**• Hardware Platform (Jetson / GPU)**Jetson Orin NX Engineering Reference Developer Kit
• DeepStream Version6.4
**• JetPack Version (valid for Jetson only)**6.0 DP
• TensorRT Version8.6.2.3
**• Issue Type( questions, new requirements, bugs)**bugs
When I am running deepstream-test5,and I want to use VLC player to watch it,but the screen is green.
my config file:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://../../../../../samples/streams/sample_720p_10min.mp4
#uri=rtsp://10.45.30.55:8554/stream
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[source1]
enable=0
type=3
uri=file://../../../../../samples/streams/sample_1080p_h264.mp4
num-sources=2
gpu-id=0
nvbuf-memory-type=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvdrmvideosink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=1
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=10.45.30.64;9092;test
topic=test
#Optional:
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=1
#sw-preset=1 #for SW enc=(0)None (1)ultrafast (2)superfast (3)veryfast (4)faster
#(5)fast (6)medium (7)slow (8)slower (9)veryslow (10)placebo
sync=0
bitrate=4000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
# set profile only for hw encoder, sw encoder selects profile based on sw-preset
#profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
# sink type = 6 by default creates msg converter + broker.
# To use multiple brokers use this group for converter and use
# sink type = 6 with disable-msgconv = 1
[message-converter]
enable=0
msg-conv-payload-type=0
# Name of library having custom implementation.
#msg-conv-msg2p-lib=<val>
# Id of component in case only selected message to parse.
#msg-conv-comp-id=<val>
# Configure this group to enable cloud message consumer.
[message-consumer0]
enable=0
conn-str=<host>;<port>
config-file=<broker config file e.g. cfg_kafka.txt>
subscribe-topic-list=<topic1>;<topic2>;<topicN>
# Use this option if message has sensor name as id instead of index (0,1,2 etc.).
#sensor-list-file=dstest5_msgconv_sample_config.txt
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1080
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
[primary-gie]
enable=1
gpu-id=0
batch-size=4
## 0=FP32, 1=INT8, 2=FP16 mode
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
nvbuf-memory-type=0
interval=0
gie-unique-id=1
model-engine-file=../../../../../samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b4_gpu0_int8.engine
labelfile-path=../../../../../samples/models/Primary_Detector/labels.txt
config-file=../../../../../samples/configs/deepstream-app/config_yee.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
[tracker]
enable=0
# For NvDCF and NvDeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=960
tracker-height=544
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_IOU.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvSORT.yml
ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDeepSORT.yml
gpu-id=0
display-tracking-id=1
[tests]
file-loop=0
terminal;
nvidia@tegra-ubuntu:~/deepstream-6.4/sources/apps/sample_apps/deepstream-agx$ deepstream-test5-app -c configs/test5_yee_kafka.txt -p 1 -t
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:07.289777870 7600 0xaaaad5e5d2d0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/home/nvidia/deepstream-6.4/sources/apps/sample_apps/deepstream-agx/configs/…/…/…/…/…/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b4_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:07.689920354 7600 0xaaaad5e5d2d0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /home/nvidia/deepstream-6.4/sources/apps/sample_apps/deepstream-agx/configs/…/…/…/…/…/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b4_gpu0_int8.engine
0:00:07.713445658 7600 0xaaaad5e5d2d0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/home/nvidia/deepstream-6.4/sources/apps/sample_apps/deepstream-agx/configs/…/…/…/…/…/samples/configs/deepstream-app/config_yee.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
Active sources : 0
**PERF: FPS 0 (Avg)
Tue Apr 9 09:18:09 2024
**PERF: 0.00 (0.00)
** INFO: <bus_callback:301>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:287>: Pipeline running
mimetype is video/x-raw
WARNING; playback mode used with URI [file:///home/nvidia/deepstream-6.4/sources/apps/sample_apps/deepstream-agx/configs/…/…/…/…/…/samples/streams/sample_720p_10min.mp4] not conforming to timestamp format; check README; using system-time
Active sources : 1
Tue Apr 9 09:18:14 2024
**PERF: 132.58 (131.90)
Active sources : 1
Tue Apr 9 09:18:19 2024
**PERF: 119.87 (125.56)
Active sources : 1
Tue Apr 9 09:18:24 2024
**PERF: 120.12 (123.62)
Active sources : 1
Tue Apr 9 09:18:29 2024
**PERF: 119.85 (122.68)
Active sources : 1
Tue Apr 9 09:18:34 2024
**PERF: 119.99 (122.13)
Active sources : 1
Tue Apr 9 09:18:39 2024
**PERF: 120.12 (121.76)
Active sources : 1
Tue Apr 9 09:18:44 2024
**PERF: 120.03 (121.50)
(deepstream-test5-app:7600): GLib-GObject-WARNING **: 09:18:48.004: g_object_get_is_valid_property: object class ‘GstUDPSrc’ has no property named ‘pt’
Active sources : 1
Tue Apr 9 09:18:49 2024
**PERF: 119.86 (121.31)
Active sources : 1
Tue Apr 9 09:18:54 2024
**PERF: 119.97 (121.16)
Active sources : 1
Tue Apr 9 09:18:59 2024
**PERF: 120.08 (121.04)
Active sources : 1
Tue Apr 9 09:19:04 2024
**PERF: 119.94 (120.95)
Active sources : 1
Tue Apr 9 09:19:09 2024
**PERF: 120.11 (120.86)
Active sources : 1
Tue Apr 9 09:19:14 2024
**PERF: 120.05 (120.80)
Active sources : 1
Tue Apr 9 09:19:19 2024
**PERF: 120.00 (120.74)
Active sources : 1
Tue Apr 9 09:19:24 2024
**PERF: 120.01 (120.69)
Active sources : 1
Tue Apr 9 09:19:29 2024
**PERF: 119.94 (120.64)
q
Quitting
nvstreammux: Successfully handled EOS for source_id=0
App run successful
