• Hardware Platform (Jetson / GPU) nano
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0
• TensorRT Version 8.6.2.3-1+cuda12.2
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA-SMI 540.2.0
- It does not show output to visualize frame by frame even after adding OSD and Sink.
- How to chage it to peoplenet model? Any references to follow it ?
Original Code :
Commond to Run : python3 deepstream_test1_rtsp_in_rtsp_out.py -i file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 -g nvinfer
Configuration File :
dstest1_pgie_config.txt (3.5 KB)
#!/usr/bin/env python3
SPDX-FileCopyrightText: Copyright (c) 2021-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
SPDX-License-Identifier: Apache-2.0
Licensed under the Apache License, Version 2.0 (the “License”);
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
Apache License, Version 2.0 | Apache Software Foundations
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an “AS IS” BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
import sys
sys.path.append(“../”)
from common.bus_call import bus_call
from common.platform_info import PlatformInfo
import pyds
import platform
import math
import time
from ctypes import *
import gi
gi.require_version(“Gst”, “1.0”)
gi.require_version(“GstRtspServer”, “1.0”)
from gi.repository import Gst, GstRtspServer, GLib
import configparser
import datetime
import argparse
MAX_DISPLAY_LEN = 64
#PGIE_CLASS_ID_VEHICLE = 0
#PGIE_CLASS_ID_BICYCLE = 1
#PGIE_CLASS_ID_PERSON = 2
#PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 33000
TILED_OUTPUT_WIDTH = 1280
TILED_OUTPUT_HEIGHT = 720
GST_CAPS_FEATURES_NVMM = “memory:NVMM”
OSD_PROCESS_MODE = 0
OSD_DISPLAY_TEXT = 0
pgie_classes_str = [“Person”]
pgie_src_pad_buffer_probe will extract metadata received on OSD sink pad
and update params for drawing rectangle, object information etc.
def pgie_src_pad_buffer_probe(pad, info, u_data):
frame_number = 0
num_rects = 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number = frame_meta.frame_num
print(
"Frame Number=",
frame_number
if ts_from_rtsp:
ts = frame_meta.ntp_timestamp/1000000000 # Retrieve timestamp, put decimal in proper position for Unix format
print("RTSP Timestamp:",datetime.datetime.utcfromtimestamp(ts).strftime('%Y-%m-%d %H:%M:%S')) # Convert timestamp to UTC
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad, data):
print(“In cb_newpad\n”)
caps = decoder_src_pad.get_current_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
source_bin = data
features = caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=", gstname)
if gstname.find("video") != -1:
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
print("features=", features)
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad = source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write(
"Failed to link decoder src pad to source bin ghost pad\n"
else:
sys.stderr.write(
" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
print(“Decodebin child added:”, name, “\n”)
if name.find(“decodebin”) != -1:
Object.connect(“child-added”, decodebin_child_added, user_data)
if ts_from_rtsp:
if name.find("source") != -1:
pyds.configure_source_for_ntp_sync(hash(Object))
def create_source_bin(index, uri):
print(“Creating source bin”)
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name = "source-bin-%02d" % index
print(bin_name)
nbin = Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri", uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added", cb_newpad, nbin)
uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin, uri_decode_bin)
bin_pad = nbin.add_pad(
Gst.GhostPad.new_no_target(
"src", Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def main(args):
# Check input arguments
number_sources = len(args)
platform_info = PlatformInfo()
# Standard GStreamer initialization
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
is_live = False
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(number_sources):
print("Creating source_bin ", i, " \n ")
uri_name = args[i]
if uri_name.find("rtsp://") == 0:
is_live = True
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = "sink_%u" % i
sinkpad = streammux.request_pad_simple(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
print("Creating Pgie \n ")
if gie=="nvinfer":
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
else:
pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating tiler \n ")
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
nvvidconv_postosd = Gst.ElementFactory.make(
"nvvideoconvert", "convertor_postosd")
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
# Create a caps filter
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property(
#"caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420")
"caps", Gst.Caps.from_string("video/x-raw, format=I420")
# Make the encoder
if codec == "H264":
#encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
encoder = Gst.ElementFactory.make("x264enc", "encoder")
print("Creating H264 Encoder")
elif codec == "H265":
#encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
print("Creating H265 Encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property("bitrate", bitrate/1000)
#if platform_info.is_integrated_gpu():
#encoder.set_property("preset-level", 1)
#encoder.set_property("insert-sps-pps", 1)
#encoder.set_property("bufapi-version", 1)
#encoder.set_property("bitrate", bitrate_kbps)
# Make the payload-encode video into RTP packets
if codec == "H264":
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
print("Creating H264 rtppay")
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
print("Creating H265 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
# ADDED: Define and configure the sink element (either nv3dsink for ARM or nveglglessink for x86)
#if platform_info.is_aarch64_platform():
sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink") # ADDED
print("Creating nv3dsink (ARM)")
# else:
# sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer") # ADDED
# print("Creating nveglglessink (x86)")
# Make the UDP sink
updsink_port_num = 5400
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
sink.set_property("host", "224.224.255.255")
sink.set_property("port", updsink_port_num)
sink.set_property("async", False)
sink.set_property("sync", 1)
streammux.set_property("width", 1920)
streammux.set_property("height", 1080)
streammux.set_property("batch-size", number_sources)
streammux.set_property("batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC)
if ts_from_rtsp:
streammux.set_property("attach-sys-ts", 0)
if gie=="nvinfer":
pgie.set_property("config-file-path", "dstest1_pgie_config.txt")
else:
pgie.set_property("config-file-path", "dstest1_pgie_inferserver_config.txt")
pgie_batch_size = pgie.get_property("batch-size")
if pgie_batch_size != number_sources:
print(
"WARNING: Overriding infer-config batch-size",
pgie_batch_size,
" with number of sources ",
number_sources,
" \n",
pgie.set_property("batch-size", number_sources)
print("Adding elements to Pipeline \n")
tiler_rows = int(math.sqrt(number_sources))
tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
sink.set_property("qos", 0)
pipeline.add(pgie)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd) # ADDED: Adding nvosd element
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
pipeline.add(sink) # ADDED: Adding sink element
streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(tiler)
tiler.link(nvosd)
nvvidconv.link(nvosd) # ADDED: Linking nvvidconv to nvosd
nvosd.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoder)
encoder.link(rtppay)
rtppay.link(sink) # ADDED: Linking rtppay to sink
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
pgie_src_pad=pgie.get_static_pad("src")
if not pgie_src_pad:
sys.stderr.write(" Unable to get src pad \n")
else:
pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
# Start streaming
rtsp_port_num = 8554
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.set_address("192.168.10.138")
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch(
'( udpsrc name=pay0 port=%d buffer-size=524288 caps="application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 " )'
% (updsink_port_num, codec)
factory.set_shared(True)
server.get_mount_points().add_factory("/ds-test", factory)
print(
"\n *** DeepStream: Launched RTSP Streaming at rtsp://192.168.10.138:%d/ds-test ***\n\n"
% rtsp_port_num
# start play back and listen to events
print("Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except BaseException:
pass
# cleanup
pipeline.set_state(Gst.State.NULL)
def parse_args():
parser = argparse.ArgumentParser(description='RTSP Output Sample Application Help ')
parser.add_argument(“-i”, “–input”,
help=“Path to input H264 elementry stream”, nargs=“+”, default=[“a”], required=True)
parser.add_argument(“-g”, “–gie”, default=“nvinfer”,
help=“choose GPU inference engine type nvinfer or nvinferserver , default=nvinfer”, choices=[‘nvinfer’,‘nvinferserver’])
parser.add_argument(“-c”, “–codec”, default=“H264”,
help=“RTSP Streaming Codec H264/H265 , default=H264”, choices=[‘H264’,‘H265’])
parser.add_argument(“-b”, “–bitrate”, default=4000000,
help=“Set the encoding bitrate “, type=int)
parser.add_argument(”–rtsp-ts”, action=“store_true”, default=False, dest=‘rtsp_ts’, help=“Attach NTP timestamp from RTSP source”,
if len(sys.argv)==1:
parser.print_help(sys.stderr)
sys.exit(1)
args = parser.parse_args()
global codec
global bitrate
global stream_path
global gie
global ts_from_rtsp
gie = args.gie
codec = args.codec
bitrate = args.bitrate
stream_path = args.input
ts_from_rtsp = args.rtsp_ts
return stream_path
if name == ‘main’:
stream_path = parse_args()
sys.exit(main(stream_path))
