• Hardware Platform (Jetson / GPU): DGX A100
• DeepStream Version nvcr.io/nvidia/deepstream:7.0-triton-multiarch
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 535.183.02
• Issue Type( questions, new requirements, bugs) questions
Hii, I am trying to create multiple CCTV Stream aggregator via RTS Protocol. What I am trying to do is to collect the frames, resize them and extract the region of interest from them then push the processes frame into a shared queue (for now I am just using a python list). For debugging I added a print statement for printing the element that is being pushed into shared queue.
But, after executing my python script I got Aborted or sometimes Segmentation Fault.
Following is my python script
import gi
import pyds
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
import numpy as np
import cv2
from parameters import IP_CAMS, KAFKA_TOPIC_NAME_PREFIX, DARKNESS_DETECTION
from confluent_kafka import Producer
# Initialize GStreamer
Gst.init(None)
ADAPTIVE_LIGHTING_THRESHOLD = 80
shared_buffer = []
# Initialize the Kafka Producer
kafka_config = {
'bootstrap.servers': '192.168.15.14:9092',
'client.id': 'camera-status-producer',
producer = Producer(kafka_config)
def roi_coordinates(roi_width: int, roi_height: int, frame_width: int, frame_height: int, x: int = 0, y: int = 0):
frame_x_center = frame_width // 2
roi_width_half = roi_width // 2
roi_left = frame_x_center - roi_width_half + x
roi_right = frame_x_center + roi_width_half + x
roi_bottom = frame_height - y
roi_top = roi_bottom - (roi_height + y)
return roi_left, roi_top, roi_right, roi_bottom
def create_mask(frame: np.ndarray, left: int, top: int, right: int, bottom: int):
mask = np.zeros_like(frame)
mask[top:bottom, left:right] = 1
return mask
def is_too_dark(frame, adaptive=True, threshold=ADAPTIVE_LIGHTING_THRESHOLD):
gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
if adaptive:
mean_intensity = cv2.mean(gray)[0]
return mean_intensity < threshold
else:
avg_intensity = np.mean(gray)
return avg_intensity < threshold
def delivery_report(err, msg):
if err is not None:
print(f"Message delivery failed: {err}")
else:
print(f"Message delivered to {msg.topic()} [{msg.partition()}]")
def send_kafka_message(cam_name, status, message):
topic_name = f"{KAFKA_TOPIC_NAME_PREFIX}_{cam_name}"
producer.produce(topic_name, key=status, value=message.encode('utf-8'), callback=delivery_report)
producer.poll(1)
def osd_sink_pad_buffer_probe(pad, info, u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer")
return Gst.PadProbeReturn.OK
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
user_meta_list = frame_meta.frame_user_meta_list
cam_name = None
while user_meta_list is not None:
try:
user_meta = pyds.NvDsUserMeta.cast(user_meta_list.data)
break
if user_meta and user_meta.user_meta_data:
cam_name = user_meta.user_meta_data
try:
user_meta_list = user_meta_list.next
break
if not cam_name:
cam_name = "unknown"
frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
roi_width, roi_height, roi_x, roi_y = IP_CAMS[cam_name][1]
roi_left, roi_top, roi_right, roi_bottom = roi_coordinates(
roi_width,
roi_height,
frame.shape[1],
frame.shape[0],
roi_x,
roi_y
mask = create_mask(frame, roi_left, roi_top, roi_right, roi_bottom)
roi_frame = frame * mask
shared_buffer.append((roi_frame, cam_name, IP_CAMS[cam_name][0]))
l_frame = l_frame.next
def create_deepstream_pipeline():
pipeline = Gst.Pipeline()
streammux = Gst.ElementFactory.make("nvstreammux", "stream-muxer")
streammux.set_property("width", 640)
streammux.set_property("height", 360)
streammux.set_property("batch-size", len(IP_CAMS))
streammux.set_property("batched-push-timeout", 40000)
pipeline.add(streammux)
for i, (cam_name, cam_details) in enumerate(IP_CAMS.items()):
cam_ip = cam_details[0]
source_bin = create_source_bin(i, cam_name, f"rtsp://{cam_ip}:554/stream1")
pipeline.add(source_bin)
source_bin.link(streammux)
osd_sink_pad = streammux.get_static_pad("src")
if not osd_sink_pad:
print("Unable to get src pad")
else:
osd_sink_pad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
return pipeline
def attach_cam_name_to_metadata(pad, info, cam_name):
if not gst_buffer:
frame_meta_list = batch_meta.frame_meta_list
while frame_meta_list is not None:
frame_meta = pyds.NvDsFrameMeta.cast(frame_meta_list.data)
user_meta = pyds.NvDsUserMeta.cast(pyds.nvds_acquire_user_meta_from_pool(batch_meta))
user_meta.user_meta_data = cam_name
pyds.nvds_add_user_meta_to_frame(frame_meta, user_meta)
try:
frame_meta_list = frame_meta_list.next
break
def on_pad_added(uridecodebin, pad, cam_name):
if pad.get_current_caps().to_string().startswith("video/"):
bin = pad.get_parent_element().get_parent()
ghost_pad = bin.get_static_pad("src")
if ghost_pad.set_target(pad):
pad.add_probe(Gst.PadProbeType.BUFFER, attach_cam_name_to_metadata, cam_name)
def create_source_bin(index, cam_name, uri):
bin_name = "source-bin-%02d" % index
nbin = Gst.Bin.new(bin_name)
uridecodebin = Gst.ElementFactory.make("uridecodebin", "uridecodebin")
uridecodebin.set_property("uri", uri)
uridecodebin.connect("pad-added", on_pad_added, cam_name)
nbin.add(uridecodebin)
bin_pad = Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC)
nbin.add_pad(bin_pad)
return nbin
def on_message(bus, message, loop):
msg_type = message.type
if msg_type == Gst.MessageType.EOS:
print("End of stream")
loop.quit()
elif msg_type == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print("Error: ", err, debug)
loop.quit()
return True
def main():
loop = GLib.MainLoop()
pipeline = create_deepstream_pipeline()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", on_message, loop)
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except Exception as e:
print(f"Exception: {e}")
finally:
pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
main()
I tried to debug the process and what I understand that there is some issue with the pipeline due to which it gets aborted.
root@4c21b0e1a926:/opt/nvidia/deepstream/deepstream-7.0# ulimit -c unlimited
root@4c21b0e1a926:/opt/nvidia/deepstream/deepstream-7.0# GST_DEBUG=4 python3 your_s
root@4c21b0e1a926:/opt/nvidia/deepstream/deepstream-7.0# GST_DEBUG=4 python3 deepstam_multicam_stream_producer.py
0:00:00.000097124 57903 0x5646ba8866b0 INFO GST_INIT gst.c:592:init_pre: Initializing GStreamer Core Library version 1.20.3
0:00:00.000285697 57903 0x5646ba8866b0 INFO GST_INIT gst.c:593:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000294048 57903 0x5646ba8866b0 INFO GST_INIT gst.c:611:init_pre: Linux 4c21b0e1a926 5.15.153.1-microsoft-standard-WSL2 #1 SMP Fri Mar 29 23:14:13 UTC 2024 x86_64
0:00:00.000386898 57903 0x5646ba8866b0 INFO GST_INIT gstmessage.c:129:_priv_gst_message_initialize: init messages
0:00:00.000482853 57903 0x5646ba8866b0 INFO GST_INIT gstcontext.c:86:_priv_gst_context_initialize: init contexts
0:00:00.000561315 57903 0x5646ba8866b0 INFO GST_PLUGIN_LOADING gstplugin.c:324:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000605961 57903 0x5646ba8866b0 INFO GST_PLUGIN_LOADING gstplugin.c:232:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.000623255 57903 0x5646ba8866b0 INFO GST_PLUGIN_LOADING gstplugin.c:234:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.000646619 57903 0x5646ba8866b0 INFO GST_REGISTRY gstregistry.c:1827:ensure_current_registry: reading registry cache: /.jbdevcontainer/gstreamer-1.0/registry.x86_64.bin
0:00:00.008289530 57903 0x5646ba8866b0 INFO GST_REGISTRY gstregistrybinary.c:683:priv_gst_registry_binary_read_cache: loaded /.jbdevcontainer/gstreamer-1.0/registry.x86_64.bin in 0.007160 seconds
0:00:00.008348647 57903 0x5646ba8866b0 INFO GST_REGISTRY gstregistry.c:1693:scan_and_update_registry: Validating plugins from registry cache: /.jbdevcontainer/gstreamer-1.0/registry.x86_64.bin
0:00:00.009504109 57903 0x5646ba8866b0 INFO GST_REGISTRY gstregistry.c:1785:scan_and_update_registry: Registry cache has not changed
0:00:00.009527926 57903 0x5646ba8866b0 INFO GST_REGISTRY gstregistry.c:1862:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.009600295 57903 0x5646ba8866b0 INFO GST_INIT gst.c:833:init_post: GLib runtime version: 2.76.6
0:00:00.009623975 57903 0x5646ba8866b0 INFO GST_INIT gst.c:835:init_post: GLib headers version: 2.72.1
0:00:00.009629340 57903 0x5646ba8866b0 INFO GST_INIT gst.c:837:init_post: initialized GStreamer successfully
0:00:00.014538873 57903 0x5646ba8866b0 INFO GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so" loaded
0:00:00.014691643 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "nvstreammux"
0:00:00.014822265 57903 0x5646ba8866b0 INFO GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<GstNvStreamMux@0x5646bac863d0> adding pad 'src'
0:00:00.015136326 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "bin"
0:00:00.015785872 57903 0x5646ba8866b0 INFO GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstplayback.so" loaded
0:00:00.015849864 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "uridecodebin"
0:00:00.016086782 57903 0x5646ba8866b0 INFO GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<source-bin-00> adding pad 'src'
0:00:00.016149622 57903 0x5646ba8866b0 INFO GST_ELEMENT_PADS gstutils.c:1816:gst_element_link_pads_full: trying to link element source-bin-00:(any) to element stream-muxer:(any)
0:00:00.016174133 57903 0x5646ba8866b0 INFO GST_PADS gstpad.c:4357:gst_pad_peer_query:<src:proxypad0> pad has no peer
0:00:00.016200432 57903 0x5646ba8866b0 ERROR nvstreammux gstnvstreammux.cpp:1611:gst_nvstreammux_request_new_pad:<stream-muxer> Pad should be named 'sink_%u' when requesting a pad
0:00:00.016281555 57903 0x5646ba8866b0 INFO GST_ELEMENT_PADS gstutils.c:1270:gst_element_get_compatible_pad:<stream-muxer> Could not find a compatible pad to link to source-bin-00:src
0:00:00.016313123 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "bin"
0:00:00.016342151 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "uridecodebin"
0:00:00.016393920 57903 0x5646ba8866b0 INFO GST_ELEMENT_PADS gstelement.c:759:gst_element_add_pad:<source-bin-01> adding pad 'src'
0:00:00.016423556 57903 0x5646ba8866b0 INFO GST_ELEMENT_PADS gstutils.c:1816:gst_element_link_pads_full: trying to link element source-bin-01:(any) to element stream-muxer:(any)
0:00:00.016445727 57903 0x5646ba8866b0 INFO GST_PADS gstpad.c:4357:gst_pad_peer_query:<src:proxypad1> pad has no peer
0:00:00.016472729 57903 0x5646ba8866b0 ERROR nvstreammux gstnvstreammux.cpp:1611:gst_nvstreammux_request_new_pad:<stream-muxer> Pad should be named 'sink_%u' when requesting a pad
0:00:00.016478952 57903 0x5646ba8866b0 INFO GST_ELEMENT_PADS gstutils.c:1270:gst_element_get_compatible_pad:<stream-muxer> Could not find a compatible pad to link to source-bin-01:src
0:00:00.016500157 57903 0x5646ba8866b0 INFO GST_ELEMENT_PADS gstelement.c:1016:gst_element_get_static_pad: found pad stream-muxer:src
0:00:00.016773062 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<stream-muxer> current NULL pending VOID_PENDING, desired next READY
0:00:00.900518588 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<stream-muxer> completed state change to READY
0:00:00.900564283 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<stream-muxer> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.900660472 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'stream-muxer' changed state to 2(READY) successfully
0:00:00.900696205 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<source-bin-01> current NULL pending VOID_PENDING, desired next READY
0:00:00.900768972 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<uridecodebin> current NULL pending VOID_PENDING, desired next READY
0:00:00.900790312 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<uridecodebin> completed state change to READY
0:00:00.900795791 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<uridecodebin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.900802622 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<source-bin-01> child 'uridecodebin' changed state to 2(READY) successfully
0:00:00.900828365 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source-bin-01> completed state change to READY
0:00:00.900846844 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source-bin-01> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.900866470 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'source-bin-01' changed state to 2(READY) successfully
0:00:00.900888229 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<source-bin-00> current NULL pending VOID_PENDING, desired next READY
0:00:00.900909093 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<uridecodebin> current NULL pending VOID_PENDING, desired next READY
0:00:00.900928117 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<uridecodebin> completed state change to READY
0:00:00.900946133 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<uridecodebin> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.900966653 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<source-bin-00> child 'uridecodebin' changed state to 2(READY) successfully
0:00:00.900998468 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source-bin-00> completed state change to READY
0:00:00.901016800 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source-bin-00> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.901036874 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'source-bin-00' changed state to 2(READY) successfully
0:00:00.901056506 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2778:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.901062183 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.901080268 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2786:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PLAYING
0:00:00.901101295 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<stream-muxer> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.901134643 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<stream-muxer> completed state change to PAUSED
0:00:00.901157529 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<stream-muxer> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.901164227 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'stream-muxer' changed state to 3(PAUSED) successfully
0:00:00.901169020 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<source-bin-01> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.901201402 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<uridecodebin> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.904724096 57903 0x5646ba8866b0 INFO GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtsp.so" loaded
0:00:00.905932157 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "rtspsrc"
0:00:00.907044111 57903 0x5646ba8866b0 INFO GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrealmedia.so" loaded
0:00:00.907082399 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "rtspreal"
0:00:00.907813638 57903 0x5646ba8866b0 INFO GST_PLUGIN_LOADING gstplugin.c:987:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstasf.so" loaded
0:00:00.907845287 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "rtspwms"
0:00:00.908091852 57903 0x5646ba8866b0 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0x5646c2b77258 on task 0x5646c296a4e0
0:00:00.908172667 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2778:gst_element_continue_state:<source> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.908194111 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.908205800 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2786:gst_element_continue_state:<source> continue state change READY to PAUSED, final PAUSED
0:00:00.924800444 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source> completed state change to PAUSED
0:00:00.924862504 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.924909404 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3397:bin_handle_async_done:<uridecodebin> committing state from READY to PAUSED, old pending PAUSED
0:00:00.924932867 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3420:bin_handle_async_done:<uridecodebin> completed state change, pending VOID
0:00:00.924941153 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<uridecodebin> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.924965323 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2797:gst_element_continue_state:<uridecodebin> nothing pending
0:00:00.924988750 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2971:gst_bin_change_state_func:<source-bin-01> child 'uridecodebin' changed state to 3(PAUSED) successfully without preroll
0:00:00.925003542 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3397:bin_handle_async_done:<source-bin-01> committing state from READY to PAUSED, old pending PAUSED
0:00:00.925023852 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3420:bin_handle_async_done:<source-bin-01> completed state change, pending VOID
0:00:00.925033332 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source-bin-01> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.925056876 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2797:gst_element_continue_state:<source-bin-01> nothing pending
0:00:00.925065547 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2971:gst_bin_change_state_func:<pipeline0> child 'source-bin-01' changed state to 3(PAUSED) successfully without preroll
0:00:00.925091689 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<source-bin-00> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.925127522 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<uridecodebin> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.925435279 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "rtspsrc"
0:00:00.925487913 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "rtspreal"
0:00:00.925517444 57903 0x5646ba8866b0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:489:gst_element_factory_create_with_properties: creating element "rtspwms"
0:00:00.925593619 57903 0x5646ba8866b0 INFO task gsttask.c:516:gst_task_set_lock: setting stream lock 0x5646c29315c8 on task 0x5646c2931250
0:00:00.925627555 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2778:gst_element_continue_state:<source> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.925653468 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.925680708 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2786:gst_element_continue_state:<source> continue state change READY to PAUSED, final PAUSED
0:00:00.925861562 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source> completed state change to PAUSED
0:00:00.925900086 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.925933706 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3397:bin_handle_async_done:<uridecodebin> committing state from READY to PAUSED, old pending PAUSED
0:00:00.925959981 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3420:bin_handle_async_done:<uridecodebin> completed state change, pending VOID
0:00:00.925999326 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<uridecodebin> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.926026108 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2797:gst_element_continue_state:<uridecodebin> nothing pending
0:00:00.926035281 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2971:gst_bin_change_state_func:<source-bin-00> child 'uridecodebin' changed state to 3(PAUSED) successfully without preroll
0:00:00.926064896 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3397:bin_handle_async_done:<source-bin-00> committing state from READY to PAUSED, old pending PAUSED
0:00:00.926086322 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3420:bin_handle_async_done:<source-bin-00> completed state change, pending VOID
0:00:00.926093222 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source-bin-00> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.926115193 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2797:gst_element_continue_state:<source-bin-00> nothing pending
0:00:00.926140871 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2971:gst_bin_change_state_func:<pipeline0> child 'source-bin-00' changed state to 3(PAUSED) successfully without preroll
0:00:00.926167697 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3397:bin_handle_async_done:<pipeline0> committing state from READY to PAUSED, old pending PLAYING
0:00:00.926188882 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:3428:bin_handle_async_done:<pipeline0> continue state change, pending PLAYING
0:00:00.926210931 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.926550718 57903 0x5646ba8866b0 INFO pipeline gstpipeline.c:533:gst_pipeline_change_state:<pipeline0> pipeline is live
0:00:00.926582826 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2778:gst_element_continue_state:<pipeline0> committing state from PAUSED to PAUSED, pending PLAYING, next PLAYING
0:00:00.926607191 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PAUSED to PAUSED (PLAYING pending)
0:00:00.926618171 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2786:gst_element_continue_state:<pipeline0> continue state change PAUSED to PLAYING, final PLAYING
0:00:00.926706847 57903 0x5646ba8866b0 INFO GST_EVENT gstevent.c:1530:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.926736475 57903 0x5646ba8866b0 INFO bin gstbin.c:2759:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:00.926749186 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<stream-muxer> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.926797954 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<stream-muxer> completed state change to PLAYING
0:00:00.926821113 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<stream-muxer> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.926833586 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'stream-muxer' changed state to 4(PLAYING) successfully
0:00:00.926866519 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source> completed state change to PLAYING
0:00:00.926889131 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.926916397 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<uridecodebin> child 'source' changed state to 4(PLAYING) successfully
0:00:00.926942823 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<uridecodebin> completed state change to PLAYING
0:00:00.926968284 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<uridecodebin> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.926993575 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<source-bin-01> child 'uridecodebin' changed state to 4(PLAYING) successfully
0:00:00.927017240 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source-bin-01> completed state change to PLAYING
0:00:00.927026743 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source-bin-01> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.927052527 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'source-bin-01' changed state to 4(PLAYING) successfully
0:00:00.927147157 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source> completed state change to PLAYING
0:00:00.927171766 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.927183961 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<uridecodebin> child 'source' changed state to 4(PLAYING) successfully
0:00:00.927207800 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<uridecodebin> completed state change to PLAYING
0:00:00.927230507 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<uridecodebin> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.927257549 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<source-bin-00> child 'uridecodebin' changed state to 4(PLAYING) successfully
0:00:00.927282212 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source-bin-00> completed state change to PLAYING
0:00:00.927304792 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<source-bin-00> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.927330335 57903 0x5646ba8866b0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'source-bin-00' changed state to 4(PLAYING) successfully
0:00:00.927354132 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<pipeline0> completed state change to PLAYING
0:00:00.927376107 57903 0x5646ba8866b0 INFO GST_STATES gstelement.c:2706:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.927473227 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:3224:gst_bin_continue_func:<pipeline0> continue state change PLAYING to PLAYING, final PLAYING
0:00:00.927567318 57903 0x7f69280010d0 INFO GST_EVENT gstevent.c:1530:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.927597169 57903 0x7f69280010d0 INFO bin gstbin.c:2759:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:00.927624850 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<stream-muxer> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.927987623 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2597:gst_bin_element_set_state:<stream-muxer> skipping transition from PLAYING to PLAYING
0:00:00.928015011 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'stream-muxer' changed state to 4(PLAYING) successfully
0:00:00.928041451 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<source-bin-01> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.928068334 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<uridecodebin> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.928078837 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<source> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.928101324 57903 0x7f69280010d0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source> completed state change to PLAYING
0:00:00.928124514 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<uridecodebin> child 'source' changed state to 4(PLAYING) successfully
0:00:00.928132244 57903 0x7f69280010d0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<uridecodebin> completed state change to PLAYING
0:00:00.928156744 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<source-bin-01> child 'uridecodebin' changed state to 4(PLAYING) successfully
0:00:00.928179433 57903 0x7f69280010d0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source-bin-01> completed state change to PLAYING
0:00:00.928203244 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'source-bin-01' changed state to 4(PLAYING) successfully
0:00:00.928261714 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<source-bin-00> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.928287700 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<uridecodebin> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.928298263 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2479:gst_bin_element_set_state:<source> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:00.928320079 57903 0x7f69280010d0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source> completed state change to PLAYING
0:00:00.928329955 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<uridecodebin> child 'source' changed state to 4(PLAYING) successfully
0:00:00.928351109 57903 0x7f69280010d0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<uridecodebin> completed state change to PLAYING
0:00:00.928374619 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<source-bin-00> child 'uridecodebin' changed state to 4(PLAYING) successfully
0:00:00.928397044 57903 0x7f69280010d0 INFO GST_STATES gstelement.c:2806:gst_element_continue_state:<source-bin-00> completed state change to PLAYING
0:00:00.928446373 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:2928:gst_bin_change_state_func:<pipeline0> child 'source-bin-00' changed state to 4(PLAYING) successfully
0:00:00.928460199 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:3406:bin_handle_async_done:<pipeline0> setting state from PLAYING to PLAYING, pending PLAYING
0:00:00.928479989 57903 0x7f69280010d0 INFO GST_STATES gstbin.c:3420:bin_handle_async_done:<pipeline0> completed state change, pending VOID
Aborted
root@4c21b0e1a926:/opt/nvidia/deepstream/deepstream-7.0# gdb python3
GNU gdb (Ubuntu 12.1-0ubuntu1~22.04) 12.1
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
--Type <RET> for more, q to quit, c to continue without paging--
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from python3...
(No debugging symbols found in python3)
(gdb) run deepstream_multicam_stream_producer.py
Starting program: /usr/bin/python3 deepstream_multicam_stream_producer.py
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7ffff1dff640 (LWP 58579)]
[New Thread 0x7ffff15fe640 (LWP 58580)]
[New Thread 0x7fffeedfd640 (LWP 58581)]
[New Thread 0x7fffea5fc640 (LWP 58582)]
[New Thread 0x7fffe7dfb640 (LWP 58583)]
[New Thread 0x7fffe55fa640 (LWP 58584)]
[New Thread 0x7fffe2df9640 (LWP 58585)]
[New Thread 0x7fffe05f8640 (LWP 58586)]
[New Thread 0x7fffdddf7640 (LWP 58587)]
[New Thread 0x7fffdb5f6640 (LWP 58588)]
[New Thread 0x7fffd8df5640 (LWP 58589)]
[New Thread 0x7fffd65f4640 (LWP 58590)]
[New Thread 0x7fffd5df3640 (LWP 58591)]
[New Thread 0x7fffd55f2640 (LWP 58592)]
[New Thread 0x7fffcedf1640 (LWP 58593)]
[New Thread 0x7fffc1210640 (LWP 58594)]
[New Thread 0x7fffc0a0f640 (LWP 58595)]
[New Thread 0x7fffbbfff640 (LWP 58596)]
[New Thread 0x7fffad7ff640 (LWP 58597)]
[New Thread 0x7fffa346a640 (LWP 58606)]
[New Thread 0x7fff8d86a640 (LWP 58615)]
[New Thread 0x7fff8d069640 (LWP 58616)]
[New Thread 0x7fff8c868640 (LWP 58617)]
[New Thread 0x7fff7bfff640 (LWP 58618)]
[New Thread 0x7fff7b7fe640 (LWP 58619)]
[New Thread 0x7fff7affd640 (LWP 58620)]
[Thread 0x7fffcedf1640 (LWP 58593) exited]
[Thread 0x7fffd55f2640 (LWP 58592) exited]
[Thread 0x7fffd5df3640 (LWP 58591) exited]
[Thread 0x7fffd65f4640 (LWP 58590) exited]
[Thread 0x7fffd8df5640 (LWP 58589) exited]
[Thread 0x7fffdb5f6640 (LWP 58588) exited]
[Thread 0x7fffdddf7640 (LWP 58587) exited]
[Thread 0x7fffe05f8640 (LWP 58586) exited]
[Thread 0x7fffe2df9640 (LWP 58585) exited]
[Thread 0x7fffe55fa640 (LWP 58584) exited]
[Thread 0x7fffe7dfb640 (LWP 58583) exited]
[Thread 0x7fffea5fc640 (LWP 58582) exited]
[Thread 0x7fffeedfd640 (LWP 58581) exited]
[Thread 0x7ffff15fe640 (LWP 58580) exited]
[Thread 0x7ffff1dff640 (LWP 58579) exited]
[Detaching after fork from child process 58621]
[New Thread 0x7fffcedf1640 (LWP 58622)]
[New Thread 0x7fffd55f2640 (LWP 58623)]
terminate called after throwing an instance of 'std::runtime_error'
what(): Unable to read configuration
Thread 28 "pool-python3" received signal SIGABRT, Aborted.
[Switching to Thread 0x7fffcedf1640 (LWP 58622)]
0x00007ffff7cd99fc in pthread_kill () from /usr/lib/x86_64-linux-gnu/libc.so.6
(gdb) backtrace
#0 0x00007ffff7cd99fc in pthread_kill () at /usr/lib/x86_64-linux-gnu/libc.so.6
#1 0x00007ffff7c85476 in raise () at /usr/lib/x86_64-linux-gnu/libc.so.6
#2 0x00007ffff7c6b7f3 in abort () at /usr/lib/x86_64-linux-gnu/libc.so.6
#3 0x00007ffff6893b9e in () at /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#4 0x00007ffff689f20c in () at /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#5 0x00007ffff689e1e9 in () at /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#6 0x00007ffff689e959 in __gxx_personality_v0 ()
#7 0x00007ffff67c0fe9 in __libunwind_Unwind_Resume ()
at /usr/lib/x86_64-linux-gnu/libunwind.so.8
#8 0x00007ffff1dd886d in () at /usr/lib/x86_64-linux-gnu/libproxy.so.1
#9 0x00007ffff1de1827 in px_proxy_factory_get_proxies ()
#10 0x00007ffff4df6827 in ()
at /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
#11 0x00007ffff7455644 in g_task_thread_pool_thread
(thread_data=0x7fff7c012980, pool_data=<optimized out>) at ../gio/gtask.c:1531
#12 0x00007ffff773e384 in g_thread_pool_thread_proxy (data=<optimized out>)
at ../glib/gthreadpool.c:350
#13 0x00007ffff773dac1 in g_thread_proxy (data=0x7fff840013a0)
at ../glib/gthread.c:831
#14 0x00007ffff7cd7ac3 in () at /usr/lib/x86_64-linux-gnu/libc.so.6
#15 0x00007ffff7d69850 in () at /usr/lib/x86_64-linux-gnu/libc.so.6
