Confision with Deepstrem appsink || Segmentation fault
I am trying to integrate Deepstream on my C++ application. For this, I had to sink the pipeline output to an appsink element. Testing with “deepstream-test3_app” example, when I use sink element as
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
    gst_bin_add_many (GST_BIN (pipeline), pgie, tiler, nvvidconv, nvosd, sink,
          NULL);
      if (!gst_element_link_many (streammux, pgie, tiler, nvvidconv, nvosd, sink,
              NULL)) {
        g_printerr ("Elements could not be linked. Exiting.\n");
        return -1;
everything works fine. But when I replace “nveglglesink” with
sink =  gst_element_factory_make ("appsink", "appsink");
      gst_app_sink_set_emit_signals((GstAppSink*)sink, true);
      gst_app_sink_set_drop((GstAppSink*)sink, true);
      gst_app_sink_set_max_buffers((GstAppSink*)sink, 1);
      GstAppSinkCallbacks callbacks = { NULL, new_preroll, new_sample };
      gst_app_sink_set_callbacks (GST_APP_SINK(sink), &callbacks, NULL, NULL);
and keep the pipeline same, I get strange behavior, specially when converting the buffer to cv::Mat, I get “segmentation fault”. I am confused whether in the pipeline, it is okey to directly add appsink element after nvosd or I am missing something? Any help would be appreciated so much.
The comprehensive code looks like this:
static GstPadProbeReturn tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  GstMeta *gst_meta = NULL;
  NvDsMeta *nvdsmeta = NULL;
  gpointer state = NULL;
  static GQuark _nvdsmeta_quark = 0;
  GstBuffer *buf = (GstBuffer *) info->data;
  NvDsFrameMeta *frame_meta = NULL;
  guint num_rects = 0, rect_index = 0;
  NvDsObjectParams *obj_meta = NULL;
  NvOSD_TextParams *txt_params = NULL;
  GstNvStreamMeta *streammeta = NULL;
  if (!_nvdsmeta_quark)
    _nvdsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
  if (probe_counter == 0) {
    gettimeofday (&start_time, NULL);
  } else if (probe_counter == FPS_PRINT_INTERVAL) {
    struct timeval cur_time;
    gettimeofday (&cur_time, NULL);
    g_print ("FPS for the last %d batches: %.2f\n", FPS_PRINT_INTERVAL,
        FPS_PRINT_INTERVAL / ((cur_time.tv_sec - start_time.tv_sec) +
            (cur_time.tv_usec - start_time.tv_usec) / 1e6));
    probe_counter = 0;
    start_time = cur_time;
  probe_counter++;
  streammeta = gst_buffer_get_nvstream_meta (buf);
  while ((gst_meta = gst_buffer_iterate_meta (buf, &state))) {
    if (gst_meta_api_type_has_tag (gst_meta->info->api, _nvdsmeta_quark)) {
      nvdsmeta = (NvDsMeta *) gst_meta;
      /* We are interested only in intercepting Meta of type
       * "NVDS_META_FRAME_INFO" as they are from our infer elements. */
      if (nvdsmeta->meta_type == NVDS_META_FRAME_INFO) {
        guint vehicle_count = 0;
        guint person_count = 0;
        frame_meta = (NvDsFrameMeta *) nvdsmeta->meta_data;
        if (frame_meta == NULL) {
          g_print ("NvDS Meta contained NULL meta \n");
          return GST_PAD_PROBE_OK;
        /* We reset the num_strings here as we plan to iterate through the
         *  the detected objects and form our own strings.
         *  The pipeline generated strings shall be discarded.
        frame_meta->num_strings = 0;
        num_rects = frame_meta->num_rects;
        /* This means we have num_rects in frame_meta->obj_params,
         * now lets iterate through them */
        for (rect_index = 0; rect_index < num_rects; rect_index++) {
          /* Now using above information we need to form a text that should
           * be displayed on top of the bounding box, so lets form it here. */
          obj_meta = (NvDsObjectParams *) & frame_meta->obj_params[rect_index];
          txt_params = &(obj_meta->text_params);
          if (txt_params->display_text)
            g_free (txt_params->display_text);
          txt_params->display_text = (char * )(g_malloc0) (MAX_DISPLAY_LEN);
          g_snprintf (txt_params->display_text, MAX_DISPLAY_LEN, "%s ",
              pgie_classes_str[obj_meta->class_id]);
          if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE)
            vehicle_count++;
          if (obj_meta->class_id == PGIE_CLASS_ID_PERSON)
            person_count++;
          /* Now set the offsets where the string should appear */
          txt_params->x_offset = obj_meta->rect_params.left;
          txt_params->y_offset = obj_meta->rect_params.top - 25;
          /* Font , font-color and font-size */
          txt_params->font_params.font_name = "Arial";
          txt_params->font_params.font_size = 10;
          txt_params->font_params.font_color.red = 1.0;
          txt_params->font_params.font_color.green = 1.0;
          txt_params->font_params.font_color.blue = 1.0;
          txt_params->font_params.font_color.alpha = 1.0;
          /* Text background color */
          txt_params->set_bg_clr = 1;
          txt_params->text_bg_clr.red = 0.0;
          txt_params->text_bg_clr.green = 0.0;
          txt_params->text_bg_clr.blue = 0.0;
          txt_params->text_bg_clr.alpha = 1.0;
          frame_meta->num_strings++;
        /* Enable this print by setting environment variable GST_DEBUG=4
         * before running the app. */
        GST_INFO ("Source %d Frame Number = %lu Number of objects = %d "
            "Vehicle Count = %d Person Count = %d", frame_meta->stream_id,
            streammeta->stream_frame_num[frame_meta->batch_id],
            num_rects, vehicle_count, person_count);
static gboolean bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_WARNING:
      gchar *debug;
      GError *error;
      gst_message_parse_warning (msg, &error, &debug);
      g_printerr ("WARNING from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      g_free (debug);
      g_printerr ("Warning: %s\n", error->message);
      g_error_free (error);
      break;
    case GST_MESSAGE_ERROR:
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      break;
    case GST_MESSAGE_ELEMENT:
      if (gst_nvmessage_is_stream_eos (msg)) {
        guint stream_id;
        if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
          g_print ("Got EOS from stream %d\n", stream_id);
      break;
    default:
      break;
  return TRUE;
static void cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, gpointer data)
  GstCaps *caps = gst_pad_query_caps (decoder_src_pad, NULL);
  const GstStructure *str = gst_caps_get_structure (caps, 0);
  const gchar *name = gst_structure_get_name (str);
  GstElement *source_bin = (GstElement *) data;
  GstCapsFeatures *features = gst_caps_get_features (caps, 0);
  /* Need to check if the pad created by the decodebin is for video and not
   * audio. */
  if (!strncmp (name, "video", 5)) {
    /* Link the decodebin pad only if decodebin has picked nvidia
     * decoder plugin nvdec_*. We do this by checking if the pad caps contain
     * NVMM memory features. */
    if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
      /* Get the source bin ghost pad */
      GstPad *bin_ghost_pad = gst_element_get_static_pad (source_bin, "src");
      if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
              decoder_src_pad)) {
        g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
      gst_object_unref (bin_ghost_pad);
    } else {
      g_printerr ("Error: Decodebin did not pick nvidia decoder plugin.\n");
static GstElement * create_source_bin (guint index, gchar * uri)
  GstElement *bin = NULL, *uri_decode_bin = NULL;
  gchar bin_name[16] = { };
  g_snprintf (bin_name, 15, "source-bin-%02d", index);
  /* Create a source GstBin to abstract this bin's content from the rest of the
   * pipeline */
  bin = gst_bin_new (bin_name);
  /* Source element for reading from the uri.
   * We will use decodebin and let it figure out the container format of the
   * stream and the codec and plug the appropriate demux and decode plugins. */
  uri_decode_bin = gst_element_factory_make ("uridecodebin", "uri-decode-bin");
  if (!bin || !uri_decode_bin) {
    g_printerr ("One element in source bin could not be created.\n");
    return NULL;
  /* We set the input uri to the source element */
  g_object_set (G_OBJECT (uri_decode_bin), "uri", uri, NULL);
  /* Connect to the "pad-added" signal of the decodebin which generates a
   * callback once a new pad for raw data has beed created by the decodebin */
  g_signal_connect (G_OBJECT (uri_decode_bin), "pad-added",
      G_CALLBACK (cb_newpad), bin);
  gst_bin_add (GST_BIN (bin), uri_decode_bin);
  /* We need to create a ghost pad for the source bin which will act as a proxy
   * for the video decoder src pad. The ghost pad will not have a target right
   * now. Once the decode bin creates the video decoder and generates the
   * cb_newpad callback, we will set the ghost pad target to the video decoder
   * src pad. */
  if (!gst_element_add_pad (bin, gst_ghost_pad_new_no_target ("src",
              GST_PAD_SRC))) {
    g_printerr ("Failed to add ghost pad in source bin\n");
    return NULL;
  return bin;
GstFlowReturn new_sample(GstAppSink *appsink, gpointer data) {
  static int framecount = 0;
  framecount++;
  GstSample *sample = gst_app_sink_pull_sample(appsink);
  GstCaps *caps = gst_sample_get_caps(sample);
  GstBuffer *buffer = gst_sample_get_buffer(sample);
  const GstStructure *info = gst_sample_get_info(sample);
  qDebug() <<" ---- Read frame and convert to opencv format ---------------" << QString::number(framecount);
  GstMapInfo map;
  gst_buffer_map (buffer, &map, GST_MAP_READ);
  // convert gstreamer data to OpenCV Mat, you could actually
  // resolve height / width from caps...
   Mat frame(Size(1280, 720), CV_8UC3, (char*)map.data, Mat::AUTO_STEP);
  int frameSize = map.size;
  qDebug() << " TODO: synchronize this.... ";
  frameQueue.push_back(frame);
  gst_buffer_unmap(buffer, &map);
  // show caps on first frame
  if (framecount == 1) {
    g_print ("%s\n", gst_caps_to_string(caps));
  gst_sample_unref (sample);
  return GST_FLOW_OK;
int main() {
std::deque<cv::Mat> frameQueue;
 int frameNo=0;
    GMainLoop *loop = NULL;
      GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
          *nvvidconv = NULL, *nvosd = NULL, *tiler = NULL;
      GstBus *bus = NULL;
      guint bus_watch_id;
      GstPad *tiler_src_pad = NULL;
      guint i, num_sources;
      guint tiler_rows, tiler_columns;
      guint pgie_batch_size;
      num_sources = 1;
      gchar vp = 'file:///home/XYZ/sample_720p.h264';
      gchar *m = &vp;
      gchar** n = &m;
      gchar*** p = &n;
     // std::cout << &p << &vp << &m << &n;
        qDebug() << " Starting ... ";
      /* Standard GStreamer initialization */
        gst_init (0, p);
    //  gst_init (0, );
      loop = g_main_loop_new (NULL, FALSE);
      /* Create gstreamer elements */
      /* Create Pipeline element that will form a connection of other elements */
      pipeline = gst_pipeline_new ("dstest3-pipeline");
      /* Create nvstreammux instance to form batches from one or more sources. */
      streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
      if (!pipeline || !streammux) {
        g_printerr ("One element could not be created. Exiting.\n");
       // return -1;
      gst_bin_add (GST_BIN (pipeline), streammux);
      //for (i = 0; i < num_sources; i++) {
        GstPad *sinkpad, *srcpad;
        gchar pad_name[16] = { };
        GstElement *source_bin = create_source_bin (0, "file:///home/sigmind/sample_720p.h264");
        if (!source_bin) {
          g_printerr ("Failed to create source bin. Exiting.\n");
         // return -1;
        gst_bin_add (GST_BIN (pipeline), source_bin);
        g_snprintf (pad_name, 15, "sink_%u", i);
        sinkpad = gst_element_get_request_pad (streammux, pad_name);
        if (!sinkpad) {
          g_printerr ("Streammux request sink pad failed. Exiting.\n");
        //  return -1;
        srcpad = gst_element_get_static_pad (source_bin, "src");
        if (!srcpad) {
          g_printerr ("Failed to get src pad of source bin. Exiting.\n");
          //return -1;
        if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
          g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
          //return -1;
        gst_object_unref (srcpad);
        gst_object_unref (sinkpad);
      /* Use nvinfer to infer on batched frame. */
      pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
      /* Use nvtiler to composite the batched frames into a 2D tiled array based
       * on the source of the frames. */
      tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
      /* Use convertor to convert from NV12 to RGBA as required by nvosd */
      nvvidconv = gst_element_factory_make ("nvvidconv", "nvvideo-converter");
      /* Create OSD to draw on the converted RGBA buffer */
      nvosd = gst_element_factory_make ("nvosd", "nv-onscreendisplay");
      /* Finally render the osd output */
     // sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
      if (!pgie || !tiler || !nvvidconv || !nvosd || !sink) {
        //return -1;
      g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
          MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
          "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
      /* Configure the nvinfer element using the nvinfer config file. */
      g_object_set (G_OBJECT (pgie),
          "config-file-path", "/home/XYZ/Downloads/DeepStream_Release/sources/apps/sample_apps/deepstream-test3/dstest3_pgie_config.txt", NULL);
      /* Override the batch-size set in the config file with the number of sources. */
      g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
      if (pgie_batch_size != num_sources) {
        g_printerr
            ("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
            pgie_batch_size, num_sources);
        g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
      tiler_rows = (guint) sqrt (num_sources);
      tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
      /* we set the tiler properties here */
      g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
          "width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
      /* we set the osd properties here */
      g_object_set (G_OBJECT (nvosd), "font-size", 15, NULL);
      /* we add a message handler */
      bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
      bus_watch_id = gst_bus_add_watch (bus, bus_call, NULL);
      gst_object_unref (bus);
      /* Set up the pipeline */
      /* we add all elements into the pipeline */
          NULL);
      /* we link the elements together
       * nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
              NULL)) {
        return -1;
      /* Lets add probe to get informed of the meta data generated, we add probe to
       * the sink pad of the osd element, since by that time, the buffer would have
       * had got all the metadata. */
      tiler_src_pad = gst_element_get_static_pad (pgie, "src");
      if (!tiler_src_pad)
        g_print ("Unable to get src pad\n");
      else
        gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
            tiler_src_pad_buffer_probe, NULL, NULL);
      /* Set the pipeline to "playing" state */
      g_print ("Now playing:");
      g_print ("\n");
      gst_element_set_state (pipeline, GST_STATE_PLAYING);
      /* Wait till pipeline encounters an error or EOS */
      g_print ("Running...\n");
    //  g_main_loop_run (loop);
      while(1) {
        g_main_iteration(false);
        if (frameQueue.size() > 0) {
          Mat frameSink = frameQueue.front();
          std::cout << "Width : " << frameSink.size().width << std::endl;
          std::cout << "Height: " << frameSink.size().height << std::endl;
         imshow("edges", frameSink);
         cv::waitKey(30);
          frameQueue.clear();
      /* Out of the main loop, clean up nicely */
      g_print ("Returned, stopping playback\n");
      gst_element_set_state (pipeline, GST_STATE_NULL);
      g_print ("Deleting pipeline\n");
      gst_object_unref (GST_OBJECT (pipeline));
      g_source_remove (bus_watch_id);
      //g_main_loop_unref (loop);
return 0;
It works good untill the line imshow(“edges”, frameSink) comes in execution, showing Segmentation Fault.
If I comment the line out, it correctly prints GBUS Message from the line
“Vehicle Count = %d Person Count = %d”, frame_meta->stream_id,
Any help is appreciated.
The buffer is cuda buffer, you can’t access it by appsink(cpu) directly.
What’s your appsink do ?
Fortunately, I have solved the problem by modifying the pipeline
gst_bin_add_many (GST_BIN (pipeline), pgie, nvvidconv, nvosd, nvvidconv1, videoconvert, capsfilter, sink, NULL);
            if (!gst_element_link_many (streammux, pgie, nvvidconv, nvosd, nvvidconv1, videoconvert, capsfilter, sink, NULL)) {
             return -1;
