Can not save multi video from multi source in deepstream
• Hardware Platform (Jetson / GPU) : Jetson Xavier NX
• DeepStream Version : 5.1
• JetPack Version (valid for Jetson only) 4.5
• TensorRT Version : 7.1.3
I made config to save multi video from multi source in deepstream config but I got only one video that includes all source.This is my config:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=rtsp://10.148.104.83:7654/stream_32_05
num-sources=1
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=3
uri=rtsp://10.148.104.83:7654/stream_32_02
num-sources=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=3
uri=rtsp://10.148.104.83:7654/stream_32_03
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=3
sync=0
enc-type=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
#1=mp4 2=mkv
container=2
#1=h264 2=h265
codec=1
output-file=result2.mkv
[sink1]
enable=1
type=3
sync=0
source-id=1
enc-type=1
gpu-id=0
nvbuf-memory-type=0
#1=mp4 2=mkv
container=2
#1=h264 2=h265
codec=1
output-file=result3.mkv
[sink2]
enable=1
type=3
sync=0
source-id=2
enc-type=1
gpu-id=0
nvbuf-memory-type=0
#1=mp4 2=mkv
container=2
#1=h264 2=h265
codec=1
output-file=result4.mkv
[osd]
enable=1
gpu-id=0
border-width=1
text-size=12
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=3
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
Set muxer output width and height
width=1280
height=720
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
#batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV5.txt
[tracker]
enable=0
tracker-width=512
tracker-height=320
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
[tests]
file-loop=0
what is my wrong? Please guide how can I save one source to one video file.
please disable tiler when save to multi files.
@Amycao thank you so much! I have tried it and it is working fine.
