With file sink , the deepstream app gets stuck after processing few frames
• Hardware Platform (Jetson / GPU) NVIDIA A100-SXM
• DeepStream Version 6.0
• TensorRT Version 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only) 470.57.02
• Issue Type( questions, new requirements, bugs) questions
I am using deepstream:6.0-triton container. I replaced EGLSink with filesink . The app gets stuck after processing few frames. With fake sink it works fine. I tried filesink with deepstream-test3 and deepstream-test1. Its not working in both sample app.
 sink = Gst.ElementFactory.make("filesink","nvvideo-renderer")
 if not sink:
    sys.stderr.write("Unable to create filesink \n")
sink.set_property("location", "out.mp4")
sink.set_property("sync", 1)
sink.set_property("async", 0)
Creating Pipeline
Creating streamux
No of sources: range(0, 1)
Creating source_bin 0
Adding: file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.mp4
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating File Sink
WARNING: Overriding infer-config batch-size 0 with number of sources 1
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
1 : file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.mp4
Starting pipeline
0:00:00.236534037 24139 0x1f2fef0 WARN nvinferserver gstnvinferserver_impl.cpp:284:validatePluginConfig: warning: Configuration file batch-size reset to: 1
WARNING: infer_proto_utils.cpp:145 auto-update preprocess.network_format to IMAGE_FORMAT_RGB
INFO: infer_grpc_backend.cpp:164 TritonGrpcBackend id:1 initialized for model: Primary_Detector
Decodebin child added: source
Decodebin child added: decodebin0
Warning: gst-library-error-quark: Configuration file batch-size reset to: 1 (5): gstnvinferserver_impl.cpp(284): validatePluginConfig (): /GstPipeline:pipeline0/GstNvInferServer:primary-inference
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: aacparse0
Decodebin child added: avdec_aac0
Decodebin child added: nvv4l2decoder0
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f4d954ef340 (GstCapsFeatures at 0x7f4cd803aa20)>
In cb_newpad
gstname= audio/x-raw
Source ID = 0 Frame Number= 0
Source ID = 0 Frame Number= 1
Source ID = 0 Frame Number= 2
Source ID = 0 Frame Number= 3
Source ID = 0 Frame Number= 4
Source ID = 0 Frame Number= 5
Source ID = 0 Frame Number= 6
Source ID = 0 Frame Number= 7
Source ID = 0 Frame Number= 8
Source ID = 0 Frame Number= 9
Source ID = 0 Frame Number= 10
Sorry for the late response, is this still an issue to support? Thanks
It duplicate the topic The output video with file sink is not saved properly in deepstream-test2 - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
