GstNvInfer:secondary2-nvinference-engine: streaming stopped, reason not-linked (-1)
• Hardware Platform (Jetson / GPU) Geforce RTX 3050 (laptop gpu)
• DeepStream Version 5.1 (devel docker image)
• TensorRT Version 7.2
• NVIDIA GPU Driver Version (valid for GPU only) 525.147.05
lpr-rtsp-out application python file:
import sys
sys.path.append('../')
import gi
import configparser
gi.require_version('Gst', '1.0')
gi.require_version("GstRtspServer", "1.0")
from gi.repository import GObject, Gst, GstRtspServer, GLib
from gi.repository import GLib
from ctypes import *
import time
import sys
import numpy as np
import cv2
import math
import platform
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import GETFPS
from common.utils import long_to_uint64
import pyds
from threading import Thread
from queue import Queue
import os
import datetime
import argparse
fps_streams={}
MUXER_OUTPUT_WIDTH=1920
MUXER_OUTPUT_HEIGHT=1080
MUXER_BATCH_TIMEOUT_USEC=4000000
TILED_OUTPUT_WIDTH=1280
TILED_OUTPUT_HEIGHT=720
GST_CAPS_FEATURES_NVMM="memory:NVMM"
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 0
pgie_classes_str= ["lpd"]
# tiler_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
def tiler_src_pad_buffer_probe(pad,info,u_data,args):
    frame_number=0
    num_rects=0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    lp_dict = {}
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        print("Frame Number is ", frame_meta.frame_num)
        print("Source id is ", frame_meta.source_id)
        print("Batch id is ", frame_meta.batch_id)
        print("Source Frame Width ", frame_meta.source_frame_width)
        print("Source Frame Height ", frame_meta.source_frame_height)
        print("Num object meta ", frame_meta.num_obj_meta)
        frame_number=frame_meta.frame_num
        l_obj=frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            if args[5] == '0':
                #no ROI
                l_class = obj_meta.classifier_meta_list
                while l_class is not None:
                    try:
                        class_meta = pyds.NvDsClassifierMeta.cast(l_class.data)
                        break
                    l_label = class_meta.label_info_list
                    while l_label is not None:
                        try:
                            label_info = pyds.NvDsLabelInfo.cast(l_label.data)
                            break
                        print(label_info.result_label)
                        try:
                            l_label=l_label.next
                            break
                    try:
                        l_class=l_class.next
                        break
            else:
                l_user_meta = obj_meta.obj_user_meta_list
                while l_user_meta:
                    try:
                        user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
                        if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSOBJ.USER_META"):
                            user_meta_data = pyds.NvDsAnalyticsObjInfo.cast(user_meta.user_meta_data)
                            print("Object {0} line crossing status: {1}".format(obj_meta.object_id, user_meta_data.lcStatus))
                            print("Object {0} roi status: {1}".format(obj_meta.object_id, user_meta_data.roiStatus))
                            print("Object {0} moving in direction: {1}".format(obj_meta.object_id, user_meta_data.dirStatus))
                            print("Object {0} overcrowding status: {1}".format(obj_meta.object_id, user_meta_data.ocStatus))
                            print(l_class)
                            if user_meta_data.roiStatus:
                                    try:
                                        break
                                        try:
                                            break
                                        try:
                                            break
                                    try:
                                        break
                        break
                try:
                    l_user_meta = l_user_meta.next
                    break
            try:
                l_obj=l_obj.next
                break
        # Get meta data from NvDsAnalyticsFrameMeta
        l_user = frame_meta.frame_user_meta_list
        while l_user:
            try:
                user_meta = pyds.NvDsUserMeta.cast(l_user.data)
                if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSFRAME.USER_META"):
                    user_meta_data = pyds.NvDsAnalyticsFrameMeta.cast(user_meta.user_meta_data)
                    if user_meta_data.objInROIcnt: print("Objs in ROI: {0}".format(user_meta_data.objInROIcnt))
                    if user_meta_data.objLCCumCnt: print("Linecrossing Cumulative: {0}".format(user_meta_data.objLCCumCnt))
                    if user_meta_data.objLCCurrCnt: print("Linecrossing Current Frame: {0}".format(user_meta_data.objLCCurrCnt))
                    if user_meta_data.ocStatus: print("Overcrowding status: {0}".format(user_meta_data.ocStatus))
                break
            try:
                l_user = l_user.next
                break
        # Get frame rate through this probe
        fps_streams["stream{0}".format(frame_meta.pad_index)].get_fps()
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
def get_frame(gst_buffer, batch_id):
    n_frame=pyds.get_nvds_buf_surface(hash(gst_buffer),batch_id)
    #convert python array into numy array format.
    frame_image=np.array(n_frame,copy=True,order='C')
    #covert the array into cv2 default color format
    frame_image=cv2.cvtColor(frame_image,cv2.COLOR_RGBA2BGRA)
    return frame_image
def cb_newpad(decodebin, decoder_src_pad,data):
    print("In cb_newpad\n")
    caps=decoder_src_pad.get_current_caps()
    gststruct=caps.get_structure(0)
    gstname=gststruct.get_name()
    source_bin=data
    features=caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=",gstname)
    if(gstname.find("video")!=-1):
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=",features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad=source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
        else:
            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
    print("Decodebin child added:", name, "\n")
    if(name.find("decodebin") != -1):
        Object.connect("child-added",decodebin_child_added,user_data)
    if name.find("nvv4l2decoder") != -1:
        if is_aarch64():
            print("Seting bufapi_version\n")
        Object.set_property("bufapi-version",True)
    if ts_from_rtsp:
        print("rtsp")
        if (name.find("source") != -1):
            pyds.configure_source_for_ntp_sync(hash(Object))
def create_source_bin(index,uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name="source-bin-%02d" %index
    print(bin_name)
    nbin=Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri",uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added",cb_newpad,nbin)
    uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin,uri_decode_bin)
    bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
def main(args):
    # Check input arguments
    if len(args) < 2:
        sys.stderr.write("Usage: {} [1:us model|2: ch_model] [1:filesink|2:fakesink|"
        "3:display sink] [0:ROI disable|0:ROI enable] <In mp4 filename> <in mp4 filename> ... "
        "<out H264 filename>\n".format(args[0]))
        sys.exit(1)
    print(args)
    for i in range(0,len(args)-6):
        fps_streams["stream{0}".format(i)]=GETFPS(i)
    number_sources=len(args)-6
    print(number_sources)
    # Standard GStreamer initialization
    GObject.threads_init()
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ",i," \n ")
        uri_name=args[6]
        if uri_name.find("rtsp://") == 0 :
            is_live = True
        else:
            uri_name="file://"+uri_name
        print(uri_name)
        print("*********************")
        source_bin=create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname="sink_%u" %i
        sinkpad= streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad=source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    queue1=Gst.ElementFactory.make("queue","queue1")
    queue2=Gst.ElementFactory.make("queue","queue2")
    queue3=Gst.ElementFactory.make("queue","queue3")
    queue4=Gst.ElementFactory.make("queue","queue4")
    queue5=Gst.ElementFactory.make("queue","queue5")
    queue6=Gst.ElementFactory.make("queue","queue6")
    queue7=Gst.ElementFactory.make("queue","queue7")
    queue8=Gst.ElementFactory.make("queue","queue8")
    queue9=Gst.ElementFactory.make("queue","queue9")
    queue10=Gst.ElementFactory.make("queue","queue10")
    queue11=Gst.ElementFactory.make("queue","queue11")
    queue12=Gst.ElementFactory.make("queue","queue12")
    queue13=Gst.ElementFactory.make("queue","queue13")
    queue14=Gst.ElementFactory.make("queue","queue14")
    pipeline.add(queue1)
    pipeline.add(queue2)
    pipeline.add(queue3)
    pipeline.add(queue4)
    pipeline.add(queue5)
    pipeline.add(queue6)
    pipeline.add(queue7)
    pipeline.add(queue8)
    pipeline.add(queue9)
    pipeline.add(queue10)
    pipeline.add(queue11)
    pipeline.add(queue12)
    pipeline.add(queue13)
    pipeline.add(queue14)
    print("Creating Pgie \n ")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    print("Creating tiler \n ")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    print("Creating nvdsanalytics \n ")
    nvanalytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
    if not nvanalytics:
        sys.stderr.write(" Unable to create nvanalytics \n")
    nvanalytics.set_property("config-file", "config_nvdsanalytics.txt")
    sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
    if not sgie1:
        sys.stderr.write(" Unable to make sgie1 \n")
    sgie2 = Gst.ElementFactory.make("nvinfer", "secondary2-nvinference-engine")
    if not sgie2:
        sys.stderr.write(" Unable to make sgie2 \n")
    print("Creating nvvidconv1 \n ")
    nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
    if not nvvidconv1:
        sys.stderr.write(" Unable to create nvvidconv1 \n")
    print("Creating filter1 \n ")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
    if not filter1:
        sys.stderr.write(" Unable to get the caps filter1 \n")
    filter1.set_property("caps", caps1)
    tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvosd.set_property('process-mode',OSD_PROCESS_MODE)
    nvosd.set_property('display-text',OSD_DISPLAY_TEXT)
    # Create a caps filter
    caps = Gst.ElementFactory.make("capsfilter", "filter")
    caps.set_property(
        "caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420")
    # Make the encoder
    if codec == "H264":
        encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
        print("Creating H264 Encoder")
    elif codec == "H265":
        encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
        print("Creating H265 Encoder")
    if not encoder:
        sys.stderr.write(" Unable to create encoder")
    encoder.set_property("bitrate", bitrate)
    if(is_aarch64()):
        encoder.set_property("preset-level", 1)
        encoder.set_property("insert-sps-pps", 1)
        #encoder.set_property("bufapi-version", 1)
        print("Creating transform \n ")
        transform=Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
        if not transform:
            sys.stderr.write(" Unable to create transform \n")
    # Make the payload-encode video into RTP packets
    if codec == "H264":
        rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
        print("Creating H264 rtppay")
        rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
        print("Creating H265 rtppay")
    if not rtppay:
        sys.stderr.write(" Unable to create rtppay")
    if args[4] == '1':
        print("Creating FileSink \n")
        sink = Gst.ElementFactory.make("filesink", "nvvideo-renderer")
        if not sink:
            sys.stderr.write(" Unable to create file sink \n")
        sink.set_property("location", args[-1])
    elif args[4] == '3':
        print("Creating EGLSink \n")
        sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
        if not sink:
            sys.stderr.write(" Unable to create egl sink \n")
    elif args[4] == '2':
        print("Creating FakeSink \n")
        sink = Gst.ElementFactory.make("fakesink", "fakesink")
        if not sink:
            sys.stderr.write(" Unable to create fake sink \n")
    elif args[4] == '4':
        print("Creating udpsink \n")
        updsink_port_num = 5400
        sink = Gst.ElementFactory.make("udpsink", "udpsink")
        if not sink:
            sys.stderr.write(" Unable to create udpsink \n")
        sink.set_property("host", "224.224.255.255")
        sink.set_property("port", updsink_port_num)
        sink.set_property("async", False)
        sink.set_property("sync", 1)
    else:
        print(" Invalid argument for sink \n")
        sys.exit(1)
    if is_live:
        print("Atleast one of the sources is live")
        streammux.set_property('live-source', 1)
    streammux.set_property('width', MUXER_OUTPUT_WIDTH)
    streammux.set_property('height', MUXER_OUTPUT_HEIGHT)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', 4000000)
    if ts_from_rtsp:
        streammux.set_property("attach-sys-ts", 0)
    pgie.set_property('config-file-path', "trafficamnet_config.txt")
    pgie_batch_size=pgie.get_property("batch-size")
    if(pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
        pgie.set_property("batch-size",number_sources)
    # Set properties of tracker
    config = configparser.ConfigParser()
    config.read('lpr_sample_tracker_config.txt')
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width':
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height':
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id':
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file':
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file':
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process':
            tracker_enable_batch_process = config.getint('tracker', key)
            tracker.set_property('enable_batch_process',
                                 tracker_enable_batch_process)
    if args[3] == '1':
        sgie1.set_property('config-file-path', "lpd_us_config.txt")
    elif args[3] == '2':
        sgie1.set_property('config-file-path', "lpd_ccpd_config.txt")
    else:
        print(" Invalid argument for LP detector model \n")
        sys.exit(1)
    sgie1.set_property('process-mode', 2)
    if args[3] == '1':
        sgie2.set_property('config-file-path', "lpr_config_sgie_us.txt")
        sgie2.set_property('config-file-path', "lpr_config_sgie_ch.txt")
    else:
        print(" Invalid argument for LP recognition model \n")
        sys.exit(1)
    sgie2.set_property('process-mode', 2)
    tiler_rows=int(math.sqrt(number_sources))
    tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
    tiler.set_property("rows",tiler_rows)
    tiler.set_property("columns",tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    sink.set_property("qos",0)
    sink.set_property("sync",0)
    if not is_aarch64():
        # Use CUDA unified memory in the pipeline so frames
        # can be easily accessed on CPU in Python.
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        nvvidconv.set_property("nvbuf-memory-type", mem_type)
        nvvidconv1.set_property("nvbuf-memory-type", mem_type)
        tiler.set_property("nvbuf-memory-type", mem_type)
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(nvanalytics)
    pipeline.add(sgie1)
    pipeline.add(sgie2)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(filter1)
    pipeline.add(nvvidconv1)
    pipeline.add(nvosd)
    pipeline.add(caps)
    pipeline.add(encoder)
    if is_aarch64():
        pipeline.add(transform)
    pipeline.add(rtppay)
    pipeline.add(sink)
    print("Linking elements in the Pipeline \n")
    if args[5] == '0':            #ROI disable
        streammux.link(pgie)
        pgie.link(queue1)
        queue1.link(tracker)
        tracker.link(queue2)
        queue2.link(sgie1)
        sgie1.link(queue3)
        queue3.link(sgie2)
        sgie2.link(queue4)
        queue4.link(nvvidconv1)
        nvvidconv1.link(queue5)
        queue5.link(filter1)
        filter1.link(queue6)
        queue6.link(tiler)
        tiler.link(queue7)
        queue7.link(nvvidconv)
        nvvidconv.link(queue8)
        queue8.link(nvosd)
        nvosd.link(queue9)
        queue9.link(caps)
        caps.link(queue10)
        queue10.link(encoder)
        encoder.link(queue11)
        if is_aarch64():
            queue11.link(transform)
            transform.link(queue12)
            queue12.link(rtppay)
            rtppay.link(queue13)
            queue13.link(sink)
        else:
            queue11.link(rtppay)
            rtppay.link(queue12)
            queue12.link(sink)
    elif args[5] == '1':               #ROI enable
        pgie.link(queue1)
        queue2.link(nvanalytics)
        nvanalytics.link(queue3)
        queue3.link(sgie1)
        sgie1.link(queue4)
        queue4.link(sgie2)
        sgie2.link(queue5)
        queue5.link(nvvidconv1)
        nvvidconv1.link(queue6)
        queue6.link(filter1)
        filter1.link(queue7)
        queue7.link(tiler)
        tiler.link(queue8)
        queue8.link(nvvidconv)
        nvvidconv.link(queue9)
        queue9.link(nvosd)
        nvosd.link(queue10)
        queue10.link(caps)
        caps.link(queuq11)
        queue11.link(encoder)
        encoder.link(queue12)
        if is_aarch64():
            queue12.link(transform)
            transform.link(queue13)
            queue13.link(rtppay)
            rtppay.link(queue14)
            queue14.link(sink)
        else:
            queue13.link(sink)
    else:
        print(" Invalid argument for ROI enable \n")
        sys.exit(1)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GObject.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    tiler_src_pad=tiler.get_static_pad("sink")
    if not tiler_src_pad:
        sys.stderr.write(" Unable to get sink pad \n")
    else:
        tiler_src_pad.add_probe(Gst.PadProbeType.BUFFER, tiler_src_pad_buffer_probe, 0, args)
    # List the sources
    print("Now playing...")
    for i, source in enumerate(args):
        if ((len(args) - 1) > i > 3):
            print(i, ": ", source)
    # Start streaming
    rtsp_port_num = 8554
    server = GstRtspServer.RTSPServer.new()
    server.props.service = "%d" % rtsp_port_num
    server.attach(None)
    factory = GstRtspServer.RTSPMediaFactory.new()
    factory.set_launch(
        '( udpsrc name=pay0 port=%d buffer-size=524288 caps="application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 " )'
        % (updsink_port_num, codec)
    factory.set_shared(True)
    server.get_mount_points().add_factory("/ds-test", factory)
    print(
        "\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n"
        % rtsp_port_num
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except Exception as e:
        print(f"Error: {e}")
        pass
    # cleanup
    thread_stop = True
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = argparse.ArgumentParser(description='RTSP Output Sample Application Help ')
    parser.add_argument("-i", "--input",
                  help="Path to input H264 elementry stream", nargs="+", default=["a"], required=True)
    parser.add_argument("-g", "--gie", default="nvinfer",
                  help="choose GPU inference engine type nvinfer or nvinferserver , default=nvinfer", choices=['nvinfer','nvinferserver'])
    parser.add_argument("-c", "--codec", default="H264",
                  help="RTSP Streaming Codec H264/H265 , default=H264", choices=['H264','H265'])
    parser.add_argument("-b", "--bitrate", default=4000000,
                  help="Set the encoding bitrate ", type=int)
    parser.add_argument("--rtsp-ts", action="store_true", default=False, dest='rtsp_ts', help="Attach NTP timestamp from RTSP source",
    if len(sys.argv)==1:
        parser.print_help(sys.stderr)
        sys.exit(1)
    args = parser.parse_args()
    global codec
    global bitrate
    global stream_path
    global gie
    global ts_from_rtsp
    gie = args.gie
    codec = args.codec
    bitrate = args.bitrate
    stream_path = args.input
    ts_from_rtsp = args.rtsp_ts
    return 0
if __name__ == '__main__':
    parse_args()
    sys.exit(main(sys.argv))
I tried to combine both license plate recogntion and deeeptream rtrsp in rtsp out sample application and followed the mentioned steps in README files in the respective directories. My primary gie is license plate detection and my secondary gie is license plate recognition and I need to feed in rtsp input and also must stream the deepstream in rtsp.
I get this following error while executing the above python file :
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: rtppcmudepay0
Decodebin child added: mulawdec0
In cb_newpad
gstname= audio/x-raw
Decodebin child added: decodebin1
Decodebin child added: rtph264depay0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f56c9b619a8 (GstCapsFeatures at 0x7f54d01098c0)>
Frame Number is  0
Source id is  0
Batch id is  0
Source Frame Width  1920
Source Frame Height  1080
Num object meta  0
Frame Number is  1
Source id is  0
Batch id is  0
Num object meta  0
Frame Number is  2
Source id is  0
Batch id is  0
Num object meta  0
Frame Number is  3
Source id is  0
Batch id is  0
Num object meta  0
0:00:19.860982126 34206      0x2c14540 WARN                 nvinfer gstnvinfer.cpp:1984:gst_nvinfer_output_loop:<secondary2-nvinference-engine> error: Internal data stream error.
0:00:19.861035922 34206      0x2c14540 WARN                 nvinfer gstnvinfer.cpp:1984:gst_nvinfer_output_loop:<secondary2-nvinference-engine> error: streaming stopped, reason not-linked (-1)
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(1984): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:secondary2-nvinference-engine:
Exiting app
[NvDCF] De-initialized
Could you add the GST_DEBUG=3 before your command and attach the new log?
