Deepstream multi stream handling
• Hardware Platform (Jetson / GPU) : Intel(R) Xeon(R) CPU @ 2.00GHz , Debian GNU/Linux 10 (buster) (GNU/Linux 4.19.0-21-cloud-amd64 x86_64\n)
• DeepStream Version : 6.1 (deepstream-6.1-triton)
• JetPack Version (valid for Jetson only) : NA
• TensorRT Version : 8.2.5
• NVIDIA GPU Driver Version (valid for GPU only) : 510.47.03
I cloned this repo “GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications” inside deepstream-6.1-triton docker image. In this I used deepstream-imagedata-multistream this app.
Command - python3 deepstream_imagedata-multistream.py file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 frames
Output -
Frames will be saved in frames
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
1 : file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
Starting pipeline
**PERF: {‘stream0’: 0.0}
After running this command a frames folder is created with subdirectory stream0 but that directory is empty. It is unable to save any frame to the stream0 directory. I want to save all the frames in the stream folder.
  1. git clone nvcr.io/nvidia/deepstream:6.1-triton
  2. docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.1 nvcr.io/nvidia/deepstream:6.1-triton
  3. please refer to deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub and steps below if you use DS6,0GA docker -
1. Prerequisites
apt install -y git python-dev python3 python3-pip python3.6-dev python3.8-dev cmake g++ build-essential
libglib2.0-dev libglib2.0-dev-bin python-gi-dev libtool m4 autoconf automake
2. Gst-python
cd /opt/nvidia/deepstream/deepstream/sources/apps/
git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
cd deepstream_python_apps/
git submodule update --init
apt-get install --reinstall ca-certificates
cd 3rdparty/gst-python/
./autogen.sh
make && make install
3. install pyds
cd deepstream_python_apps/bindings/
mkdir build
cd build
cmake ..
make
pip3 install ./pyds-1.1.0-py3-none-linux_x86_64.whl
  1. cd /opt/nvidia/deepstream/deepstream-6.1/deepstream_python_apps/apps/deepstream-imagedata-multistream
  2. python3 deepstream_imagedata-multistream.py file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 frames
Did you use original sample?
yes i used the original sample @Amycao
Please change egl sink to fakesink and try again.
