Deepstream-app is not running and is not presenting any errors
• Hardware Platform (T4)
• DeepStream Version 5.1
• TensorRT Version 7.2.1.6
• NVIDIA GPU Driver Version (valid for GPU only) 460.32.03
**• Issue Type( questions, new requirements, bugs)**bugs
I have installed 5.1 . (previously have successfully worked with 5.0). However, when I try to run deepstream-app, it doens’t run and doesn’t print any errors. Even when trying with gst-debug=1,2,3
When trying with gst-debug=4, I get a lot of info prints and the last of them is :“0:00:01.177358001 8221 0x557ed0ab00c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED”. I also tried to clean the gstreamer cache and it didn’t help
Best regards
Can you paste the log here?
I will do it in several posts as the info log is very long
0:00:00.000397020 18040 0x56308d0b30c0 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.000887456 18040 0x56308d0b30c0 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.001099765 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.001194438 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.001208215 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.001226341 18040 0x56308d0b30c0 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/sysadm/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.015590438 18040 0x56308d0b30c0 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/sysadm/.cache/gstreamer-1.0/registry.x86_64.bin in 0.014335 seconds
0:00:00.015639373 18040 0x56308d0b30c0 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/sysadm/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.017157504 18040 0x56308d0b30c0 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.017172125 18040 0x56308d0b30c0 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.017180499 18040 0x56308d0b30c0 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.017187879 18040 0x56308d0b30c0 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.017193266 18040 0x56308d0b30c0 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.017540985 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “pipeline” named “pipeline”
0:00:00.017633863 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “multi_src_bin”
0:00:00.995832167 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so” loaded
0:00:00.995874864 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvstreammux” named “src_bin_muxer”
0:00:00.996105708 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstNvStreamMux@0x56308d5481f0 adding pad ‘src’
0:00:00.996153263 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin0”
0:00:00.996797707 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstplayback.so” loaded
0:00:00.996810173 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.997407969 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.997420910 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “queue”
0:00:00.997493767 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55a1c0 adding pad ‘sink’
0:00:00.997510155 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55a1c0 adding pad ‘src’
0:00:00.997804471 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so” loaded
0:00:00.997816641 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvvideoconvert” named “nvvidconv_elem”
0:00:00.997947431 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d55ffa0 adding pad ‘sink’
0:00:00.997988231 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d55ffa0 adding pad ‘src’
0:00:00.998007041 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “capsfilter” named “src_cap_filter_nvvidconv”
0:00:00.998056057 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d562250 adding pad ‘sink’
0:00:00.998068739 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d562250 adding pad ‘src’
0:00:00.998087108 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998125022 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter_nvvidconv:src
0:00:00.998171657 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter_nvvidconv:src and src:proxypad0
0:00:00.998183691 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter_nvvidconv:src and src:proxypad0, successful
0:00:00.998191161 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998200120 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<src_cap_filter_nvvidconv:src> Received event on flushing pad. Discarding
0:00:00.998213891 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin0> adding pad ‘src’
0:00:00.998225437 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.998354358 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x56308d5671e0 adding pad ‘sink’
0:00:00.998369157 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.998384873 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55a4c0 adding pad ‘sink’
0:00:00.998398125 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55a4c0 adding pad ‘src’
0:00:00.998411763 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.998458575 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x56308d56a000 adding pad ‘sink’
0:00:00.998487210 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.998498183 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.998512318 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.998530191 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.998540521 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.998547851 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.998558283 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.998564387 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998570998 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.998603728 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.998612430 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad queue:sink
0:00:00.998622851 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee0:src_0 and queue:sink
0:00:00.998631210 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.998639327 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:queue:src pad has no peer
0:00:00.998647633 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee0:src_0 and queue:sink, successful
0:00:00.998654633 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998660936 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:tee0:src_0 Received event on flushing pad. Discarding
0:00:00.998670604 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element queue:(any) to element nvvidconv_elem:(any)
0:00:00.998678563 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link queue:src and nvvidconv_elem:sink
0:00:00.998686239 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.998698014 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvidconv_elem:src> pad has no peer
0:00:00.998754950 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: queue and nvvidconv_elem in same bin, no need for ghost pads
0:00:00.998764736 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link queue:src and nvvidconv_elem:sink
0:00:00.998772879 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.998781843 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvidconv_elem:src> pad has no peer
0:00:00.998814387 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked queue:src and nvvidconv_elem:sink, successful
0:00:00.998820504 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998826827 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:queue:src Received event on flushing pad. Discarding
0:00:00.998836687 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvvidconv_elem:(any) to element src_cap_filter_nvvidconv:(any)
0:00:00.998845093 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvvidconv_elem:src and src_cap_filter_nvvidconv:sink
0:00:00.998853710 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.998887089 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<src_sub_bin0:src> pad has no peer
0:00:00.998898764 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvvidconv_elem and src_cap_filter_nvvidconv in same bin, no need for ghost pads
0:00:00.998909304 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvvidconv_elem:src and src_cap_filter_nvvidconv:sink
0:00:00.998918039 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.998950312 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<src_sub_bin0:src> pad has no peer
0:00:00.998961970 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvvidconv_elem:src and src_cap_filter_nvvidconv:sink, successful
0:00:00.998967995 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998973760 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvvidconv_elem:src> Received event on flushing pad. Discarding
0:00:00.998990563 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.998998702 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.999007717 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee0:src_1 and fakequeue:sink
0:00:00.999015615 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.999027027 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee0:src_1 and fakequeue:sink, successful
0:00:00.999033123 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.999041045 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:tee0:src_1 Received event on flushing pad. Discarding
0:00:00.999080047 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_0’ in element “src_bin_muxer”
0:00:00.999107082 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_0’
0:00:00.999117008 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin0:src
0:00:00.999127298 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin0:src and src_bin_muxer:sink_0
0:00:00.999138470 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.999182690 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.999205122 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin0:src and src_bin_muxer:sink_0, successful
0:00:00.999211425 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.999218065 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<src_sub_bin0:src> Received event on flushing pad. Discarding
0:00:00.999227786 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_bin_muxer:src
0:00:00.999246809 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_bin_muxer:src and src:proxypad1
0:00:00.999255265 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_bin_muxer:src and src:proxypad1, successful
0:00:00.999260948 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.999267089 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<src_bin_muxer:src> Received event on flushing pad. Discarding
0:00:00.999275686 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<multi_src_bin> adding pad ‘src’
0:00:00.999320963 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “tee” named “tiler_tee”
0:00:00.999350236 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x56308d56a150 adding pad ‘sink’
0:00:00.999370608 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “processing_bin_0”
0:00:00.999385865 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “sink_bin”
0:00:00.999398006 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “sink_bin_queue”
0:00:00.999413329 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55a7c0 adding pad ‘sink’
0:00:00.999427024 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55a7c0 adding pad ‘src’
0:00:00.999443314 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad sink_bin_queue:sink
0:00:00.999459161 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad2 and sink_bin_queue:sink
0:00:00.999467372 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad2 and sink_bin_queue:sink, successful
0:00:00.999473182 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.999483194 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<sink_bin> adding pad ‘sink’
0:00:00.999491525 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “tee” named “sink_bin_tee”
0:00:00.999510981 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x56308d56a2a0 adding pad ‘sink’
0:00:00.999528394 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element sink_bin_queue:(any) to element sink_bin_tee:(any)
0:00:00.999537225 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link sink_bin_queue:src and sink_bin_tee:sink
0:00:00.999546888 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:00.999558577 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: sink_bin_queue and sink_bin_tee in same bin, no need for ghost pads
0:00:00.999567958 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink_bin_queue:src and sink_bin_tee:sink
0:00:00.999576344 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:00.999587242 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink_bin_queue:src and sink_bin_tee:sink, successful
0:00:00.999593322 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.999601148 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<sink_bin_queue:src> Received event on flushing pad. Discarding
0:00:00.999775858 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “sink_sub_bin1”
0:00:00.999793237 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “sink_sub_bin_sink1”
0:00:00.999806465 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x56308d574be0 adding pad ‘sink’
0:00:00.999822695 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “capsfilter” named “sink_sub_bin_cap_filter1”
0:00:00.999834344 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d562590 adding pad ‘sink’
0:00:00.999844728 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d562590 adding pad ‘src’
0:00:00.999863085 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “render_queue1”
0:00:00.999879300 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55aac0 adding pad ‘sink’
0:00:00.999892663 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55aac0 adding pad ‘src’
0:00:00.999914450 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element sink_sub_bin_cap_filter1:(any) to element sink_sub_bin_sink1:(any)
0:00:00.999923393 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink
0:00:00.999931961 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_sub_bin_cap_filter1:sink> pad has no peer
0:00:00.999942697 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: sink_sub_bin_cap_filter1 and sink_sub_bin_sink1 in same bin, no need for ghost pads
0:00:00.999952515 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink
0:00:00.999960123 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_sub_bin_cap_filter1:sink> pad has no peer
0:00:00.999969801 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink, successful
0:00:00.999975721 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.999982093 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<sink_sub_bin_cap_filter1:src> Received event on flushing pad. Discarding
0:00:00.999991751 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element render_queue1:(any) to element sink_sub_bin_cap_filter1:(any)
0:00:00.999999887 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link render_queue1:src and sink_sub_bin_cap_filter1:sink
0:00:01.000007468 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<render_queue1:sink> pad has no peer
0:00:01.000018046 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: render_queue1 and sink_sub_bin_cap_filter1 in same bin, no need for ghost pads
0:00:01.000026657 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link render_queue1:src and sink_sub_bin_cap_filter1:sink
0:00:01.000033883 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<render_queue1:sink> pad has no peer
0:00:01.000044238 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked render_queue1:src and sink_sub_bin_cap_filter1:sink, successful
0:00:01.000050436 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.000056658 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<render_queue1:src> Received event on flushing pad. Discarding
0:00:01.000065796 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad render_queue1:sink
0:00:01.000081810 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad3 and render_queue1:sink
0:00:01.000089647 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad3 and render_queue1:sink, successful
0:00:01.000095817 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.000105490 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<sink_sub_bin1> adding pad ‘sink’
0:00:01.000128684 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<sink_bin_tee> adding pad ‘src_0’
0:00:01.000137057 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad sink_sub_bin1:sink
0:00:01.000145893 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink_bin_tee:src_0 and sink_sub_bin1:sink
0:00:01.000155896 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:01.000170950 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink_bin_tee:src_0 and sink_sub_bin1:sink, successful
0:00:01.000176966 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.000183454 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<sink_bin_tee:src_0> Received event on flushing pad. Discarding
0:00:01.000207891 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “osd_bin”
0:00:01.000221330 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvvideoconvert” named “osd_conv”
0:00:01.000237039 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d577ef0 adding pad ‘sink’
0:00:01.000247384 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d577ef0 adding pad ‘src’
0:00:01.000257570 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “osd_queue”
0:00:01.000272640 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55adc0 adding pad ‘sink’
0:00:01.000295184 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55adc0 adding pad ‘src’
0:00:01.000307500 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “osd_conv_queue”
0:00:01.000321089 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55b0c0 adding pad ‘sink’
0:00:01.000333650 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55b0c0 adding pad ‘src’
0:00:01.003591712 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so” loaded
0:00:01.003606177 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvdsosd” named “nvosd0”
0:00:01.003681200 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d589fa0 adding pad ‘sink’
0:00:01.003695096 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d589fa0 adding pad ‘src’
0:00:01.004065619 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element osd_queue:(any) to element osd_conv:(any)
0:00:01.004076702 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link osd_queue:src and osd_conv:sink
0:00:01.004086701 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:01.004097141 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_conv:src> pad has no peer
0:00:01.004140497 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: osd_queue and osd_conv in same bin, no need for ghost pads
0:00:01.004152095 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link osd_queue:src and osd_conv:sink
0:00:01.004160784 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:01.004169408 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_conv:src> pad has no peer
0:00:01.004220694 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked osd_queue:src and osd_conv:sink, successful
0:00:01.004227519 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.004235418 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<osd_queue:src> Received event on flushing pad. Discarding
0:00:01.004247297 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element osd_conv:(any) to element osd_conv_queue:(any)
0:00:01.004256771 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link osd_conv:src and osd_conv_queue:sink
0:00:01.004265594 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:01.004298818 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_conv_queue:src> pad has no peer
0:00:01.004309635 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: osd_conv and osd_conv_queue in same bin, no need for ghost pads
0:00:01.004319480 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link osd_conv:src and osd_conv_queue:sink
0:00:01.004327877 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:01.004359248 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_conv_queue:src> pad has no peer
0:00:01.004370428 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked osd_conv:src and osd_conv_queue:sink, successful
0:00:01.004376782 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.004384594 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<osd_conv:src> Received event on flushing pad. Discarding
0:00:01.004395765 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element osd_conv_queue:(any) to element nvosd0:(any)
0:00:01.004404455 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link osd_conv_queue:src and nvosd0:sink
0:00:01.004413243 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:01.004445580 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvosd0:src pad has no peer
0:00:01.004464317 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: osd_conv_queue and nvosd0 in same bin, no need for ghost pads
0:00:01.004474270 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link osd_conv_queue:src and nvosd0:sink
0:00:01.004483821 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:01.004515827 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvosd0:src pad has no peer
0:00:01.004546914 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked osd_conv_queue:src and nvosd0:sink, successful
0:00:01.004568488 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.004575890 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<osd_conv_queue:src> Received event on flushing pad. Discarding
0:00:01.004585640 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad osd_queue:sink
0:00:01.004604827 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad4 and osd_queue:sink
0:00:01.004613071 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad4 and osd_queue:sink, successful
0:00:01.004618911 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.004628158 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<osd_bin> adding pad ‘sink’
0:00:01.004636050 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nvosd0:src
0:00:01.004651411 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvosd0:src and src:proxypad5
0:00:01.004659448 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvosd0:src and src:proxypad5, successful
0:00:01.004665221 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.004671604 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvosd0:src Received event on flushing pad. Discarding
0:00:01.004679286 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<osd_bin> adding pad ‘src’
0:00:01.004701141 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element osd_bin:(any) to element sink_bin:(any)
0:00:01.004709859 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link osd_bin:src and sink_bin:sink
0:00:01.004721187 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_bin:sink> pad has no peer
0:00:01.004780406 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: osd_bin and sink_bin in same bin, no need for ghost pads
0:00:01.004791223 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link osd_bin:src and sink_bin:sink
0:00:01.004801900 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_bin:sink> pad has no peer
0:00:01.004851839 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked osd_bin:src and sink_bin:sink, successful
0:00:01.004858506 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.004865223 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<osd_bin:src> Received event on flushing pad. Discarding
0:00:01.004875072 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad osd_bin:sink
0:00:01.004891794 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad6 and osd_bin:sink
0:00:01.004899779 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad6 and osd_bin:sink, successful
0:00:01.004905466 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.004915462 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<processing_bin_0> adding pad ‘sink’
0:00:01.004923549 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nvosd0:sink
0:00:01.004960099 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “tiled_display_bin”
0:00:01.004974397 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “tiled_display_queue”
0:00:01.004995476 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55b3c0 adding pad ‘sink’
0:00:01.005010110 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55b3c0 adding pad ‘src’
0:00:01.005500836 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so” loaded
0:00:01.005513662 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvmultistreamtiler” named “tiled_display_tiler”
0:00:01.005579708 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d6410d0 adding pad ‘sink’
0:00:01.005593499 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d6410d0 adding pad ‘src’
0:00:01.005621819 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element tiled_display_queue:(any) to element tiled_display_tiler:(any)
0:00:01.005632161 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link tiled_display_queue:src and tiled_display_tiler:sink
0:00:01.005641468 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<tiled_display_queue:sink> pad has no peer
0:00:01.005651689 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<tiled_display_tiler:src> pad has no peer
0:00:01.005676347 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: tiled_display_queue and tiled_display_tiler in same bin, no need for ghost pads
0:00:01.005686974 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tiled_display_queue:src and tiled_display_tiler:sink
0:00:01.005695184 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<tiled_display_queue:sink> pad has no peer
0:00:01.005703711 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<tiled_display_tiler:src> pad has no peer
0:00:01.005723452 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tiled_display_queue:src and tiled_display_tiler:sink, successful
0:00:01.005729947 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.005737059 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<tiled_display_queue:src> Received event on flushing pad. Discarding
0:00:01.005747325 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad tiled_display_queue:sink
0:00:01.005765077 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad7 and tiled_display_queue:sink
0:00:01.005773097 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad7 and tiled_display_queue:sink, successful
0:00:01.005778720 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.005788420 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<tiled_display_bin> adding pad ‘sink’
0:00:01.005796207 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad tiled_display_tiler:src
0:00:01.005822928 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tiled_display_tiler:src and src:proxypad8
0:00:01.005831655 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tiled_display_tiler:src and src:proxypad8, successful
0:00:01.005837520 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.005843708 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<tiled_display_tiler:src> Received event on flushing pad. Discarding
0:00:01.005851648 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<tiled_display_bin> adding pad ‘src’
0:00:01.005869645 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element tiled_display_bin:(any) to element processing_bin_0:(any)
0:00:01.005878361 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link tiled_display_bin:src and processing_bin_0:sink
0:00:01.005889444 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<tiled_display_bin:sink> pad has no peer
0:00:01.005957357 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: tiled_display_bin and processing_bin_0 in same bin, no need for ghost pads
0:00:01.005994061 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tiled_display_bin:src and processing_bin_0:sink
0:00:01.006005973 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<tiled_display_bin:sink> pad has no peer
0:00:01.006068678 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tiled_display_bin:src and processing_bin_0:sink, successful
0:00:01.006076327 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.006083706 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<tiled_display_bin:src> Received event on flushing pad. Discarding
0:00:01.006103860 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<tiler_tee> adding pad ‘src_0’
0:00:01.006112804 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad tiled_display_bin:sink
0:00:01.006122274 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tiler_tee:src_0 and tiled_display_bin:sink
0:00:01.006130914 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<tiler_tee:sink> pad has no peer
0:00:01.006213560 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tiler_tee:src_0 and tiled_display_bin:sink, successful
0:00:01.006221124 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.006228420 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<tiler_tee:src_0> Received event on flushing pad. Discarding
0:00:01.006238891 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad sink_sub_bin_sink1:sink
0:00:01.006247267 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad tiled_display_bin:sink
0:00:01.006256853 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “primary_gie_bin”
0:00:01.006291593 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvvideoconvert” named “primary_gie_conv”
0:00:01.006335021 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d6460d0 adding pad ‘sink’
0:00:01.006345473 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d6460d0 adding pad ‘src’
0:00:01.006356101 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “primary_gie_queue”
0:00:01.006371954 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55b6c0 adding pad ‘sink’
0:00:01.006395074 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x56308d55b6c0 adding pad ‘src’
0:00:01.022088323 18040 0x56308d0b30c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so” loaded
0:00:01.022109102 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvinfer” named “primary_gie”
0:00:01.022241146 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d64f990 adding pad ‘sink’
0:00:01.022257991 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x56308d64f990 adding pad ‘src’
0:00:01.022639028 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element primary_gie_queue:(any) to element primary_gie_conv:(any)
0:00:01.022653871 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link primary_gie_queue:src and primary_gie_conv:sink
0:00:01.022666173 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_queue:sink> pad has no peer
0:00:01.022677837 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_conv:src> pad has no peer
0:00:01.022728171 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: primary_gie_queue and primary_gie_conv in same bin, no need for ghost pads
0:00:01.022741927 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary_gie_queue:src and primary_gie_conv:sink
0:00:01.022750607 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_queue:sink> pad has no peer
0:00:01.022759278 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_conv:src> pad has no peer
0:00:01.022793560 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary_gie_queue:src and primary_gie_conv:sink, successful
0:00:01.022800361 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.022807876 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary_gie_queue:src> Received event on flushing pad. Discarding
0:00:01.022821843 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element primary_gie_conv:(any) to element primary_gie:(any)
0:00:01.022830711 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link primary_gie_conv:src and primary_gie:sink
0:00:01.022839380 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_queue:sink> pad has no peer
0:00:01.022872131 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie:src> pad has no peer
0:00:01.022890397 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: primary_gie_conv and primary_gie in same bin, no need for ghost pads
0:00:01.022900151 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary_gie_conv:src and primary_gie:sink
0:00:01.022908607 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_queue:sink> pad has no peer
0:00:01.022939904 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie:src> pad has no peer
0:00:01.022956800 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary_gie_conv:src and primary_gie:sink, successful
0:00:01.022963173 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.022969666 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary_gie_conv:src> Received event on flushing pad. Discarding
0:00:01.022979819 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad primary_gie:src
0:00:01.023003443 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary_gie:src and src:proxypad9
0:00:01.023011956 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary_gie:src and src:proxypad9, successful
0:00:01.023017874 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.023024283 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary_gie:src> Received event on flushing pad. Discarding
0:00:01.023033147 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<primary_gie_bin> adding pad ‘src’
0:00:01.023041263 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad primary_gie_queue:sink
0:00:01.023056206 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad10 and primary_gie_queue:sink
0:00:01.023064424 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad10 and primary_gie_queue:sink, successful
0:00:01.023070246 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.023079839 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<primary_gie_bin> adding pad ‘sink’
0:00:01.023100624 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad primary_gie_bin:src
0:00:01.023108649 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad primary_gie_bin:src
0:00:01.023117336 18040 0x56308d0b30c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “tee” named “common_analytics_tee”
0:00:01.023137906 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x56308d56a3f0 adding pad ‘sink’
0:00:01.023155529 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element primary_gie_bin:(any) to element common_analytics_tee:(any)
0:00:01.023165314 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link primary_gie_bin:src and common_analytics_tee:sink
0:00:01.023178663 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_bin:sink> pad has no peer
0:00:01.023232303 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: primary_gie_bin and common_analytics_tee in same bin, no need for ghost pads
0:00:01.023243745 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary_gie_bin:src and common_analytics_tee:sink
0:00:01.023254989 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_bin:sink> pad has no peer
0:00:01.023302322 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary_gie_bin:src and common_analytics_tee:sink, successful
0:00:01.023309177 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.023315877 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary_gie_bin:src> Received event on flushing pad. Discarding
0:00:01.023327237 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element common_analytics_tee:(any) to element tiler_tee:(any)
0:00:01.023428675 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<common_analytics_tee> adding pad ‘src_0’
0:00:01.023446100 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: common_analytics_tee and tiler_tee in same bin, no need for ghost pads
0:00:01.023456275 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link common_analytics_tee:src_0 and tiler_tee:sink
0:00:01.023468903 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_bin:sink> pad has no peer
0:00:01.023583563 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked common_analytics_tee:src_0 and tiler_tee:sink, successful
0:00:01.023591361 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.023598353 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<common_analytics_tee:src_0> Received event on flushing pad. Discarding
0:00:01.023615488 18040 0x56308d0b30c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element multi_src_bin:(any) to element primary_gie_bin:(any)
0:00:01.023624319 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link multi_src_bin:src and primary_gie_bin:sink
0:00:01.023756644 18040 0x56308d0b30c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: multi_src_bin and primary_gie_bin in same bin, no need for ghost pads
0:00:01.023768034 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link multi_src_bin:src and primary_gie_bin:sink
0:00:01.023891361 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked multi_src_bin:src and primary_gie_bin:sink, successful
0:00:01.023898861 18040 0x56308d0b30c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:01.023906155 18040 0x56308d0b30c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<multi_src_bin:src> Received event on flushing pad. Discarding
0:00:01.027682063 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<processing_bin_0> current NULL pending VOID_PENDING, desired next READY
0:00:01.027748943 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin> current NULL pending VOID_PENDING, desired next READY
0:00:01.027781010 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin1> current NULL pending VOID_PENDING, desired next READY
0:00:01.027809153 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin_sink1> current NULL pending VOID_PENDING, desired next READY
0:00:01.027830286 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin_sink1> completed state change to READY
0:00:01.027850716 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin_sink1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.027900543 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘sink_sub_bin_sink1’ changed state to 2(READY) successfully
0:00:01.027922103 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin_cap_filter1> current NULL pending VOID_PENDING, desired next READY
0:00:01.027939223 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin_cap_filter1> completed state change to READY
0:00:01.027955383 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin_cap_filter1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.027978080 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘sink_sub_bin_cap_filter1’ changed state to 2(READY) successfully
0:00:01.027996400 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<render_queue1> current NULL pending VOID_PENDING, desired next READY
0:00:01.028012480 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<render_queue1> completed state change to READY
0:00:01.028028087 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<render_queue1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028048997 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘render_queue1’ changed state to 2(READY) successfully
0:00:01.028070287 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin1> completed state change to READY
0:00:01.028086470 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028107077 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_sub_bin1’ changed state to 2(READY) successfully
0:00:01.028125430 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin_tee> current NULL pending VOID_PENDING, desired next READY
0:00:01.028141290 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin_tee> completed state change to READY
0:00:01.028157343 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin_tee> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028177427 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_bin_tee’ changed state to 2(READY) successfully
0:00:01.028195297 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin_queue> current NULL pending VOID_PENDING, desired next READY
0:00:01.028211120 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin_queue> completed state change to READY
0:00:01.028225870 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028246680 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_bin_queue’ changed state to 2(READY) successfully
0:00:01.028262590 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin> completed state change to READY
0:00:01.028277680 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028297464 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<processing_bin_0> child ‘sink_bin’ changed state to 2(READY) successfully
0:00:01.028316297 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_bin> current NULL pending VOID_PENDING, desired next READY
0:00:01.028345510 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:01.028361717 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:01.028376847 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028396557 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<osd_bin> child ‘nvosd0’ changed state to 2(READY) successfully
0:00:01.028414540 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_conv_queue> current NULL pending VOID_PENDING, desired next READY
0:00:01.028430320 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<osd_conv_queue> completed state change to READY
0:00:01.028446120 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<osd_conv_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028466070 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<osd_bin> child ‘osd_conv_queue’ changed state to 2(READY) successfully
0:00:01.028484437 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_conv> current NULL pending VOID_PENDING, desired next READY
0:00:01.028502607 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<osd_conv> completed state change to READY
0:00:01.028517350 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<osd_conv> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028538290 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<osd_bin> child ‘osd_conv’ changed state to 2(READY) successfully
0:00:01.028556150 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_queue> current NULL pending VOID_PENDING, desired next READY
0:00:01.028571564 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<osd_queue> completed state change to READY
0:00:01.028587441 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<osd_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028608327 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<osd_bin> child ‘osd_queue’ changed state to 2(READY) successfully
0:00:01.028624871 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<osd_bin> completed state change to READY
0:00:01.028640404 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<osd_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028659901 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<processing_bin_0> child ‘osd_bin’ changed state to 2(READY) successfully
0:00:01.028676381 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<processing_bin_0> completed state change to READY
0:00:01.028692347 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<processing_bin_0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028712511 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘processing_bin_0’ changed state to 2(READY) successfully
0:00:01.028731297 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<tiled_display_bin> current NULL pending VOID_PENDING, desired next READY
0:00:01.028756181 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<tiled_display_tiler> current NULL pending VOID_PENDING, desired next READY
0:00:01.028772334 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<tiled_display_tiler> completed state change to READY
0:00:01.028787414 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<tiled_display_tiler> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028832451 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<tiled_display_bin> child ‘tiled_display_tiler’ changed state to 2(READY) successfully
0:00:01.028852061 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<tiled_display_queue> current NULL pending VOID_PENDING, desired next READY
0:00:01.028868484 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<tiled_display_queue> completed state change to READY
0:00:01.028883981 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<tiled_display_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028904987 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<tiled_display_bin> child ‘tiled_display_queue’ changed state to 2(READY) successfully
0:00:01.028922061 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<tiled_display_bin> completed state change to READY
0:00:01.028937454 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<tiled_display_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.028957491 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘tiled_display_bin’ changed state to 2(READY) successfully
0:00:01.028975771 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<tiler_tee> current NULL pending VOID_PENDING, desired next READY
0:00:01.028991924 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<tiler_tee> completed state change to READY
0:00:01.029006874 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<tiler_tee> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.029027584 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘tiler_tee’ changed state to 2(READY) successfully
0:00:01.029049081 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<common_analytics_tee> current NULL pending VOID_PENDING, desired next READY
0:00:01.029067221 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<common_analytics_tee> completed state change to READY
0:00:01.029084251 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<common_analytics_tee> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.029106464 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘common_analytics_tee’ changed state to 2(READY) successfully
0:00:01.029127411 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary_gie_bin> current NULL pending VOID_PENDING, desired next READY
0:00:01.029156278 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary_gie> current NULL pending VOID_PENDING, desired next READY
0:00:01.029174231 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<primary_gie> completed state change to READY
0:00:01.029191508 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<primary_gie> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.029214158 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<primary_gie_bin> child ‘primary_gie’ changed state to 2(READY) successfully
0:00:01.029234904 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary_gie_conv> current NULL pending VOID_PENDING, desired next READY
0:00:01.029253541 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<primary_gie_conv> completed state change to READY
0:00:01.029270978 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<primary_gie_conv> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.029292785 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<primary_gie_bin> child ‘primary_gie_conv’ changed state to 2(READY) successfully
0:00:01.029312488 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary_gie_queue> current NULL pending VOID_PENDING, desired next READY
0:00:01.029331065 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<primary_gie_queue> completed state change to READY
0:00:01.029348435 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<primary_gie_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.029372831 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<primary_gie_bin> child ‘primary_gie_queue’ changed state to 2(READY) successfully
0:00:01.029390608 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<primary_gie_bin> completed state change to READY
0:00:01.029407745 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<primary_gie_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.029429538 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘primary_gie_bin’ changed state to 2(READY) successfully
0:00:01.029449628 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<multi_src_bin> current NULL pending VOID_PENDING, desired next READY
0:00:01.029477845 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_bin_muxer> current NULL pending VOID_PENDING, desired next READY
0:00:01.156856593 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_bin_muxer> completed state change to READY
0:00:01.156889824 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_bin_muxer> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.156918191 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<multi_src_bin> child ‘src_bin_muxer’ changed state to 2(READY) successfully
0:00:01.156937412 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_sub_bin0> current NULL pending VOID_PENDING, desired next READY
0:00:01.156970184 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_fakesink> current NULL pending VOID_PENDING, desired next READY
0:00:01.156983473 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_fakesink> completed state change to READY
0:00:01.156993464 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_fakesink> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157007357 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘src_fakesink’ changed state to 2(READY) successfully
0:00:01.157018190 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:01.157027892 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:01.157036843 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157048814 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘fakequeue’ changed state to 2(READY) successfully
0:00:01.157060390 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_cap_filter_nvvidconv> current NULL pending VOID_PENDING, desired next READY
0:00:01.157070014 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_cap_filter_nvvidconv> completed state change to READY
0:00:01.157079016 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_cap_filter_nvvidconv> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157096228 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘src_cap_filter_nvvidconv’ changed state to 2(READY) successfully
0:00:01.157108327 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvidconv_elem> current NULL pending VOID_PENDING, desired next READY
0:00:01.157122140 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvidconv_elem> completed state change to READY
0:00:01.157131134 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvidconv_elem> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157143203 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘nvvidconv_elem’ changed state to 2(READY) successfully
0:00:01.157153666 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:01.157162805 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:01.157171635 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157183296 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘queue’ changed state to 2(READY) successfully
0:00:01.157193395 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:01.157203426 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:01.157212325 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157224188 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘tee0’ changed state to 2(READY) successfully
0:00:01.157235211 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_elem> current NULL pending VOID_PENDING, desired next READY
0:00:01.157249546 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_elem> completed state change to READY
0:00:01.157258586 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_elem> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157271636 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘src_elem’ changed state to 2(READY) successfully
0:00:01.157281274 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_sub_bin0> completed state change to READY
0:00:01.157290302 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_sub_bin0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157302055 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<multi_src_bin> child ‘src_sub_bin0’ changed state to 2(READY) successfully
0:00:01.157316453 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<multi_src_bin> completed state change to READY
0:00:01.157325497 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<multi_src_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.157337697 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘multi_src_bin’ changed state to 2(READY) successfully
0:00:01.157350643 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:01.157360167 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:01.157371430 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:01.157391293 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<processing_bin_0> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.157407468 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.157423832 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin1> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.157440291 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin_sink1> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.157465038 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin_sink1> completed state change to PAUSED
0:00:01.157474963 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin_sink1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.157488687 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘sink_sub_bin_sink1’ changed state to 3(PAUSED) successfully
0:00:01.157499436 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin_cap_filter1> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.157517181 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin_cap_filter1> completed state change to PAUSED
0:00:01.157526561 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin_cap_filter1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.157539024 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘sink_sub_bin_cap_filter1’ changed state to 3(PAUSED) successfully
0:00:01.157549750 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<render_queue1> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.157580870 18040 0x56308d0b30c0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x56308d571250 on task 0x56308d71b050
0:00:01.157592104 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:<render_queue1:src> created task 0x56308d71b050
0:00:01.157671847 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<render_queue1> completed state change to PAUSED
0:00:01.157683584 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<render_queue1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.157696849 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘render_queue1’ changed state to 3(PAUSED) successfully
0:00:01.157712379 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin1> completed state change to PAUSED
0:00:01.157721775 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.157735080 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_sub_bin1’ changed state to 3(PAUSED) successfully
0:00:01.157746308 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin_tee> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.157761505 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin_tee> completed state change to PAUSED
0:00:01.157770863 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin_tee> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.157782501 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_bin_tee’ changed state to 3(PAUSED) successfully
0:00:01.157793339 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin_queue> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.157811162 18040 0x56308d0b30c0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x56308d570470 on task 0x56308d71b170
0:00:01.157820712 18040 0x56308d0b30c0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:<sink_bin_queue:src> created task 0x56308d71b170
0:00:01.158017891 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin_queue> completed state change to PAUSED
0:00:01.158030225 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin_queue> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.158043806 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_bin_queue’ changed state to 3(PAUSED) successfully
0:00:01.158058596 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin> completed state change to PAUSED
0:00:01.158068196 18040 0x56308d0b30c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.158080594 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<processing_bin_0> child ‘sink_bin’ changed state to 3(PAUSED) successfully
0:00:01.158092032 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_bin> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.158115768 18040 0x56308d0b30c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
(base) sysadm@ubuntu-t4:/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-app$
I modified the config file to run only with one source to reduce the size of the log…thanks a lot
Seems the log is not complete, except this, can you paste the configuration and log from standard output?
Regarding the log, If I run with gst-debug = 1 or 2 or 3 , I don’t get anything. (And also if I run without any gst-debug)
I am attaching another log
(base) sysadm@ubuntu-t4:/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-app$ ./deepstream-app -c …/…/…/…/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt --gst-debug=4
0:00:00.000501486 19486 0x55882b0d40c0 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.001057759 19486 0x55882b0d40c0 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.001351778 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.001481266 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.001496746 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.001521226 19486 0x55882b0d40c0 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/sysadm/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.015946603 19486 0x55882b0d40c0 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/sysadm/.cache/gstreamer-1.0/registry.x86_64.bin in 0.014396 seconds
0:00:00.015996258 19486 0x55882b0d40c0 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/sysadm/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.017494427 19486 0x55882b0d40c0 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.017508382 19486 0x55882b0d40c0 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.017516506 19486 0x55882b0d40c0 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.017524035 19486 0x55882b0d40c0 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.017529245 19486 0x55882b0d40c0 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.017861904 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “pipeline” named “pipeline”
0:00:00.017956975 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “multi_src_bin”
0:00:00.973770912 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so” loaded
0:00:00.973815321 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvstreammux” named “src_bin_muxer”
0:00:00.974062983 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstNvStreamMux@0x55882b56a1f0 adding pad ‘src’
0:00:00.974110002 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin0”
0:00:00.974765876 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstplayback.so” loaded
0:00:00.974777860 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.975427177 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.975440470 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “queue”
0:00:00.975513862 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57a1c0 adding pad ‘sink’
0:00:00.975532107 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57a1c0 adding pad ‘src’
0:00:00.975856779 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so” loaded
0:00:00.975868745 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvvideoconvert” named “nvvidconv_elem”
0:00:00.976028502 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b580a70 adding pad ‘sink’
0:00:00.976044538 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b580a70 adding pad ‘src’
0:00:00.976075885 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “capsfilter” named “src_cap_filter_nvvidconv”
0:00:00.976134505 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b582250 adding pad ‘sink’
0:00:00.976146108 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b582250 adding pad ‘src’
0:00:00.976162842 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.976192422 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter_nvvidconv:src
0:00:00.976237081 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter_nvvidconv:src and src:proxypad0
0:00:00.976247948 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter_nvvidconv:src and src:proxypad0, successful
0:00:00.976253855 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.976261302 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<src_cap_filter_nvvidconv:src> Received event on flushing pad. Discarding
0:00:00.976273889 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin0> adding pad ‘src’
0:00:00.976282957 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.976353928 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x55882b587410 adding pad ‘sink’
0:00:00.976367518 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.976382662 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57a4c0 adding pad ‘sink’
0:00:00.976396212 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57a4c0 adding pad ‘src’
0:00:00.976409724 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.976458130 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x55882b58b000 adding pad ‘sink’
0:00:00.976485704 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.976495953 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.976523117 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.976539527 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.976549721 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.976557654 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.976567950 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.976573955 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.976580397 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.976615026 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.976624243 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad queue:sink
0:00:00.976633978 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee0:src_0 and queue:sink
0:00:00.976641931 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.976650913 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:queue:src pad has no peer
0:00:00.976659603 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee0:src_0 and queue:sink, successful
0:00:00.976665303 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.976671596 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:tee0:src_0 Received event on flushing pad. Discarding
0:00:00.976681601 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element queue:(any) to element nvvidconv_elem:(any)
0:00:00.976689806 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link queue:src and nvvidconv_elem:sink
0:00:00.976697531 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.976708986 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvidconv_elem:src> pad has no peer
0:00:00.976767039 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: queue and nvvidconv_elem in same bin, no need for ghost pads
0:00:00.976777253 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link queue:src and nvvidconv_elem:sink
0:00:00.976785456 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.976794403 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvidconv_elem:src> pad has no peer
0:00:00.976827696 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked queue:src and nvvidconv_elem:sink, successful
0:00:00.976833777 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.976841629 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:queue:src Received event on flushing pad. Discarding
0:00:00.976852393 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvvidconv_elem:(any) to element src_cap_filter_nvvidconv:(any)
0:00:00.976861330 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvvidconv_elem:src and src_cap_filter_nvvidconv:sink
0:00:00.976870107 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.976905690 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<src_sub_bin0:src> pad has no peer
0:00:00.976917273 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvvidconv_elem and src_cap_filter_nvvidconv in same bin, no need for ghost pads
0:00:00.976926430 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvvidconv_elem:src and src_cap_filter_nvvidconv:sink
0:00:00.976934742 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.976965970 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<src_sub_bin0:src> pad has no peer
0:00:00.976977586 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvvidconv_elem:src and src_cap_filter_nvvidconv:sink, successful
0:00:00.976983647 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.976990190 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvvidconv_elem:src> Received event on flushing pad. Discarding
0:00:00.977005886 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.977014300 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.977023152 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee0:src_1 and fakequeue:sink
0:00:00.977030520 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.977041973 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee0:src_1 and fakequeue:sink, successful
0:00:00.977047839 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.977054269 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:tee0:src_1 Received event on flushing pad. Discarding
0:00:00.977091865 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_0’ in element “src_bin_muxer”
0:00:00.977119122 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_0’
0:00:00.977129926 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin0:src
0:00:00.977139606 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin0:src and src_bin_muxer:sink_0
0:00:00.977150866 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.977197615 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.977220729 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin0:src and src_bin_muxer:sink_0, successful
0:00:00.977226928 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.977233655 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<src_sub_bin0:src> Received event on flushing pad. Discarding
0:00:00.977243432 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_bin_muxer:src
0:00:00.977262746 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_bin_muxer:src and src:proxypad1
0:00:00.977271453 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_bin_muxer:src and src:proxypad1, successful
0:00:00.977277180 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.977283208 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<src_bin_muxer:src> Received event on flushing pad. Discarding
0:00:00.977291675 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<multi_src_bin> adding pad ‘src’
0:00:00.977336296 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “tee” named “tiler_tee”
0:00:00.977363822 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x55882b58b150 adding pad ‘sink’
0:00:00.977381131 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvstreamdemux” named “demuxer”
0:00:00.977429299 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstNvStreamDemux@0x55882b592070 adding pad ‘sink’
0:00:00.977452943 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “processing_bin_0”
0:00:00.977468441 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “sink_bin”
0:00:00.977481162 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “sink_bin_queue”
0:00:00.977496548 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57a7c0 adding pad ‘sink’
0:00:00.977510273 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57a7c0 adding pad ‘src’
0:00:00.977529795 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad sink_bin_queue:sink
0:00:00.977548754 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad2 and sink_bin_queue:sink
0:00:00.977557312 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad2 and sink_bin_queue:sink, successful
0:00:00.977563231 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.977572875 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<sink_bin> adding pad ‘sink’
0:00:00.977581022 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “tee” named “sink_bin_tee”
0:00:00.977597261 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x55882b58b2a0 adding pad ‘sink’
0:00:00.977612662 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element sink_bin_queue:(any) to element sink_bin_tee:(any)
0:00:00.977621211 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link sink_bin_queue:src and sink_bin_tee:sink
0:00:00.977630318 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:00.977641748 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: sink_bin_queue and sink_bin_tee in same bin, no need for ghost pads
0:00:00.977651586 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink_bin_queue:src and sink_bin_tee:sink
0:00:00.977659522 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:00.977670404 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink_bin_queue:src and sink_bin_tee:sink, successful
0:00:00.977676274 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.977682327 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<sink_bin_queue:src> Received event on flushing pad. Discarding
0:00:00.977837402 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “sink_sub_bin1”
0:00:00.977854905 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “sink_sub_bin_sink1”
0:00:00.977868512 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x55882b597890 adding pad ‘sink’
0:00:00.977885051 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “capsfilter” named “sink_sub_bin_cap_filter1”
0:00:00.977896891 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b582590 adding pad ‘sink’
0:00:00.977907474 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b582590 adding pad ‘src’
0:00:00.977923098 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “render_queue1”
0:00:00.977950084 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57aac0 adding pad ‘sink’
0:00:00.977966288 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57aac0 adding pad ‘src’
0:00:00.977984554 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element sink_sub_bin_cap_filter1:(any) to element sink_sub_bin_sink1:(any)
0:00:00.977992737 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink
0:00:00.978000804 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_sub_bin_cap_filter1:sink> pad has no peer
0:00:00.978011094 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: sink_sub_bin_cap_filter1 and sink_sub_bin_sink1 in same bin, no need for ghost pads
0:00:00.978022744 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink
0:00:00.978029928 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_sub_bin_cap_filter1:sink> pad has no peer
0:00:00.978039618 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink_sub_bin_cap_filter1:src and sink_sub_bin_sink1:sink, successful
0:00:00.978045323 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.978051164 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<sink_sub_bin_cap_filter1:src> Received event on flushing pad. Discarding
0:00:00.978072301 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element render_queue1:(any) to element sink_sub_bin_cap_filter1:(any)
0:00:00.978080690 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link render_queue1:src and sink_sub_bin_cap_filter1:sink
0:00:00.978088235 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<render_queue1:sink> pad has no peer
0:00:00.978098724 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: render_queue1 and sink_sub_bin_cap_filter1 in same bin, no need for ghost pads
0:00:00.978106987 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link render_queue1:src and sink_sub_bin_cap_filter1:sink
0:00:00.978114194 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<render_queue1:sink> pad has no peer
0:00:00.978124386 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked render_queue1:src and sink_sub_bin_cap_filter1:sink, successful
0:00:00.978130346 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.978135918 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<render_queue1:src> Received event on flushing pad. Discarding
0:00:00.978144848 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad render_queue1:sink
0:00:00.978161064 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad3 and render_queue1:sink
0:00:00.978169436 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad3 and render_queue1:sink, successful
0:00:00.978176110 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.978184758 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<sink_sub_bin1> adding pad ‘sink’
0:00:00.978207988 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<sink_bin_tee> adding pad ‘src_0’
0:00:00.978216058 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad sink_sub_bin1:sink
0:00:00.978224853 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink_bin_tee:src_0 and sink_sub_bin1:sink
0:00:00.978239280 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<sink_bin:sink> pad has no peer
0:00:00.978255241 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink_bin_tee:src_0 and sink_sub_bin1:sink, successful
0:00:00.978261237 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.978267857 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<sink_bin_tee:src_0> Received event on flushing pad. Discarding
0:00:00.978292596 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “osd_bin”
0:00:00.978306047 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvvideoconvert” named “osd_conv”
0:00:00.978318557 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b59b2d0 adding pad ‘sink’
0:00:00.978329179 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b59b2d0 adding pad ‘src’
0:00:00.978340056 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “osd_queue”
0:00:00.978363336 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57adc0 adding pad ‘sink’
0:00:00.978377243 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57adc0 adding pad ‘src’
0:00:00.978389621 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “osd_conv_queue”
0:00:00.978403301 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57b0c0 adding pad ‘sink’
0:00:00.978416357 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57b0c0 adding pad ‘src’
0:00:00.981660476 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so” loaded
0:00:00.981674823 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvdsosd” named “nvosd0”
0:00:00.981757243 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b5ada30 adding pad ‘sink’
0:00:00.981770682 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b5ada30 adding pad ‘src’
0:00:00.982122271 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element osd_queue:(any) to element osd_conv:(any)
0:00:00.982132666 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link osd_queue:src and osd_conv:sink
0:00:00.982142266 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.982151986 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_conv:src> pad has no peer
0:00:00.982196966 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: osd_queue and osd_conv in same bin, no need for ghost pads
0:00:00.982208031 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link osd_queue:src and osd_conv:sink
0:00:00.982215702 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.982223761 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_conv:src> pad has no peer
0:00:00.982257228 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked osd_queue:src and osd_conv:sink, successful
0:00:00.982263355 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.982270502 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<osd_queue:src> Received event on flushing pad. Discarding
0:00:00.982281658 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element osd_conv:(any) to element osd_conv_queue:(any)
0:00:00.982290142 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link osd_conv:src and osd_conv_queue:sink
0:00:00.982298619 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.982330579 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_conv_queue:src> pad has no peer
0:00:00.982340598 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: osd_conv and osd_conv_queue in same bin, no need for ghost pads
0:00:00.982349712 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link osd_conv:src and osd_conv_queue:sink
0:00:00.982357359 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.982387325 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_conv_queue:src> pad has no peer
0:00:00.982400100 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked osd_conv:src and osd_conv_queue:sink, successful
0:00:00.982405972 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.982412265 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<osd_conv:src> Received event on flushing pad. Discarding
0:00:00.982422795 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element osd_conv_queue:(any) to element nvosd0:(any)
0:00:00.982430725 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link osd_conv_queue:src and nvosd0:sink
0:00:00.982438702 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.982469978 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvosd0:src pad has no peer
0:00:00.982488522 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: osd_conv_queue and nvosd0 in same bin, no need for ghost pads
0:00:00.982497742 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link osd_conv_queue:src and nvosd0:sink
0:00:00.982505920 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_queue:sink> pad has no peer
0:00:00.982536298 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:nvosd0:src pad has no peer
0:00:00.982551631 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked osd_conv_queue:src and nvosd0:sink, successful
0:00:00.982557371 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.982564563 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<osd_conv_queue:src> Received event on flushing pad. Discarding
0:00:00.982573915 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad osd_queue:sink
0:00:00.982593107 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad4 and osd_queue:sink
0:00:00.982601485 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad4 and osd_queue:sink, successful
0:00:00.982607225 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.982616244 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<osd_bin> adding pad ‘sink’
0:00:00.982624123 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nvosd0:src
0:00:00.982641294 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvosd0:src and src:proxypad5
0:00:00.982649528 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvosd0:src and src:proxypad5, successful
0:00:00.982654997 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.982661217 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:nvosd0:src Received event on flushing pad. Discarding
0:00:00.982669658 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<osd_bin> adding pad ‘src’
0:00:00.982690821 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element osd_bin:(any) to element sink_bin:(any)
0:00:00.982699273 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link osd_bin:src and sink_bin:sink
0:00:00.982710307 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_bin:sink> pad has no peer
0:00:00.982766187 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: osd_bin and sink_bin in same bin, no need for ghost pads
0:00:00.982776374 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link osd_bin:src and sink_bin:sink
0:00:00.982786557 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<osd_bin:sink> pad has no peer
0:00:00.982863159 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked osd_bin:src and sink_bin:sink, successful
0:00:00.982870779 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.982878893 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<osd_bin:src> Received event on flushing pad. Discarding
0:00:00.982890239 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad osd_bin:sink
0:00:00.982909667 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad6 and osd_bin:sink
0:00:00.982919411 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad6 and osd_bin:sink, successful
0:00:00.982926226 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.982935476 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<processing_bin_0> adding pad ‘sink’
0:00:00.982943694 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nvosd0:sink
0:00:00.982984103 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘src_00’ in element “demuxer”
0:00:00.983002136 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_00’
0:00:00.983011464 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad demuxer:src_00
0:00:00.983019153 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad processing_bin_0:sink
0:00:00.983030184 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link demuxer:src_00 and processing_bin_0:sink
0:00:00.983099302 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked demuxer:src_00 and processing_bin_0:sink, successful
0:00:00.983106994 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.983119697 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad sink_sub_bin_sink1:sink
0:00:00.983145293 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad demuxer:sink
0:00:00.983169632 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “primary_gie_bin”
0:00:00.983202893 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvvideoconvert” named “primary_gie_conv”
0:00:00.983216575 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b6618d0 adding pad ‘sink’
0:00:00.983227425 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b6618d0 adding pad ‘src’
0:00:00.983238133 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “primary_gie_queue”
0:00:00.983254787 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57b3c0 adding pad ‘sink’
0:00:00.983268483 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x55882b57b3c0 adding pad ‘src’
0:00:00.997626174 19486 0x55882b0d40c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so” loaded
0:00:00.997642016 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvinfer” named “primary_gie”
0:00:00.997745304 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b57e8f0 adding pad ‘sink’
0:00:00.997770265 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseTransform@0x55882b57e8f0 adding pad ‘src’
0:00:00.998098557 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element primary_gie_queue:(any) to element primary_gie_conv:(any)
0:00:00.998110302 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link primary_gie_queue:src and primary_gie_conv:sink
0:00:00.998118373 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_queue:sink> pad has no peer
0:00:00.998126902 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_conv:src> pad has no peer
0:00:00.998178992 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: primary_gie_queue and primary_gie_conv in same bin, no need for ghost pads
0:00:00.998189949 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary_gie_queue:src and primary_gie_conv:sink
0:00:00.998197212 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_queue:sink> pad has no peer
0:00:00.998204936 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_conv:src> pad has no peer
0:00:00.998236380 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary_gie_queue:src and primary_gie_conv:sink, successful
0:00:00.998242402 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998249526 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary_gie_queue:src> Received event on flushing pad. Discarding
0:00:00.998276479 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element primary_gie_conv:(any) to element primary_gie:(any)
0:00:00.998284709 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link primary_gie_conv:src and primary_gie:sink
0:00:00.998292832 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_queue:sink> pad has no peer
0:00:00.998324337 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie:src> pad has no peer
0:00:00.998341486 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: primary_gie_conv and primary_gie in same bin, no need for ghost pads
0:00:00.998350412 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary_gie_conv:src and primary_gie:sink
0:00:00.998357947 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_queue:sink> pad has no peer
0:00:00.998387697 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie:src> pad has no peer
0:00:00.998403615 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary_gie_conv:src and primary_gie:sink, successful
0:00:00.998409516 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998415739 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary_gie_conv:src> Received event on flushing pad. Discarding
0:00:00.998424827 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad primary_gie:src
0:00:00.998445700 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary_gie:src and src:proxypad7
0:00:00.998453918 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary_gie:src and src:proxypad7, successful
0:00:00.998459728 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998465658 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary_gie:src> Received event on flushing pad. Discarding
0:00:00.998474268 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<primary_gie_bin> adding pad ‘src’
0:00:00.998481875 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad primary_gie_queue:sink
0:00:00.998499510 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link sink:proxypad8 and primary_gie_queue:sink
0:00:00.998507772 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked sink:proxypad8 and primary_gie_queue:sink, successful
0:00:00.998513482 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998522240 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<primary_gie_bin> adding pad ‘sink’
0:00:00.998541280 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad primary_gie_bin:src
0:00:00.998548365 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad primary_gie_bin:src
0:00:00.998556402 19486 0x55882b0d40c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “tee” named “common_analytics_tee”
0:00:00.998575480 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x55882b58b3f0 adding pad ‘sink’
0:00:00.998591409 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element primary_gie_bin:(any) to element common_analytics_tee:(any)
0:00:00.998599896 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link primary_gie_bin:src and common_analytics_tee:sink
0:00:00.998611721 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_bin:sink> pad has no peer
0:00:00.998664391 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: primary_gie_bin and common_analytics_tee in same bin, no need for ghost pads
0:00:00.998675152 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary_gie_bin:src and common_analytics_tee:sink
0:00:00.998684975 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_bin:sink> pad has no peer
0:00:00.998743608 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary_gie_bin:src and common_analytics_tee:sink, successful
0:00:00.998749692 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998756515 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary_gie_bin:src> Received event on flushing pad. Discarding
0:00:00.998766935 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element common_analytics_tee:(any) to element demuxer:(any)
0:00:00.998803739 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<common_analytics_tee> adding pad ‘src_0’
0:00:00.998838684 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: common_analytics_tee and demuxer in same bin, no need for ghost pads
0:00:00.998849708 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link common_analytics_tee:src_0 and demuxer:sink
0:00:00.998862158 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary_gie_bin:sink> pad has no peer
0:00:00.998916321 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked common_analytics_tee:src_0 and demuxer:sink, successful
0:00:00.998923217 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.998930202 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<common_analytics_tee:src_0> Received event on flushing pad. Discarding
0:00:00.998941327 19486 0x55882b0d40c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element multi_src_bin:(any) to element primary_gie_bin:(any)
0:00:00.998950178 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link multi_src_bin:src and primary_gie_bin:sink
0:00:00.999004371 19486 0x55882b0d40c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: multi_src_bin and primary_gie_bin in same bin, no need for ghost pads
0:00:00.999014789 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link multi_src_bin:src and primary_gie_bin:sink
0:00:00.999063711 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked multi_src_bin:src and primary_gie_bin:sink, successful
0:00:00.999070528 19486 0x55882b0d40c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.999077324 19486 0x55882b0d40c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<multi_src_bin:src> Received event on flushing pad. Discarding
0:00:00.999602276 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<processing_bin_0> current NULL pending VOID_PENDING, desired next READY
0:00:00.999619314 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin> current NULL pending VOID_PENDING, desired next READY
0:00:00.999631534 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin1> current NULL pending VOID_PENDING, desired next READY
0:00:00.999658614 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin_sink1> current NULL pending VOID_PENDING, desired next READY
0:00:00.999667997 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin_sink1> completed state change to READY
0:00:00.999678413 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin_sink1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999699946 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘sink_sub_bin_sink1’ changed state to 2(READY) successfully
0:00:00.999709124 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin_cap_filter1> current NULL pending VOID_PENDING, desired next READY
0:00:00.999716942 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin_cap_filter1> completed state change to READY
0:00:00.999724567 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin_cap_filter1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999734767 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘sink_sub_bin_cap_filter1’ changed state to 2(READY) successfully
0:00:00.999742950 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<render_queue1> current NULL pending VOID_PENDING, desired next READY
0:00:00.999750109 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<render_queue1> completed state change to READY
0:00:00.999757300 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<render_queue1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999766742 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘render_queue1’ changed state to 2(READY) successfully
0:00:00.999775419 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin1> completed state change to READY
0:00:00.999782537 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999791932 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_sub_bin1’ changed state to 2(READY) successfully
0:00:00.999800493 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin_tee> current NULL pending VOID_PENDING, desired next READY
0:00:00.999807806 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin_tee> completed state change to READY
0:00:00.999814593 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin_tee> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999824833 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_bin_tee’ changed state to 2(READY) successfully
0:00:00.999832790 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin_queue> current NULL pending VOID_PENDING, desired next READY
0:00:00.999840160 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin_queue> completed state change to READY
0:00:00.999846873 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999856712 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_bin_queue’ changed state to 2(READY) successfully
0:00:00.999863890 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin> completed state change to READY
0:00:00.999870933 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999879837 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<processing_bin_0> child ‘sink_bin’ changed state to 2(READY) successfully
0:00:00.999887742 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_bin> current NULL pending VOID_PENDING, desired next READY
0:00:00.999900073 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.999907315 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:00.999914843 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999923769 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<osd_bin> child ‘nvosd0’ changed state to 2(READY) successfully
0:00:00.999931747 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_conv_queue> current NULL pending VOID_PENDING, desired next READY
0:00:00.999939063 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<osd_conv_queue> completed state change to READY
0:00:00.999946352 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<osd_conv_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999955710 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<osd_bin> child ‘osd_conv_queue’ changed state to 2(READY) successfully
0:00:00.999963629 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_conv> current NULL pending VOID_PENDING, desired next READY
0:00:00.999971445 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<osd_conv> completed state change to READY
0:00:00.999978469 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<osd_conv> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.999987633 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<osd_bin> child ‘osd_conv’ changed state to 2(READY) successfully
0:00:00.999995603 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_queue> current NULL pending VOID_PENDING, desired next READY
0:00:01.000003093 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<osd_queue> completed state change to READY
0:00:01.000010258 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<osd_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000025529 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<osd_bin> child ‘osd_queue’ changed state to 2(READY) successfully
0:00:01.000033015 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<osd_bin> completed state change to READY
0:00:01.000040010 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<osd_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000049679 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<processing_bin_0> child ‘osd_bin’ changed state to 2(READY) successfully
0:00:01.000056693 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<processing_bin_0> completed state change to READY
0:00:01.000063698 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<processing_bin_0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000072742 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘processing_bin_0’ changed state to 2(READY) successfully
0:00:01.000081085 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:01.000088546 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:01.000095460 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000105545 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘demuxer’ changed state to 2(READY) successfully
0:00:01.000113678 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<common_analytics_tee> current NULL pending VOID_PENDING, desired next READY
0:00:01.000121655 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<common_analytics_tee> completed state change to READY
0:00:01.000128563 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<common_analytics_tee> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000137475 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘common_analytics_tee’ changed state to 2(READY) successfully
0:00:01.000145635 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary_gie_bin> current NULL pending VOID_PENDING, desired next READY
0:00:01.000156938 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary_gie> current NULL pending VOID_PENDING, desired next READY
0:00:01.000164268 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<primary_gie> completed state change to READY
0:00:01.000172405 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<primary_gie> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000181252 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<primary_gie_bin> child ‘primary_gie’ changed state to 2(READY) successfully
0:00:01.000189565 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary_gie_conv> current NULL pending VOID_PENDING, desired next READY
0:00:01.000196966 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<primary_gie_conv> completed state change to READY
0:00:01.000203779 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<primary_gie_conv> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000212662 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<primary_gie_bin> child ‘primary_gie_conv’ changed state to 2(READY) successfully
0:00:01.000220443 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary_gie_queue> current NULL pending VOID_PENDING, desired next READY
0:00:01.000227659 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<primary_gie_queue> completed state change to READY
0:00:01.000234508 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<primary_gie_queue> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000244899 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<primary_gie_bin> child ‘primary_gie_queue’ changed state to 2(READY) successfully
0:00:01.000252092 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<primary_gie_bin> completed state change to READY
0:00:01.000259545 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<primary_gie_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.000268601 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘primary_gie_bin’ changed state to 2(READY) successfully
0:00:01.000276715 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<multi_src_bin> current NULL pending VOID_PENDING, desired next READY
0:00:01.000287664 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_bin_muxer> current NULL pending VOID_PENDING, desired next READY
0:00:01.105202860 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_bin_muxer> completed state change to READY
0:00:01.105237371 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_bin_muxer> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105262843 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<multi_src_bin> child ‘src_bin_muxer’ changed state to 2(READY) successfully
0:00:01.105294174 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_sub_bin0> current NULL pending VOID_PENDING, desired next READY
0:00:01.105339320 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_fakesink> current NULL pending VOID_PENDING, desired next READY
0:00:01.105349688 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_fakesink> completed state change to READY
0:00:01.105357148 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_fakesink> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105367127 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘src_fakesink’ changed state to 2(READY) successfully
0:00:01.105375132 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:01.105382132 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:01.105388788 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105397905 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘fakequeue’ changed state to 2(READY) successfully
0:00:01.105406471 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_cap_filter_nvvidconv> current NULL pending VOID_PENDING, desired next READY
0:00:01.105413503 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_cap_filter_nvvidconv> completed state change to READY
0:00:01.105420544 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_cap_filter_nvvidconv> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105434361 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘src_cap_filter_nvvidconv’ changed state to 2(READY) successfully
0:00:01.105442883 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvidconv_elem> current NULL pending VOID_PENDING, desired next READY
0:00:01.105452098 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvidconv_elem> completed state change to READY
0:00:01.105458873 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvidconv_elem> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105467878 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘nvvidconv_elem’ changed state to 2(READY) successfully
0:00:01.105475701 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:01.105482663 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:01.105489403 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105499557 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘queue’ changed state to 2(READY) successfully
0:00:01.105507458 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:01.105514721 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:00:01.105521667 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105530930 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘tee0’ changed state to 2(READY) successfully
0:00:01.105539031 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<src_elem> current NULL pending VOID_PENDING, desired next READY
0:00:01.105549844 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_elem> completed state change to READY
0:00:01.105556764 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_elem> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105566283 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<src_sub_bin0> child ‘src_elem’ changed state to 2(READY) successfully
0:00:01.105573316 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<src_sub_bin0> completed state change to READY
0:00:01.105580106 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<src_sub_bin0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105588857 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<multi_src_bin> child ‘src_sub_bin0’ changed state to 2(READY) successfully
0:00:01.105596004 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<multi_src_bin> completed state change to READY
0:00:01.105603163 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<multi_src_bin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105613496 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘multi_src_bin’ changed state to 2(READY) successfully
0:00:01.105622760 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<tiler_tee> current NULL pending VOID_PENDING, desired next READY
0:00:01.105629988 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<tiler_tee> completed state change to READY
0:00:01.105636781 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<tiler_tee> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:01.105645400 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func: child ‘tiler_tee’ changed state to 2(READY) successfully
0:00:01.105653708 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:01.105660503 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:01.105668844 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:01.105685427 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<processing_bin_0> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.105698150 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.105711100 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin1> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.105722889 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin_sink1> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.105745513 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin_sink1> completed state change to PAUSED
0:00:01.105752851 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin_sink1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.105763064 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘sink_sub_bin_sink1’ changed state to 3(PAUSED) successfully
0:00:01.105771167 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_sub_bin_cap_filter1> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.105785359 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin_cap_filter1> completed state change to PAUSED
0:00:01.105792249 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin_cap_filter1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.105802363 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘sink_sub_bin_cap_filter1’ changed state to 3(PAUSED) successfully
0:00:01.105810420 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<render_queue1> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.105844714 19486 0x55882b0d40c0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x55882b5914a0 on task 0x55882b73e050
0:00:01.105853256 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:<render_queue1:src> created task 0x55882b73e050
0:00:01.105978999 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<render_queue1> completed state change to PAUSED
0:00:01.105987653 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<render_queue1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.105999145 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_sub_bin1> child ‘render_queue1’ changed state to 3(PAUSED) successfully
0:00:01.106011280 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_sub_bin1> completed state change to PAUSED
0:00:01.106018167 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_sub_bin1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.106027417 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_sub_bin1’ changed state to 3(PAUSED) successfully
0:00:01.106035873 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin_tee> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.106047337 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin_tee> completed state change to PAUSED
0:00:01.106054007 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin_tee> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.106062852 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_bin_tee’ changed state to 3(PAUSED) successfully
0:00:01.106070950 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<sink_bin_queue> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.106083836 19486 0x55882b0d40c0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x55882b5906c0 on task 0x55882b73e170
0:00:01.106090557 19486 0x55882b0d40c0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:<sink_bin_queue:src> created task 0x55882b73e170
0:00:01.106158036 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin_queue> completed state change to PAUSED
0:00:01.106166705 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin_queue> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.106178505 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<sink_bin> child ‘sink_bin_queue’ changed state to 3(PAUSED) successfully
0:00:01.106189323 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<sink_bin> completed state change to PAUSED
0:00:01.106196030 19486 0x55882b0d40c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<sink_bin> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:01.106204899 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<processing_bin_0> child ‘sink_bin’ changed state to 3(PAUSED) successfully
0:00:01.106213165 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<osd_bin> current READY pending VOID_PENDING, desired next PAUSED
0:00:01.106230179 19486 0x55882b0d40c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
(base) sysadm@ubuntu-t4:/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-app$
And here is the config file:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=2
columns=5
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../streams/sample_1080p_h264.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
#iframeinterval=10
bitrate=400000
profile=0
set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
Set muxer output width and height
width=1920
height=1080
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
If set to TRUE, system timestamp will be attached as ntp timestamp
If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tracker]
enable=0
For the case of NvDCF tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_iou.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process and enable-past-frame applicable to DCF only
enable-batch-process=1
enable-past-frame=0
display-tracking-id=1
[secondary-gie0]
enable=0
model-engine-file=../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=0
model-engine-file=../../models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
batch-size=16
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_secondary_carcolor.txt
[secondary-gie2]
enable=0
model-engine-file=../../models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
batch-size=16
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
config-file=config_infer_secondary_carmake.txt
[tests]
file-loop=0
It did not have error from the log.
Deepstream-app is not running and is not presenting any errors
what do you mean by not running? Can you paste the standard output? not gst debug log.
There is no any output. It doesn’t write anything in the terminal. After a sec it just shows again the current directory in the terminal and that it is. I used to work with DS5.0 , and there indeed was output but here, nothing happens. No prints at all in the terminal.
How about disable sink0 enable sink1, to see if output successful?
[sink0]
enable=0
[sink1]
enable=1
You can quickly run with docker to check if your environments have issues.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_docker_containers.html#a-docker-container-for-dgpu
I tried and the created out movie is of size zero
I run docker and unfortunately the same problem occurred . Does it mean that the problem is in my NVIDIA driver? or Ubuntu? Up to two weeks ago DS5.0 perfectly worked on this computer (including code modification compilation). Therefore, I suspect it is the NVIDIA driver (which was upgraded).I installed the driver through software updates as the run file didn’t work for me. chose "Using NVIDIA Server Driver metapackage from nvidia-driver-460-server(proprietary, tested).
Anyway, here it takes only about one sec to get the terminal directory. Therefore, I figured that only a small portion of the program has executed
problem solved. I uninstalled all nvidia drivers /remains using
sudo apt-get purge nvidia*
and then installed driver from run file (with few more commands before ,that unfortunately are not listed in the installation guidelines).
Now deepstream-app works and also the docker works
Thanks a lot
Glad to know. thanks.
