I am using 4 cameras, and 3 of them are sumsung cameras and 1 is AXIS for RTSP streaming running on Deepstream 5.0. Below is my config file and Jetson Nano specs.
The issue that i am facing right now is proper encoding of H264 streaming coming from the sources. There is always frames pixels not properly encoded and pixels distorted. Please check the image:
CONFIG File:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=640
height=480
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://facit:FacitData123@192.168.0.104:554/Test/media.smp
gpu-id=0
#(0): memtype_device - Memory type Device
#(1): memtype_pinned - Memory type Host Pinned
#(2): memtype_unified - Memory type Unified
cudadec-memtype=0
#intra-decode-enable=1
#num-extra-surfaces=5
#latency=0
#camera-fps-n=25
#camera-fps-d=1
[source1]
enable=1
type=4
uri=rtsp://facit:FacitData123@192.168.0.106:554/Test/media.smp
gpu-id=0
cudadec-memtype=0
#latency=0
#camera-fps-n=25
#camera-fps-d=1
[source2]
enable=1
type=4
uri=rtsp://facit:FacitData123@192.168.0.103:554/Test/media.smp
gpu-id=0
cudadec-memtype=0
#latency=0
#camera-fps-n=25
#camera-fps-d=1
[source3]
enable=1
type=4
uri=rtsp://facit:facit@192.168.0.91:554/axis-media/media.amp
gpu-id=0
cudadec-memtype=0
#latency=0
#camera-fps-n=25
#camera-fps-d=1
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
#codec=1
#enc-type=0
[sink1]
enable=1
type=2
sync=0
source-id=1
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink2]
enable=1
type=2
sync=0
source-id=2
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink3]
enable=1
type=2
sync=0
source-id=3
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[osd]
enable=0
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
width=640
height=480
enable-padding=0
nvbuf-memory-type=0
#config-file property is mandatory for any gie section.
#Other properties are optional and if set will override the properties set in
#the infer config file.
[primary-gie]
enable=0
gpu-id=0
model-engine-file=…/…/models/Primary_Detector_Nano/resnet10.caffemodel_b8_gpu0_fp16.engine
batch-size=8
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_nano.txt
[tracker]
enable=0
tracker-width=640
tracker-height=384
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_iou.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process and enable-past-frame applicable to DCF only
enable-batch-process=1
enable-past-frame=0
display-tracking-id=1
[tests]
file-loop=0
Hardware Platform: Jetson Nano
DeepStream Version: 5.0 latest version
JetPack Version: 4.4 latest [L4T 32.4.3]
TensorRT Version: 7.1.3.0
NVIDIA GPU Driver Version: CUDA 10.2
