Refer to this sample, I tested it in deepstream:7.1-triton-multiarch
import numpy as np
import sys
import gi
gi.require_version("Gst", "1.0")
from gi.repository import Gst, GLib
import pyds
import ctypes
import cupy as cp
import imageio
frame_num = 0
def on_new_sample(sink, user_data):
sample = sink.emit("pull-sample")
global frame_num
frame_num += 1
if sample:
gst_buffer = sample.get_buffer()
if gst_buffer:
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
# Create dummy owner object to keep memory for the image array alive
owner = None
# Getting Image data using nvbufsurface
# the input should be address of buffer and batch_id
# Retrieve dtype, shape of the array, strides, pointer to the GPU buffer, and size of the allocated memory
data_type, shape, strides, dataptr, size = (
pyds.get_nvds_buf_surface_gpu(hash(gst_buffer), frame_meta.batch_id)
# dataptr is of type PyCapsule -> Use ctypes to retrieve the pointer as an int to pass into cupy
ctypes.pythonapi.PyCapsule_GetPointer.restype = ctypes.c_void_p
ctypes.pythonapi.PyCapsule_GetPointer.argtypes = [
ctypes.py_object,
ctypes.c_char_p,
# Get pointer to buffer and create UnownedMemory object from the gpu buffer
c_data_ptr = ctypes.pythonapi.PyCapsule_GetPointer(dataptr, None)
unownedmem = cp.cuda.UnownedMemory(c_data_ptr, size, owner)
# Create MemoryPointer object from unownedmem, at index 0
memptr = cp.cuda.MemoryPointer(unownedmem, 0)
# Create cupy array to access the image data. This array is in GPU buffer
n_frame_gpu = cp.ndarray(
shape=shape,
dtype=data_type,
memptr=memptr,
strides=strides,
order="C",
# Initialize cuda.stream object for stream synchronization
stream = cp.cuda.stream.Stream(
null=True
stream.synchronize()
if frame_num % 500 == 0:
# Save the CuPy array to an image file
imageio.imsave(f"output-{frame_num}.png", cp.asnumpy(n_frame_gpu))
try:
l_frame = l_frame.next
break
return Gst.FlowReturn.OK
def bus_call(bus, message, loop):
t = message.type
if t == Gst.MessageType.EOS:
print("End-of-stream")
loop.quit()
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print(f"Error: {err}, Debug info: {debug}")
loop.quit()
return True
def cb_newpad(decodebin, decoder_src_pad, sink_pad):
print("In cb_newpad\n")
caps = decoder_src_pad.get_current_caps()
if not caps:
caps = decoder_src_pad.query_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
features = caps.get_features(0)
print("gstname=", gstname)
if gstname.find("video") != -1:
print("features=", features)
if features.contains("memory:NVMM"):
ret = decoder_src_pad.link(sink_pad)
if ret != Gst.PadLinkReturn.OK:
sys.stderr.write("Failed to link decoder\n")
else:
sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def main(args):
# Check input arguments
if len(args) != 2:
print(f"usage: {args[0]} uri")
sys.exit(1)
Gst.init(None)
pipeline = Gst.Pipeline.new("test-pipeline")
uridecodebin = Gst.ElementFactory.make("uridecodebin", "uridecodebin")
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
filter = Gst.ElementFactory.make("capsfilter", "filter1")
tee = Gst.ElementFactory.make("tee", "tee")
queue1 = Gst.ElementFactory.make("queue", "queue1")
queue2 = Gst.ElementFactory.make("queue", "queue2")
fakesink = Gst.ElementFactory.make("fakesink", "fakesink")
appsink = Gst.ElementFactory.make("appsink", "appsink")
if (
not pipeline
or not uridecodebin
or not streammux
or not nvvidconv
or not filter
or not tee
or not queue1
or not queue2
or not fakesink
or not appsink
print("One element could not be created. Exiting.")
return -1
uridecodebin.set_property("uri", args[1])
caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
filter.set_property("caps", caps)
pipeline.add(uridecodebin)
pipeline.add(streammux)
pipeline.add(nvvidconv)
pipeline.add(filter)
pipeline.add(tee)
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(fakesink)
pipeline.add(appsink)
uridecodebin.connect("pad-added", cb_newpad, streammux.request_pad_simple("sink_0"))
streammux.link(nvvidconv)
nvvidconv.link(filter)
filter.link(tee)
tee_to_appsink_pad = tee.request_pad_simple("src_0")
q1_sink_pad = queue1.get_static_pad("sink")
tee_to_appsink_pad.link(q1_sink_pad)
queue1.link(fakesink)
tee_to_3d_pad = tee.request_pad_simple("src_1")
q2_sink_pad = queue2.get_static_pad("sink")
tee_to_3d_pad.link(q2_sink_pad)
queue2.link(appsink)
streammux.set_property("width", 1920)
streammux.set_property("height", 1080)
streammux.set_property("batch-size", 1)
appsink.set_property("emit-signals", True)
appsink.set_property("sync", False)
appsink.set_property("drop", True)
appsink.connect("new-sample", on_new_sample, pipeline)
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
print("Starting pipeline")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
pipeline.set_state(Gst.State.NULL)
if __name__ == "__main__":
sys.exit(main(sys.argv))
By the way, your TRT version does not match DS-7.1, which may cause some problems. It is recommended that you use Docker
