RuntimeError: get_nvds_buf_Surface: Currently we only support RGBA color Format
• Hardware Platform (Jetson / GPU) - GeForce RTX 2080 Ti
• DeepStream Version - 6.3
• TensorRT Version - 8.6.1
• NVIDIA GPU Driver Version (valid for GPU only) - 530.41.03
If I want to save a frame I get: n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id) RuntimeError: get_nvds_buf_Surface: Currently we only support RGBA color Format
This is my full code:
#!/usr/bin/env python3
import sys
sys.path.append('../')
import gi
import configparser
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
from gi.repository import GLib
from ctypes import *
import time
import sys
import math
import random
import platform
from common.is_aarch_64 import is_aarch64
import argparse
from common.FPS import PERF_DATA
from common.bus_call import bus_call
import pyds
from PIL import Image
import numpy as np
import cv2
import os
perf_data = None
OSD_PROCESS_MODE = 0
OSD_DISPLAY_TEXT = 1
MAX_DISPLAY_LEN=64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
SGIE_CLASS_ID_FACE = 0
SGIE_CLASS_ID_LP = 1
PRIMARY_DETECTOR_UID = 1
SECONDARY_DETECTOR_UID = 2
SECOND_DETECTOR_IS_SECONDARY = 1
MUXER_OUTPUT_WIDTH=1920
MUXER_OUTPUT_HEIGHT=1080
MUXER_BATCH_TIMEOUT_USEC=4000000
TILED_OUTPUT_WIDTH=1280
TILED_OUTPUT_HEIGHT=720
GPU_ID = 0
MAX_NUM_SOURCES = 1
SINK_ELEMENT = "nveglglessink"
PGIE_CONFIG_FILE = "dstest2_pgie_config.txt"
TRACKER_CONFIG_FILE = "dstest2_tracker_config2.txt"
SGIE1_CONFIG_FILE = "dstest2_sgie1_config_license_face.txt"
SGIE2_CONFIG_FILE = "dstest2_sgie1_config.txt"
SGIE3_CONFIG_FILE = "dstest2_sgie2_config.txt"
SGIE4_CONFIG_FILE = "dstest2_sgie3_config.txt"
CONFIG_GPU_ID = "gpu-id"
CONFIG_GROUP_TRACKER = "tracker"
CONFIG_GROUP_TRACKER_WIDTH = "tracker-width"
CONFIG_GROUP_TRACKER_HEIGHT = "tracker-height"
CONFIG_GROUP_TRACKER_LL_CONFIG_FILE = "ll-config-file"
CONFIG_GROUP_TRACKER_LL_LIB_FILE = "ll-lib-file"
CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS = "enable-batch-process"
g_num_sources = 0
g_source_id_list = [0] * MAX_NUM_SOURCES
g_eos_list = [False] * MAX_NUM_SOURCES
g_source_enabled = [False] * MAX_NUM_SOURCES
g_source_bin_list = [None] * MAX_NUM_SOURCES
# pgie_classes_str= ["Vehicle", "TwoWheeler", "Person","RoadSign"]
# sgie_classes_str = ["Face", "License Plate"]
# frame_number = 0
uri = ""
loop = None
pipeline = None
streammux = None
sink = None
pgie = None
sgie1 = None
sgie2 = None
sgie3 = None
sgie4 = None
nvvideoconvert = None
nvosd = None
tiler = None
tracker = None
trackersec = None
output_dir = 'output'
if not os.path.exists(output_dir):
    os.makedirs(output_dir)
def osd_sink_pad_buffer_probe(pad, info, u_data):
    # This time we maintain two separate counters for primary and secondary objects
    primary_obj_counter = {
        PGIE_CLASS_ID_PERSON: 0,
        PGIE_CLASS_ID_VEHICLE: 0,
    secondary_obj_counter = {
        SGIE_CLASS_ID_FACE: 0,
        SGIE_CLASS_ID_LP: 0,
    frame_number = 0
    # global frame_number
    global SECOND_DETECTOR_IS_SECONDARY
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return Gst.PadProbeReturn.OK
    # Retrieve batch metadata from the gst_buffer
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        l_obj = frame_meta.obj_meta_list
        source_id = frame_meta.source_id
        frame_number = frame_meta.frame_num
        if frame_number % 30 == 0:
            frame_image_np = np.array(n_frame, copy=True, order='C')
            frame_image_np = cv2.cvtColor(frame_image_np, cv2.COLOR_RGBA2BGR)
            filename = os.path.join(output_dir, "frame_{}.png".format(frame_number))
            cv2.imwrite(filename, frame_image_np)
        while l_obj is not None:
            obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
            l_class = obj_meta.classifier_meta_list
            if obj_meta.unique_component_id == PRIMARY_DETECTOR_UID:
                if obj_meta.class_id in [PGIE_CLASS_ID_PERSON, PGIE_CLASS_ID_VEHICLE]:
                    primary_obj_counter[obj_meta.class_id] += 1
            elif obj_meta.unique_component_id == SECONDARY_DETECTOR_UID:
                if obj_meta.class_id in [SGIE_CLASS_ID_FACE, SGIE_CLASS_ID_LP]:
                    secondary_obj_counter[obj_meta.class_id] += 1
                    if obj_meta.class_id == 0 and obj_meta.parent.class_id == 2:
                        print('Face detected at Tracking ID:', obj_meta.parent.object_id)
                    if obj_meta.class_id == 1 and obj_meta.parent.class_id == 0:
                        l_class_parent = obj_meta.parent.classifier_meta_list
                        color = 'undetected'
                        model = 'undetected'
                        vehicle_type = 'undetected'
                        if l_class_parent is not None:
                            while l_class_parent is not None:
                                class_meta_parent = pyds.NvDsClassifierMeta.cast(l_class_parent.data)
                                # top = int(obj_meta.rect_params.top)
                                # left = int(obj_meta.rect_params.left)
                                # width = int(obj_meta.rect_params.width)
                                # height = int(obj_meta.rect_params.height)
                                if class_meta_parent.unique_component_id == 3:
                                    l_label_parent = class_meta_parent.label_info_list
                                    label_color = pyds.NvDsLabelInfo.cast(l_label_parent.data)
                                    color = label_color.result_label if label_color.result_label else 'undetected'
                                if class_meta_parent.unique_component_id == 4:
                                    label_model = pyds.NvDsLabelInfo.cast(l_label_parent.data)
                                    model = label_model.result_label if label_model.result_label else 'undetected'
                                if class_meta_parent.unique_component_id == 5:
                                    label_vehicle_type = pyds.NvDsLabelInfo.cast(l_label_parent.data)
                                    vehicle_type = label_vehicle_type.result_label if label_vehicle_type.result_label else 'undetected'
                                l_class_parent = l_class_parent.next
                        print('License Plate detected for vehicle with Tracking ID: {}, Color: {}, Model: {}, Type: {}'
                              .format(obj_meta.parent.object_id, color, model, vehicle_type))
            l_obj = l_obj.next
        print("Source ID:", source_id,
            "Frame Number:", frame_number,
            "Person Count:", primary_obj_counter[PGIE_CLASS_ID_PERSON],
            "Vehicle Count:", primary_obj_counter[PGIE_CLASS_ID_VEHICLE],
            "Face Count:", secondary_obj_counter[SGIE_CLASS_ID_FACE],
            "License Plate Count:", secondary_obj_counter[SGIE_CLASS_ID_LP])
        try:
            l_frame = l_frame.next
        except StopIteration:
            break
def cb_newpad(decodebin, decoder_src_pad, data):
    print("In cb_newpad\n")
    caps = decoder_src_pad.get_current_caps()
    gststruct = caps.get_structure(0)
    gstname = gststruct.get_name()
    source_bin = data
    features = caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=", gstname)
    if gstname.find("video") != -1:
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=", features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad = source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write(
                    "Failed to link decoder src pad to source bin ghost pad\n"
        else:
            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
    print("Decodebin child added:", name, "\n")
    if name.find("decodebin") != -1:
        Object.connect("child-added", decodebin_child_added, user_data)
    if "source" in name:
        source_element = child_proxy.get_by_name("source")
        if source_element.find_property("drop-on-latency") != None:
            Object.set_property("drop-on-latency", True)
def create_source_bin(index, uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name = "source-bin-%02d" % index
    print(bin_name)
    nbin = Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri", uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added", cb_newpad, nbin)
    uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin, uri_decode_bin)
    bin_pad = nbin.add_pad(Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
def make_element(element_name, i):
    element = Gst.ElementFactory.make(element_name, element_name)
    if not element:
        sys.stderr.write(" Unable to create {0}".format(element_name))
    element.set_property("name", "{0}-{1}".format(element_name, str(i)))
    return element
def main(args, requested_pgie=None, config=None, disable_probe=False):
    global g_num_sources
    global g_source_bin_list
    global uri
    global loop
    global pipeline
    global streammux
    global sink
    global pgie
    global sgie1
    global sgie2
    global sgie3
    global nvvideoconvert
    global nvosd
    global tiler
    global tracker
    global trackersec
    input_sources = args
    number_sources = len(input_sources)
    global perf_data
    perf_data = PERF_DATA(number_sources)
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ", i, " \n ")
        uri_name = input_sources[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname = "sink_%u" % i
        sinkpad = streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad = source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    # queue1 = Gst.ElementFactory.make("queue", "queue1")
    # pipeline.add(queue1)
    print("Creating Pgie \n ")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    print("Creating nvtracker \n ")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    print("Creating nvtracker2 \n ")
    trackersec = Gst.ElementFactory.make("nvtracker", "trackersec")
    if not trackersec:
    print("Creating sgie1 \n ")
    sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
    if not sgie1:
        sys.stderr.write(" Unable to make sgie1 \n")
    print("Creating sgie2 \n ")
    sgie2 = Gst.ElementFactory.make("nvinfer", "secondary2-nvinference-engine")
    if not sgie2:
        sys.stderr.write(" Unable to make sgie2 \n")
    print("Creating sgie3 \n ")
    sgie3 = Gst.ElementFactory.make("nvinfer", "secondary3-nvinference-engine")
    if not sgie3:
        sys.stderr.write(" Unable to make sgie3 \n")
    print("Creating sgie4 \n ")
    sgie4 = Gst.ElementFactory.make("nvinfer", "secondary4-nvinference-engine")
    if not sgie4:
        sys.stderr.write(" Unable to make sgie4 \n")
    print("Creating tiler \n ")
    tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvideoconvert = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvideoconvert:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvvidconv1 \n ")
    nvvideoconvert1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
    if not nvvideoconvert1:
        sys.stderr.write(" Unable to create nvvidconv1 \n")
    print("Creating filter1 \n ")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
    if not filter1:
        sys.stderr.write(" Unable to get the caps filter1 \n")
    filter1.set_property("caps", caps1)
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    if is_aarch64():
        print("Creating nv3dsink \n")
        sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
        if not sink:
            sys.stderr.write(" Unable to create nv3dsink \n")
    else:
        print("Creating EGLSink \n")
        sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
        if not sink:
            sys.stderr.write(" Unable to create egl sink \n")
    if is_live:
        print("Atleast one of the sources is live")
        streammux.set_property('live-source', 1)
    print("Creating nvstreamdemux \n ")
    nvstreamdemux = Gst.ElementFactory.make("nvstreamdemux", "nvstreamdemux")
    if not nvstreamdemux:
        sys.stderr.write(" Unable to create nvstreamdemux \n")
    if is_live:
        streammux.set_property("live-source", 1)
    streammux.set_property("width", 960)
    streammux.set_property("height", 540)
    streammux.set_property("batch-size", number_sources)
    streammux.set_property("batched-push-timeout", 4000000)
    pgie.set_property("config-file-path", PGIE_CONFIG_FILE)
    pgie.set_property("unique-id", PRIMARY_DETECTOR_UID)
    pgie_batch_size = pgie.get_property("batch-size")
    if pgie_batch_size != number_sources:
        print(
            "WARNING: Overriding infer-config batch-size",
            pgie_batch_size,
            " with number of sources ",
            number_sources,
            " \n",
        pgie.set_property("batch-size", number_sources)
    sgie1.set_property('config-file-path', SGIE1_CONFIG_FILE)
    sgie1.set_property("unique-id", SECONDARY_DETECTOR_UID)
    sgie1.set_property("process-mode", 2 if SECOND_DETECTOR_IS_SECONDARY else 1)
    sgie2.set_property('config-file-path', SGIE2_CONFIG_FILE)
    sgie2.set_property("unique-id", 3)
    sgie2.set_property("process-mode", 2)
    sgie3.set_property('config-file-path', SGIE3_CONFIG_FILE)
    sgie3.set_property("unique-id", 4)
    sgie3.set_property("process-mode", 2)
    sgie4.set_property('config-file-path', SGIE4_CONFIG_FILE)
    sgie4.set_property("unique-id", 5)
    sgie4.set_property("process-mode", 2)
    config = configparser.ConfigParser()
    config.read(TRACKER_CONFIG_FILE)
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width' :
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
            trackersec.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
            trackersec.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
            trackersec.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
            trackersec.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
            trackersec.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process' :
            tracker_enable_batch_process = config.getint('tracker', key)
            # tracker.set_property('enable_batch_process', tracker_enable_batch_process)
            # trackersec.set_property('enable_batch_process', tracker_enable_batch_process)
    tiler_rows=int(math.sqrt(number_sources))
    tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
    tiler.set_property("rows",tiler_rows)
    tiler.set_property("columns",tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    #Set gpu IDs of tiler, nvvideoconvert, and nvosd
    tiler.set_property("gpu_id", GPU_ID)
    nvvideoconvert.set_property("gpu_id", GPU_ID)
    nvosd.set_property("gpu_id", GPU_ID)
    #Set gpu ID of sink if not aarch64
    if(not is_aarch64()):
        sink.set_property("gpu_id", GPU_ID)
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(sgie1)
    # pipeline.add(trackersec)
    pipeline.add(sgie2)
    pipeline.add(sgie3)
    pipeline.add(sgie4)
    pipeline.add(tiler)
    pipeline.add(nvvideoconvert)
    pipeline.add(nvosd)
    pipeline.add(sink)
    print("Linking elements in the Pipeline \n")
    streammux.link(pgie)
    pgie.link(tracker)
    tracker.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(sgie3)
    sgie3.link(sgie4)
    sgie4.link(tiler)
    tiler.link(nvvideoconvert)
    nvvideoconvert.link(nvosd)
    nvosd.link(sink)
    sink.set_property("sync", 0)
    sink.set_property("qos",0)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    pgie_src_pad = tiler.get_static_pad("sink")
    if not pgie_src_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
        # perf callback function to print fps every 5 sec
        GLib.timeout_add(5000, perf_data.perf_print_callback)
    # List the sources
    print("Now playing...")
    for i, source in enumerate(input_sources):
        print(i, ": ", source)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = argparse.ArgumentParser(prog="deepstream_demux_multi_in_multi_out.py",
        description="deepstream-demux-multi-in-multi-out takes multiple URI streams as input" \
            "and uses `nvstreamdemux` to split batches and output separate buffer/streams")
    parser.add_argument(
        "-i",
        "--input",
        help="Path to input streams",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
    args = parser.parse_args()
    stream_paths = args.input
    return stream_paths
if __name__ == "__main__":
    stream_paths = parse_args()
    sys.exit(main(stream_paths))
You can refer this topic
That looks same problem. must be use CUDA unified memory.
import sys
import gi
import configparser
import time
import sys
import math
import random
import platform
import argparse
import pyds
import numpy as np
import cv2
import os
perf_data = None
MAX_DISPLAY_LEN=64
GPU_ID = 0
MAX_NUM_SOURCES = 1
g_num_sources = 0
uri = ""
loop = None
pipeline = None
streammux = None
sink = None
pgie = None
sgie1 = None
sgie2 = None
sgie3 = None
sgie4 = None
nvvideoconvert1 = None
nvosd = None
tiler = None
tracker = None
trackersec = None
    frame_number = 0
    if not gst_buffer:
            l_obj = l_obj.next
        try:
            break
    source_bin = data
                sys.stderr.write(
        else:
    print(bin_name)
    if not nbin:
    if not bin_pad:
        return None
    return nbin
    if not element:
    return element
    global uri
    global loop
    global pipeline
    global streammux
    global sink
    global pgie
    global sgie1
    global sgie2
    global sgie3
    global nvvideoconvert1
    global nvosd
    global tiler
    global tracker
    global trackersec
    global perf_data
    Gst.init(None)
    is_live = False
    if not pipeline:
    if not streammux:
            is_live = True
        if not source_bin:
        if not sinkpad:
        if not srcpad:
    if not pgie:
    if not tracker:
    if not trackersec:
    if not sgie1:
    if not sgie2:
    if not sgie3:
    if not sgie4:
    if not tiler:
    if not filter1:
    if not nvosd:
    if is_aarch64():
        if not sink:
    else:
        if not sink:
    if is_live:
    if is_live:
        print(
            pgie_batch_size,
            number_sources,
            " \n",
    config.sections()
    if not is_aarch64():
        # sink.set_property("gpu_id", GPU_ID)
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        nvvideoconvert.set_property("nvbuf-memory-type", mem_type)
    pipeline.add(pgie)
    pipeline.add(sgie1)
    pipeline.add(sgie2)
    pipeline.add(sgie3)
    pipeline.add(sgie4)
    pipeline.add(tiler)
    pipeline.add(filter1)
    pipeline.add(nvvideoconvert1)
    pipeline.add(nvosd)
    pipeline.add(sink)
    pgie.link(tracker)
    tracker.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(sgie3)
    sgie3.link(sgie4)
    sgie4.link(nvvideoconvert1)
    nvvideoconvert1.link(filter1)
    filter1.link(tiler)
    nvosd.link(sink)
    else:
    # List the sources
    try:
        loop.run()
    except:
        pass
    # cleanup
def parse_args():
        "-i",
        "--input",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
    return stream_paths
According to your code, the pipeline should be like below
    pgie.link(tracker)
    tracker.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(sgie3)
    sgie3.link(sgie4)
    sgie4.link(tiler)
    nvvideoconvert.link(filter1)
    filter1.link(nvosd)
    nvosd.link(sink)
And
       tiler.set_property("nvbuf-memory-type", mem_type)
    pipeline.add(pgie)
    pipeline.add(sgie1)
    pipeline.add(sgie2)
    pipeline.add(sgie3)
    pipeline.add(sgie4)
    pipeline.add(tiler)
    pipeline.add(nvosd)
    pipeline.add(sink)
    pgie.link(tracker)
    tracker.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(sgie3)
    sgie3.link(sgie4)
    sgie4.link(tiler)
    filter1.link(nvosd)
    nvosd.link(sink)
    else:
Due to osd_sink_pad_buffer_probe is added for sink pad of tiler.
You can try the following code.
    pgie.link(tracker)
    tracker.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(sgie3)
    sgie3.link(sgie4)
    filter1.link(tiler)
    nvosd.link(sink)
it saves the image, but i get line 144, in osd_sink_pad_buffer_probe if obj_meta.class_id == 0 and obj_meta.parent.class_id == 2: AttributeError: 'NoneType' object has no attribute 'class_id' if it detects a face or a plate(its a back to back script, vehicle-license plate; person-face).
if i have pgie_src_pad = sgie4.get_static_pad("sink") instead of pgie_src_pad = tiler.get_static_pad("sink") it creates the relationship between vehicle-plate/person-face, but i get again n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id) RuntimeError: get_nvds_buf_Surface: Currently we only support RGBA color Format
this is my full code
import sys
import gi
import configparser
import time
import sys
import math
import random
import platform
import argparse
import pyds
import numpy as np
import cv2
import os
perf_data = None
MAX_DISPLAY_LEN=64
GPU_ID = 0
MAX_NUM_SOURCES = 1
g_num_sources = 0
uri = ""
loop = None
pipeline = None
streammux = None
sink = None
pgie = None
sgie1 = None
sgie2 = None
sgie3 = None
sgie4 = None
nvosd = None
tiler = None
tracker = None
trackersec = None
    frame_number = 0
    if not gst_buffer:
            l_obj = l_obj.next
        try:
            break
    source_bin = data
                sys.stderr.write(
        else:
    print(bin_name)
    if not nbin:
    if not bin_pad:
        return None
    return nbin
    if not element:
    return element
    global uri
    global loop
    global pipeline
    global streammux
    global sink
    global pgie
    global sgie1
    global sgie2
    global sgie3
    global nvosd
    global tiler
    global tracker
    global trackersec
    global perf_data
    Gst.init(None)
    is_live = False
    if not pipeline:
    if not streammux:
            is_live = True
        if not source_bin:
        if not sinkpad:
        if not srcpad:
    if not pgie:
    if not tracker:
    if not trackersec:
    if not sgie1:
    if not sgie2:
    if not sgie3:
    if not sgie4:
    if not tiler:
    if not filter1:
    if not nvosd:
    if is_aarch64():
        if not sink:
    else:
        if not sink:
    if is_live:
    if is_live:
        print(
            pgie_batch_size,
            number_sources,
            " \n",
    config.sections()
    # if not is_aarch64():
    #     # sink.set_property("gpu_id", GPU_ID)
    #     mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
    #     streammux.set_property("nvbuf-memory-type", mem_type)
    #     nvvideoconvert.set_property("nvbuf-memory-type", mem_type)
    #     tiler.set_property("nvbuf-memory-type", mem_type)
    pipeline.add(pgie)
    pipeline.add(sgie1)
    pipeline.add(sgie2)
    pipeline.add(sgie3)
    pipeline.add(sgie4)
    pipeline.add(tiler)
    pipeline.add(nvosd)
    pipeline.add(sink)
    pgie.link(tracker)
    tracker.link(sgie1)
    sgie1.link(sgie2)
    sgie2.link(sgie3)
    sgie3.link(sgie4)
    filter1.link(tiler)
    nvosd.link(sink)
        nvvideoconvert1.set_property("nvbuf-memory-type", mem_type)
    else:
    # List the sources
    try:
        loop.run()
    except:
        pass
    # cleanup
def parse_args():
        "-i",
        "--input",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
    return stream_paths
It seems that the meta was dropped during the conversion.
I have a advise.
The probe function is added to osd and sgie4 at the same time, the probe function of sgie4 is only used to analyze meta data. The function of saving pictures is placed in the probe function of osd
