Deepstream_test_2.py filesink mode result a corrupted file
• Hardware Platform (Jetson / GPU) :RTX2080TI
• DeepStream Version :5.0
• TensorRT Version :TensorRT-7.0.0.11
• NVIDIA GPU Driver Version (valid for GPU only) :Driver Version: 440.82 CUDA Version: 10.2
• Issue Type( questions, new requirements, bugs) :questions
I run the command:
python deepstream_test_2.py /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
result a mp4 file like
-rw-r–r-- 1 root root 92288 6月 11 19:35 output1111.mp4
However, the output1111.mp4 is corrupted. Anything wrong?
Here is the modified deepstream_test_2.py:
# print("Creating EGLSink \n")
# sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
# if not sink:
#     sys.stderr.write(" Unable to create egl sink \n")
print("Creating Filesink \n")
sink = Gst.ElementFactory.make("filesink", "filesink")
if not sink:
    sys.stderr.write(" Unable to create file sink \n")
sink.set_property("location", "./output1111.mp4")
sink.set_property("sync", 0)
deepstream_test_2.py (14.8 KB)
Any suggestion?
You can not just use filesink, it’s not one plugin, please refer to function create_encode_file_bin in sources/apps/apps-common/src/deepstream_sink_bin.c for how to encode to file.
@Amycao
So how to save .mp4 out of test2 app?
Hi imsk,
Please help to open a new topic with more details of your issue. Thanks
