1.My function is that 2 rtsp stream go to infer, and output 2 rtsp stream which is inferred by “nvstreamdemux”.
2.The problem is that one rtsp stream is off, some error happen, log is as bellow. And the code “gst_element_set_state (pipeline, GST_STATE_NULL);” can not jump out
3.The code is base on test3, which is as bellow:
* Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include <gst/rtsp-server/rtsp-server.h>
#include "gstnvdsmeta.h"
#include <stdlib.h>
#include <ctype.h>
//#include "gstnvstreammeta.h"
#ifndef PLATFORM_TEGRA
#include "gst-nvmessage.h"
#endif
#define MAX_DISPLAY_LEN 64
/* The muxer output resolution must be set if the input streams will be of
* different resolution. The muxer will scale all the input frames to this
* resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
#define TILED_OUTPUT_WIDTH 1920
#define TILED_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
* pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
#define bufSize 1024
#define MaxKeyLength 80
#define CONFIG_PATH "/home/user/XM_COSO_RTG/Broad.conf"
#define FPS_PRINT_INTERVAL 300
//static struct timeval start_time = { };
//static guint probe_counter = 0;
/* tiler_sink_pad_buffer_probe will extract metadata received on OSD sink pad
* and update params for drawing rectangle, object information etc. */
* @param buf
* @desc 删除buf中的制表符以及注释
char *trimSp(char *buf)
char tbuf[bufSize] = {'\0'};
if (buf == NULL || strlen(buf) == 0)
return NULL;
int len = strlen(buf);
int i = 0, j = 0;
while (i < len)
//此处注释使用 //
//若注释使用 # 则使用以下代码代替
//if (buf[i] == '#')
// break;
//if (buf[i] == '/' && buf[i + 1] == '/')
//break;
if (iscntrl(buf[i]) == 0 && isspace(buf[i]) == 0)
tbuf[j] = buf[i];
j++;
i++;
//将结果复制到buf
memset(buf, '\0', len);
strncpy(buf, tbuf, strlen(tbuf));
return buf;
* @param buf
* @desc 获取 = 在字符串中的位置
int getPos(char *buf)
return -1;
int i = 0;
while (i < len)
if (buf[i] == '=')
break;
i++;
return i++;
* @param file
* @param AppName
* @param KeyName
* @param KeyVal
* @desc 从文件‘file’中的[AppName]中读取属性KeyName的值KeyVal
int ReadConf(char *file, char *AppName, char *KeyName, char *KeyVal)
char buf[bufSize] = {'\0'};
int find_app_name = 0;
if (file == NULL || strlen(file) == 0) //文件名(路径)检查
return -1;
FILE *fp = fopen(file, "r"); //打开文件
if (fp == NULL) //文件句柄检查
return -1;
while (fgets(buf, bufSize, fp) != NULL)
char *tbuf = trimSp(buf);
int pos = getPos(tbuf);
int len = strlen(tbuf);
//printf("string:%s\n", tbuf);
//查找到 [NAME]
if (len > 0 && len == pos && tbuf[0] == '[' && tbuf[len - 1] == ']')
//存放NAME
char *t_appname = (char *)malloc(len - 1);
memset(t_appname, '\0', len - 1);
strncpy(t_appname, tbuf + 1, len - 2);
//查找到AppName
if (strncmp(t_appname, AppName, strlen(t_appname)) == 0)
find_app_name = 1;
else
find_app_name = 0;
//注意释放空间,防止内存泄露
free(t_appname);
else
//属性名 与 属性值
if (len > 0 && pos != len && find_app_name)
char *val = tbuf + pos + 1;//属性值
tbuf[pos] = '\0';//将=替换为\0 用以分割属性名 与 属性值
char *key = tbuf;//属性名
//查找到属性名
if (strncmp(key, KeyName, strlen(key)) == 0)
//将值复制到 KeyVal
strncpy(KeyVal, val, strlen(val));
break;
//关闭文件句柄
if (fp != NULL)
fclose(fp);
return 1;
static GstPadProbeReturn
tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
NvDsObjectMeta *obj_meta = NULL;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsDisplayMeta *display_meta = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
int offset = 0;
if(frame_meta->obj_meta_list != NULL)
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
display_meta->num_labels = 1;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "WARMMING");
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Courier";
txt_params->font_params.font_size = 25;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 0.0;
txt_params->font_params.font_color.blue = 0.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 0.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
return GST_PAD_PROBE_OK;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning (msg, &error, &debug);
g_printerr ("WARNING from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
g_free (debug);
g_printerr ("Warning: %s\n", error->message);
g_error_free (error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
break;
case GST_MESSAGE_ELEMENT:
if (gst_nvmessage_is_stream_eos (msg)) {
guint stream_id;
if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
g_print ("Got EOS from stream %d\n", stream_id);
break;
#endif
default:
break;
return TRUE;
static void
cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, gpointer data)
g_print ("In cb_newpad\n");
GstCaps *caps = gst_pad_get_current_caps (decoder_src_pad);
const GstStructure *str = gst_caps_get_structure (caps, 0);
const gchar *name = gst_structure_get_name (str);
GstElement *source_bin = (GstElement *) data;
GstCapsFeatures *features = gst_caps_get_features (caps, 0);
/* Need to check if the pad created by the decodebin is for video and not
* audio. */
if (!strncmp (name, "video", 5)) {
/* Link the decodebin pad only if decodebin has picked nvidia
* decoder plugin nvdec_*. We do this by checking if the pad caps contain
* NVMM memory features. */
if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
/* Get the source bin ghost pad */
GstPad *bin_ghost_pad = gst_element_get_static_pad (source_bin, "src");
if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
decoder_src_pad)) {
g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
gst_object_unref (bin_ghost_pad);
} else {
g_printerr ("Error: Decodebin did not pick nvidia decoder plugin.\n");
static void
decodebin_child_added (GstChildProxy * child_proxy, GObject * object,
gchar * name, gpointer user_data)
g_print ("Decodebin child added: %s\n", name);
if (g_strrstr (name, "decodebin") == name) {
g_signal_connect (G_OBJECT (object), "child-added",
G_CALLBACK (decodebin_child_added), user_data);
if (g_strstr_len (name, -1, "nvv4l2decoder") == name) {
g_print ("Seting bufapi_version\n");
g_object_set (object, "bufapi-version", TRUE, NULL);
static GstElement *
create_source_bin (guint index, gchar *uri)
GstElement *bin = NULL, *uri_decode_bin = NULL;
gchar bin_name[16] = { };
g_snprintf (bin_name, 15, "source-bin-%02d", index);
/* Create a source GstBin to abstract this bin's content from the rest of the
* pipeline */
bin = gst_bin_new (bin_name);
/* Source element for reading from the uri.
* We will use decodebin and let it figure out the container format of the
* stream and the codec and plug the appropriate demux and decode plugins. */
uri_decode_bin = gst_element_factory_make ("uridecodebin", "uri-decode-bin");
if (!bin || !uri_decode_bin) {
g_printerr ("One element in source bin could not be created.\n");
return NULL;
/* We set the input uri to the source element */
g_object_set (G_OBJECT (uri_decode_bin), "uri", uri, "async-handling", 1, NULL);
/* Connect to the "pad-added" signal of the decodebin which generates a
* callback once a new pad for raw data has beed created by the decodebin */
g_signal_connect (G_OBJECT (uri_decode_bin), "pad-added",
G_CALLBACK (cb_newpad), bin);
g_signal_connect (G_OBJECT (uri_decode_bin), "child-added",
G_CALLBACK (decodebin_child_added), bin);
gst_bin_add (GST_BIN (bin), uri_decode_bin);
/* We need to create a ghost pad for the source bin which will act as a proxy
* for the video decoder src pad. The ghost pad will not have a target right
* now. Once the decode bin creates the video decoder and generates the
* cb_newpad callback, we will set the ghost pad target to the video decoder
* src pad. */
if (!gst_element_add_pad (bin, gst_ghost_pad_new_no_target ("src",
GST_PAD_SRC))) {
g_printerr ("Failed to add ghost pad in source bin\n");
return NULL;
return bin;
static gboolean
start_rtsp_streaming (guint rtsp_port_num, guint updsink_port_num)
GstRTSPServer *server;
GstRTSPMountPoints *mounts;
GstRTSPMediaFactory *factory;
char udpsrc_pipeline[512];
char port_num_Str[64] = { 0 };
char *encoder_name;
encoder_name = "H264";
sprintf (udpsrc_pipeline,
"( udpsrc name=pay0 port=%d caps=\"application/x-rtp, media=video, "
"clock-rate=90000, encoding-name=%s, payload=96 \" )",
updsink_port_num, encoder_name);
sprintf (port_num_Str, "%d", rtsp_port_num);
server = gst_rtsp_server_new ();
g_object_set (server, "service", port_num_Str, NULL);
mounts = gst_rtsp_server_get_mount_points (server);
factory = gst_rtsp_media_factory_new ();
gst_rtsp_media_factory_set_launch (factory, udpsrc_pipeline);
gst_rtsp_media_factory_set_shared (factory, TRUE);
gst_rtsp_mount_points_add_factory (mounts, "/ds-test", factory);
g_object_unref (mounts);
gst_rtsp_server_attach (server, NULL);
g_print
("\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n",
rtsp_port_num);
return TRUE;
static GstElement *
create_rtsp_bin (guint index){
GstElement *bin = NULL, *queue_out = NULL, *nvvidconv = NULL, *nvosd = NULL, *transform = NULL, *cap_filter = NULL,
*encoder = NULL, *rtppay = NULL, *sink = NULL;
GstCaps *caps = NULL;
gchar bin_name[16] = {};
g_snprintf (bin_name, 15, "rtsp-bin-%02d", index);
g_print ("create rtsp_bin: %s\n", bin_name);
g_snprintf (bin_name, 15, "queue_out-%02d", index);
queue_out = gst_element_factory_make ("queue", bin_name);
g_snprintf (bin_name, 15, "nvvidconv-%02d", index);
nvvidconv = gst_element_factory_make ("nvvideoconvert", bin_name);
g_snprintf (bin_name, 15, "nvosd-%02d", index);
nvosd = gst_element_factory_make ("nvdsosd", bin_name);
g_snprintf (bin_name, 15, "transform-%02d", index);
transform = gst_element_factory_make ("nvvideoconvert", bin_name);
g_snprintf (bin_name, 15, "filter-%02d", index);
cap_filter = gst_element_factory_make ("capsfilter", bin_name);
g_snprintf (bin_name, 15, "h264-encoder-%02d", index);
encoder = gst_element_factory_make ("nvv4l2h264enc", bin_name);
g_snprintf (bin_name, 15, "rtppay-h264-%02d", index);
rtppay = gst_element_factory_make ("rtph264pay", bin_name);
g_snprintf (bin_name, 15, "udpsink-%02d", index);
sink = gst_element_factory_make ("udpsink", bin_name);
gst_bin_add_many (GST_BIN (bin), queue_out, nvvidconv, nvosd, transform, cap_filter, encoder, rtppay, sink, NULL);
caps = gst_caps_from_string ("video/x-raw(memory:NVMM), format=I420");
g_object_set (G_OBJECT (cap_filter), "caps", caps, NULL);
g_object_set (G_OBJECT (encoder), "bitrate", 4000000, NULL);
g_object_set (G_OBJECT (encoder), "preset-level", 1, NULL);
g_object_set (G_OBJECT (encoder), "insert-sps-pps", 1, NULL);
g_object_set (G_OBJECT (encoder), "bufapi-version", 1, NULL);
gst_caps_unref(caps);
g_object_set (G_OBJECT (sink), "port", 5400+index, "async", 1, "sync", 0, NULL);
if (!gst_element_link_many (queue_out, nvvidconv, nvosd, transform, cap_filter, encoder, rtppay, sink, NULL)) {
g_printerr ("Elements could not be linked: 3. Exiting.\n");
return NULL;
gboolean ret = TRUE;
ret = start_rtsp_streaming (8554+index, 5400+index);
if (ret != TRUE) {
g_print ("%s: start_rtsp_straming function failed\n", __func__);
GstPad *queue_out_sink = gst_element_get_static_pad (queue_out, "sink");
gst_element_add_pad(bin, gst_ghost_pad_new("sink",queue_out_sink));
gst_object_unref(queue_out_sink);
return bin;
int
main (int argc, char *argv[])
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *streammux = NULL, *streamdemux = NULL, *pgie = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *tiler_src_pad = NULL;
guint i,num_sources;
guint pgie_batch_size;
guint tiler_rows, tiler_columns;
gchar KeyValue[MaxKeyLength];
gchar rtsp_source [MaxKeyLength];
GMutex struct_lock;
memset(KeyValue,'\0',MaxKeyLength);
ReadConf(CONFIG_PATH, "source", "num", KeyValue);
num_sources = atoi(KeyValue);
g_printerr("sourceNum is %d\n", num_sources);
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("dstest3-pipeline");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
streamdemux = gst_element_factory_make ("nvstreamdemux", "stream-demuxer");
if (!pipeline || !streammux) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), streammux);
gst_bin_add (GST_BIN (pipeline), streamdemux);
for (i = 0; i < num_sources; i++) {
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = {};
gchar source_name[8] ={};
g_snprintf (source_name, 7, "url_%1d", i);
memset(rtsp_source,'\0',MaxKeyLength);
ReadConf(CONFIG_PATH, "camera", source_name, rtsp_source);
g_printerr("rtsp_source is %s\n", rtsp_source);
GstElement *source_bin = create_source_bin (i, rtsp_source);
GstElement *rtsp_bin = create_rtsp_bin (i);
if (!source_bin) {
g_printerr ("Failed to create source bin. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), source_bin);
g_snprintf (pad_name, 15, "sink_%u", i);
sinkpad = gst_element_get_request_pad (streammux, pad_name);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (source_bin, "src");
if (!srcpad) {
g_printerr ("Failed to get src pad of source bin. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
//demux
if(! rtsp_bin)
return -1;
gst_bin_add (GST_BIN (pipeline), rtsp_bin);
g_snprintf (pad_name, 15, "src_%u", i);
srcpad = gst_element_get_request_pad (streamdemux, pad_name);
if (!srcpad) {
g_printerr ("Streamdemux request src pad failed. Exiting.\n");
return -1;
sinkpad = gst_element_get_static_pad (rtsp_bin, "sink");
if (!sinkpad) {
g_printerr ("Failed to get sink pad of rtsp_bin. Exiting.\n");
return -1;
g_printerr ("Failed to link streamdemuxbin to rtsp_bin. Exiting.\n");
return -1;
gst_object_unref (srcpad);
gst_object_unref (sinkpad);
/* Use nvinfer to infer on batched frame. */
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
if (!pgie ) {
return -1;
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", num_sources, "live-source", 1,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
g_object_set (G_OBJECT (pgie),
"config-file-path", "/home/user/XM_COSO_RTG/dstest3_pgie_config.txt","batch-size", num_sources, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
gst_bin_add_many (GST_BIN (pipeline), pgie, NULL);
if (!gst_element_link_many (streammux, pgie, streamdemux, NULL)) {
g_printerr ("Elements could not be linked. Exiting.\n");
return -1;
/* Set the pipeline to "playing" state */
g_print ("Now playing:");
g_print (" %s,", argv[i + 1]);
g_print ("\n");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (pipeline),
GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-playing");
g_main_loop_run (loop);
//g_mutex_lock (&struct_lock);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
//g_mutex_unlock (&struct_lock);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
