 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4007:gst_rtspsrc_stream_configure_udp: connecting UDP source 0 to manager
0:00:01.709929543 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4038:gst_rtspsrc_stream_configure_udp: connecting UDP source 1 to manager
0:00:01.710081577 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4082:gst_rtspsrc_stream_configure_udp_sinks: configure RTP UDP sink for ip:add:dest:ser:6972
0:00:01.711443529 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4105:gst_rtspsrc_stream_configure_udp_sinks: RTP UDP src has sock 0x7fa00217c0
0:00:01.711649679 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4147:gst_rtspsrc_stream_configure_udp_sinks: configure RTCP UDP sink for ip:add:dest:ser:6973
0:00:01.712806315 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4171:gst_rtspsrc_stream_configure_udp_sinks: RTCP UDP src has sock 0x7fa0021910
0:00:01.713033195 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3294:request_rtcp_encoder: decoder session 1, stream 0x7fa004b930, 0
0:00:01.713068039 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3294:request_rtcp_encoder: decoder session 1, stream 0x7fa004d540, 1
0:00:01.713191583 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:send_rtcp_src_1
0:00:01.713224136 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:01.713327888 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command LOOP
0:00:01.713351430 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:01.713379659 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
0:00:01.713642789 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:3202:set_manager_buffer_mode: auto buffering mode, have clock (NULL)
0:00:01.713687217 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:3222:set_manager_buffer_mode: auto buffering mode
0:00:01.713705759 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:3227:set_manager_buffer_mode: selected slave
0:00:01.713743260 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd WAIT
0:00:01.713765135 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5585:gst_rtspsrc_loop_send_cmd: cancel previous request LOOP
0:00:01.713784823 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd: connection flush busy LOOP
0:00:01.713807011 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 1
0:00:01.713826543 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:4751:gst_rtspsrc_connection_flush: connection flush
0:00:01.713896179 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5337:gst_rtspsrc_loop_udp: got interrupted
0:00:01.713920034 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5636:gst_rtspsrc_loop: pausing task, reason flushing
0:00:01.713940347 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd WAIT
0:00:01.713961858 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd: connection flush busy LOOP
0:00:01.713982066 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 1
0:00:01.714139049 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd PLAY
0:00:01.714169257 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5598:gst_rtspsrc_loop_send_cmd: not interrupting busy cmd WAIT
New clock: GstSystemClock
Progress: (request) Sending PLAY request
0:00:01.714511816 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command PLAY
0:00:01.714533952 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:01.714551400 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4751:gst_rtspsrc_connection_flush: connection flush
0:00:01.714580307 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7886:gst_rtspsrc_play: PLAY…
0:00:01.714601661 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4364:gst_rtspsrc_send_dummy_packets: sending dummy packet to stream 0x7fa004b930
0:00:01.714984585 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4364:gst_rtspsrc_send_dummy_packets: sending dummy packet to stream 0x7fa004d540
0:00:01.715734443 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:01.715770173 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:01.715835278 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
0:00:01.726331569 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:01.726380059 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:01.726416049 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7077:gst_rtspsrc_parse_range: parsed range npt=now-
0:00:01.726448758 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7088:gst_rtspsrc_parse_range: range: type 1, min 0.000000 - type 2, max 0.000000
0:00:01.726475530 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7098:gst_rtspsrc_parse_range: range: min 0:00:00.000000000
0:00:01.726506885 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7113:gst_rtspsrc_parse_range: range: max 99:99:99.999999999
0:00:01.726536260 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7701:gst_rtspsrc_parse_rtpinfo: parsing RTP-Info url=rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=1;seq=4690;rtptime=308619691
0:00:01.726561886 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7710:gst_rtspsrc_parse_rtpinfo: parsing info url=rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=1;seq=4690;rtptime=308619691
0:00:01.726590219 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field url=rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=1
0:00:01.726628241 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field seq=4690
0:00:01.726653450 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field rtptime=308619691
0:00:01.726682461 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7742:gst_rtspsrc_parse_rtpinfo: found stream 0x7fa004b930, setting: seqbase 4690, timebase 308619691
0:00:01.726705482 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7701:gst_rtspsrc_parse_rtpinfo: parsing RTP-Info url=rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=2;seq=3400;rtptime=3907380471
0:00:01.726727826 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7710:gst_rtspsrc_parse_rtpinfo: parsing info url=rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=2;seq=3400;rtptime=3907380471
0:00:01.726756993 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field url=rtsp://ip:add:dest:ser/H264?ch=3&subtype=0/trackID=2
0:00:01.726783192 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field seq=3400
0:00:01.726805848 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field rtptime=3907380471
0:00:01.726830953 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7742:gst_rtspsrc_parse_rtpinfo: found stream 0x7fa004d540, setting: seqbase 3400, timebase 3907380471
0:00:01.726851839 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4442:gst_rtspsrc_configure_caps: configuring stream caps
0:00:01.726976008 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4480:gst_rtspsrc_configure_caps: stream 0x7fa004b930, pt 96, caps application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4D4028, sprop-parameter-sets=(string)“Z01AKJWgHgCJ+WbAQA==,aO48gA==”, a-framerate=(string)0S, clock-base=(uint)308619691, seqnum-base=(uint)4690, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
0:00:01.727122990 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4480:gst_rtspsrc_configure_caps: stream 0x7fa004d540, pt 8, caps application/x-rtp, media=(string)audio, payload=(int)8, clock-rate=(int)8000, a-framerate=(string)0S, clock-base=(uint)3907380471, seqnum-base=(uint)3400, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
0:00:01.727172522 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4490:gst_rtspsrc_configure_caps: clear session
0:00:01.728431816 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:8071:gst_rtspsrc_play: mark DISCONT, we did a seek to another position
0:00:01.728509474 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command LOOP
0:00:01.728539162 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:01.728580517 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
Progress: (request) Sent PLAY request
0:00:06.734466186 12309 0x7fa0068e30 DEBUG rtspsrc gstrtspsrc.c:8271:gst_rtspsrc_handle_message: timeout on UDP port
0:00:06.735019113 12309 0x7fa0068e30 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd RECONNECT
0:00:06.735253492 12309 0x7fa0068e30 DEBUG rtspsrc gstrtspsrc.c:5585:gst_rtspsrc_loop_send_cmd: cancel previous request LOOP
0:00:06.735579696 12309 0x7fa0068e30 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd: connection flush busy LOOP
0:00:06.735897150 12309 0x7fa0068e30 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 1
0:00:06.736269865 12309 0x7fa0068e30 DEBUG rtspsrc gstrtspsrc.c:4751:gst_rtspsrc_connection_flush: connection flush
0:00:06.737201758 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5337:gst_rtspsrc_loop_udp: got interrupted
0:00:06.737423116 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5636:gst_rtspsrc_loop: pausing task, reason flushing
0:00:06.738502355 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd WAIT
0:00:06.738256257 12309 0x7fa0068c50 DEBUG rtspsrc gstrtspsrc.c:8271:gst_rtspsrc_handle_message: timeout on UDP port
0:00:06.738843559 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5572:gst_rtspsrc_loop_send_cmd: ignore, we were reconnecting
0:00:06.739816911 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd: connection flush busy LOOP
0:00:06.740143636 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 1
0:00:06.740379265 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command RECONNECT
0:00:06.740492184 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:06.740593124 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4751:gst_rtspsrc_connection_flush: connection flush
0:00:06.740844222 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5398:gst_rtspsrc_reconnect: doing reconnect
0:00:06.741078653 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7569:gst_rtspsrc_close: TEARDOWN…
0:00:06.748916769 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:06.749146148 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:06.749313964 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
0:00:06.827146620 12309 0x5586f78940 WARN rtspsrc gstrtspsrc.c:5978:gst_rtspsrc_try_send: server closed connection
0:00:06.827248341 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4736:gst_rtsp_conninfo_reconnect: reconnecting connection…
0:00:06.827269956 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4715:gst_rtsp_conninfo_close: closing connection…
0:00:06.827437407 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4659:gst_rtsp_conninfo_connect: connecting (rtsp://auth:auth@ip:add:dest:ser/H264?ch=3&subtype=0)…
0:00:06.835240470 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:06.835329638 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:06.835373805 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
0:00:06.841733664 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:06.841783926 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 454
0:00:06.841827364 12309 0x5586f78940 WARN rtspsrc gstrtspsrc.c:6161:gst_rtspsrc_send: error: Unhandled error
0:00:06.841848406 12309 0x5586f78940 WARN rtspsrc gstrtspsrc.c:6161:gst_rtspsrc_send: error: Session Not Found (454)
0:00:06.841970700 12309 0x5586f78940 WARN rtspsrc gstrtspsrc.c:7671:gst_rtspsrc_close: error: Could not send message. (Generic error)
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Unhandled error
Additional debug info:
gstrtspsrc.c(6161): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
Execution ended after 0:00:05.127905090
0:00:06.842201590 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd WAIT
0:00:06.842224611 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5585:gst_rtspsrc_loop_send_cmd: cancel previous request LOOP
0:00:06.842243205 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5598:gst_rtspsrc_loop_send_cmd: not interrupting busy cmd RECONNECT
0:00:06.842344249 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd PAUSE
0:00:06.842365343 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5598:gst_rtspsrc_loop_send_cmd: not interrupting busy cmd RECONNECT
Setting pipeline to READY …
0:00:06.842645921 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd CLOSE
0:00:06.842671025 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5585:gst_rtspsrc_loop_send_cmd: cancel previous request PAUSE
0:00:06.842699307 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd: connection flush busy RECONNECT
0:00:06.842720037 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 1
0:00:06.842737433 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:4751:gst_rtspsrc_connection_flush: connection flush
Setting pipeline to NULL …
0:00:06.842939572 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:8422:gst_rtspsrc_stop: stopping
0:00:06.842962333 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd WAIT
0:00:06.842981865 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5579:gst_rtspsrc_loop_send_cmd: ignore, we were closing
0:00:06.843000094 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd: connection flush busy RECONNECT
0:00:06.843018636 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 1
0:00:06.842050597 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:7637:gst_rtspsrc_close: closing connection…
0:00:06.843561667 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4715:gst_rtsp_conninfo_close: closing connection…
0:00:06.843674690 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:4721:gst_rtsp_conninfo_close: freeing connection…
0:00:06.843729899 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:2058:gst_rtspsrc_cleanup: cleanup
0:00:06.843761150 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1994:gst_rtspsrc_stream_free: free stream 0x7fa004b930
0:00:06.847586065 12309 0x5586f78940 DEBUG rtspsrc gstrtspsrc.c:1994:gst_rtspsrc_stream_free: free stream 0x7fa004d540
0:00:06.848814318 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:7569:gst_rtspsrc_close: TEARDOWN…
0:00:06.848857131 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:7574:gst_rtspsrc_close: not ready, doing cleanup
0:00:06.848875933 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:7637:gst_rtspsrc_close: closing connection…
0:00:06.848894632 12309 0x5586f52210 DEBUG rtspsrc gstrtspsrc.c:2058:gst_rtspsrc_cleanup: cleanup
Freeing pipeline …
