Use deepstream cannot parse rtsp
• Hardware Platform (GPU)
• DeepStream Version 5.1
• TensorRT Version 7.2
• Issue Type( questions)
I use deepstream-app sample to run my rtsp video,but failed.
this is my commond
`/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-app$ ./deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
Runtime commands:
h: Print this help
q: Quit
    p: Pause
    r: Resume
** INFO: <bus_callback:181>: Pipeline ready
ERROR from src_elem0: Unhandled error
Debug info: gstrtspsrc.c(6161): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Session Not Found (454)
ERROR from src_elem0: Could not write to resource.
Debug info: gstrtspsrc.c(8115): gst_rtspsrc_play (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Could not send message. (Generic error)
** INFO: <reset_source_pipeline:1433>: Resetting source 0
WARNING from src_elem0: Could not read from resource.
Debug info: gstrtspsrc.c(5280): gst_rtspsrc_loop_udp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
The server closed the connection.
ERROR from src_elem0: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(5348): gst_rtspsrc_loop_udp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Could not connect to server. (Generic error)
ERROR from src_elem0: Internal data stream error.
Debug info: gstrtspsrc.c(5653): gst_rtspsrc_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
streaming stopped, reason error (-5)
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)`
and i use follow commond to debug,dubug message :
za@za:~app$ gst-launch-1.0 -e --gst-debug=rtspsrc:5 rtspsrc location=rtsp://XXXX/rtp/XXX ! decodebin ! fakesink
0:00:00.008153416 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:8617:gst_rtspsrc_uri_set_uri: parsing URI
0:00:00.008164550 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:8624:gst_rtspsrc_uri_set_uri: configuring URI
0:00:00.008168727 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:8640:gst_rtspsrc_uri_set_uri: set uri: rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688
0:00:00.008171094 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:8642:gst_rtspsrc_uri_set_uri: request uri is: rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688
设置暂停管道 …
0:00:00.008652551 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:8391:gst_rtspsrc_start: starting
0:00:00.008678305 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd OPEN
0:00:00.008681888 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:5598:gst_rtspsrc_loop_send_cmd: not interrupting busy cmd unknown
管道正在使用且不需要 PREROLL …
进度:(open)Opening Stream
0:00:00.008796865 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command OPEN
0:00:00.008907448 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:00.008987111 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4614:gst_rtsp_conninfo_connect: creating connection (rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688)…
0:00:00.009140690 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4625:gst_rtsp_conninfo_connect: sanitized uri rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688
0:00:00.009154220 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4659:gst_rtsp_conninfo_connect: connecting (rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688)…
进度:(connect)Connecting to rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688
0:00:00.012891805 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7342:gst_rtspsrc_retrieve_sdp: create options… (async)
0:00:00.012899420 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7351:gst_rtspsrc_retrieve_sdp: send options…
0:00:00.012911717 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.012914917 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.012916938 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
进度:(open)Retrieving server options
0:00:00.013897666 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:00.013902512 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:00.013907444 13824 0x55f64f09ad40 INFO rtspsrc gstrtspsrc.c:7364:gst_rtspsrc_retrieve_sdp: Now using version: 1.0
0:00:00.013911889 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7371:gst_rtspsrc_retrieve_sdp: create describe…
0:00:00.013914733 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7388:gst_rtspsrc_retrieve_sdp: send describe…
0:00:00.013922672 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.013925397 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.013927751 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
进度:(open)Retrieving media info
0:00:00.017831695 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:00.017839254 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:00.017843051 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7446:gst_rtspsrc_retrieve_sdp: parse SDP…
0:00:00.017858882 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7077:gst_rtspsrc_parse_range: parsed range npt=now-
0:00:00.017865419 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7088:gst_rtspsrc_parse_range: range: type 1, min 0.000000 - type 2, max 0.000000
0:00:00.017868416 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7098:gst_rtspsrc_parse_range: range: min 0:00:00.000000000
0:00:00.017873030 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7113:gst_rtspsrc_parse_range: range: max 99:99:99.999999999
0:00:00.017903716 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1782:gst_rtspsrc_collect_payloads: mapping sdp session level attributes to caps
0:00:00.017906873 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1784:gst_rtspsrc_collect_payloads: mapping sdp media level attributes to caps
0:00:00.017909489 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1802:gst_rtspsrc_collect_payloads: looking at 0 pt: 96
0:00:00.017921370 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1941:gst_rtspsrc_create_stream: stream 0, (0x7fc4b4033040)
0:00:00.017923251 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1942:gst_rtspsrc_create_stream: port: 0
0:00:00.017925027 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1943:gst_rtspsrc_create_stream: container: 0
0:00:00.017926736 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1944:gst_rtspsrc_create_stream: control: trackID=0
0:00:00.017929133 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1979:gst_rtspsrc_create_stream: setup: rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=0
0:00:00.017932793 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1782:gst_rtspsrc_collect_payloads: mapping sdp session level attributes to caps
0:00:00.017934608 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1784:gst_rtspsrc_collect_payloads: mapping sdp media level attributes to caps
0:00:00.017936813 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1802:gst_rtspsrc_collect_payloads: looking at 0 pt: 98
0:00:00.017946549 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1941:gst_rtspsrc_create_stream: stream 1, (0x7fc4b40341c0)
0:00:00.017949154 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1942:gst_rtspsrc_create_stream: port: 0
0:00:00.017951525 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1943:gst_rtspsrc_create_stream: container: 0
0:00:00.017953842 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1944:gst_rtspsrc_create_stream: control: trackID=1
0:00:00.017956464 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:1979:gst_rtspsrc_create_stream: setup: rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=1
0:00:00.017961091 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:455:default_select_stream: default handler
0:00:00.017963848 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:466:select_stream_accum: accum 1
0:00:00.017966715 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:455:default_select_stream: default handler
0:00:00.017971412 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6798:gst_rtspsrc_setup_streams_start: doing setup of stream 0x7fc4b4033040 with rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=0
0:00:00.017974769 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6813:gst_rtspsrc_setup_streams_start: protocols = 0x7, protocol mask = 0x1
0:00:00.017977380 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6281:gst_rtspsrc_create_transports_string: got transports (NULL)
0:00:00.017979945 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6311:gst_rtspsrc_create_transports_string: adding UDP unicast
0:00:00.017982531 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6338:gst_rtspsrc_create_transports_string: prepared transports RTP/AVP;unicast;client_port=%%u1-%%u2
0:00:00.017985035 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6828:gst_rtspsrc_setup_streams_start: replace ports in RTP/AVP;unicast;client_port=%%u1-%%u2
0:00:00.018257681 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2167:gst_rtspsrc_alloc_udp_ports: got RTP port 56274
0:00:00.018308944 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2199:gst_rtspsrc_alloc_udp_ports: starting RTCP on port 56275
0:00:00.018326922 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6839:gst_rtspsrc_setup_streams_start: transport is now RTP/AVP;unicast;client_port=56274-56275
0:00:00.018336242 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.018339262 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.018341869 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
进度:(request)SETUP stream 0
0:00:00.019311940 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:00.019315466 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:00.019321464 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6555:gst_rtsp_src_setup_stream_from_response: stream 0x7fc4b4033040 as UDP unicast
0:00:00.019324183 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4248:gst_rtspsrc_stream_configure_transport: configuring transport for stream 0x7fc4b4033040
0:00:00.019326634 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4257:gst_rtspsrc_stream_configure_transport: setting media type to application/x-rtp
0:00:00.019329961 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3491:gst_rtspsrc_stream_configure_manager: using manager rtpbin
0:00:00.019593727 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3202:set_manager_buffer_mode: auto buffering mode, have clock (NULL)
0:00:00.019597760 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3222:set_manager_buffer_mode: auto buffering mode
0:00:00.019604882 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3227:set_manager_buffer_mode: selected slave
0:00:00.019608306 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3590:gst_rtspsrc_stream_configure_manager: connect to signals on session manager, stream 0x7fc4b4033040
0:00:00.020170638 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 0, stream 0x7fc4b4033040, 0
0:00:00.020203181 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtp_sink_0
0:00:00.020206894 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:00.020245695 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 0, stream 0x7fc4b4033040, 0
0:00:00.020265947 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtcp_sink_0
0:00:00.020268907 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:00.020273689 13824 0x55f64f09ad40 INFO rtspsrc gstrtspsrc.c:3633:gst_rtspsrc_stream_configure_manager: configure bandwidth in session 0x7fc4b404e2d0
0:00:00.020282548 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3981:gst_rtspsrc_stream_configure_udp: setting up UDP source
0:00:00.020289455 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4007:gst_rtspsrc_stream_configure_udp: connecting UDP source 0 to manager
0:00:00.020307309 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4038:gst_rtspsrc_stream_configure_udp: connecting UDP source 1 to manager
0:00:00.020313214 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4082:gst_rtspsrc_stream_configure_udp_sinks: configure RTP UDP sink for 34.191.45.139:53406
0:00:00.020516010 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4105:gst_rtspsrc_stream_configure_udp_sinks: RTP UDP src has sock 0x7fc4a80127c0
0:00:00.020575644 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4147:gst_rtspsrc_stream_configure_udp_sinks: configure RTCP UDP sink for 34.191.45.139:53407
0:00:00.020714030 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4171:gst_rtspsrc_stream_configure_udp_sinks: RTCP UDP src has sock 0x7fc4a8012910
0:00:00.020748211 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3294:request_rtcp_encoder: decoder session 0, stream 0x7fc4b4033040, 0
0:00:00.020764672 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:send_rtcp_src_0
0:00:00.020767790 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:00.020776714 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:455:default_select_stream: default handler
0:00:00.020779608 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:466:select_stream_accum: accum 1
0:00:00.020782138 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:455:default_select_stream: default handler
0:00:00.020785637 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6798:gst_rtspsrc_setup_streams_start: doing setup of stream 0x7fc4b40341c0 with rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=1
0:00:00.020788653 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6813:gst_rtspsrc_setup_streams_start: protocols = 0x1, protocol mask = 0x1
0:00:00.020791279 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6281:gst_rtspsrc_create_transports_string: got transports (NULL)
0:00:00.020793686 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6311:gst_rtspsrc_create_transports_string: adding UDP unicast
0:00:00.020796363 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6338:gst_rtspsrc_create_transports_string: prepared transports RTP/AVP;unicast;client_port=%%u1-%%u2
0:00:00.020798686 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6828:gst_rtspsrc_setup_streams_start: replace ports in RTP/AVP;unicast;client_port=%%u1-%%u2
0:00:00.020858635 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2167:gst_rtspsrc_alloc_udp_ports: got RTP port 44939
0:00:00.020861995 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2175:gst_rtspsrc_alloc_udp_ports: RTP port not even
0:00:00.020864367 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2177:gst_rtspsrc_alloc_udp_ports: free RTP udpsrc
0:00:00.020877484 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2182:gst_rtspsrc_alloc_udp_ports: retry 1
0:00:00.020928122 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2167:gst_rtspsrc_alloc_udp_ports: got RTP port 44940
0:00:00.020969181 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2199:gst_rtspsrc_alloc_udp_ports: starting RTCP on port 44941
0:00:00.020985656 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6839:gst_rtspsrc_setup_streams_start: transport is now RTP/AVP;unicast;client_port=44940-44941
0:00:00.020994947 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.020997768 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
进度:(request)SETUP stream 1
0:00:00.021000428 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
0:00:00.021848798 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:00.021856328 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:00.021862610 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:6555:gst_rtsp_src_setup_stream_from_response: stream 0x7fc4b40341c0 as UDP unicast
0:00:00.021865334 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4248:gst_rtspsrc_stream_configure_transport: configuring transport for stream 0x7fc4b40341c0
0:00:00.021867928 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4257:gst_rtspsrc_stream_configure_transport: setting media type to application/x-rtp
0:00:00.021871366 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3491:gst_rtspsrc_stream_configure_manager: using manager rtpbin
0:00:00.021978540 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 1, stream 0x7fc4b4033040, 0
0:00:00.021983766 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 1, stream 0x7fc4b40341c0, 1
0:00:00.022018146 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtp_sink_1
0:00:00.022022004 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:00.022049391 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 1, stream 0x7fc4b4033040, 0
0:00:00.022053198 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3261:request_rtp_decoder: decoder session 1, stream 0x7fc4b40341c0, 1
0:00:00.022072607 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtcp_sink_1
0:00:00.022075466 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:00.022080156 13824 0x55f64f09ad40 INFO rtspsrc gstrtspsrc.c:3633:gst_rtspsrc_stream_configure_manager: configure bandwidth in session 0x7fc4b404e600
0:00:00.022088709 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3981:gst_rtspsrc_stream_configure_udp: setting up UDP source
0:00:00.022094909 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4007:gst_rtspsrc_stream_configure_udp: connecting UDP source 0 to manager
0:00:00.022103218 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4038:gst_rtspsrc_stream_configure_udp: connecting UDP source 1 to manager
0:00:00.022107883 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4082:gst_rtspsrc_stream_configure_udp_sinks: configure RTP UDP sink for 34.191.45.139:49060
0:00:00.022195375 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4105:gst_rtspsrc_stream_configure_udp_sinks: RTP UDP src has sock 0x7fc4a8012a60
0:00:00.022214418 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4147:gst_rtspsrc_stream_configure_udp_sinks: configure RTCP UDP sink for 34.191.45.139:49061
0:00:00.022285441 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4171:gst_rtspsrc_stream_configure_udp_sinks: RTCP UDP src has sock 0x7fc4a8012bb0
0:00:00.022307465 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3294:request_rtcp_encoder: decoder session 1, stream 0x7fc4b4033040, 0
0:00:00.022311413 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3294:request_rtcp_encoder: decoder session 1, stream 0x7fc4b40341c0, 1
0:00:00.022323371 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:send_rtcp_src_1
0:00:00.022326197 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:3063:new_manager_pad: ignoring unknown stream
0:00:00.022337705 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command LOOP
0:00:00.022340450 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:00.022343393 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
进度:(open)Opened Stream
设置播放管道 …
0:00:00.022420237 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:3202:set_manager_buffer_mode: auto buffering mode, have clock (NULL)
0:00:00.022424746 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:3222:set_manager_buffer_mode: auto buffering mode
0:00:00.022427430 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:3227:set_manager_buffer_mode: selected slave
0:00:00.022432745 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd WAIT
0:00:00.022435386 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:5585:gst_rtspsrc_loop_send_cmd: cancel previous request LOOP
0:00:00.022437982 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd: connection flush busy LOOP
0:00:00.022440472 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 1
0:00:00.022442887 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:4751:gst_rtspsrc_connection_flush: connection flush
0:00:00.022456807 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5337:gst_rtspsrc_loop_udp: got interrupted
0:00:00.022459937 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5636:gst_rtspsrc_loop: pausing task, reason flushing
0:00:00.022462424 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd WAIT
0:00:00.022464853 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd: connection flush busy LOOP
0:00:00.022467256 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 1
0:00:00.022482366 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd: sending cmd PLAY
0:00:00.022485210 13824 0x55f64f0790f0 DEBUG rtspsrc gstrtspsrc.c:5598:gst_rtspsrc_loop_send_cmd: not interrupting busy cmd WAIT
0:00:00.022490398 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command PLAY
0:00:00.022493138 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:00.022495330 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4751:gst_rtspsrc_connection_flush: connection flush
New clock: GstSystemClock
0:00:00.022498588 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7886:gst_rtspsrc_play: PLAY…
0:00:00.022501595 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4364:gst_rtspsrc_send_dummy_packets: sending dummy packet to stream 0x7fc4b4033040
进度:(request)Sending PLAY request
0:00:00.022550473 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4364:gst_rtspsrc_send_dummy_packets: sending dummy packet to stream 0x7fc4b40341c0
0:00:00.022622303 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.022626512 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send: default handler
0:00:00.022629355 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send: sending message
0:00:00.023748328 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response: received response message
0:00:00.023752236 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response: got response message 200
0:00:00.023756221 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7077:gst_rtspsrc_parse_range: parsed range npt=now-
0:00:00.023763196 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7088:gst_rtspsrc_parse_range: range: type 1, min 0.000000 - type 2, max 0.000000
0:00:00.023766612 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7098:gst_rtspsrc_parse_range: range: min 0:00:00.000000000
0:00:00.023769619 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7113:gst_rtspsrc_parse_range: range: max 99:99:99.999999999
0:00:00.023772314 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7701:gst_rtspsrc_parse_rtpinfo: parsing RTP-Info url=rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=0;seq=63545;rtptime=-1724572426
0:00:00.023775799 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7710:gst_rtspsrc_parse_rtpinfo: parsing info url=rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=0;seq=63545;rtptime=-1724572426
0:00:00.023778728 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field url=rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=0
0:00:00.023781499 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field seq=63545
0:00:00.023784173 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field rtptime=-1724572426
0:00:00.023787927 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7742:gst_rtspsrc_parse_rtpinfo: found stream 0x7fc4b4033040, setting: seqbase 63545, timebase -1724572426
0:00:00.023790522 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7701:gst_rtspsrc_parse_rtpinfo: parsing RTP-Info url=rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=1;seq=22529;rtptime=228479680
0:00:00.023793420 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7710:gst_rtspsrc_parse_rtpinfo: parsing info url=rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=1;seq=22529;rtptime=228479680
0:00:00.023802838 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field url=rtsp://34.191.45.139:554/rtp/34010000052000051131_34010221051190050688/trackID=1
0:00:00.023805453 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field seq=22529
0:00:00.023807839 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7724:gst_rtspsrc_parse_rtpinfo: parsing field rtptime=228479680
0:00:00.023810761 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:7742:gst_rtspsrc_parse_rtpinfo: found stream 0x7fc4b40341c0, setting: seqbase 22529, timebase 228479680
0:00:00.023813270 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4442:gst_rtspsrc_configure_caps: configuring stream caps
0:00:00.023841157 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4480:gst_rtspsrc_configure_caps: stream 0x7fc4b4033040, pt 96, caps application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)420033, sprop-parameter-sets=(string)“Z0IAM5Y1QCAAIfTcBAQFAAAHCAABX5CE,aM4xsg==”, ssrc=(uint)152, clock-base=(uint)2570394870, seqnum-base=(uint)63545, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
0:00:00.023853209 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4480:gst_rtspsrc_configure_caps: stream 0x7fc4b40341c0, pt 98, caps application/x-rtp, media=(string)audio, payload=(int)98, clock-rate=(int)8000, encoding-name=(string)MPEG4-GENERIC, encoding-params=(string)1, streamtype=(string)5, profile-level-id=(string)1, mode=(string)AAC-hbr, sizelength=(string)13, indexlength=(string)3, indexdeltalength=(string)3, config=(string)1588, ssrc=(uint)155, clock-base=(uint)228479680, seqnum-base=(uint)22529, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
0:00:00.023858379 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4490:gst_rtspsrc_configure_caps: clear session
0:00:00.024089918 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:8071:gst_rtspsrc_play: mark DISCONT, we did a seek to another position
0:00:00.024100815 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread: got command LOOP
进度:(request)Sent PLAY request
0:00:00.024103949 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush: set flushing 0
0:00:00.024109209 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
0:00:00.034831754 13824 0x7fc4b4050e30 DEBUG rtspsrc gstrtspsrc.c:2916:pad_blocked: pad udpsrc0:src blocked, activating streams
0:00:00.034841868 13824 0x7fc4b4050e30 DEBUG rtspsrc gstrtspsrc.c:4385:gst_rtspsrc_activate_streams: activating streams
0:00:00.034846832 13824 0x7fc4b4050e30 DEBUG rtspsrc gstrtspsrc.c:4425:gst_rtspsrc_activate_streams: unblocking stream pad 0x7fc4b4033040
0:00:00.034851629 13824 0x7fc4b4050e30 DEBUG rtspsrc gstrtspsrc.c:4425:gst_rtspsrc_activate_streams: unblocking stream pad 0x7fc4b40341c0
0:00:02.033612694 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtp_src_0_152_96
0:00:02.033678894 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2998:new_manager_pad: stream: 0, SSRC 00000098, PT 96
0:00:02.033700549 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:3016:new_manager_pad: stream 0x7fc4b4033040, container 0, added 1, setup 1
0:00:02.033721739 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:3016:new_manager_pad: stream 0x7fc4b40341c0, container 0, added 0, setup 1
0:00:02.033862397 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2942:copy_sticky_events:<‘’:recv_rtp_src_0_152_96> store sticky event stream-start event: 0x7fc49c005d20, time 99:99:99.999999999, seq-num 180, GstEventStreamStart, stream-id=(string)b9049c323800fa1dbf0c9c2f5d6dcf0e63b50fc2c5030d1c14e44a893d14e333, flags=(GstStreamFlags)GST_STREAM_FLAG_NONE, group-id=(uint)3;
0:00:02.033939745 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2942:copy_sticky_events:<‘’:recv_rtp_src_0_152_96> store sticky event caps event: 0x7fc474006c10, time 99:99:99.999999999, seq-num 247, GstEventCaps, caps=(GstCaps)“application/x-rtp,\ media=(string)video,\ payload=(int)96,\ clock-rate=(int)90000,\ encoding-name=(string)H264,\ packetization-mode=(string)1,\ profile-level-id=(string)420033,\ sprop-parameter-sets=(string)"Z0IAM5Y1QCAAIfTcBAQFAAAHCAABX5CE\,aM4xsg\=\=",\ ssrc=(uint)152,\ clock-base=(uint)2570394870,\ seqnum-base=(uint)63545,\ npt-start=(guint64)0,\ play-speed=(double)1,\ play-scale=(double)1”;
0:00:02.034005661 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2942:copy_sticky_events:<‘’:recv_rtp_src_0_152_96> store sticky event segment event: 0x7fc49c005e00, time 99:99:99.999999999, seq-num 167, GstEventSegment, segment=(GstSegment)“GstSegment, flags=(GstSegmentFlags)GST_SEGMENT_FLAG_NONE, rate=(double)1, applied-rate=(double)1, format=(GstFormat)GST_FORMAT_TIME, base=(guint64)0, offset=(guint64)0, start=(guint64)0, stop=(guint64)18446744073709551615, time=(guint64)0, position=(guint64)0, duration=(guint64)18446744073709551615;”;
0:00:02.034042652 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query caps
0:00:02.034109069 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query caps
0:00:02.034159388 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.034424770 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.038785865 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.039146657 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.039506019 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.039792612 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.040947828 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.070171096 13824 0x7fc478004630 DEBUG rtspsrc gstrtspsrc.c:2990:new_manager_pad: got new manager pad manager:recv_rtp_src_1_155_98
0:00:02.070190066 13824 0x7fc478004630 DEBUG rtspsrc gstrtspsrc.c:2998:new_manager_pad: stream: 1, SSRC 0000009b, PT 98
0:00:02.070193999 13824 0x7fc478004630 DEBUG rtspsrc gstrtspsrc.c:3016:new_manager_pad: stream 0x7fc4b4033040, container 0, added 1, setup 1
0:00:02.070196277 13824 0x7fc478004630 DEBUG rtspsrc gstrtspsrc.c:3016:new_manager_pad: stream 0x7fc4b40341c0, container 0, added 1, setup 1
0:00:02.070230137 13824 0x7fc478004630 DEBUG rtspsrc gstrtspsrc.c:2942:copy_sticky_events:<‘’:recv_rtp_src_1_155_98> store sticky event stream-start event: 0x7fc484004ed0, time 99:99:99.999999999, seq-num 191, GstEventStreamStart, stream-id=(string)e88cc1b95c4e49b5d7ece59e91fa849af3be3a2be27dc49ce1b8c0f82875f0b3, flags=(GstStreamFlags)GST_STREAM_FLAG_NONE, group-id=(uint)5;
0:00:02.070245431 13824 0x7fc478004630 DEBUG rtspsrc gstrtspsrc.c:2942:copy_sticky_events:<‘’:recv_rtp_src_1_155_98> store sticky event caps event: 0x7fc4740076c0, time 99:99:99.999999999, seq-num 310, GstEventCaps, caps=(GstCaps)“application/x-rtp,\ media=(string)audio,\ payload=(int)98,\ clock-rate=(int)8000,\ encoding-name=(string)MPEG4-GENERIC,\ encoding-params=(string)1,\ streamtype=(string)5,\ profile-level-id=(string)1,\ mode=(string)AAC-hbr,\ sizelength=(string)13,\ indexlength=(string)3,\ indexdeltalength=(string)3,\ config=(string)1588,\ ssrc=(uint)155,\ clock-base=(uint)228479680,\ seqnum-base=(uint)22529,\ npt-start=(guint64)0,\ play-speed=(double)1,\ play-scale=(double)1”;
0:00:02.070263514 13824 0x7fc478004630 DEBUG rtspsrc gstrtspsrc.c:2942:copy_sticky_events:<‘’:recv_rtp_src_1_155_98> store sticky event segment event: 0x7fc478006010, time 99:99:99.999999999, seq-num 178, GstEventSegment, segment=(GstSegment)“GstSegment, flags=(GstSegmentFlags)GST_SEGMENT_FLAG_NONE, rate=(double)1, applied-rate=(double)1, format=(GstFormat)GST_FORMAT_TIME, base=(guint64)0, offset=(guint64)0, start=(guint64)0, stop=(guint64)18446744073709551615, time=(guint64)0, position=(guint64)0, duration=(guint64)18446744073709551615;”;
0:00:02.070266707 13824 0x7fc478004630 DEBUG rtspsrc gstrtspsrc.c:3052:new_manager_pad: We added all streams
0:00:02.076271333 13824 0x7fc4b4087000 DEBUG rtspsrc gstrtspsrc.c:8298:gst_rtspsrc_handle_message: got error from udpsrc3
0:00:02.076282577 13824 0x7fc4b4087000 DEBUG rtspsrc gstrtspsrc.c:8312:gst_rtspsrc_handle_message: combined flows: ok
0:00:02.118749006 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.119116315 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.119190665 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.122158339 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.150626070 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query seeking
0:00:02.150637484 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:02.293479601 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event reconfigure
0:00:02.306323273 13824 0x7fc490009590 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query latency
0:00:02.306351869 13824 0x7fc490009590 DEBUG rtspsrc gstrtspsrc.c:2577:gst_rtspsrc_handle_src_event: pad rtspsrc0:recv_rtp_src_0_152_96 received event latency
0:00:02.462192385 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:03.120286538 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:04.552431809 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:05.071792660 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:06.072755344 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:07.512200048 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:09.032633991 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:10.111996617 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:10.474571080 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:11.953580792 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:13.490001586 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:14.913168866 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:15.157386784 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:16.433721478 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:17.918587515 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:19.359814892 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:20.191005444 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:20.870670110 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:22.311668703 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:23.809112239 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:25.194965295 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:25.316348995 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:26.792506357 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:28.241887394 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:28.496599976 13824 0x7fc4b4050e80 WARN rtspsrc gstrtspsrc.c:3155:on_timeout: source 0000009b, stream 0000009b in session 1 timed out
0:00:28.496609450 13824 0x7fc4b4050e80 DEBUG rtspsrc gstrtspsrc.c:3114:gst_rtspsrc_do_stream_eos: setting stream for session 1 to EOS
0:00:29.750047984 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:30.213755601 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:31.193341254 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:32.673277593 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:34.256562477 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:35.281894698 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:35.671998542 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:37.110390006 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:38.637301612 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:40.113553885 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:40.285907830 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:41.592092446 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:43.071270221 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:44.558800918 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:45.313048169 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:46.032591454 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:47.512457566 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:49.031344321 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:50.318839505 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:50.472113207 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:51.991012026 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:53.436188070 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:54.912157057 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:55.031765828 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5272:gst_rtspsrc_loop_udp: timeout, sending keep-alive
0:00:55.031776825 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4845:gst_rtspsrc_send_keep_alive: creating server keep-alive
0:00:55.031800697 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
0:00:55.032513839 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5265:gst_rtspsrc_loop_udp: we received a server message
0:00:55.032528129 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5308:gst_rtspsrc_loop_udp: ignoring response message
0:00:55.032531297 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
0:00:55.350862471 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:00:56.435346329 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:57.871825498 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:00:59.392283656 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:00.352934337 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:00.829642401 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:02.314923842 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:03.845689274 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:05.272946158 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:05.355649267 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:06.762581037 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:08.308648140 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:09.710998163 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:10.390390628 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:11.192254896 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:12.674971000 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:14.242302466 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:15.391224904 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:15.673910194 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:17.213482899 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:18.593548313 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:20.121518012 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:20.428948116 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:21.552384589 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:23.074614474 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:24.591581329 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:25.482366798 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:26.034358670 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:27.511902077 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:29.004047105 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:30.433262986 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:30.509889805 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:31.969115174 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:33.396749203 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:34.910221267 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:35.511501259 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:36.354279264 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:37.871036940 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:39.319382178 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:40.514258733 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:40.831705891 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:42.304431979 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:43.796436487 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:45.271136217 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:45.549859913 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:46.750902028 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:48.292954929 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:49.749587609 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:50.087599504 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5272:gst_rtspsrc_loop_udp: timeout, sending keep-alive
0:01:50.087608985 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4845:gst_rtspsrc_send_keep_alive: creating server keep-alive
0:01:50.087628636 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 55 seconds
0:01:50.088398746 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5265:gst_rtspsrc_loop_udp: we received a server message
0:01:50.088405215 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5308:gst_rtspsrc_loop_udp: ignoring response message
0:01:50.088408291 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
0:01:50.589965503 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:51.193866700 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:52.672501073 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:54.149989907 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:55.669958654 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:01:55.673628015 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:57.189616195 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:01:58.589731517 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:00.070049197 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:00.670082393 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:01.595527000 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:03.070139720 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:04.552462295 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:05.681821798 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:05.996085540 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:07.472210324 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:08.991101341 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:10.441349596 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:10.700924471 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:11.932681008 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:13.402004249 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:14.872031855 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:15.749373540 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:16.355517454 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:17.832493649 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:19.351338912 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:20.789115222 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:20.833418666 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:22.331046494 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:23.751597662 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:25.270982597 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:25.828899069 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:26.750322313 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:28.242321036 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:29.671311243 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:30.868902246 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:31.188886452 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:32.669333711 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:34.150028558 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:35.603489280 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:35.909211370 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:37.112574957 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:38.554783588 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:40.109315843 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:40.948858608 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:41.553463853 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:43.030676408 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:44.550946218 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:45.143438516 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5272:gst_rtspsrc_loop_udp: timeout, sending keep-alive
0:02:45.143448067 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4845:gst_rtspsrc_send_keep_alive: creating server keep-alive
0:02:45.143469898 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
0:02:45.144297950 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5265:gst_rtspsrc_loop_udp: we received a server message
0:02:45.144304776 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5308:gst_rtspsrc_loop_udp: ignoring response message
0:02:45.144308706 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
0:02:45.952028106 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:45.990546524 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:47.509927192 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:48.949980507 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:50.431990103 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:50.993948085 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:51.950557284 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:53.388665590 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:54.909668412 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:56.068766069 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:02:56.360814851 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:57.870687470 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:02:59.382792890 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:00.828664528 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:01.069639155 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:02.372605792 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:03.749069472 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:05.230209820 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:06.110231538 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:06.749735988 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:08.192878457 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:09.668714374 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:11.148628996 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:12.498124002 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:12.730355001 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:14.148823596 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:15.630682890 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:16.188556248 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:17.150194760 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:18.591985387 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:20.093027041 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:21.276746724 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:21.629931155 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:23.116643294 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:24.520347322 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:26.030890944 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:26.333827027 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:27.509957078 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:28.997545238 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:30.510617821 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:31.389643673 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:31.968906646 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:33.431904200 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:34.912741128 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:36.392046707 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:36.392339388 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:37.871450325 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:39.350134110 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:40.195745906 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5272:gst_rtspsrc_loop_udp: timeout, sending keep-alive
0:03:40.195770076 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:4845:gst_rtspsrc_send_keep_alive: creating server keep-alive
0:03:40.195807556 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
0:03:40.196546595 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5265:gst_rtspsrc_loop_udp: we received a server message
0:03:40.196553455 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5308:gst_rtspsrc_loop_udp: ignoring response message
0:03:40.196557950 13824 0x55f64f09ad40 DEBUG rtspsrc gstrtspsrc.c:5253:gst_rtspsrc_loop_udp: doing receive with timeout 54 seconds
0:03:40.830693802 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:41.433029015 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:42.387532640 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:43.791303142 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:45.317180499 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:46.468972907 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:46.751390270 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:48.230404410 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:49.709077347 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:51.189294041 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:51.471012699 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:52.673106308 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:54.188450691 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:55.669803330 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
0:03:56.509104408 13824 0x7fc4b4050c50 DEBUG rtspsrc gstrtspsrc.c:3179:on_ssrc_active: source in session 0 is active
0:03:57.112658012 13824 0x7fc49c004f70 DEBUG rtspsrc gstrtspsrc.c:2719:gst_rtspsrc_handle_src_query: pad rtspsrc0:recv_rtp_src_0_152_96 received query duration
Try this pipeline work or not:
gst-launch-1.0 rtspsrc location=“RTSP IP” latency=100 protocols=tcp ! queue ! rtph264depay ! nvv4l2decoder ! queue ! nvvideoconvert ! “video/x-raw, format=(string)NV12” ! x264enc ! matroskamux ! filesink location=testdddd.mkv sync=false
thank you, this pipeline works well
can you tell me the reason?
From your log, rtsp trying with UDP protocols, but failed. so suggest you try with TCP protocols using that pipeline.
Thank you for your patience in answering my questions
