I use deepstream-app to run yolov3 sample. I found it cannot play rtsp source. I confirmed there are rtsp and rtp packets captured by tcpdump tool. But app cannot play rtsp stream. Below is log. please help me.
Setting pipeline to PAUSED …
0:00:00.110039262 15688 0x55794668f0 WARN omx gstomx.c:2826:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/lee/.config:/etc/xdg/xdg-unity:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:a123456789@192.168.0.203:554:/0
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
0:00:00.523734642 15688 0x7f7c03a8f0 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc0:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.524139257 15688 0x7f7c03a940 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc1:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Progress: (request) Sent PLAY request
Opening in BLOCKING MODE
0:00:02.610742993 15688 0x7f4c002a30 WARN v4l2 gstv4l2object.c:4410:gst_v4l2_object_probe_caps:nvv4l2decoder0:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.610966581 15688 0x7f4c002a30 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7f3807fe40 Failed to determine interlace mode
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
lee@lee-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo$ gst-launch-1.0 uridecodebin uri=“rtsp://admin:a123456789@192.168.0.203:554/0” ! autovideosink
0:00:00.066366544 15179 0x559a0fb790 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “uridecodebin”
0:00:00.067325443 15179 0x559a0fb790 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “autovideosink”
0:00:00.068548508 15179 0x559a0fb790 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “fake-video-sink”
0:00:00.069039718 15179 0x559a0fb790 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “pipeline”
0:00:00.108708307 15179 0x559a0fb790 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvoverlaysink” named “autovideosink0-actual-sink-nvoverlay”
0:00:00.123988556 15179 0x559a0fb790 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “rtspsrc” named “source”
0:00:00.127159629 15179 0x559a0fb790 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtspwms”
0:00:00.128226243 15179 0x559a0fb790 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtspreal”
0:00:00.482301015 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:00:00.483850614 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:00:00.484632102 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:00:00.511770866 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “rtpbin” named “manager”
0:00:00.513542742 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpsession”
0:00:00.514666221 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpssrcdemux”
0:00:00.517129792 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpstorage”
0:00:00.517514664 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “funnel”
0:00:00.517784845 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “funnel”
0:00:00.520181438 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsink”
0:00:00.521730782 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “fakesrc”
0:00:00.522874646 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsink”
0:00:00.524481814 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:00:00.525127716 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:00:00.547697234 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpsession”
0:00:00.548056185 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpssrcdemux”
0:00:00.548220541 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpstorage”
0:00:00.548386912 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “funnel”
0:00:00.548485314 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “funnel”
0:00:00.550983445 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsink”
0:00:00.552031435 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “fakesrc”
0:00:00.552756346 15179 0x559a11ade0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsink”
0:00:00.642422598 15179 0x7f8c03aa30 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpjitterbuffer”
0:00:00.643165941 15179 0x7f8c03aa30 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpptdemux”
0:00:02.642575136 15179 0x7f70002f70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “decodebin”
0:00:02.643168940 15179 0x7f70002f70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “typefind” named “typefind”
0:00:02.653662691 15179 0x7f70002f70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtph264depay”
0:00:02.656598495 15179 0x7f70002f70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “h264parse”
0:00:02.658022236 15179 0x7f70002f70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “capsfilter”
0:00:02.664306172 15179 0x7f70002f70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “nvv4l2decoder”
I have found the root cause. When rtsp stream contains autodio stream and video stream, it cannot play successly. When it only contains video stream, it is well. Please check.
We have RTSP sources with audio stream and don’t observe the issue. Probably you don’t modify config file correctly. You may refer to the config files in the posts:
