I was currently running a depstream-app -c with the rtsp camera, and streaming it with the VLC Media Player at the other computer, and it work as well. the program shown the link to stream “rtsp://localhost:8554/ds-tes”
I was curiously about this link and i search it, then found this from “deepstream_sink_bin.c” at “deepstream_sdk_v4.0.2_jetson\sources\apps\apps-common\src”
“DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-tes”
How to use that code in deepstream python ?
Because, i want to running a deepstream python program “deepstream-test3.py” with RTSP camera, and i want to stream it at the other computer, but i get some problem here.
- How to create an rtsp sink with deepstream python program?
- And how to streaming it at the other computer as well as deepstream-app program ?
Thank you before.
This is my edited-program from “deepstream-test3.py”
# import platform
# from ctypes import *
# from gi.repository import GLib
# import configparser
# import time
import sys
sys.path.append('../')
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
import sys
import math
import sqlite3
import datetime as dt
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import GETFPS
import pyds
fps_streams = {}
MAX_DISPLAY_LEN = 64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 80
MUXER_BATCH_TIMEOUT_USEC = 4000000
TILED_OUTPUT_WIDTH = 1280
TILED_OUTPUT_HEIGHT = 720
GST_CAPS_FEATURES_NVMM = "memory:NVMM"
pgie_classes_str = ["Vehicle", "TwoWheeler", "Person", "RoadSign"]
# tiler_sink_pad_buffer_probe will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
def tiler_src_pad_buffer_probe(pad, info, u_data):
# init database
try:
conn = sqlite3.connect(
"visitor.sqlite", detect_types=sqlite3.PARSE_DECLTYPES)
c = conn.cursor()
sql = """
CREATE TABLE IF NOT EXISTS visitors (
id INTEGER unique primary key AUTOINCREMENT,
event varchar(50),
camera_host varchar(50),
time_detection timestamp,
detection int
c.execute(sql)
conn.commit()
# print("MAIN TABLE CREATED")
except sqlite3.Error as e:
print(e)
frame_number = 0
num_rects = 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.glist_get_nvds_frame_meta()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
frame_meta = pyds.glist_get_nvds_frame_meta(l_frame.data)
except StopIteration:
break
print("Frame Number is ", frame_meta.frame_num)
print("Source id is ", frame_meta.source_id)
print("Batch id is ", frame_meta.batch_id)
print("Source Frame Width ", frame_meta.source_frame_width)
print("Source Frame Height ", frame_meta.source_frame_height)
print("Num object meta ", frame_meta.num_obj_meta)
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
num_rects = frame_meta.num_obj_meta
obj_counter = {
PGIE_CLASS_ID_VEHICLE: 0,
PGIE_CLASS_ID_PERSON: 0,
PGIE_CLASS_ID_BICYCLE: 0,
PGIE_CLASS_ID_ROADSIGN: 0
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta = pyds.glist_get_nvds_object_meta(l_obj.data)
break
obj_counter[obj_meta.class_id] += 1
try:
l_obj = l_obj.next
break
"""display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, vehicle_count, person)
py_nvosd_text_params.x_offset = 10;
py_nvosd_text_params.y_offset = 12;
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
py_nvosd_text_params.font_params.font_color.red = 1.0
py_nvosd_text_params.font_params.font_color.green = 1.0
py_nvosd_text_params.font_params.font_color.blue = 1.0
py_nvosd_text_params.font_params.font_color.alpha = 1.0
py_nvosd_text_params.set_bg_clr = 1
py_nvosd_text_params.text_bg_clr.red = 0.0
py_nvosd_text_params.text_bg_clr.green = 0.0
py_nvosd_text_params.text_bg_clr.blue = 0.0
py_nvosd_text_params.text_bg_clr.alpha = 1.0
#print("Frame Number=", frame_number, "Number of Objects=",num_rects,"Vehicle_count=",vehicle_count,"Person_count=",person)
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)"""
print("Frame Number=", frame_number, "Number of Objects=", num_rects, "Vehicle_count=",
obj_counter[PGIE_CLASS_ID_VEHICLE], "Person_count=", obj_counter[PGIE_CLASS_ID_PERSON])
c.execute("""INSERT INTO visitors (camera_host, event, time_detection, detection)
VALUES ('{}','{}','{}',{})""".format("IP-CAM", "TESTING", dt.datetime.now(), obj_counter[PGIE_CLASS_ID_PERSON]))
conn.commit()
c.close()
conn.close()
# Get frame rate through this probe
fps_streams["stream{0}".format(frame_meta.pad_index)].get_fps()
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad, data):
print("In cb_newpad\n")
caps = decoder_src_pad.get_current_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
source_bin = data
features = caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=", gstname)
if(gstname.find("video") != -1):
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
print("features=", features)
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad = source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write(
"Failed to link decoder src pad to source bin ghost pad\n")
else:
sys.stderr.write(
" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
print("Decodebin child added:", name, "\n")
if(name.find("decodebin") != -1):
Object.connect("child-added", decodebin_child_added, user_data)
if(is_aarch64() and name.find("nvv4l2decoder") != -1):
print("Seting bufapi_version\n")
Object.set_property("bufapi-version", True)
def create_source_bin(index, uri):
print("Creating source bin")
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name = "source-bin-%02d" % index
print(bin_name)
nbin = Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri", uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added", cb_newpad, nbin)
uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin, uri_decode_bin)
bin_pad = nbin.add_pad(
Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def main(args):
# Check input arguments
if len(args) < 2:
sys.stderr.write("usage: %s <uri1> [uri2] ... [uriN]\n" % args[0])
sys.exit(1)
for i in range(0, len(args) - 1):
fps_streams["stream{0}".format(i)] = GETFPS(i)
number_sources = len(args) - 1
# Standard GStreamer initialization
GObject.threads_init()
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(number_sources):
print("Creating source_bin ", i, " \n ")
uri_name = args[i + 1]
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = "sink_%u" % i
sinkpad = streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating tiler \n ")
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
if(is_aarch64()):
print("Creating transform \n ")
transform = Gst.ElementFactory.make(
"nvegltransform", "nvegl-transform")
if not transform:
sys.stderr.write(" Unable to create transform \n")
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
#sink = Gst.ElementFactory.make("fakesink", "fakesink")
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
streammux.set_property('width', 1280)
streammux.set_property('height', 720)
streammux.set_property('batch-size', number_sources)
streammux.set_property('batched-push-timeout', 4000000)
pgie.set_property('config-file-path', "dstest3_pgie_config.txt")
pgie_batch_size = pgie.get_property("batch-size")
if(pgie_batch_size != number_sources):
print("WARNING: Overriding infer-config batch-size",
pgie_batch_size, " with number of sources ", number_sources, " \n")
pgie.set_property("batch-size", number_sources)
tiler_rows = int(math.sqrt(number_sources))
tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
print("Adding elements to Pipeline \n")
pipeline.add(pgie)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
if is_aarch64():
pipeline.add(transform)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
streammux.link(pgie)
pgie.link(tiler)
tiler.link(nvvidconv)
nvvidconv.link(nvosd)
if is_aarch64():
nvosd.link(transform)
transform.link(sink)
else:
nvosd.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
tiler_src_pad = pgie.get_static_pad("src")
if not tiler_src_pad:
sys.stderr.write(" Unable to get src pad \n")
else:
tiler_src_pad.add_probe(Gst.PadProbeType.BUFFER,
tiler_src_pad_buffer_probe, 0)
# List the sources
print("Now playing...")
for i, source in enumerate(args):
if (i != 0):
print(i, ": ", source)
print("Starting pipeline \n")
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except IndexError:
pass
# cleanup
print("Exiting app\n")
pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
sys.exit(main(sys.argv))
