nvtracker standalone user sample
https://devtalk.nvidia.com/default/topic/1066252/deepstream-sdk/klt-nvmot-usage/
get nvtracker history
Fix for a memory accumulation bug in GstBaseParse
A memory accumulation bug was found in GStreamer’s Base Parse class which potentially affects all codec parsers provided by GStreamer. This bug is seen only with long duration seekable streams (mostly containerized files e.g. mp4). This does not affect live sources like RTSP. We have filed an issue on GStreamer’s gitlab project (https://gitlab.freedesktop.org/gstreamer/gstreamer/-/issues/468).
Temporary fix
$ gst-inspect-1.0 --version
gst-inspect-1.0 version 1.14.5
GStreamer 1.14.5
https://launchpad.net/distros/ubuntu/+source/gstreamer1.0
$ git clone git@gitlab.freedesktop.org:gstreamer/gstreamer.git
$ cd gstreamer
$ git checkout 1.14.5
$ sudo apt install libbison-dev build-essential flex debhelper
$ ./autogen.sh –noconfigure
./configure –prefix=(pwd)/out # Don’t want to overwrite system libs
diff --git a/libs/gst/base/gstbaseparse.c b/libs/gst/base/gstbaseparse.c
index 41adf130e..ffc662a45 100644
--- a/libs/gst/base/gstbaseparse.c
+++ b/libs/gst/base/gstbaseparse.c
@@ -1906,6 +1906,9 @@ gst_base_parse_add_index_entry (GstBaseParse * parse, guint64 offset,
GST_LOG_OBJECT (parse, "Adding key=%d index entry %" GST_TIME_FORMAT
" @ offset 0x%08" G_GINT64_MODIFIER "x", key, GST_TIME_ARGS (ts), offset);
+ if (!key)
+ goto exit;
if (G_LIKELY (!force)) {
if (!parse->priv->upstream_seekable) {
$ cat patch.txt | patch -p1
make -j(nproc) && make install
sudo cp /usr/lib/x86_64-linux-gnu/libgstbase-1.0.so.0.1405.0 {HOME}/libgstbase-1.0.so.0.1405.0.backup
$ sudo cp out/lib/libgstbase-1.0.so.0.1405.0 /usr/lib/x86_64-linux-gnu/
[DS5.0 xx_All_App] For DS 5.0 DP: how to integrate nvdsanalytics plugin in C deepstream-app
These are rough steps, but additional modifications in header files required
For DS 5.0 GA we would be adding the support for meta access
The original Yolo implementation via CUDA kernel in DeepStream is based on old Yolo models (v2, v3) so it may not suit new Yolo models like YoloV4. Location: /opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/kernels.cu
We are trying to embed Yolo layer into tensorRT engine while converting darknet or pytorch into engine, this is before deploying to DeepStream. This new solution would cause the old Yolo cuda kernel in DeepStream no longer to be used.
You can try following steps to make DeepStream working for YoloV4:
objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/nvdsparsebbox_Yolo.cpp
and rebuild libnvdsinfer_custom_impl_Yolo.so
static NvDsInferParseObjectInfo convertBBoxYoloV4(const float& bx1, const float& by1, const float& bx2,
const float& by2, const uint& netW, const uint& netH)
NvDsInferParseObjectInfo b;
// Restore coordinates to network input resolution
float x1 = bx1 * netW;
float y1 = by1 * netH;
float x2 = bx2 * netW;
float y2 = by2 * netH;
x1 = clamp(x1, 0, netW);
y1 = clamp(y1, 0, netH);
x2 = clamp(x2, 0, netW);
y2 = clamp(y2, 0, netH);
b.left = x1;
b.width = clamp(x2 - x1, 0, netW);
b.top = y1;
b.height = clamp(y2 - y1, 0, netH);
return b;
static void addBBoxProposalYoloV4(const float bx, const float by, const float bw, const float bh,
const uint& netW, const uint& netH, const int maxIndex,
const float maxProb, std::vector<NvDsInferParseObjectInfo>& binfo)
NvDsInferParseObjectInfo bbi = convertBBoxYoloV4(bx, by, bw, bh, netW, netH);
if (bbi.width < 1 || bbi.height < 1) return;
bbi.detectionConfidence = maxProb;
bbi.classId = maxIndex;
binfo.push_back(bbi);
static std::vector<NvDsInferParseObjectInfo>
decodeYoloV4Tensor(
const float* boxes, const float* scores,
const uint num_bboxes, NvDsInferParseDetectionParams const& detectionParams,
std::vector<NvDsInferParseObjectInfo> binfo;
uint bbox_location = 0;
uint score_location = 0;
for (uint b = 0; b < num_bboxes; ++b)
float bx1 = boxes[bbox_location];
float by1 = boxes[bbox_location + 1];
float bx2 = boxes[bbox_location + 2];
float by2 = boxes[bbox_location + 3];
float maxProb = 0.0f;
int maxIndex = -1;
for (uint c = 0; c < detectionParams.numClassesConfigured; ++c)
float prob = scores[score_location + c];
if (prob > maxProb)
maxProb = prob;
maxIndex = c;
if (maxProb > detectionParams.perClassPreclusterThreshold[maxIndex])
addBBoxProposalYoloV4(bx1, by1, bx2, by2, netW, netH, maxIndex, maxProb, binfo);
bbox_location += 4;
score_location += detectionParams.numClassesConfigured;
return binfo;
extern "C" bool NvDsInferParseCustomYoloV4(
std::vector<NvDsInferLayerInfo> const& outputLayersInfo,
NvDsInferNetworkInfo const& networkInfo,
std::vector<NvDsInferParseObjectInfo>& objectList)
if (NUM_CLASSES_YOLO != detectionParams.numClassesConfigured)
std::cerr << "WARNING: Num classes mismatch. Configured:"
<< detectionParams.numClassesConfigured
<< ", detected by network: " << NUM_CLASSES_YOLO << std::endl;
std::vector<NvDsInferParseObjectInfo> objects;
const NvDsInferLayerInfo &boxes = outputLayersInfo[0]; // num_boxes x 4
const NvDsInferLayerInfo &scores = outputLayersInfo[1]; // num_boxes x num_classes
// 3 dimensional: [num_boxes, 1, 4]
assert(boxes.inferDims.numDims == 3);
// 2 dimensional: [num_boxes, num_classes]
assert(scores.inferDims.numDims == 2);
// The second dimension should be num_classes
assert(detectionParams.numClassesConfigured == scores.inferDims.d[1]);
uint num_bboxes = boxes.inferDims.d[0];
// std::cout << "Network Info: " << networkInfo.height << " " << networkInfo.width << std::endl;
std::vector<NvDsInferParseObjectInfo> outObjs =
decodeYoloV4Tensor(
(const float*)(boxes.buffer), (const float*)(scores.buffer), num_bboxes, detectionParams,
networkInfo.width, networkInfo.height);
objects.insert(objects.end(), outObjs.begin(), outObjs.end());
objectList = objects;
return true;
1. [DS5.0GA_Jetson_dGPU_Plugin] Measure of the FPS of pipeline
2. [DS5.0GA_Jetson_dGPU_Plugin] Dump the Inference Input
3. [DS5_Jetson_dGPU_Plugin] Dump the Inference outputs
4. [DS5.0GA_Jetson_App] Rotate camera input image with NvBufSurfTransform() API
5. [DS5.0GA_App] Generate GStreamer Pipeline Graph
Use one of below method according to your application type to generate the GST pipeline graph.
4.1 deepstream-app
run "export GST_DEBUG_DUMP_DOT_DIR=/tmp/" before deepstream-app command, e.g.
$ sudo apt-get install graphviz
$ export GST_DEBUG_DUMP_DOT_DIR=/tmp/
$ deepstream-app -c deepstream_app_config_yoloV2.txt
$ cd /tmp/
$ dot -Tpng 0.03.47.898178403-ds-app-playing.dot >~/0.03.47.898178403-ds-app-playing.png // png file includes the graph
4.2 gstreamer command line
for exmaple,
$ run "export GST_DEBUG_DUMP_DOT_DIR=/tmp/" before deepstream-app command, e.g.
$ gst-launch-1.0 ....
$ cd /tmp/
4.3 DeepStream application
for exmaple
4.3.1 add "g_setenv("GST_DEBUG_DUMP_DOT_DIR", "/tmp", TRUE);" before gst_init()
4.3.2 add "GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS(GST_BIN(gst_objs.pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "demo-app-pipeline");" at the point where want to export the dot file, e.g. when switching to PLAYING
BTW, need to include header file - #include <gio/gio.h>
4.4 Python DeepStream
Refer to https://forums.developer.nvidia.com/t/python-deepstream-program-not-generating-dot-file/163837/8?u=mchi
7. [DS 5.0GA_All_App] Enable Latency measurement for deepstream sample apps
If you are using deepstream-app, to check the component latency directly, you need to set the env
If you are using other deepstream sample apps such as deepstream-test3, you need to apply the following patch and set the env
diff --git a/apps/deepstream/sample_apps/deepstream-test3/deepstream_test3_app.c b/apps/deepstream/sample_apps/deepstream-test3/deepstream_test3_app.c
index 426bd69..c7c2472 100644
--- a/apps/deepstream/sample_apps/deepstream-test3/deepstream_test3_app.c
+++ b/apps/deepstream/sample_apps/deepstream-test3/deepstream_test3_app.c
@@ -26,6 +26,7 @@
#include <math.h>
#include <string.h>
#include <sys/time.h>
+#include <stdlib.h>
#include "gstnvdsmeta.h"
//#include "gstnvstreammeta.h"
@@ -73,6 +74,41 @@ gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
//static guint probe_counter = 0;
+typedef struct {
+ GMutex *lock;
+ int num_sources;
+}LatencyCtx;
+static GstPadProbeReturn
+latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
+ LatencyCtx *ctx = (LatencyCtx *) u_data;
+ static int batch_num = 0;
+ guint i = 0, num_sources_in_batch = 0;
+ if(nvds_enable_latency_measurement)
+ GstBuffer *buf = (GstBuffer *) info->data;
+ NvDsFrameLatencyInfo *latency_info = NULL;
+ g_mutex_lock (ctx->lock);
+ latency_info = (NvDsFrameLatencyInfo *)
+ calloc(1, ctx->num_sources * sizeof(NvDsFrameLatencyInfo));;
+ g_print("\n************BATCH-NUM = %d**************\n",batch_num);
+ num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
+ for(i = 0; i < num_sources_in_batch; i++)
+ g_print("Source id = %d Frame_num = %d Frame latency = %lf (ms) \n",
+ latency_info[i].source_id,
+ latency_info[i].frame_num,
+ latency_info[i].latency);
+ g_mutex_unlock (ctx->lock);
+ batch_num++;
+ return GST_PAD_PROBE_OK;
/* tiler_sink_pad_buffer_probe will extract metadata received on OSD sink pad
* and update params for drawing rectangle, object information etc. */
@@ -107,9 +143,9 @@ tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
num_rects++;
- g_print ("Frame Number = %d Number of objects = %d "
- "Vehicle Count = %d Person Count = %d\n",
- frame_meta->frame_num, num_rects, vehicle_count, person_count);
+ // g_print ("Frame Number = %d Number of objects = %d "
+ // "Vehicle Count = %d Person Count = %d\n",
+ // frame_meta->frame_num, num_rects, vehicle_count, person_count);
#if 0
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params;
@@ -383,7 +419,7 @@ main (int argc, char *argv[])
#ifdef PLATFORM_TEGRA
transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
- sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
+ sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
if (!pgie || !tiler || !nvvidconv || !nvosd || !sink) {
g_printerr ("One element could not be created. Exiting.\n");
@@ -467,6 +503,18 @@ gst_bin_add_many (GST_BIN (pipeline), queue1, pgie, queue2, tiler, queue3,
tiler_src_pad_buffer_probe, NULL, NULL);
gst_object_unref (tiler_src_pad);
+ GstPad *sink_pad = gst_element_get_static_pad (nvosd, "src");
+ if (!sink_pad)
+ g_print ("Unable to get src pad\n");
+ else {
+ LatencyCtx *ctx = (LatencyCtx *)g_malloc0(sizeof(LatencyCtx));
+ ctx->lock = (GMutex *)g_malloc0(sizeof(GMutex));
+ ctx->num_sources = num_sources;
+ gst_pad_add_probe (sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
+ latency_measurement_buf_prob, ctx, NULL);
+ gst_object_unref (sink_pad);
/* Set the pipeline to "playing" state */
g_print ("Now playing:");
for (i = 0; i < num_sources; i++) {
8. [DS 5.0GA_All_App] Enable Perf measurement(FPS) for deepstream sample apps
enable-perf-measurement=1
under Application Group in the config filediff --git a/sources/apps/sample_apps/deepstream-test2/deepstream_test2_app.c b/sources/apps/sample_apps/deepstream-test2/deepstream_test2_app.c
index a2231acf535b4826adb766ed28f3aa80294c7f82..e37d7504ed07c9db77e5d3cdac2c4943fd0d1010 100755
--- a/sources/apps/sample_apps/deepstream-test2/deepstream_test2_app.c
+++ b/sources/apps/sample_apps/deepstream-test2/deepstream_test2_app.c
@@ -28,6 +28,7 @@
#include <string.h>
+#include "deepstream_perf.h"
#define PGIE_CONFIG_FILE "dstest2_pgie_config.txt"
#define SGIE1_CONFIG_FILE "dstest2_sgie1_config.txt"
@@ -51,6 +52,29 @@
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
+#define MAX_STREAMS 64
+typedef struct
+ /** identifies the stream ID */
+ guint32 stream_index;
+ gdouble fps[MAX_STREAMS];
+ gdouble fps_avg[MAX_STREAMS];
+ guint32 num_instances;
+ guint header_print_cnt;
+ GMutex fps_lock;
+ gpointer context;
+ /** Test specific info */
+ guint32 set_batch_size;
+}DemoPerfCtx;
+typedef struct {
+ GMutex *lock;
+ int num_sources;
+}LatencyCtx;
gint frame_number = 0;
/* These are the strings of the labels for the respective models */
gchar sgie1_classes_str[12][32] = { "black", "blue", "brown", "gold", "green",
@@ -80,6 +104,66 @@ guint sgie1_unique_id = 2;
guint sgie2_unique_id = 3;
guint sgie3_unique_id = 4;
+ * callback function to print the performance numbers of each stream.
+static void
+perf_cb (gpointer context, NvDsAppPerfStruct * str)
+ DemoPerfCtx *thCtx = (DemoPerfCtx *) context;
+ g_mutex_lock(&thCtx->fps_lock);
+ /** str->num_instances is == num_sources */
+ guint32 numf = str->num_instances;
+ guint32 i;
+ for (i = 0; i < numf; i++) {
+ thCtx->fps[i] = str->fps[i];
+ thCtx->fps_avg[i] = str->fps_avg[i];
+ thCtx->context = thCtx;
+ g_print ("**PERF: ");
+ g_print ("%.2f (%.2f)\t", thCtx->fps[i], thCtx->fps_avg[i]);
+ g_print ("\n");
+ g_mutex_unlock(&thCtx->fps_lock);
+ * callback function to print the latency of each component in the pipeline.
+ batch_num++;
/* This is the buffer probe function that we have registered on the sink pad
* of the OSD element. All the infer elements in the pipeline shall attach
* their metadata to the GstBuffer, here we will iterate & process the metadata
@@ -144,9 +228,9 @@ osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
nvds_add_display_meta_to_frame(frame_meta, display_meta);
- frame_number, num_rects, vehicle_count, person_count);
+ // frame_number, num_rects, vehicle_count, person_count);
frame_number++;
@@ -586,6 +670,30 @@ main (int argc, char *argv[])
gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
osd_sink_pad_buffer_probe, NULL, NULL);
+ GstPad *sink_pad = gst_element_get_static_pad (nvvidconv1, "src");
+ if (!sink_pad)
+ g_print ("Unable to get sink pad\n");
+ else {
+ ctx->num_sources = argc - 2;
+ GstPad *tiler_pad = gst_element_get_static_pad (nvtiler, "sink");
+ if (!tiler_pad)
+ g_print ("Unable to get tiler_pad pad\n");
+ else {
+ NvDsAppPerfStructInt *str = (NvDsAppPerfStructInt *)g_malloc0(sizeof(NvDsAppPerfStructInt));
+ DemoPerfCtx *perf_ctx = (DemoPerfCtx *)g_malloc0(sizeof(DemoPerfCtx));
+ g_mutex_init(&perf_ctx->fps_lock);
+ str->context = perf_ctx;
+ enable_perf_measurement (str, tiler_pad, argc-2, 1, 0, perf_cb);
+ gst_object_unref (tiler_pad);
g_print ("Now playing: %s\n", argv[1]);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
9. [DS 5.0GA_Jetson_App] Capture HW & SW Memory Leak log
nvmemstat.py.txt (4.6 KB)
10. [ALL_Jetson_plugin] Jetson GStreamer Plugins Using with DeepStream
For the user of Jetson DeepStream (JetPack), there are some accelerated gstreamer plugins which is hardware accelerated by Jetson but are not listed in DeepStream plugin list GStreamer Plugin Overview — DeepStream 5.1 Release documentation.
Some of these plugins can be used in the DeepStream pipeline to extend the DeepStream functions while some of them are not compatible to DeepStreamSDK.
The basic document for the Gstreamer accelerated plugins is Tegra Linux Driver
DeepStream compatible plugins:
Typical usage:
gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4 ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt ! nvtracker tracker-width=640 tracker-height=480 ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so enable-batch-process=1 ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! nvmultistreamtiler ! nvdsosd ! nvvideoconvert ! nvegltransform ! nveglglessink
Typical usage:
Gst-launch-1.0 nvarguscamerasrc bufapi-version=true sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=640,height=480,framerate=30/1,format=NV12’ ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt ! nvtracker tracker-width=640 tracker-height=480 ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so enable-batch-process=1 ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! nvmultistreamtiler ! nvdsosd ! nvvideoconvert ! nvegltransform ! nveglglessink
The related topic in forum:
Typical usage:
gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 bufapi-version=1 ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,framerate=60/1’ ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! mx.sink_0 nvv4l2camerasrc device=/dev/video1 bufapi-version=1 ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,framerate=60/1’ ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! mx.sink_1 nvstreammux width=1920 height=1080 batch-size=2 live-source=1 name=mx ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt batch-size=2 ! nvvideoconvert ! nvmultistreamtiler width=1920 height=1080 rows=1 columns=2 ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink sync=0
Low camera frame rate - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
Typical pipeline:
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder bufapi-version=1 ! nvvideoconvert ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt ! nvdrmvideosink conn_id=0 plane_id=1 set_mode=0 -e
Which videosink for Jetson TX2 in EGLFS? - Jetson & Embedded Systems / Jetson TX2 - NVIDIA Developer Forums
Typical pipeline:
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder bufapi-version=1 ! nvvideoconvert ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt ! nv3dsink sync=false
Note: The nv3dsink plugin is a window-based rendering sink, and based on X11.
Typical pipeline:
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder bufapi-version=1 ! nvvideoconvert ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt ! nvoverlaysink sync=0
Note:The nvoverlaysink plugin is deprecated in L4T release 32.1. Please use nvdrmvideosink or nv3dsink for rendering gst-v4l2 decoder output.
DeepStream Incompatible Plugins
11. [DS 5.x_All_App] How to implement a python binding
Refer following samples from forum users:
12. [DS 5.0GA_Jetson_App]: Dump NV12 NvBufSurface into a YUV file
Each NV12 NvBufSurface includes two semi-planes which are not continuous in memory.
gstnvinfer_dump_NV12_NvBufSurface.patch (4.9 KB)
This is a sample change to /opt/nvidia/deepstream/deepstream-5.1/sources/gst-plugins/gst-nvinfer/gstnvinfer.cpp to dump the NV12 NvBufSurface before transforming to RGB data.
After getting the YUV file, we can view it in https://rawpixels.net/ as below
13. [DS 5.x_All_App] How to access and modify the NvBufSurface
14. [All_Jetson_App] Check memory leakage with valgrind
[DSx_All_App] Debug Tips for DeepStream Accuracy Issue
15.1 Confirm your model has got good accuracy in training and inference outside DeepStream
15.2 When deploying a ONNX model to DeepStream with nvinfer plugin, confirm if below nvinfer parameters are set correctly
15.2.1 Input scale & offset
1). net-scale-factor =
2). offsets
The usage of these two parameters are as below (from doc)
16. [DeepStream 6.0 GA] python binding installation
Download the wheel files directly from Releases · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
Or build it referring to steps below:
16.1 dGPU+x86 platform & Triton docker
16.2 dGPU+x86 platform & non-Triton docker
please refer to deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub and steps below if you use DS6,0GA docker -
## 1. Prerequisites
apt install -y git python-dev python3 python3-pip python3.6-dev python3.8-dev cmake g++ build-essential \
libglib2.0-dev libglib2.0-dev-bin python-gi-dev libtool m4 autoconf automake
# 2. Gst-python
cd /opt/nvidia/deepstream/deepstream/sources/apps/
git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
cd deepstream_python_apps/
git submodule update --init
apt-get install --reinstall ca-certificates
cd 3rdparty/gst-python/
./autogen.sh
make && make install
# 3. install pyds
cd deepstream_python_apps/bindings/
mkdir build
cd build
cmake ..
make
pip3 install ./pyds-1.1.0-py3-none-linux_x86_64.whl
# 4. run sample
mv apps/* ./
cd deepstream-test1/
python3 deepstream_test_1.py ../../../../samples/streams/sample_qHD.h264
16.3 Jetson dockers
Rrefer to deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub and steps below if you use DS6,0GA docker -
## 1. Prerequisites
apt-get update
# 2. Gst-python
./autogen.sh
# 3. install pyds
mkdir build
cd build
cmake .. -DPYTHON_MAJOR_VERSION=3 -DPYTHON_MINOR_VERSION=6 -DPIP_PLATFORM=linux_aarch64 -DDS_PATH=/opt/nvidia/deepstream/deepstream
make
pip3 install ./pyds-1.1.0-py3-none-linux_aarch64.whl
# 4. run sample
mv apps/* ./
17.[DeepStream_dGPU_App] Using OpenCV to run deepstream pipeline
Sometimes the gstreamer pipeline in opencv will fail. Please refer to the following topic to resolve this problem.
How to compile OpenCV with Gstreamer [Ubuntu&Windows] | by Galaktyk 01 | Medium
18. Open model deployment on DeepStream (Thanks for the sharing!)
Yolov5-small : Custom Yolov5 on Deepstream 6.0 (Thanks @raghavendra.ramya)
Yolo2/3/4/5/OR : Improved DeepStream for YOLO models (Thanks @marcoslucianops )
YoloV5+Triton : Triton Inference through docker - #7 by mchi
YoloV4 : GitHub - NVIDIA-AI-IOT/yolov4_deepstream + deepstream_yolov4.tgz - Google Drive
YoloV4+dspreprocess : deepstream_yolov4_with_nvdspreprocess.tgz - Google Drive
