Get errors when running deepstream-imagedata-multistream application
• Hardware Platform (Jetson / GPU): Quadro P620
• Using this image: nvcr.io/nvidia/deepstream:6.2-devel
• NVIDIA GPU Driver Version (valid for GPU only): 525.125.06
I want to get the image frame from the stream, so I try running deepstream-imagedata-multistream. However, I get errors with logging below:
Frames will be saved in  frames
Creating Pipeline
Creating streamux
Creating source_bin  0
Creating source bin
source-bin-00
Creating Pgie
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing...
1 :  file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
Starting pipeline
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See `CUDA_MODULE_LOADING` in https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#env-vars
0:00:02.400585348    80      0x3d9fea0 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/app/runtime/Codes/DeepStream_testPipeline/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.411947002    80      0x3d9fea0 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /app/runtime/Codes/DeepStream_testPipeline/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:02.413177201    80      0x3d9fea0 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest_imagedata_config.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: aacparse0
Decodebin child added: avdec_aac0
Decodebin child added: nvv4l2decoder0
In cb_newpad
In cb_newpad
Frame Number= 0 Number of Objects= 8 Vehicle_count= 6 Person_count= 2
0:00:02.605970945    80      0x3118640 WARN                 nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop:<primary-inference> error: Internal data stream error.
0:00:02.605983859    80      0x3118640 WARN                 nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop:<primary-inference> error: streaming stopped, reason not-negotiated (-4)
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(2369): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Exiting app
FYI, I run it successfully by using this DS63 image nvcr.io/nvidia/deepstream:6.3-gc-triton-devel with NVIDIA driver version 535.54.03. However, I dont know why but I can not run docker-compose commands by using DS63 images provided in Docker Containers — DeepStream 6.3 Release documentation. Therefore, I would like to use the DS62 container above.
Did you checkout the correct branch? DS-6.2 use the tag v1.1.6.
What error does docker-compose report? I recommend using the latest version to avoid encountering some issues that have been fixed.
The error still exists.
docker-compose doesnt log any error, it stucks on a command I dont know where it comes. When I use “docker-compose ps”, I see the running command is “/opt/nvidia/deepstream/deepstream…” but not the command I set. When I use “docker-compose logs …” to see the logging, I also see that it stucks on something. The docker-compose’s version I use is 1.29.2, I will try later versions of docker-compose.
I’ve upgraded docker-compose’s version and my custom service is working when using deepstream:6.3-samples container.
However, I find other 2 issues:
  • Run deepstream-imagedata-multistream successfully, but when I use probe_function at nvosd instead of tiler, it raises Segmentation fault (Core dump). It is a minor issue for me and I just report it.
  • I can not display the rtsp output stream anymore (by using the gstreamer command below) when using Software encoder like x264enc/x265enc instead of HW encoder with bitrate=1000000. All the commands are running without errors, but the output stream just doesnt pop up. NOTE: the output stream displays normally using the DS62 image.
Here is the display command:
gst-launch-1.0 rtspsrc location="rtsp://127.0.0.1:8554/ds-test" latency=0 ! rtph264depay ! avdec_h264 ! xvimagesink sync=false
And here is the sample code modified from deepstream_test1_rtsp_in_rtsp_out:
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2021 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import sys
sys.path.append("../../")
from common.bus_call import bus_call
from common.is_aarch_64 import is_aarch64
import pyds
import platform
import math
import time
from ctypes import *
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GstRtspServer", "1.0")
from gi.repository import Gst, GstRtspServer, GLib
import configparser
import datetime
import argparse
MAX_DISPLAY_LEN = 64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 4000000
TILED_OUTPUT_WIDTH = 1280
TILED_OUTPUT_HEIGHT = 720
GST_CAPS_FEATURES_NVMM = "memory:NVMM"
OSD_PROCESS_MODE = 0
OSD_DISPLAY_TEXT = 0
pgie_classes_str = ["Vehicle", "TwoWheeler", "Person", "RoadSign"]
# pgie_src_pad_buffer_probe  will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
def pgie_src_pad_buffer_probe(pad, info, u_data):
    frame_number = 0
    num_rects = 0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number = frame_meta.frame_num
        print(
            "Frame Number=",
            frame_number
        if ts_from_rtsp:
            ts = frame_meta.ntp_timestamp/1000000000 # Retrieve timestamp, put decimal in proper position for Unix format
            print("RTSP Timestamp:",datetime.datetime.utcfromtimestamp(ts).strftime('%Y-%m-%d %H:%M:%S')) # Convert timestamp to UTC
        try:
            l_frame = l_frame.next
            break
    return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad, data):
    print("In cb_newpad\n")
    caps = decoder_src_pad.get_current_caps()
    gststruct = caps.get_structure(0)
    gstname = gststruct.get_name()
    source_bin = data
    features = caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=", gstname)
    if gstname.find("video") != -1:
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=", features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad = source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write(
                    "Failed to link decoder src pad to source bin ghost pad\n"
        else:
            sys.stderr.write(
                " Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
    print("Decodebin child added:", name, "\n")
    if name.find("decodebin") != -1:
        Object.connect("child-added", decodebin_child_added, user_data)
    if ts_from_rtsp:
        if name.find("source") != -1:
            pyds.configure_source_for_ntp_sync(hash(Object))
def create_source_bin(index, uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name = "source-bin-%02d" % index
    print(bin_name)
    nbin = Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri", uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added", cb_newpad, nbin)
    uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin, uri_decode_bin)
    bin_pad = nbin.add_pad(
        Gst.GhostPad.new_no_target(
            "src", Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
def main(args):
    # Check input arguments
    number_sources = len(args)
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ", i, " \n ")
        uri_name = args[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname = "sink_%u" % i
        sinkpad = streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad = source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    print("Creating Pgie \n ")
    if gie=="nvinfer":
        pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    else:
        pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    print("Creating tiler \n ")
    tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvvidconv_postosd = Gst.ElementFactory.make(
        "nvvideoconvert", "convertor_postosd")
    if not nvvidconv_postosd:
        sys.stderr.write(" Unable to create nvvidconv_postosd \n")
    # ****** Create video filter to convert frames to RGBA ************
    print("Creating filter1")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter = Gst.ElementFactory.make("capsfilter", "filter")
    if not filter:
        sys.stderr.write(" Unable to get the caps filter \n")
    filter.set_property("caps", caps1)
    # Create a caps filter
    caps = Gst.ElementFactory.make("capsfilter", "filter")
    caps.set_property(
        "caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420")
    # Make the encoder
    if codec == "H264":
        # encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
        encoder = Gst.ElementFactory.make("x264enc", "encoder")
        print("Creating H264 Encoder")
    elif codec == "H265":
        # encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
        encoder = Gst.ElementFactory.make("x265enc", "encoder")
        print("Creating H265 Encoder")
    if not encoder:
        sys.stderr.write(" Unable to create encoder")
    encoder.set_property("bitrate", bitrate)
    if is_aarch64():
        encoder.set_property("preset-level", 1)
        encoder.set_property("insert-sps-pps", 1)
        #encoder.set_property("bufapi-version", 1)
    # Make the payload-encode video into RTP packets
    if codec == "H264":
        rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
        print("Creating H264 rtppay")
        rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
        print("Creating H265 rtppay")
    if not rtppay:
        sys.stderr.write(" Unable to create rtppay")
    # Make the UDP sink
    updsink_port_num = 5400
    sink = Gst.ElementFactory.make("udpsink", "udpsink")
    if not sink:
        sys.stderr.write(" Unable to create udpsink")
    sink.set_property("host", "224.224.255.255")
    sink.set_property("port", updsink_port_num)
    sink.set_property("async", False)
    sink.set_property("sync", 1)
    streammux.set_property("width", 1920)
    streammux.set_property("height", 1080)
    streammux.set_property("batch-size", number_sources)
    streammux.set_property("batched-push-timeout", 4000000)
    if ts_from_rtsp:
        streammux.set_property("attach-sys-ts", 0)
    if gie=="nvinfer":
        pgie.set_property("config-file-path", "dstest1_pgie_config.txt")
    else:
        pgie.set_property("config-file-path", "dstest1_pgie_inferserver_config.txt")
    pgie_batch_size = pgie.get_property("batch-size")
    if pgie_batch_size != number_sources:
        print(
            "WARNING: Overriding infer-config batch-size",
            pgie_batch_size,
            " with number of sources ",
            number_sources,
            " \n",
        pgie.set_property("batch-size", number_sources)
    print("Adding elements to Pipeline \n")
    tiler_rows = int(math.sqrt(number_sources))
    tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
    tiler.set_property("rows", tiler_rows)
    tiler.set_property("columns", tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    sink.set_property("qos", 0)
    pipeline.add(pgie)
    pipeline.add(tiler)
    pipeline.add(filter)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(nvvidconv_postosd)
    pipeline.add(encoder)
    pipeline.add(rtppay)
    pipeline.add(sink)
    streammux.link(pgie)
    pgie.link(nvvidconv)
    nvvidconv.link(filter)
    filter.link(tiler)
    tiler.link(nvosd)
    nvosd.link(nvvidconv_postosd)
    nvvidconv_postosd.link(encoder)
    encoder.link(rtppay)
    rtppay.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    pgie_src_pad=pgie.get_static_pad("src")
    if not pgie_src_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
    # Start streaming
    rtsp_port_num = 8554
    server = GstRtspServer.RTSPServer.new()
    server.props.service = "%d" % rtsp_port_num
    server.attach(None)
    factory = GstRtspServer.RTSPMediaFactory.new()
    factory.set_launch(
        '( udpsrc name=pay0 port=%d buffer-size=524288 caps="application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 " )'
        % (updsink_port_num, codec)
    factory.set_shared(True)
    server.get_mount_points().add_factory("/ds-test", factory)
    print(
        "\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n"
        % rtsp_port_num
    # start play back and listen to events
    print("Starting pipeline \n")
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except BaseException:
        pass
    # cleanup
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = argparse.ArgumentParser(description='RTSP Output Sample Application Help ')
    parser.add_argument("-i", "--input",
                  help="Path to input H264 elementry stream", nargs="+", default=["a"], required=True)
    parser.add_argument("-g", "--gie", default="nvinfer",
                  help="choose GPU inference engine type nvinfer or nvinferserver , default=nvinfer", choices=['nvinfer','nvinferserver'])
    parser.add_argument("-c", "--codec", default="H264",
                  help="RTSP Streaming Codec H264/H265 , default=H264", choices=['H264','H265'])
    parser.add_argument("-b", "--bitrate", default=4000000,
                  help="Set the encoding bitrate ", type=int)
    parser.add_argument("--rtsp-ts", action="store_true", default=False, dest='rtsp_ts', help="Attach NTP timestamp from RTSP source",
    if len(sys.argv)==1:
        parser.print_help(sys.stderr)
        sys.exit(1)
    args = parser.parse_args()
    global codec
    global bitrate
    global stream_path
    global gie
    global ts_from_rtsp
    gie = args.gie
    codec = args.codec
    bitrate = args.bitrate
    stream_path = args.input
    ts_from_rtsp = args.rtsp_ts
    return stream_path
if __name__ == '__main__':
    stream_path = parse_args()
    sys.exit(main(stream_path))
I have tried your command line, It’s can work fine.
How do you run this command line ? In your docker ?
If you want display in docker, Must be like below.
xhost +
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.3 nvcr.io/nvidia/deepstream:6.3-gc-triton-devel
No, I just run the app in docker (nvcr.io/nvidia/deepstream:6.3-samples) and display ouput on localhost.
It works fine when you use SW enc with bitrate=1000000, right ? So weird. Gstreamer version on localhost is 1.16.3.
With bitrate=1000000, I even cannot display output by VLC. However, VLC can display it with default bitrate=2048 while the above gstreamer command cannot.
Thank you for your support, @junshengy .
